[GRASS-SVN] r69755 - in grass/branches/releasebranch_7_2/gui/wxpython: mapdisp mapwin
svn_grass at osgeo.org
Sat Oct 29 15:19:12 PDT 2016
Author: annakrat
Date: 2016-10-29 15:19:12 -0700 (Sat, 29 Oct 2016)
New Revision: 69755
grass/branches/releasebranch_7_2/gui/wxpython/mapdisp/frame.py
grass/branches/releasebranch_7_2/gui/wxpython/mapwin/buffered.py
fix d.to.rast, which was broken since new rendering (merge from trunk, r69754)
Modified: grass/branches/releasebranch_7_2/gui/wxpython/mapdisp/frame.py
--- grass/branches/releasebranch_7_2/gui/wxpython/mapdisp/frame.py 2016-10-29 22:01:52 UTC (rev 69754)
+++ grass/branches/releasebranch_7_2/gui/wxpython/mapdisp/frame.py 2016-10-29 22:19:12 UTC (rev 69755)
@@ -665,7 +665,7 @@
dlg.Destroy()
- def DOutFile(self, command):
+ def DOutFile(self, command, callback=None):
"""Saves map to image by running d.out.file from gui or d.mon.
Command is expected to be validated by parser.
@@ -699,7 +699,7 @@
if each['ext'] == extType:
bitmapType = each['type']
break
- self.MapWindow.SaveToFile(name, bitmapType, int(width), int(height))
+ self.MapWindow.SaveToFile(name, bitmapType, int(width), int(height), callback)
def DOutFileOptData(self, dcmd, layer, params, propwin):
"""Dummy function which is called when d.out.file is called
@@ -713,6 +713,49 @@
def DToRast(self, command):
"""Saves currently loaded composition of layers as a raster map.
+ def _DToRastDone():
+ # import back as red, green, blue rasters
+ returncode, messages = RunCommand(
+ 'r.in.gdal', flags='o', input=pngFile, output=tmpName, quiet=True,
+ overwrite=overwrite, getErrorMsg=True)
+ if not returncode == 0:
+ self._giface.WriteError(_('Failed to run d.to.rast:\n') + messages)
+ return
+ # set region for composite
+ grass.use_temp_region()
+ returncode, messages = RunCommand('g.region', raster=tmpName + '.red',
+ quiet=True, getErrorMsg=True)
+ grass.del_temp_region()
+ return
+ # composite
+ 'r.composite', red=tmpName + '.red', green=tmpName + '.green',
+ blue=tmpName + '.blue', output=outputRaster, quiet=True,
+ RunCommand(
+ 'g.remove',
+ type='raster',
+ flags='f',
+ quiet=True,
+ name=[tmpName + '.red', tmpName + '.green', tmpName + '.blue'])
+ grass.try_remove(pngFile)
+ return
+ # alignExtent changes only region variable
+ oldRegion = self.GetMap().GetCurrentRegion().copy()
+ self.GetMap().AlignExtentFromDisplay()
+ region = self.GetMap().GetCurrentRegion().copy()
+ self.GetMap().region.update(oldRegion)
+ RunCommand('r.region', map=outputRaster, n=region['n'], s=region['s'],
+ e=region['e'], w=region['w'], quiet=True)
if self.IsPaneShown('3d'):
_('d.to.rast can be used only in 2D mode.'))
@@ -734,55 +777,10 @@
tmpName = 'd_to_rast_tmp'
pngFile = grass.tempfile(create=False) + '.png'
dOutFileCmd = ['d.out.file', 'output=' + pngFile, 'format=png']
- self.DOutFile(dOutFileCmd)
- # import back as red, green, blue rasters
- returncode, messages = RunCommand(
- 'r.in.gdal', flags='o', input=pngFile, output=tmpName, quiet=True,
- overwrite=overwrite, getErrorMsg=True)
- if not returncode == 0:
- self._giface.WriteError(_('Failed to run d.to.rast:\n') + messages)
- return
- # set region for composite
- grass.use_temp_region()
- returncode, messages = RunCommand('g.region', raster=tmpName + '.red',
- quiet=True, getErrorMsg=True)
- grass.del_temp_region()
- return
- # composite
- 'r.composite', red=tmpName + '.red', green=tmpName + '.green',
- blue=tmpName + '.blue', output=outputRaster, quiet=True,
- RunCommand(
- 'g.remove',
- type='raster',
- flags='f',
- quiet=True,
- name=[
- tmpName +
- '.red',
- tmpName +
- '.green',
- tmpName +
- '.blue'])
- grass.try_remove(pngFile)
- return
+ self.DOutFile(dOutFileCmd, callback=_DToRastDone)
- # alignExtent changes only region variable
- oldRegion = self.GetMap().GetCurrentRegion().copy()
- self.GetMap().AlignExtentFromDisplay()
- region = self.GetMap().GetCurrentRegion().copy()
- self.GetMap().region.update(oldRegion)
- RunCommand('r.region', map=outputRaster, n=region['n'], s=region['s'],
- e=region['e'], w=region['w'], quiet=True)
def DToRastOptData(self, dcmd, layer, params, propwin):
"""Dummy function which is called when d.to.rast is called
and returns parsed and validated command which is then passed
Modified: grass/branches/releasebranch_7_2/gui/wxpython/mapwin/buffered.py
--- grass/branches/releasebranch_7_2/gui/wxpython/mapwin/buffered.py 2016-10-29 22:01:52 UTC (rev 69754)
+++ grass/branches/releasebranch_7_2/gui/wxpython/mapwin/buffered.py 2016-10-29 22:19:12 UTC (rev 69755)
@@ -671,7 +671,7 @@
event.Skip()
- def SaveToFile(self, FileName, FileType, width, height):
+ def SaveToFile(self, FileName, FileType, width, height, callback=None):
"""This draws the pseudo DC to a buffer that can be saved to
a file.
@@ -689,18 +689,22 @@
self._fileName = FileName
self._fileType = FileType
+ self._saveToFileCallback = callback
self._busy = wx.BusyInfo(message=_("Please wait, exporting image..."),
parent=self)
wx.Yield()
self.Map.ChangeMapSize((width, height))
- self.Map.Render(force=True, windres=self._properties.resolution)
renderMgr = self.Map.GetRenderMgr()
+ # this seems wrong, rendering should have callback
+ # when callback present, rendering does not emit signal
+ # just calls callback
renderMgr.renderDone.disconnect(self._updateMFinished)
renderMgr.renderDone.connect(self._saveToFileDone)
+ self.Map.Render(force=True, windres=self._properties.resolution)
- def _saveToFileDone(self):
+ def _saveToFileDone(self, callback=None):
renderMgr.renderDone.disconnect(self._saveToFileDone)
@@ -756,6 +760,8 @@
self.UpdateMap(render=True)
self.Refresh()
+ if self._saveToFileCallback:
+ self._saveToFileCallback()
def GetOverlay(self):
"""Converts rendered overlay files to wx.Image
