[GRASS-SVN] r69335 - grass-addons/grass7/misc/m.printws
svn_grass at osgeo.org
Thu Sep 1 07:34:14 PDT 2016
Author: kuszinger
Date: 2016-09-01 07:34:14 -0700 (Thu, 01 Sep 2016)
New Revision: 69335
grass-addons/grass7/misc/m.printws/m.printws.html
grass-addons/grass7/misc/m.printws/m.printws.py
macro syntax change, map features resize rules enhancements
Modified: grass-addons/grass7/misc/m.printws/m.printws.html
--- grass-addons/grass7/misc/m.printws/m.printws.html 2016-09-01 12:01:17 UTC (rev 69334)
+++ grass-addons/grass7/misc/m.printws/m.printws.html 2016-09-01 14:34:14 UTC (rev 69335)
@@ -82,7 +82,7 @@
</li>
<li>Reopen the d.legend.vect dialog.
</li>
-<li>On the In/Out tab cut hte text from the "Output csv file:" field and paste it to the "Input legend file:"
+<li>On the In/Out tab cut the text from the "Output csv file:" field and paste it to the "Input legend file:"
</li>
<li>Clik OK and check if you legend is still the same as you want it to be.
</li>
@@ -144,15 +144,24 @@
<h3>Title macros</h3>
There is a macro possibility for titles.
<ul>
- <li>%DISPLAY% - as it is in the <b>title</b> field by default - in any of the text fields the name
+ <li>$DISPLAY - as it is in the <b>title</b> field by default - in any of the text fields the name
of the corresponting display will be used for text.</li>
- <li>%USERNAME% - for user login name</li>
- <li>%TIME24% - 15:25:33</li>
- <li>%DATEYMD% - like 2016.08.02</li>
- <li>%DATEMDY% - like 08/02/2016</li>
- <li>%GXW% - name of the workspace file printed (full path)</li>
+ <li>$USERNAME - for user login name</li>
+ <li>$TIME24 - 15:25:33</li>
+ <li>$DATEYMD - 2016.08.02</li>
+ <li>$DATEMDY - 08/02/2016</li>
+ <li>$GXW - name of the workspace file printed (full path)</li>
</ul>
+Please take care of possible command line variable expansion rules of your
+own operating system or shell. For example on Linux or generally in Bash <b>$</b> sign
+is used for shell variables. So, when calling m.printws from command line take care
+to use single quotes around such parameter values like this to prevent substitution:
+<div class="code"><pre>
+... maintitle='$DISPLAY' ...
+</pre></div>
<h3>Fill your map display</h3>
By filling the map display of GRASS GIS positioning of map gadgets like legends,
scale and north arrow could be more consequent. A fully drawn map window is also a space saver
@@ -181,7 +190,7 @@
-# create a landscape 150dpi PDF copy of a workspace
+# create am A4 landscape 150dpi PDF copy of a workspace
m.printws input=/home/kuszi/grassdata/Duna/maps/VP/nice_vectors_workspace.gxw \
output=/home/kuszi/grassdata/Duna/maps/VP/sample_generated_printws maintitle=MAIN \
subtitle=sub psunderleft=left psunderright=right psundercentral=center \
Modified: grass-addons/grass7/misc/m.printws/m.printws.py
--- grass-addons/grass7/misc/m.printws/m.printws.py 2016-09-01 12:01:17 UTC (rev 69334)
+++ grass-addons/grass7/misc/m.printws/m.printws.py 2016-09-01 14:34:14 UTC (rev 69335)
@@ -64,7 +64,6 @@
#%option
#% key: maintitle
#% type: string
-#% answer: %DISPLAY%
#% description: Main title of map sheet
#% guisection: Titles
#%end
@@ -198,20 +197,30 @@
REMOVE_TMPDIR = True
PROXIES = {}
+# UPSIZE is better global as it is universal at a moment
+# an we save a lot of parameter passing when parsing xml
+global UPSIZE
+UPSIZE = 1.0
# set upsize "constants"
UPSD = {}
ALLTASKDIC = {}
ALLTASKDIC['width'] = 1.0 # 1 by 1 correction if any
-ALLTASKDIC['fontsize'] = 1.0 # 1 by 1 correction if any
UPSD['*'] = ALLTASKDIC
DVECTDIC = {}
-DVECTDIC['size'] = 1.0 # 1 by 1 correction if any
+DVECTDIC['size'] = 1.0 # symbol size
+DVECTDIC['label_size'] = 1.5 # label size
UPSD['d.vect'] = DVECTDIC
+DGRIDDIC = {}
+DGRIDDIC['size'] = 0.0 # force not touching grid line distance
+DGRIDDIC['fontsize'] = 1.0 # 1 by 1 correction if any
+UPSD['d.grid'] = DGRIDDIC
# PAGE dictionary
PAGEDIC = {}
@@ -240,15 +249,19 @@
+# test
+# m.printws.py --overwrite input=/home/kuszi/grassdata/workspaces_7/EURASEAA.gxw dpi=100 output=/home/kuszi/grassdata/mapdefs/euraseeaa.bmp page=A4portrait maintitle=$DISPLAY pagemargin=0
def upsizeifnecessary(task, lastparam, value, upsize):
val = UPSD.get('*').get(lastparam, 0.0)
+ print task + " " + lastparam + " " + str(value) + " " + str(upsize)
if val > 0:
- return str(float(value) * val * upsize)
+ print "## " + task + " " + lastparam + " " + str(value) + " " + str(upsize) + " > " + str(float(value) * val * upsize)
