[GRASS-SVN] r69398 - in grass/branches/releasebranch_7_2: gui/wxpython/core gui/wxpython/lmgr gui/wxpython/xml scripts
svn_grass at osgeo.org
Wed Sep 7 12:50:52 PDT 2016
Author: martinl
Date: 2016-09-07 12:50:52 -0700 (Wed, 07 Sep 2016)
New Revision: 69398
Removed:
grass/branches/releasebranch_7_2/scripts/v.krige/
grass/branches/releasebranch_7_2/gui/wxpython/core/gconsole.py
grass/branches/releasebranch_7_2/gui/wxpython/lmgr/frame.py
grass/branches/releasebranch_7_2/gui/wxpython/xml/toolboxes.xml
grass/branches/releasebranch_7_2/gui/wxpython/xml/wxgui_items.xml
grass/branches/releasebranch_7_2/scripts/Makefile
v.krige removed from core distribution (see #3136 for details)
Modified: grass/branches/releasebranch_7_2/gui/wxpython/core/gconsole.py
--- grass/branches/releasebranch_7_2/gui/wxpython/core/gconsole.py 2016-09-07 19:43:51 UTC (rev 69397)
+++ grass/branches/releasebranch_7_2/gui/wxpython/core/gconsole.py 2016-09-07 19:50:52 UTC (rev 69398)
@@ -534,8 +534,7 @@
# no arguments given
if hasParams and \
- not isinstance(self._guiparent, FormNotebook) and \
- command[0] != 'v.krige':
+ not isinstance(self._guiparent, FormNotebook):
# also parent must be checked, see #3135 for details
try:
GUI(parent=self._guiparent,
Modified: grass/branches/releasebranch_7_2/gui/wxpython/lmgr/frame.py
--- grass/branches/releasebranch_7_2/gui/wxpython/lmgr/frame.py 2016-09-07 19:43:51 UTC (rev 69397)
+++ grass/branches/releasebranch_7_2/gui/wxpython/lmgr/frame.py 2016-09-07 19:50:52 UTC (rev 69398)
@@ -861,7 +861,7 @@
# check list of dummy commands for GUI modules that do not have GRASS
# bin modules or scripts.
- if cmd in ['vcolors', 'r.mapcalc', 'r3.mapcalc', 'v.krige']:
+ if cmd in ['vcolors', 'r.mapcalc', 'r3.mapcalc']:
return cmdlist
try:
Modified: grass/branches/releasebranch_7_2/gui/wxpython/xml/toolboxes.xml
--- grass/branches/releasebranch_7_2/gui/wxpython/xml/toolboxes.xml 2016-09-07 19:43:51 UTC (rev 69397)
+++ grass/branches/releasebranch_7_2/gui/wxpython/xml/toolboxes.xml 2016-09-07 19:50:52 UTC (rev 69398)
@@ -1039,8 +1039,6 @@
<label>Raster series interpolation</label>
</module-item>
<separator/>
- <wxgui-item name="OrdinaryOrBlockKriging"/>
- <separator/>
<module-item name="r.fillnulls">
<label>Fill NULL cells</label>
</module-item>
Modified: grass/branches/releasebranch_7_2/gui/wxpython/xml/wxgui_items.xml
--- grass/branches/releasebranch_7_2/gui/wxpython/xml/wxgui_items.xml 2016-09-07 19:43:51 UTC (rev 69397)
+++ grass/branches/releasebranch_7_2/gui/wxpython/xml/wxgui_items.xml 2016-09-07 19:50:52 UTC (rev 69398)
@@ -334,12 +334,6 @@
<description>Configuration editor for r.li.'index'</description>
<keywords>raster,landscape structure analysis</keywords>
</wxgui-item>
- <wxgui-item name="OrdinaryOrBlockKriging">
- <label>Ordinary or block kriging</label>
- <command>v.krige</command>
- <description>Performs ordinary or block kriging.</description>
- <keywords>vector,raster,interpolation,kriging</keywords>
- </wxgui-item>
<wxgui-item name="CreateNewVectorMap">
<label>Create new vector map</label>
<handler>OnNewVector</handler>
Modified: grass/branches/releasebranch_7_2/scripts/Makefile
--- grass/branches/releasebranch_7_2/scripts/Makefile 2016-09-07 19:43:51 UTC (rev 69397)
+++ grass/branches/releasebranch_7_2/scripts/Makefile 2016-09-07 19:50:52 UTC (rev 69398)
@@ -75,8 +75,7 @@
v.unpack \
v.what.strds \
v.what.vect \
- wxpyimgview \
- v.krige
+ wxpyimgview
include $(MODULE_TOPDIR)/include/Make/Dir.make
