[GRASS-SVN] r69682 - grass/trunk/lib/gis/testsuite
svn_grass at osgeo.org
Thu Oct 6 14:44:43 PDT 2016
Author: wenzeslaus
Date: 2016-10-06 14:44:43 -0700 (Thu, 06 Oct 2016)
New Revision: 69682
Added:
grass/trunk/lib/gis/testsuite/gis_lib_str_color.py
libgis: ctypes-based test for G_str_to_color (grass and names syntax)
Added: grass/trunk/lib/gis/testsuite/gis_lib_str_color.py
--- grass/trunk/lib/gis/testsuite/gis_lib_str_color.py (rev 0)
+++ grass/trunk/lib/gis/testsuite/gis_lib_str_color.py 2016-10-06 21:44:43 UTC (rev 69682)
@@ -0,0 +1,77 @@
+"""Test of gis library string to color conversions
+ at author Vaclav Petras
+from ctypes import byref, c_int
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+import grass.lib.gis as libgis
+class StringToColorTestCase(TestCase):
+ """Test C function G_str_to_color() from gis library"""
+ def convert_color(self, string, red, green, blue):
+ """General test function to convert string to color
+ red, green, blue are expected values.
+ r = c_int()
+ g = c_int()
+ b = c_int()
+ ret = libgis.G_str_to_color(string, byref(r), byref(g), byref(b))
+ colors = ("{string} -> "
+ "{r.value}, {g.value}, {b.value}".format(**locals()))
+ self.assertEqual(ret, 1,
+ msg="Not successful return code (%s)" % colors)
+ self.assertEqual(r.value, red,
+ msg="Wrong number for red (%s)" % colors)
+ self.assertEqual(g.value, green,
+ msg="Wrong number for green (%s)" % colors)
+ self.assertEqual(b.value, blue,
+ msg="Wrong number for blue (%s)" % colors)
+ def test_grass_format(self):
+ """Test GRASS GIS color format (RRR:GGG:BBB)"""
+ self.convert_color("50:150:250", 50, 150, 250)
+ def test_grass_format_black(self):
+ """Test GRASS GIS color black color"""
+ self.convert_color("0:0:0", 0, 0, 0)
+ def test_grass_format_white(self):
+ """Test GRASS GIS color white color"""
+ self.convert_color("255:255:255", 255, 255, 255)
+ def test_grass_format_separators(self):
+ """Test GRASS GIS color format with all allowed separators"""
+ self.convert_color("50,150,250", 50, 150, 250)
+ self.convert_color("50;150;250", 50, 150, 250)
+ self.convert_color("50 150 250", 50, 150, 250)
+ def test_grass_format_multiple_separators(self):
+ """Test GRASS GIS color format with duplicated separators"""
+ self.convert_color("50, 150, 250", 50, 150, 250)
+ self.convert_color("50::150:250", 50, 150, 250)
+ self.convert_color("50 ; 150 ; 250", 50, 150, 250)
+ def test_grass_format_whitespace(self):
+ """Test with whitespace (spaces) around the string"""
+ self.convert_color(" 50:150:250 ", 50, 150, 250)
+ def test_grass_named_black(self):
+ self.convert_color("black", 0, 0, 0)
+ def test_grass_named_white(self):
+ self.convert_color("white", 255, 255, 255)
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/lib/gis/testsuite/gis_lib_str_color.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
