[GRASS-SVN] r69651 - grass/trunk/vector/v.external
svn_grass at osgeo.org
Mon Oct 3 08:47:31 PDT 2016
Author: martinl
Date: 2016-10-03 08:47:30 -0700 (Mon, 03 Oct 2016)
New Revision: 69651
Added:
grass/trunk/vector/v.external/proj.c
grass/trunk/vector/v.external/local_proto.h
grass/trunk/vector/v.external/main.c
v.external: fix check projection
Modified: grass/trunk/vector/v.external/local_proto.h
--- grass/trunk/vector/v.external/local_proto.h 2016-10-03 15:11:43 UTC (rev 69650)
+++ grass/trunk/vector/v.external/local_proto.h 2016-10-03 15:47:30 UTC (rev 69651)
@@ -21,4 +21,6 @@
int list_layers(FILE *, const char *, char **, int, int);
void get_table_name(const char *, char **, char **);
+/* proj.c */
+void check_projection(const char *, int);
#endif
Modified: grass/trunk/vector/v.external/main.c
--- grass/trunk/vector/v.external/main.c 2016-10-03 15:11:43 UTC (rev 69650)
+++ grass/trunk/vector/v.external/main.c 2016-10-03 15:47:30 UTC (rev 69651)
@@ -135,100 +135,7 @@
/* check projection match */
if (!flags.override->answer) {
- int err = 0;
- char error_msg[8192];
- struct Cell_head cellhd, loc_wind;
- struct Key_Value *loc_proj_info, *loc_proj_units;
- struct Key_Value *proj_info, *proj_units;
- proj_info = proj_units = NULL;
- loc_proj_info = G_get_projinfo();
- loc_proj_units = G_get_projunits();
- G_get_default_window(&loc_wind);
- G_get_window(&cellhd);
- if ((err =
- G_compare_projections(loc_proj_info, loc_proj_units,
- proj_info, proj_units)) != TRUE) {
- int i_value;
- strcpy(error_msg,
- _("Projection of dataset does not"
- " appear to match current location.\n\n"));
- /* TODO: output this info sorted by key: */
- if (loc_wind.proj != cellhd.proj || err != -2) {
- if (loc_proj_info != NULL) {
- strcat(error_msg, _("GRASS LOCATION PROJ_INFO is:\n"));
- for (i_value = 0; i_value < loc_proj_info->nitems;
- i_value++)
- sprintf(error_msg + strlen(error_msg), "%s: %s\n",
- loc_proj_info->key[i_value],
- loc_proj_info->value[i_value]);
- strcat(error_msg, "\n");
- if (proj_info != NULL) {
- strcat(error_msg, _("Import dataset PROJ_INFO is:\n"));
- for (i_value = 0; i_value < proj_info->nitems; i_value++)
- proj_info->key[i_value],
- proj_info->value[i_value]);
- else {
- if (cellhd.proj == PROJECTION_XY)
- "Dataset proj = %d (unreferenced/unknown)\n",
- cellhd.proj);
- else if (cellhd.proj == PROJECTION_LL)
- "Dataset proj = %d (lat/long)\n",
- cellhd.proj);
- else if (cellhd.proj == PROJECTION_UTM)
- "Dataset proj = %d (UTM), zone = %d\n",
- cellhd.proj, cellhd.zone);
- else
- "Dataset proj = %d (unknown), zone = %d\n",
- else {
- if (loc_proj_units != NULL) {
- strcat(error_msg, "GRASS LOCATION PROJ_UNITS is:\n");
- for (i_value = 0; i_value < loc_proj_units->nitems;
- i_value++)
- loc_proj_units->key[i_value],
- loc_proj_units->value[i_value]);
- if (proj_units != NULL) {
- strcat(error_msg, "Import dataset PROJ_UNITS is:\n");
- for (i_value = 0; i_value < proj_units->nitems; i_value++)
- proj_units->key[i_value],
- proj_units->value[i_value]);
- _("\nIn case of no significant differences in the projection definitions,"
- " use the -o flag to ignore them and use"
- " current location definition.\n"));
- strcat(error_msg,
- _("Consider generating a new location with 'location' parameter"
- " from input data set.\n"));
- G_fatal_error("%s", error_msg);
- else {
- G_verbose_message(_("Projection of input dataset and current location "
- "appear to match"));
+ check_projection(dsn, ilayer);
/* create new vector map */
