[GRASS-SVN] r69711 - grass/trunk/lib/init
Wed Oct 19 17:40:52 PDT 2016
Author: wenzeslaus
Date: 2016-10-19 17:40:52 -0700 (Wed, 19 Oct 2016)
New Revision: 69711
   grass/trunk/lib/init/grass.py
init: more explanations for invalid location or mapset
Also added comments from
https://lists.osgeo.org/pipermail/grass-dev/2016-September/082317.html
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py	2016-10-20 00:13:13 UTC (rev 69710)
+++ grass/trunk/lib/init/grass.py	2016-10-20 00:40:52 UTC (rev 69711)
@@ -800,9 +800,15 @@
         fatal(err.value.strip('"').strip("'").replace('\\n', os.linesep))
+# TODO: distinguish between valid for getting maps and usable as current
+# https://lists.osgeo.org/pipermail/grass-dev/2016-September/082317.html
 # interface created according to the current usage
 def is_mapset_valid(full_mapset):
     """Return True if GRASS Mapset is valid"""
+    # WIND is created from DEFAULT_WIND by `g.region -d` and functions
+    # or modules which create a new mapset. Most modules will fail if
+    # WIND doesn't exist (assuming that neither GRASS_REGION nor
+    # WIND_OVERRIDE environmental variables are set).
     return os.access(os.path.join(full_mapset, "WIND"), os.R_OK)
@@ -812,6 +818,10 @@
     :param gisdbase: Path to GRASS GIS database directory
     :param location: name of a Location
+    # DEFAULT_WIND file should not be required until you do something
+    # that actually uses them. The check is just a heuristic; a directory
+    # containing a PERMANENT/DEFAULT_WIND file is probably a GRASS
+    # location, while a directory lacking it probably isn't.
     return os.access(os.path.join(gisdbase, location,
                                   "PERMANENT", "DEFAULT_WIND"), os.F_OK)
@@ -840,10 +850,16 @@
         return _("<%s> is not a valid GRASS Location"
                  " because PERMANENT Mapset does not have a DEFAULT_WIND file"
                  " (default computational region)") % full_location
-    else:
+    elif mapset not in os.listdir(full_location):
         return _("Mapset <{mapset}> doesn't exist in GRASS Location <{loc}>. "
                  "A new mapset can be created by '-c' switch.").format(
                      mapset=mapset, loc=location)
+    elif not os.path.isdir(os.path.join(full_location, mapset)):
+        return _("<%s> is not a GRASS Mapset"
+                 " because it is not a directory") % mapset
+    else:
+        return _("Mapset <{mapset}> is invalid for an unknown reason").format(
+                     mapset=mapset, loc=location)
 def set_mapset(gisrc, arg, geofile=None, create_new=False):
