[GRASS-SVN] r69746 - in grass/trunk: temporal temporal/t.rast.neighbors temporal/t.rast.to.rast3 temporal/t.vect.observe.strds temporal/t.vect.what.strds vector/v.buffer vector/v.db.select
Thu Oct 27 14:20:55 PDT 2016
Author: neteler
Date: 2016-10-27 14:20:55 -0700 (Thu, 27 Oct 2016)
New Revision: 69746
   grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html
   grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.html
   grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.html
   grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html
   grass/trunk/temporal/temporalintro.html
   grass/trunk/vector/v.buffer/v.buffer.html
   grass/trunk/vector/v.db.select/v.db.select.html
temporal manual: language improvements (contributed by veroandreo); minor vector manual improvements
Modified: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html	2016-10-27 19:55:31 UTC (rev 69745)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html	2016-10-27 21:20:55 UTC (rev 69746)
@@ -7,19 +7,19 @@
 and the aggregation method can be chosen.
 <p>
 The user must provide an input and an output space time raster dataset and
-the basename  of the resulting raster maps. The resulting STRDS will have
+the basename of the resulting raster maps. The resulting STRDS will have
 the same temporal resolution as the input dataset.
 All maps will be processed using the current region settings.
 <p>
 The user can select a subset of the input space time raster dataset for
 processing using a SQL WHERE statement. The number of CPU's to be used
 for parallel processing can be specified with the <em>nprocs</em>
-option, to speedup the computation on multi-core system.
+option to speedup the computation on multi-core system.
 <h2>EXAMPLE</h2>
-To smooth the maps contained into a space time dataset run:
+To smooth the maps contained in a space time dataset run:
 <div class="code"><pre>
 t.rast.neighbors input=tempmean_monthly output=smooth_tempmean_monthly \
@@ -76,8 +76,7 @@
-# now compare the values between original data and the smoothed one
-t.rast.list input=smooth_tempmean_monthly columns=name,start_time,min,max
+# now compare the values between the original and the smoothed dataset
 name|start_time|min|max
Modified: grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.html
--- grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.html	2016-10-27 19:55:31 UTC (rev 69745)
+++ grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.html	2016-10-27 21:20:55 UTC (rev 69746)
@@ -27,6 +27,27 @@
 based granularity as well. This may result in millions of space time
 voxel cube layers!
+<h3>Management of open file limits</h3>
+The maximum number of raster maps that can be processed is given by the
+per-user limit of the operating system. For example, both the the hard and soft
+limit for users is typically 1024. The soft limit can be changed with e.g.
+ulimit -n 4096 (UNIX-based operating systems) but not higher than the
+hard limit. If the latter is too low, you can as superuser add an entry in
+<div class="code"><pre>
+/etc/security/limits.conf
+# <domain>      <type>  <item>         <value>
+your_username  hard    nofile          4096
+</pre></div>
+This will raise the hard limit to 4096 files. Also have a look at the overall
+limit of the operating system
+cat /proc/sys/fs/file-max
+</pre></div>
+which, on modern Linux systems, is several 100,000 files.
 <h2>EXAMPLE</h2>
 To create a voxel map layer from a subset of the <em>tempmean_monthly</em>
 space time dataset, run:
Modified: grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.html
--- grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.html	2016-10-27 19:55:31 UTC (rev 69745)
+++ grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.html	2016-10-27 21:20:55 UTC (rev 69746)
@@ -11,11 +11,11 @@
 start to end). A column name must be specified for each input space
 time raster dataset.
 <p>
-As results  a new space time vector dataset is generated that contains
-a single (new) vector map that links to as many time stamped attribute
-tables as raster map layer are present in the input space time raster
-dataset. Hence, for each time step in the space time raster dataset a
-new attribute table is created. The GRASS GIS Temporal Framework allows
+The result is a new space time vector dataset that contains a single
+(new) vector map which links to as many time-stamped attribute tables
+as raster map layers are present in the input space time raster dataset.
+Hence, for each time step in the space time raster dataset a new
+attribute table is created. The GRASS GIS Temporal Framework allows
 to time stamp attribute tables that can be linked to a single vector
 map layer.
 <p>
@@ -29,7 +29,7 @@
 <h2>EXAMPLE</h2>
-The example show how to create a space time vector dataset and a vector
+The example shows how to create a space time vector dataset and a vector
 layer starting from a point vector and a space time raster dataset:
Modified: grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html
--- grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html	2016-10-27 19:55:31 UTC (rev 69745)
+++ grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html	2016-10-27 21:20:55 UTC (rev 69746)
@@ -1,14 +1,14 @@
 <h2>DESCRIPTION</h2>
-The module <em>t.vect.what.strds</em> samples a space time raster dataset
-at spatio-temporal locations of a space time vector dataset.
