[GRASS-SVN] r69717 - grass-addons/grass7/raster/r.scatterplot
Sat Oct 22 15:42:34 PDT 2016
Author: wenzeslaus
Date: 2016-10-22 15:42:34 -0700 (Sat, 22 Oct 2016)
New Revision: 69717
Added:
   grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables.png
   grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables_3rd_color.png
   grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables_3rd_z.png
   grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables_3rd_z_4th_color.png
   grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables_3rd_z_4th_color2.png
   grass-addons/grass7/raster/r.scatterplot/r_scatterplot_3_variables.png
   grass-addons/grass7/raster/r.scatterplot/r_scatterplot_3_variables_3_colors.png
   grass-addons/grass7/raster/r.scatterplot/r_scatterplot_3_variables_3_colors_overlap.png
   grass-addons/grass7/raster/r.scatterplot/r.scatterplot.html
   grass-addons/grass7/raster/r.scatterplot/r_scatterplot.png
r.scatterplot: unique images for description based on landsat (not using r3.scatterplot's)
Modified: grass-addons/grass7/raster/r.scatterplot/r.scatterplot.html
--- grass-addons/grass7/raster/r.scatterplot/r.scatterplot.html	2016-10-22 17:10:13 UTC (rev 69716)
+++ grass-addons/grass7/raster/r.scatterplot/r.scatterplot.html	2016-10-22 22:42:34 UTC (rev 69717)
@@ -47,9 +47,9 @@
 variables are associated with one point.
 <center>
-<img src="r3_scatterplot_2_variables.png">
-<img src="r3_scatterplot_2_variables_3rd_color.png">
-<img src="r3_scatterplot_2_variables_3rd_z.png">
+<img src="r_scatterplot_2_variables.png">
+<img src="r_scatterplot_2_variables_3rd_color.png">
+<img src="r_scatterplot_2_variables_3rd_z.png">
 <p><em>
     Figure: One scatter plot of two variables (left),
     the same scatter plot but with color showing third variable (middle),
@@ -57,9 +57,13 @@
 </em></p>
 </center>
+r.scatterplot input=lsat7_2002_30,lsat7_2002_40 output=scatterplot \
+    color_raster=landclass96 z_raster=lsat7_2002_50
 <center>
-<img src="r3_scatterplot_2_variables_3rd_z_4th_color.png">
-<img src="r3_scatterplot_2_variables_3rd_z_4th_color2.png">
+<img src="r_scatterplot_2_variables_3rd_z_4th_color.png">
+<img src="r_scatterplot_2_variables_3rd_z_4th_color2.png">
 <p><em>
     Figure: One scatter plot in with one variable as Z coordinate and
     another variable as color (two rotated views).
@@ -76,8 +80,12 @@
 variables. Each scatter plot is placed into a separate layer of
 the output vector map.
+r.scatterplot input=lsat7_2002_30,lsat7_2002_40,lsat7_2002_50 output=scatterplot
+d.vect -c map=scatterplot layer=-1 color=none width=1 icon=basic/point
 <center>
-<img src="r3_scatterplot_3_variables_3_colors_overlap.png">
+<img src="r_scatterplot_3_variables_3_colors_overlap.png">
 <p><em>
     Figure: Three overlapping scatter plots of three variables A, B, and C.
     Individual scatter plots are distinguished by color.
@@ -95,16 +103,22 @@
 represented as Z coordinate or color. In that case, Z coordinate
 or color is same for all the scatter plots.
+r.scatterplot input=lsat7_2002_30,lsat7_2002_40,lsat7_2002_50 output=scatterplot -f
 <center>
-<img src="r3_scatterplot_3_variables_3_colors.png">
+<img src="r_scatterplot_3_variables_3_colors.png">
 <p><em>
     Figure: Three scatter plots of three variables A, B, and C.
     First one is A and B, second A and C, and third B and C.
 </em></p>
 </center>
+r.scatterplot input=lsat7_2002_30,lsat7_2002_40,lsat7_2002_50 output=scatterplot color_raster=landclass96 -f
 <center>
-<img src="r3_scatterplot_3_variables.png">
+<img src="r_scatterplot_3_variables.png">
 <p><em>
     with color showing a fourth variable D in all scatter plots.
@@ -152,7 +166,8 @@
 <h3>Landsat bands</h3>
-Set the computation region to one of the raster maps:
+In the full North Carolina sample location,
+set the computation region to one of the raster maps:
 <div class="code"><pre>
 g.region raster=lsat7_2002_30
@@ -172,7 +187,8 @@
 <center>
 <img src="r_scatterplot.png">
 <p><em>
-    Figure: Scatter plot showing third variable as color
+    Figure: Scatter plot showing red and near infrared Landsat bands
+    colored using land cover classes
 </em></p>
 </center>
@@ -182,6 +198,7 @@
 <em>
 <a href="r.stats.html">r.stats</a>,
 <a href="d.correlate.html">d.correlate</a>,
+<a href="r3.scatterplot.html">r3.scatterplot</a>,
 <a href="v.mkgrid.html">v.mkgrid</a>,
 <a href="v.vect.stats.html">v.vect.stats</a>,
 <a href="g.region.html">g.region</a>
Property changes on: grass-addons/grass7/raster/r.scatterplot/r_scatterplot.png
___________________________________________________________________
Modified: svn:mime-type
   - application/octet-stream
   + image/png
Added: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables.png
(Binary files differ)
Property changes on: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables.png
Added: svn:mime-type
   + image/png
Added: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables_3rd_color.png
Property changes on: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables_3rd_color.png
   + image/png
Added: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables_3rd_z.png
Property changes on: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables_3rd_z.png
   + image/png
Added: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables_3rd_z_4th_color.png
Property changes on: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables_3rd_z_4th_color.png
   + image/png
Added: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables_3rd_z_4th_color2.png
Property changes on: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_2_variables_3rd_z_4th_color2.png
   + image/png
Added: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_3_variables.png
Property changes on: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_3_variables.png
   + image/png
Added: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_3_variables_3_colors.png
Property changes on: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_3_variables_3_colors.png
   + image/png
Added: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_3_variables_3_colors_overlap.png
Property changes on: grass-addons/grass7/raster/r.scatterplot/r_scatterplot_3_variables_3_colors_overlap.png
   + image/png