+ return str(float(value) * val * UPSIZE)
val = UPSD.get(task, {}).get(lastparam, 0.0)
if val > 0:
return value
@@ -267,22 +280,22 @@
params = task.getElementsByTagName("parameter")
paramdic['task'] = command
for p in params:
- paramdic[p.getAttribute('name')] = p.getElementsByTagName("value")[0].childNodes[0].data
+ paramdic[p.getAttribute('name')] = upsizeifnecessary(paramdic['task'],p.getAttribute('name'),p.getElementsByTagName("value")[0].childNodes[0].data,UPSIZE)
flags = task.getElementsByTagName("flag")
for f in flags:
- if (f.getAttribute('name') <> 'verbose') and (f.getAttribute('name') <> 'overwrite'):
+ if (f.getAttribute('name') <> 'verbose') and (f.getAttribute('name') <> 'overwrite') and (f.getAttribute('name') <> 'quiet'):
flagdic [f.getAttribute('name')] = f.getAttribute('name')
def processoverlay(dom,flagdic,paramdic):
params = dom.getElementsByTagName("parameter")
for p in params:
flags = dom.getElementsByTagName("flag")
for f in flags:
@@ -311,7 +324,7 @@
l.append((opacity, paramdic['task'] , paramdic, flagdic))
-def readworkspace(wspname, upsize):
+def readworkspace(wspname):
# READS WORKSPACE FILE
displaydic = {} # adding support for more displays
grass.verbose(_("Layers: "))
@@ -530,6 +543,7 @@
def decodetextmacros(text, dic):
+ # Yes, indeed, macros ARE case sensitive !!!
result = text
for key in dic:
result = re.sub(key, dic[key], result)
@@ -549,11 +563,21 @@
global GISDBASE, LAYERCOUNT, LASTFILE
textmacros = {}
+ # %nam% macros are kept for backward compatibility
textmacros['%TIME24%'] = time.strftime("%H:%M:%S")
textmacros['%DATEYMD%'] = time.strftime("%Y.%m.%d")
textmacros['%DATEMDY%'] = time.strftime("%m/%d/%Y")
textmacros['%USERNAME%'] = pwd.getpwuid(os.getuid())[0]
+ # using $ for macros in the future. New items should be created
+ # exclusively as $macros later on
+ textmacros['\$TIME24'] = textmacros['%TIME24%']
+ textmacros['\$DATEYMD'] = textmacros['%DATEYMD%']
+ textmacros['\$DATEMDY'] = textmacros['%DATEMDY%']
+ textmacros['\$USERNAME'] = textmacros['%USERNAME%']
+ textmacros['\$SPC'] = u'\u00A0' #?? d.text won't display at string end hmmm
# saves region for restoring at end
savedregionname = "tmp.%s.%d" % (
os.path.basename(sys.argv[0]), os.getpid())
@@ -571,14 +595,16 @@
else:
screendpioption = 100.0
- upsize = dpioption / screendpioption
+ global UPSIZE
+ UPSIZE = float(dpioption) / float(screendpioption)
if len(options['input']) > 0:
- displays = readworkspace(options['input'], upsize)
+ displays = readworkspace(options['input'])
else:
quit()
textmacros['%GXW%'] = options['input']
+ textmacros['\$GXW'] = textmacros['%GXW%']
displaycounter = 0
@@ -586,6 +612,7 @@
# each display is a whole and independent file assembly
for key in displays:
textmacros['%DISPLAY%'] = key
+ textmacros['\$DISPLAY'] = key
grass.verbose(_('printws: rendering display: ' + key))
displaycounter = displaycounter + 1
layers = copy.deepcopy(displays[key])
@@ -627,7 +654,7 @@
pageoption = 'A4landscape'
# parsing titles, etc.
- if len(options['titlefont']) > 1:
+ if len(options['titlefont']) > 0:
isAsterisk = options['titlefont'].find('*')
if isAsterisk > 0:
titlefont = getfontbypattern(
@@ -638,7 +665,7 @@
titlefont = getfontbypattern('Open') # try to find something UTF-8
grass.verbose(_("printws: titlefont: " + titlefont))
- if len(options['titlecolor']) > 1:
+ if len(options['titlecolor']) > 0:
titlecolor = options['titlecolor']
else:
titlecolor = black
@@ -749,18 +776,21 @@
mapsizesindots = dictodots(mapsizes, dpioption)
# changing region resolution to match print resolution
- # to eliminate unnecessary CPU/data transfer (make it faster
- # with invisible detail loss only). Does only downscale.
+ # to eliminate unnecessary CPU heating/data transfer
+ # so as to make it faster
+ # with only invisible detail loss.
colsregiontomap = mapsizesindots['w'] / regioncols
rowsregiontomap = mapsizesindots['h'] / regionrows
newewres = ewres
newnsres = nsres
- if colsregiontomap < 1:
- newewres = ewres / colsregiontomap
- if rowsregiontomap < 1:
- newnsres = nsres / rowsregiontomap
+ # if colsregiontomap < 1:
+ # CHANGE: also enables raising of resolution to prevent
+ # pixelation because of low resolution setting...
+ newewres = ewres / colsregiontomap
+ # if rowsregiontomap < 1:
+ newnsres = nsres / rowsregiontomap
grass.run_command("g.region", ewres=str(newewres), nsres=str(newnsres))
