[GRASS-SVN] r69340 - grass-addons/grass7/vector/v.in.pygbif
svn_grass at osgeo.org
Thu Sep 1 13:57:13 PDT 2016
Author: sbl
Date: 2016-09-01 13:57:13 -0700 (Thu, 01 Sep 2016)
New Revision: 69340
grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
v.in.pygbif: some more fixes
Modified: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
--- grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py 2016-09-01 20:51:00 UTC (rev 69339)
+++ grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py 2016-09-01 20:57:13 UTC (rev 69340)
@@ -30,13 +30,13 @@
#%option G_OPT_V_OUTPUT
#% key: output
-#% description: Name of resulting vector map with species occurrences
+#% description: Name of resulting vector map with occurrences
#% required : yes
#%end
#%option
-#% key: species
-#% description: Comma separated list of species names or keys to fetch data for
+#% key: taxa
+#% description: Comma separated list of taxon names or keys to fetch data for
#% required : yes
#%end
@@ -72,24 +72,24 @@
#%flag
#% key: p
-#% description: Print result from matching species names and exit
+#% description: Print result from matching taxa names and exit
#% suppress_required: yes
#%end
#%flag
#% key: i
-#% description: Produce individual map for each species
+#% description: Produce individual map for each taxon
#%end
#%flag
#% key: g
-#% description: Print result from matching species names in shell script style and exit
+#% description: Print result from matching taxon names in shell script style and exit
#%end
#%flag
#% key: o
-#% description: Print number of matching occurrences per species and exit
+#% description: Print number of matching occurrences per taxon and exit
#%end
@@ -194,7 +194,7 @@
print_occ_number = flags['o']
allow_no_geom = flags['n']
hasGeoIssue = flags['s']
- splist = options['species'].split(',')
+ taxa_list = options['taxa'].split(',')
institutionCode = options['institutioncode']
basisofrecord = options['basisofrecord']
recordedby = options['recordedby'].split(',')
@@ -208,7 +208,8 @@
# Number of occurrences to fetch in one request
chunk_size = 300
# lat/lon proj string
- latlon = '+proj=longlat +no_defs +a=6378137 +rf=298.257223563 +towgs84=0.000,0.000,0.000'
+ latlon_crs = ['+proj=longlat +no_defs +a=6378137 +rf=298.257223563 +towgs84=0.000,0.000,0.000',
+ '+proj=longlat +no_defs +a=6378137 +rf=298.257223563 +towgs84=0,0,0,0,0,0,0']
# List attributes available in Darwin Core
# not all attributes are returned in each request
# to avoid key errors when accessing the dictionary returned by pygbif
@@ -350,7 +351,7 @@
# Set reprojection parameters
# Set target projection of current LOCATION
- target_crs = grass.read_command('g.proj', flags='fj').rstrip('\n')
+ target_crs = grass.read_command('g.proj', flags='fj').rstrip(os.linesep)
target = osr.SpatialReference(target_crs)
target.ImportFromProj4(target_crs)
if target == 'XY location (unprojected)':
@@ -359,7 +360,7 @@
# Set source projection from GBIF
source = osr.SpatialReference()
source.ImportFromEPSG(4326)
- if target_crs != source:
+ if target_crs not in latlon_crs:
transform = osr.CoordinateTransformation(source, target)
reverse_transform = osr.CoordinateTransformation(target, source)
@@ -386,10 +387,10 @@
else:
# Do not limit import spatially if LOCATION is able to take global data
if no_region_limit:
- if target_crs != latlon:
- grass.fatal('Import of data outside the current region is'
- 'only supported in an WGS84 location!')
- pol = None
+ grass.fatal('Import of data from outside the current region is'
+ 'only supported in a WGS84 location!')
+ region_pol = None
else:
# Limit import spatially to current region
# if LOCATION is !NOT! able to take global data
@@ -399,7 +400,7 @@
region['n'], region['w'], region['s'])
# Do not reproject in latlon LOCATIONS
pol = ogr.CreateGeometryFromWkt(region_pol)
pol.Transform(reverse_transform)
pol = pol.ExportToWkt()
@@ -414,7 +415,7 @@
cat = 1
# Import data for each species
- for s in splist:
+ for s in taxa_list:
# Get the taxon key if not the taxon key is provided as input
try:
key = int(s)
@@ -440,8 +441,12 @@
print 'No alternatives found for the given taxon'
continue
if print_species_shell:
- for m in species_match['alternatives']:
- print m['scientificName'] + ' ' + m['status']
+ print 'match={}'.format(species_match['scientificName'])
+ if 'alternatives' in species_match.keys():
+ alternatives = []
+ for m in species_match['alternatives']:
+ alternatives.append(m['scientificName'])
+ print 'alternatives={}'.format(','.join(alternatives))
continue
try:
returns_n = occurrences.search(taxonKey=key,
@@ -468,7 +473,7 @@
grass.warning('No occurrences for current search for taxon {0}...'.format(s))
continue
elif returns_n >= 200000:
- grass.warning('Your search returns {0} records.\n'
+ grass.warning('Your search for {1} returns {0} records.\n'
'Unfortunately, the GBIF search API is limited to 200,000 records per request.\n'
'The download will be incomplete. Please consider to split up your search.'.format(returns_n, s))
@@ -508,14 +513,14 @@
# Write the returned data to map and attribute table
for res in returns['results']:
- if source != target:
point = ogr.CreateGeometryFromWkt('POINT ({} {})'.format(res['decimalLongitude'], res['decimalLatitude']))
point.Transform(transform)
x = point.GetX()
y = point.GetY()
else:
x = res['decimalLatitude']
- x = res['decimalLongitude']
+ y = res['decimalLongitude']
point = Point(x, y)
