[GRASS-SVN] r69414 - grass/trunk/vector/v.net.visibility
    svn_grass at osgeo.org
    Thu Sep  8 19:35:18 PDT 2016
Author: wenzeslaus
Date: 2016-09-08 19:35:18 -0700 (Thu, 08 Sep 2016)
New Revision: 69414
   grass/trunk/vector/v.net.visibility/v.net.visibility.html
v.net.visibility: change name in example to one likely intended, add paragraph for img
Modified: grass/trunk/vector/v.net.visibility/v.net.visibility.html
--- grass/trunk/vector/v.net.visibility/v.net.visibility.html	2016-09-09 02:30:11 UTC (rev 69413)
+++ grass/trunk/vector/v.net.visibility/v.net.visibility.html	2016-09-09 02:35:18 UTC (rev 69414)
@@ -101,8 +101,8 @@
 g.region vector=zipcodes_wake
 d.mon wx0
 d.vect areas_7_11_25
-v.net.visibility input=zipcodes_wake output=graph
-v.net.visibility input=zipcodes_wake visibility=graph output=new_graph \
+v.net.visibility input=areas_7_11_25 output=graph
+v.net.visibility input=areas_7_11_25 visibility=graph output=new_graph \
       coordinates=669547.97,208348.20
 d.erase
@@ -129,6 +129,7 @@
 <p>
 <img src="v_net_visibility.png">
+<p>
 Load data using here document syntax (Bash and unix-like commands lines only):
 <div class="code"><pre>
