[GRASS-SVN] r69649 - grass/trunk/vector/v.external
svn_grass at osgeo.org
Mon Oct 3 08:08:44 PDT 2016
Author: martinl
Date: 2016-10-03 08:08:44 -0700 (Mon, 03 Oct 2016)
New Revision: 69649
grass/trunk/vector/v.external/args.c
grass/trunk/vector/v.external/list.c
grass/trunk/vector/v.external/local_proto.h
grass/trunk/vector/v.external/main.c
v.external: change layer option to be not required
Modified: grass/trunk/vector/v.external/args.c
--- grass/trunk/vector/v.external/args.c 2016-10-03 08:54:37 UTC (rev 69648)
+++ grass/trunk/vector/v.external/args.c 2016-10-03 15:08:44 UTC (rev 69649)
@@ -29,7 +29,7 @@
"\t\tESRI Shapefile: shapefile name\n"
"\t\tMapInfo File: mapinfo file name\n"
"\t\tPostGIS database: table name");
- options->layer->required = YES;
+ options->layer->required = NO;
options->layer->key_desc = "name";
options->layer->gisprompt = "old,datasource_layer,datasource_layer";
Modified: grass/trunk/vector/v.external/list.c
--- grass/trunk/vector/v.external/list.c 2016-10-03 08:54:37 UTC (rev 69648)
+++ grass/trunk/vector/v.external/list.c 2016-10-03 15:08:44 UTC (rev 69649)
@@ -18,10 +18,10 @@
static char **format_list(int *, size_t *);
static char *feature_type(const char *);
#ifdef HAVE_OGR
-static int list_layers_ogr(FILE *, const char *, const char *, int);
+static int list_layers_ogr(FILE *, const char *, char **, int);
#endif /* HAVE_OGR */
#ifdef HAVE_POSTGRES
-static int list_layers_pg(FILE *, const char *, const char *, int);
+static int list_layers_pg(FILE *, const char *, char **, int);
#endif /* HAVE_POSTGRES */
int cmp(const void *a, const void *b)
@@ -102,7 +102,7 @@
G_free(list);
-int list_layers(FILE *fd, const char *dsn, const char *layer, int print_types, int use_ogr)
+int list_layers(FILE *fd, const char *dsn, char **layer, int print_types, int use_ogr)
if (!use_ogr) {
@@ -139,7 +139,7 @@
-int list_layers_pg(FILE *fd, const char *conninfo, const char *table, int print_types)
+int list_layers_pg(FILE *fd, const char *conninfo, char **table, int print_types)
int row, ntables, ret, print_schema;
char *value_schema, *value_table, *value_type, *value_column;
@@ -171,7 +171,7 @@
/* get schema & table_name */
table_name = schema_name = NULL;
if (table)
- get_table_name(table, &table_name, &schema_name);
+ get_table_name(*table, &table_name, &schema_name);
ntables = PQntuples(res);
G_debug(3, " nrows = %d", ntables);
@@ -235,7 +235,7 @@
#ifdef HAVE_OGR
-int list_layers_ogr(FILE *fd, const char *dsn, const char *layer, int print_types)
+int list_layers_ogr(FILE *fd, const char *dsn, char **layer, int print_types)
int i, ret;
int nlayers;
@@ -263,12 +263,22 @@
/* Make a list of available layers */
nlayers = OGR_DS_GetLayerCount(Ogr_ds);
- if (fd)
+ if (fd) {
G_message(n_("Data source <%s> (format '%s') contains %d layer:",
"Data source <%s> (format '%s') contains %d layers:",
nlayers),
dsn, OGR_Dr_GetName(OGR_DS_GetDriver(Ogr_ds)), nlayers);
+ else if (layer && !(*layer)) {
+ /* return first layer by default (if layer not defined) */
+ if (nlayers > 0) {
+ Ogr_layer = OGR_DS_GetLayer(Ogr_ds, 0);
+ Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
+ *layer = G_store((char *) OGR_FD_GetName(Ogr_featuredefn));
+ return 0;
+ return -1;
G_get_default_window(&loc_wind);
if (print_types && loc_wind.proj != PROJECTION_XY) {
@@ -333,7 +343,7 @@
if (layer)
- if (strcmp(layer_name, layer) == 0) {
+ if (strcmp(layer_name, *layer) == 0) {
ret = i;
Modified: grass/trunk/vector/v.external/local_proto.h
--- grass/trunk/vector/v.external/local_proto.h 2016-10-03 08:54:37 UTC (rev 69648)
+++ grass/trunk/vector/v.external/local_proto.h 2016-10-03 15:08:44 UTC (rev 69649)
@@ -18,7 +18,7 @@
/* list.c */
void list_formats();
-int list_layers(FILE *, const char *, const char *, int, int);
+int list_layers(FILE *, const char *, char **, int, int);
void get_table_name(const char *, char **, char **);
#endif
Modified: grass/trunk/vector/v.external/main.c
--- grass/trunk/vector/v.external/main.c 2016-10-03 08:54:37 UTC (rev 69648)
+++ grass/trunk/vector/v.external/main.c 2016-10-03 15:08:44 UTC (rev 69649)
@@ -41,7 +41,7 @@
FILE *fd;
int ilayer, use_ogr;
- char buf[GPATH_MAX], *dsn;
+ char buf[GPATH_MAX], *dsn, *layer;
const char *output;
G_gisinit(argv[0]);
@@ -108,22 +108,26 @@
exit(EXIT_SUCCESS);
+ /* get layer index/name */
+ layer = NULL;
+ if (options.layer->answer)
+ layer = G_store(options.layer->answer);
+ ilayer = list_layers(NULL, dsn, &layer,
+ FALSE, use_ogr);
+ if (ilayer == -1) {
+ G_fatal_error(_("Layer <%s> not available"), options.layer->answer);
+ else
+ G_fatal_error(_("No layer defined"));
+ G_debug(2, "layer '%s' was found", layer);
/* define name for output */
if (!options.output->answer)
- output = options.layer->answer;
+ output = layer;
else
output = options.output->answer;
- /* get layer index */
- ilayer = list_layers(NULL, dsn, options.layer->answer,
- FALSE, use_ogr);
- if (ilayer == -1) {
- G_fatal_error(_("Layer <%s> not available"), options.layer->answer);
- G_debug(2, "layer '%s' was found", options.layer->answer);
if (G_find_vector2(output, G_mapset()) && !G_check_overwrite(argc, argv)) {
G_fatal_error(_("option <%s>: <%s> exists. To overwrite, use the --overwrite flag"),
options.output->key, output);
@@ -254,7 +258,7 @@
if (!use_ogr) {
char *table_name, *schema_name;
- get_table_name(options.layer->answer, &table_name, &schema_name);
+ get_table_name(layer, &table_name, &schema_name);
fprintf(fd, "format: postgis\n");
fprintf(fd, "conninfo: %s\n", dsn);
@@ -268,7 +272,7 @@
else {
fprintf(fd, "format: ogr\n");
fprintf(fd, "dsn: %s\n", dsn);
- fprintf(fd, "layer: %s\n", options.layer->answer);
+ fprintf(fd, "layer: %s\n", layer);
fclose(fd);
