[GRASS-SVN] r69752 - grass-addons/grass7/vector/v.surf.tps
svn_grass at osgeo.org
Fri Oct 28 14:25:12 PDT 2016
Author: mmetz
Date: 2016-10-28 14:25:12 -0700 (Fri, 28 Oct 2016)
New Revision: 69752
grass-addons/grass7/vector/v.surf.tps/main.c
grass-addons/grass7/vector/v.surf.tps/tps.c
grass-addons/grass7/vector/v.surf.tps/v.surf.tps.html
v.surf.tps: reduce tiling artefacts
Modified: grass-addons/grass7/vector/v.surf.tps/main.c
--- grass-addons/grass7/vector/v.surf.tps/main.c 2016-10-28 20:55:24 UTC (rev 69751)
+++ grass-addons/grass7/vector/v.surf.tps/main.c 2016-10-28 21:25:12 UTC (rev 69752)
@@ -113,7 +113,7 @@
ov_opt->key = "overlap";
ov_opt->type = TYPE_DOUBLE;
ov_opt->required = NO;
- ov_opt->answer = "0.8";
+ ov_opt->answer = "0.1";
ov_opt->label =
_("Overlap factor <= 1");
ov_opt->description =
Modified: grass-addons/grass7/vector/v.surf.tps/tps.c
--- grass-addons/grass7/vector/v.surf.tps/tps.c 2016-10-28 20:55:24 UTC (rev 69751)
+++ grass-addons/grass7/vector/v.surf.tps/tps.c 2016-10-28 21:25:12 UTC (rev 69752)
@@ -214,8 +214,10 @@
break;
- if (isnull)
+ if (isnull) {
+ Rast_set_d_null_value(&outbuf[col], 1);
continue;
result = B[0];
@@ -544,6 +546,13 @@
wmin = 10;
wmax = 0;
+ if (overlap > 1.0)
+ overlap = 1.0;
+ if (overlap < 0.0)
+ overlap = 0.0;
+ /* keep in sync with weight calculation below */
+ overlap = exp((overlap - 1.0) * 8.0);
for (ridx = 0; ridx < nrows; ridx++) {
G_percent(ridx, nrows, 1);
@@ -851,15 +860,12 @@
- dx = abs(icol - col) / dxi;
- dy = abs(irow - row) / dyi;
+ dx = fabs(2.0 * icol - (icol2 + icol1)) / dxi;
+ dy = fabs(2.0 * irow - (irow2 + irow1)) / dyi;
- dx = fabs(icol - (icol2 + icol1) / 2.0) / dxi;
- dy = fabs(irow - (irow2 + irow1) / 2.0) / dyi;
dist2 = (dx * dx + dy * dy);
- weight = exp(-dist2 * 2);
+ weight = exp(-dist2 * 4.0);
if (wmin > weight)
wmin = weight;
Modified: grass-addons/grass7/vector/v.surf.tps/v.surf.tps.html
--- grass-addons/grass7/vector/v.surf.tps/v.surf.tps.html 2016-10-28 20:55:24 UTC (rev 69751)
+++ grass-addons/grass7/vector/v.surf.tps/v.surf.tps.html 2016-10-28 21:25:12 UTC (rev 69752)
@@ -30,7 +30,8 @@
the <b>min</b> option is smaller than the numer of input points.
Tiling artefacts occur with low values for the <b>min</b> option and the
<b>overlap</b> option. Increasing both options will reduce tiling
-artefacts but processing will take more time.
+artefacts but processing will take more time. Values for the
+<b>overlap</b> option must be between 0 and 1.
<p>
The module works best with evenly spaced sparse points. In case of