+The module <em>t.vect.what.strds</em> samples a space time raster dataset
+(STRDS) at the spatio-temporal locations of a space time vector dataset (STVDS).
 <h2>EXAMPLE</h2>
 The example is based on the space time vector dataset "precip_stations at climate_2009_2012"
 created in the <a href="t.vect.observe.strds.html">t.vect.observe.strds</a> example.
-In below example the command fills the new column "new_temp" with values
+In the example below, the module fills the new column "new_temp" with values
 extracted from the "tempmean_monthly" space time raster dataset:
Modified: grass/trunk/temporal/temporalintro.html
--- grass/trunk/temporal/temporalintro.html	2016-10-27 19:55:31 UTC (rev 69745)
+++ grass/trunk/temporal/temporalintro.html	2016-10-27 21:20:55 UTC (rev 69746)
@@ -1,7 +1,7 @@
 <!-- meta page description: Temporal data processing in GRASS GIS -->
 <!-- meta page index: temporal -->
-The temporal enabled GRASS introduces three new datatypes that
+The temporal enabled GRASS introduces three new data types that
 are designed to handle time series data:
 <ul>
   <li> <em>Space time raster datasets</em> (strds) are designed to manage
@@ -20,15 +20,17 @@
 <h3>Temporal data management in general</h3>
-<p>Space time datasets are stored in a temporal database.
-A core principle of the temporal framework is that temporal databases are mapset specific.
-A new temporal databases is created, when a temporal command is invoked in a mapset
-that does not contain a temporal database. For example if a mapset was recently created.
-<b>As a result, space-time datasets are mapset specific and can only register raster, 3D raster or
-vector maps from the same mapset.</b> By default space-time datasets can not register
-maps from other mapsets. This is a security measure, since the registration of maps in
-a space-time dataset will always modify the metadata of the registered map. This is critical if:
-</p>
+Space time datasets are stored in a temporal database. A core principle of the
+temporal framework is that temporal databases are mapset specific. A new temporal
+database is created when a temporal command is invoked in a mapset that does not
+contain any temporal databases yet. For example, when a mapset was recently created.
+<p>
+<b>Therefore, as space-time datasets are mapset specific, they can only register
+raster, 3D raster or vector maps from the same mapset.</b>
+<p>
+By default, space-time datasets can not register maps from other mapsets. This is
+a security measure, since the registration of maps in a space-time dataset will
+always modify the metadata of the registered map. This is critical if:
 <ul>
     <li>
         The user has no write access to the maps from other mapsets he wants to register
@@ -39,64 +41,63 @@
     </li>
 </ul>
-SQLite3 or PostgreSQL are supported as temporal database back end.
-Temporal databases stored in other mapsets can be accessed as long as they are in the
-user's current mapset search path (managed with <a href="g.mapsets.html">g.mapsets</a>).
-Access to space-time datasets from other mapsets is read only.
-They can not be modified or removed.
+SQLite3 or PostgreSQL are supported as temporal database backends.
+Temporal databases stored in other mapsets can be accessed as long as those
+other mapsets are in the user's current mapset search path (managed with
+<a href="g.mapsets.html">g.mapsets</a>). Access to space-time datasets from
+other mapsets is read-only. They can not be modified or removed.
 <p>
 Connection settings are performed with <a href="t.connect.html">t.connect</a>.
-As default a sqlite3 database will be created in the current mapset that
-stores all space time datasets and registered time series maps.
-</p>
-New space time datasets are created in the temporal database with
+As default, a SQLite3 database will be created in the current mapset that
+stores all space-time datasets and registered time series maps.
+<p>
+New space-time datasets are created in the temporal database with
 <a href="t.create.html">t.create</a>. The name of the new dataset, the
 type (strds, str3ds, stvds), the title and the description must be
-provided for creation. Optional the temporal type (absolute, relative)
-and semantic information can be provided.
+provided for creation. Optionally, the temporal type (absolute, relative)
+and the semantic information can be provided.
 <p>
 The module <a href="t.register.html">t.register</a> is designed to
 register raster, 3D raster and vector maps in the temporal database and
-in space time datasets. It supports different input options. Maps
+in the space-time datasets. It supports different input options. Maps
 to register can be provided as a comma separated string at the command line, or
 in an input file. The module supports the definition of time stamps
 (time instances or intervals) for each map in the input file.