Added: grass/trunk/vector/v.external/proj.c
--- grass/trunk/vector/v.external/proj.c (rev 0)
+++ grass/trunk/vector/v.external/proj.c 2016-10-03 15:47:30 UTC (rev 69651)
@@ -0,0 +1,126 @@
+#include <grass/gis.h>
+#include <grass/gprojects.h>
+#include <grass/glocale.h>
+#ifdef HAVE_OGR
+#include "ogr_api.h"
+#endif
+void check_projection(const char *dsn, int ilayer)
+#ifdef HAVE_OGR
+ int err = 0;
+ char error_msg[8192];
+ struct Cell_head cellhd, loc_wind;
+ struct Key_Value *loc_proj_info, *loc_proj_units;
+ struct Key_Value *proj_info, *proj_units;
+ OGRDataSourceH Ogr_ds;
+ OGRLayerH Ogr_layer;
+ OGRSpatialReferenceH Ogr_projection;
+ proj_info = proj_units = NULL;
+ loc_proj_info = G_get_projinfo();
+ loc_proj_units = G_get_projunits();
+ G_get_default_window(&loc_wind);
+ G_get_window(&cellhd);
+ Ogr_ds = OGROpen(dsn, FALSE, NULL);
+ if (!Ogr_ds) {
+ G_fatal_error(_("Unable to open data source '%s'"), dsn);
+ if (ilayer > OGR_DS_GetLayerCount(Ogr_ds))
+ return;
+ Ogr_layer = OGR_DS_GetLayer(Ogr_ds, ilayer);
+ Ogr_projection = OGR_L_GetSpatialRef(Ogr_layer);
+ if (GPJ_osr_to_grass(&cellhd, &proj_info,
+ &proj_units, Ogr_projection, 0) < 0)
+ G_warning(_("Unable to convert input map projection information to "
+ "GRASS format for checking"));
+ OGR_DS_Destroy(Ogr_ds);
+ if ((err =
+ G_compare_projections(loc_proj_info, loc_proj_units,
+ proj_info, proj_units)) != TRUE) {
+ int i_value;
+ strcpy(error_msg,
+ _("Projection of dataset does not"
+ " appear to match current location.\n\n"));
+ /* TODO: output this info sorted by key: */
+ if (loc_wind.proj != cellhd.proj || err != -2) {
+ if (loc_proj_info != NULL) {
+ strcat(error_msg, _("GRASS LOCATION PROJ_INFO is:\n"));
+ for (i_value = 0; i_value < loc_proj_info->nitems;
+ i_value++)
+ sprintf(error_msg + strlen(error_msg), "%s: %s\n",
+ loc_proj_info->key[i_value],
+ loc_proj_info->value[i_value]);
+ strcat(error_msg, "\n");
+ if (proj_info != NULL) {
+ strcat(error_msg, _("Import dataset PROJ_INFO is:\n"));
+ for (i_value = 0; i_value < proj_info->nitems; i_value++)
+ proj_info->key[i_value],
+ proj_info->value[i_value]);
+ else {
+ if (cellhd.proj == PROJECTION_XY)
+ "Dataset proj = %d (unreferenced/unknown)\n",
+ cellhd.proj);
+ else if (cellhd.proj == PROJECTION_LL)
+ "Dataset proj = %d (lat/long)\n",
+ cellhd.proj);
+ else if (cellhd.proj == PROJECTION_UTM)
+ "Dataset proj = %d (UTM), zone = %d\n",
+ cellhd.proj, cellhd.zone);
+ else
+ "Dataset proj = %d (unknown), zone = %d\n",
+ else {
+ if (loc_proj_units != NULL) {
+ strcat(error_msg, "GRASS LOCATION PROJ_UNITS is:\n");
+ for (i_value = 0; i_value < loc_proj_units->nitems;
+ i_value++)
+ loc_proj_units->key[i_value],
+ loc_proj_units->value[i_value]);
+ if (proj_units != NULL) {
+ strcat(error_msg, "Import dataset PROJ_UNITS is:\n");
+ for (i_value = 0; i_value < proj_units->nitems; i_value++)
+ proj_units->key[i_value],
+ proj_units->value[i_value]);
+ _("\nIn case of no significant differences in the projection definitions,"
+ " use the -o flag to ignore them and use"
+ " current location definition.\n"));
+ strcat(error_msg,
+ _("Consider generating a new location with 'location' parameter"
+ " from input data set.\n"));
+ G_fatal_error("%s", error_msg);
+ else {
+ G_verbose_message(_("Projection of input dataset and current location "
+ "appear to match"));
+#endif
Property changes on: grass/trunk/vector/v.external/proj.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:eol-style
+ native
