[GRASS-SVN] r69749 - in grass/branches/releasebranch_7_2: imagery/i.landsat.toar raster raster/r.compress raster/r.patch temporal temporal/t.rast.algebra temporal/t.select vector/v.generalize
svn_grass at osgeo.org
Fri Oct 28 07:02:22 PDT 2016
Author: martinl
Date: 2016-10-28 07:02:21 -0700 (Fri, 28 Oct 2016)
New Revision: 69749
grass/branches/releasebranch_7_2/imagery/i.landsat.toar/landsat_set.c
grass/branches/releasebranch_7_2/raster/r.compress/r.compress.html
grass/branches/releasebranch_7_2/raster/r.patch/r.patch.html
grass/branches/releasebranch_7_2/raster/rasterintro.html
grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.py
grass/branches/releasebranch_7_2/temporal/t.select/t.select.py
grass/branches/releasebranch_7_2/temporal/temporalintro.html
grass/branches/releasebranch_7_2/vector/v.generalize/v.generalize.html
Patch to fix various spelling errors (relbr72; see #3194)
Modified: grass/branches/releasebranch_7_2/imagery/i.landsat.toar/landsat_set.c
--- grass/branches/releasebranch_7_2/imagery/i.landsat.toar/landsat_set.c 2016-10-28 14:01:13 UTC (rev 69748)
+++ grass/branches/releasebranch_7_2/imagery/i.landsat.toar/landsat_set.c 2016-10-28 14:02:21 UTC (rev 69749)
@@ -378,7 +378,7 @@
/* Spectral radiances at detector */
double Lmax[][4] = {
{240., 170., 150., 127.}, /* before April 6, 1984 */
- {268., 179., 159., 123.}, /* betweeen */
+ {268., 179., 159., 123.}, /* between */
{268., 179., 148., 123.} /* after November 9, 1984 */
double Lmin[][4] = {
Modified: grass/branches/releasebranch_7_2/raster/r.compress/r.compress.html
--- grass/branches/releasebranch_7_2/raster/r.compress/r.compress.html 2016-10-28 14:01:13 UTC (rev 69748)
+++ grass/branches/releasebranch_7_2/raster/r.compress/r.compress.html 2016-10-28 14:02:21 UTC (rev 69749)
@@ -114,7 +114,7 @@
<dt><strong>ZLIB</strong></dt>
<dd>ZLIB's deflate is the default compression method for all raster
maps. GRASS GIS 7 uses by default 1 as ZLIB compression level which is the
-best compromise betweeen speed and compression ratio, also when
+best compromise between speed and compression ratio, also when
compared to other available compression methods. Valid levels are in
the range [1, 9] and can be set with the environment variable
<tt>GRASS_ZLIB_LEVEL</tt>.</dd>
Modified: grass/branches/releasebranch_7_2/raster/r.patch/r.patch.html
--- grass/branches/releasebranch_7_2/raster/r.patch/r.patch.html 2016-10-28 14:01:13 UTC (rev 69748)
+++ grass/branches/releasebranch_7_2/raster/r.patch/r.patch.html 2016-10-28 14:02:21 UTC (rev 69749)
@@ -84,7 +84,7 @@
from the <em>input</em> maps and creates these files for the patched,
composite <em>output</em> map. This can be quite time consuming for
certain maps, especially if there are many different category values
-across the patched maps. The <em>-s</em> flag allows to disable the reading
+across the patched maps. The <em>-s</em> flag allows disabling the reading
and creation of these support files, meaning that the <em>output</em>
map will have no category labels and no explicit color table.
Modified: grass/branches/releasebranch_7_2/raster/rasterintro.html
--- grass/branches/releasebranch_7_2/raster/rasterintro.html 2016-10-28 14:01:13 UTC (rev 69748)
+++ grass/branches/releasebranch_7_2/raster/rasterintro.html 2016-10-28 14:02:21 UTC (rev 69749)
@@ -302,7 +302,7 @@
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.py 2016-10-28 14:01:13 UTC (rev 69748)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.py 2016-10-28 14:02:21 UTC (rev 69749)
@@ -65,7 +65,7 @@
#%flag
#% key: d
-#% description: Perform a dry run, compute all depenencies and module calls but don't run them
+#% description: Perform a dry run, compute all dependencies and module calls but don't run them
#%end
import grass.script
Modified: grass/branches/releasebranch_7_2/temporal/t.select/t.select.py
--- grass/branches/releasebranch_7_2/temporal/t.select/t.select.py 2016-10-28 14:01:13 UTC (rev 69748)
+++ grass/branches/releasebranch_7_2/temporal/t.select/t.select.py 2016-10-28 14:02:21 UTC (rev 69749)
@@ -42,7 +42,7 @@
#%flag
#% key: d
#%end
Modified: grass/branches/releasebranch_7_2/temporal/temporalintro.html
--- grass/branches/releasebranch_7_2/temporal/temporalintro.html 2016-10-28 14:01:13 UTC (rev 69748)
+++ grass/branches/releasebranch_7_2/temporal/temporalintro.html 2016-10-28 14:02:21 UTC (rev 69749)
@@ -135,7 +135,7 @@
methods to list maps and uses SQL queries to determine how these maps
are selected and sorted. Subsets of space-time raster datasets can
be extracted with <a href="t.rast.extract.html">t.rast.extract</a> that
-allows to perform additional mapcalc operations on the selected raster
+allows performing additional mapcalc operations on the selected raster
maps.
<ul>
Modified: grass/branches/releasebranch_7_2/vector/v.generalize/v.generalize.html
--- grass/branches/releasebranch_7_2/vector/v.generalize/v.generalize.html 2016-10-28 14:01:13 UTC (rev 69748)
+++ grass/branches/releasebranch_7_2/vector/v.generalize/v.generalize.html 2016-10-28 14:02:21 UTC (rev 69749)
@@ -29,7 +29,7 @@
<p>Lines and boundaries are not translated if they would collapse to a
single point. Boundaries are not translated if they would intersect
-with themselves or other boundaries. Such erroneus features are written
+with themselves or other boundaries. Such erroneous features are written
to an optional <em>error</em> vector map. Overlaying the <em>error</em>
map over the generalized map indicates the kind of error.
Lines/boundaries collapsing to a point are written out as points,