 With  <a href="t.unregister.html">t.unregister</a> maps can be unregistered
-from space time datasets and the temporal database.
-</p>
+from space-time datasets and from the temporal database.
+<p>
 <b>Important</b><br>
 <i>Use only temporal commands like t.register to attach a time stamp to
 raster, 3D raster and vector maps. The commands r.timestamp, r3.timestamp and
 v.timestamp should not be used, since they do not register maps in
 the temporal database and modify only the metadata of the map in the
-spatial database. However maps with timestamps attached with *.timestamp modules
-and be registered in space-time datasets using the existing timestamp.</i>
+spatial database. However, maps with timestamps attached with *.timestamp modules
+can be registered in space-time datasets using the existing timestamp.</i>
 <p>
-The module <a href="t.remove.html">t.remove</a> will remove the space time datasets
-from the temporal database and optionally all registered maps. It will take care of multiple map registration,
-hence if maps are registered in several space-time datasets in the current mapset.
-Use  <a href="t.support.html">t.support</a>
+The module <a href="t.remove.html">t.remove</a> will remove the space-time datasets
+from the temporal database and optionally all registered maps. It will take care
+of multiple map registration, hence if maps are registered in several space-time
+datasets in the current mapset.
+Use <a href="t.support.html">t.support</a>
 to modify the metadata of space time datasets or to update the metadata
 that is derived from registered maps. This module also checks for removed
-and modified maps and updates the space time datasets accordingly.
-Rename a space time dataset with <a href="t.rename.html">t.rename</a>.
-</p>
-To print information about space time datasets or registered maps, the
+and modified maps and updates the space-time datasets accordingly.
+Rename a space-time dataset with <a href="t.rename.html">t.rename</a>.
+<p>
+To print information about space-time datasets or registered maps, the
 module  <a href="t.info.html">t.info</a> can be used.
-<a href="t.list.html">t.list</a> will list all space time datasets and
+<a href="t.list.html">t.list</a> will list all space-time datasets and
 registered maps in the temporal database.
 <p>
-To compute and check the temporal topology of a space time datasets the
+To compute and check the temporal topology of space-time datasets the
 module <a href="t.topology.html">t.topology</a> was designed. The module
-<a href="t.sample.html">t.sample</a> samples input space time dataset(s)
-with a sample space time dataset and print the result to standard output.
-Several different sample methods are supported that can be combined.
-</p>
+<a href="t.sample.html">t.sample</a> samples input space-time dataset(s)
+with a sample space-time dataset and prints the result to standard output.
+Different sampling methods are supported and can be combined.
 <p>
 List of general management modules:
-</p>
 <ul>
     <li><a href="t.connect.html">t.connect</a></li>
     <li><a href="t.create.html">t.create</a></li>
@@ -111,7 +112,7 @@
     <li><a href="t.topology.html">t.topology</a></li>
 </ul>
-<h3>Modules to visualize space time datasets and temporal data</h3>
+<h3>Modules to visualize space-time datasets and temporal data</h3>
 <ul>
     <li><a href="g.gui.animation.html">g.gui.animation</a></li>
@@ -120,21 +121,21 @@
     <li><a href="g.gui.tplot.html">g.gui.tplot</a></li>
 </ul>
-<h3>Modules to process space time raster datasets</h3>
+<h3>Modules to process space-time raster datasets</h3>
 The focus of the temporal GIS framework is the processing and analysis of
-raster time series. Hence the majority of the temporal modules are designed to process space time raster
-datasets. However, there are several modules to process space time 3D raster datasets
-and space time vector datasets.
+raster time series. Hence, the majority of the temporal modules are designed
+to process space-time raster datasets. However, there are several modules to
+process space-time 3D raster datasets and space-time vector datasets.
 <h4>Querying and map calculation</h4>
-Registered maps of a space time raster datasets can be listed using
+Registered maps of a space-time raster dataset can be listed using
 <a href="t.rast.list.html">t.rast.list</a>. This module supports several
-methods how the maps should be listed using SQL queries do determine how
-they are selected and sorted. Subsets of space time raster datasets can
+methods to list maps and uses SQL queries to determine how these maps
+are selected and sorted. Subsets of space-time raster datasets can
 be extracted with <a href="t.rast.extract.html">t.rast.extract</a> that
-allows additionally to perform mapcalc operations on the selected raster
+allows to perform additional mapcalc operations on the selected raster
 maps.
 <ul>
@@ -145,21 +146,23 @@
     <li><a href="t.rast.neighbors.html">t.rast.neighbors</a></li>
 </ul>
-Additionally, there is <a href="v.what.strds.html">v.what.strds</a>.
