[GRASS-SVN] r69658 - grass/trunk/raster/r.stream.extract
svn_grass at osgeo.org
Mon Oct 3 14:09:59 PDT 2016
Author: neteler
Date: 2016-10-03 14:09:59 -0700 (Mon, 03 Oct 2016)
New Revision: 69658
Added:
grass/trunk/raster/r.stream.extract/r_stream_extract_accum_orig_zoom.png
grass/trunk/raster/r.stream.extract/r_stream_extract_accum_weighted_zoom.png
grass/trunk/raster/r.stream.extract/r_stream_extract_streams_noweight.png
grass/trunk/raster/r.stream.extract/r_stream_extract_weights_zoom.png
grass/trunk/raster/r.stream.extract/r.stream.extract.html
r.stream.extract manual: screenshots added
Modified: grass/trunk/raster/r.stream.extract/r.stream.extract.html
--- grass/trunk/raster/r.stream.extract/r.stream.extract.html 2016-10-03 18:40:15 UTC (rev 69657)
+++ grass/trunk/raster/r.stream.extract/r.stream.extract.html 2016-10-03 21:09:59 UTC (rev 69658)
@@ -110,7 +110,7 @@
<p>
Another possibility is to restrict channel initiation to valleys
determined from terrain morphology. Valleys can be determined with
-<em><a href="r.param.scale.html">r.param.scale</a></em> <tt>param=crosc</tt>
+<em><a href="r.param.scale.html">r.param.scale</a></em> <tt>method=crosc</tt>
(cross-sectional or tangential curvature). Curvature values < 0
indicate concave features, i.e. valleys. The size of the processing
window determines whether narrow or broad valleys will be identified
@@ -166,18 +166,18 @@
r.watershed ele=elev_ned_30m at PERMANENT acc=elevation.10m.acc
# curvature to get narrow valleys
-r.param.scale input=elev_ned_30m at PERMANENT output=tangential_curv_5 size=5 param=crosc
+r.param.scale input=elev_ned_30m at PERMANENT output=tangential_curv_5 size=5 method=crosc
# curvature to get a bit broader valleys
-r.param.scale input=elev_ned_30m at PERMANENT output=tangential_curv_7 size=7 param=crosc
+r.param.scale input=elev_ned_30m at PERMANENT output=tangential_curv_7 size=7 method=crosc
# curvature to get broad valleys
-r.param.scale input=elev_ned_30m at PERMANENT output=tangential_curv_11 size=11 param=crosc
+r.param.scale input=elev_ned_30m at PERMANENT output=tangential_curv_11 size=11 method=crosc
# create weight map
-r.mapcalc "weight = if(tangential_curv_5 < 0, -100 * tangential_curv_5, \
- if(tangential_curv_7 < 0, -100 * tangential_curv_7, \
- if(tangential_curv_11 < 0, -100 * tangential_curv_11, 0.000001)))"
+r.mapcalc "weight = if(tangential_curv_5 < 0, -100 * tangential_curv_5, \
+ if(tangential_curv_7 < 0, -100 * tangential_curv_7, \
+ if(tangential_curv_11 < 0, -100 * tangential_curv_11, 0.000001)))"
# weigh accumulation map
r.mapcalc expr="elev_ned_30m.acc.weighed = elev_ned_30m.acc * weight"
@@ -186,11 +186,27 @@
r.colors map=elev_ned_30m.acc.weighed raster=elev_ned_30m.acc
</pre></div>
+<p>
+<a href="r_stream_extract_weights_zoom.png">
+<img src="r_stream_extract_weights_zoom.png" width="400"></a><br>
+Weight map (spatial subset with lake in the southern half)
+<p>
+<a href="r_stream_extract_accum_orig_zoom.png">
+<img src="r_stream_extract_accum_orig_zoom.png" width="400"></a><br>
+Original flow accumulation map (spatial subset with lake in the southern half)
+<p>
+<a href="r_stream_extract_accum_weighted_zoom.png">
+<img src="r_stream_extract_accum_weighted_zoom.png" width="400"></a><br>
+Weighed flow accumulation map (spatial subset with lake in the southern half)
+<p>
Display both the original and the weighed accumulation map.
Compare them and proceed if the weighed accumulation map makes sense.
<div class="code"><pre>
-# extract streams
+# extract streams from weighed map
r.stream.extract elevation=elev_ned_30m at PERMANENT \
accumulation=elev_ned_30m.acc.weighed \
threshold=1000 \
@@ -203,8 +219,24 @@
stream_rast=elev_ned_30m.streams.noweight
</pre></div>
+<p>
Now display both stream maps and decide which one is more realistic.
+d.shade color=elev_ned_30m_streams_noweight shade=elevation_shade brighten=20
+<p>
+<a href="r_stream_extract_streams_noweight.png">
+<img src="r_stream_extract_streams_noweight.png" width="400"></a><br>
+Extracted streams from original flow accumulation map
+TODO: ERROR: Accumulation raster map is NULL but elevation map is not NULL
+<p>
+<a href="r_stream_extract_streams_weight.png">
+<img src="r_stream_extract_streams_weight.png" width="400"></a><br>
+Extracted streams from weighed flow accumulation map
<h2>REFERENCES</h2>
<ul>
Added: grass/trunk/raster/r.stream.extract/r_stream_extract_accum_orig_zoom.png
(Binary files differ)
Property changes on: grass/trunk/raster/r.stream.extract/r_stream_extract_accum_orig_zoom.png
___________________________________________________________________
Added: svn:mime-type
+ image/png
Added: grass/trunk/raster/r.stream.extract/r_stream_extract_accum_weighted_zoom.png
Property changes on: grass/trunk/raster/r.stream.extract/r_stream_extract_accum_weighted_zoom.png
+ image/png
Added: grass/trunk/raster/r.stream.extract/r_stream_extract_streams_noweight.png
Property changes on: grass/trunk/raster/r.stream.extract/r_stream_extract_streams_noweight.png
+ image/png
Added: grass/trunk/raster/r.stream.extract/r_stream_extract_weights_zoom.png
Property changes on: grass/trunk/raster/r.stream.extract/r_stream_extract_weights_zoom.png
+ image/png
