[GRASS-SVN] r69633 - grass/branches/releasebranch_7_0/lib/init
svn_grass at osgeo.org
Sun Oct 2 12:17:18 PDT 2016
Author: neteler
Date: 2016-10-02 12:17:18 -0700 (Sun, 02 Oct 2016)
New Revision: 69633
grass/branches/releasebranch_7_0/lib/init/grass7.html
grass7 helptext: 'Sample data' section added
Modified: grass/branches/releasebranch_7_0/lib/init/grass7.html
--- grass/branches/releasebranch_7_0/lib/init/grass7.html 2016-10-02 19:17:10 UTC (rev 69632)
+++ grass/branches/releasebranch_7_0/lib/init/grass7.html 2016-10-02 19:17:18 UTC (rev 69633)
@@ -84,6 +84,17 @@
these checks fail then <em>grass70</em> will automatically switch back
to the text user interface mode.
+<h2>SAMPLE DATA</h2>
+The GRASS GIS project provides several free sample geospatial datasets
+as ready-to-use locations. They are available to download at
+<a href="https://grass.osgeo.org/download/sample-data/">https://grass.osgeo.org/download/sample-data/</a>.
+The "North Carolina data set" is a modern package of geospatial data from
+North Carolina (USA), and it includes raster, vector, LiDAR and satellite
+data. This is the most extensively used data set in the documentation and
+the examples throughout the user manual pages are based upon it.
<h2>ENVIRONMENT VARIABLES</h2>
A number of environment variables are available at GRASS startup to
@@ -186,7 +197,7 @@
<dl>
<dt>LOCATION
<dd> A fully qualified path to a mapset
- (eg <tt>/usr/local/share/grassdata/spearfish60/PERMANENT</tt>). This
+ (eg <tt>/usr/local/share/grassdata/spearfish70/PERMANENT</tt>). This
environment variable overrides the GISDBASE, LOCATION_NAME, and
MAPSET variables.
<dt>GISDBASE
@@ -264,9 +275,9 @@
The environment variables are defined as follows:
<div class="code"><pre>
-LOCATION = /usr/local/share/grassdata/spearfish60/PERMANENT
+LOCATION = /usr/local/share/grassdata/spearfish70/PERMANENT
GISDBASE = /usr/local/share/grassdata
-LOCATION_NAME = spearfish60
+LOCATION_NAME = spearfish70
MAPSET = PERMANENT
</pre></div>