+Moreover, there is <a href="v.what.strds.html">v.what.strds</a>, that uploads
+space-time raster dataset values at positions of vector points, to the
+attribute table of the vector map.
 <h4>Aggregation and accumulation analysis</h4>
-The temporal framework support the aggregation of space time raster
+The temporal framework supports the aggregation of space-time raster
 datasets. It provides three modules to perform aggregation using different
-approaches. To aggregate a space time raster map using a temporal
+approaches. To aggregate a space-time raster map using a temporal
 granularity like 4 months, 7 days and so on use
 <a href="t.rast.aggregate.html">t.rast.aggregate</a>. The module
 <a href="t.rast.aggregate.ds.html">t.rast.aggregate.ds</a> allows the
-aggregation of raster map series using the intervals of the maps (raster,
-3D raster and vector) of a 2. space time dataset. A simple interface to
+aggregation of a raster map time series using the intervals of the maps (raster,
+3D raster and vector) of another space-time dataset. A simple interface to
 <a href="r.series.html">r.series</a> is the module
 <a href="t.rast.series.html">t.rast.series</a> that processes the whole
-input space time raster dataset or a subset of it.
+input space-time raster dataset or a subset of it.
 <ul>
     <li><a href="t.rast.aggregate.html">t.rast.aggregate</a></li>
@@ -171,14 +174,14 @@
 <h4>Export/import conversion</h4>
-Space time raster datasets can be exported with <a href="t.rast.export.html">t.rast.export</a>
-as compressed tar archive. Such archives can be imported
-using <a href="t.rast.import.html">t.rast.import</a>,
+Space-time raster datasets can be exported with <a href="t.rast.export.html">t.rast.export</a>
+as a compressed tar archive. Such archives can then be imported
+using <a href="t.rast.import.html">t.rast.import</a>.
 <p>
 The module <a href="t.rast.to.rast3.html">t.rast.to.rast3</a> converts
-space time raster datasets into space time voxel cubes. All 3D raster modules
-can be used to process such voxel cubes. This conversion allows the export of space time raster datasets
-as netcdf files that include time as one dimension.
+space-time raster datasets into space-time voxel cubes. All 3D raster modules
+can be used to process such voxel cubes. This conversion allows the export of
+space-time raster datasets as netCDF files that include time as one dimension.
 <ul>
     <li><a href="t.rast.export.html">t.rast.export</a></li>
@@ -197,7 +200,7 @@
 <h3>Modules to manage, process and analyze STR3DS and STVDS</h3>
-Several space time vector dataset modules were developed, to allow the handling
+Several space-time vector dataset modules were developed to allow the handling
 of vector time series data.
 <ul>
@@ -210,8 +213,8 @@
     <li><a href="t.vect.db.select.html">t.vect.db.select</a></li>
 </ul>
-The space time 3D raster dataset modules are doing exactly the same as their raster
-pendants but with 3D raster map layers:
+The space-time 3D raster dataset modules are doing exactly the same as their
+raster pendants, but with 3D raster map layers:
 <ul>
     <li><a href="t.rast3d.list.html">t.rast3d.list</a></li>
@@ -232,4 +235,3 @@
 <li><a href="http://www.geostat-course.org/Topic_Gebbert">GEOSTAT 2012 TGRASS Course</a></li>
 </ul>
Modified: grass/trunk/vector/v.buffer/v.buffer.html
--- grass/trunk/vector/v.buffer/v.buffer.html	2016-10-27 19:55:31 UTC (rev 69745)
+++ grass/trunk/vector/v.buffer/v.buffer.html	2016-10-27 21:20:55 UTC (rev 69746)
@@ -125,6 +125,9 @@
 <h3>Buffer inside input areas</h3>
+In this example, an internal buffer ("inward buffer" or "negative buffer")
+is generated using a negative <b>distance</b> value:
 v.buffer input=lakes output=lakes_buffer type=area distance=-50
 </pre></div>
Modified: grass/trunk/vector/v.db.select/v.db.select.html
--- grass/trunk/vector/v.db.select/v.db.select.html	2016-10-27 19:55:31 UTC (rev 69745)
+++ grass/trunk/vector/v.db.select/v.db.select.html	2016-10-27 21:20:55 UTC (rev 69746)
@@ -55,7 +55,7 @@
 </pre></div>
-<h3>Select empty vector features (no data entries)</h3>
+<h3>Select not empty vector features (no data entries)</h3>
 v.db.select geonames_wake where="ALTERNATEN IS NOT NULL"
