[GRASS-SVN] r69428 - sandbox/alexandris/i.rgb.hsl
svn_grass at osgeo.org
Sat Sep 10 11:50:46 PDT 2016
Author: nikosa
Date: 2016-09-10 11:50:46 -0700 (Sat, 10 Sep 2016)
New Revision: 69428
sandbox/alexandris/i.rgb.hsl/close_files.c
sandbox/alexandris/i.rgb.hsl/globals.h
sandbox/alexandris/i.rgb.hsl/main.c
sandbox/alexandris/i.rgb.hsl/open_files.c
sandbox/alexandris/i.rgb.hsl/rgb_to_hsl.c
various minor changes, unsigned for the columns variable
Modified: sandbox/alexandris/i.rgb.hsl/close_files.c
--- sandbox/alexandris/i.rgb.hsl/close_files.c 2016-09-10 16:31:19 UTC (rev 69427)
+++ sandbox/alexandris/i.rgb.hsl/close_files.c 2016-09-10 18:50:46 UTC (rev 69428)
@@ -8,7 +8,7 @@
int close_files(char *hue, char *saturation, char *lightness,
- int fd_output[3], DCELL * output_rowbuffer[3])
+ int fd_output[3], DCELL *output_rowbuffer[3])
int row;
struct Colors colors;
@@ -31,7 +31,6 @@
Rast_get_fp_range_min_max(&range, &min, &max);
Rast_make_grey_scale_fp_colors(&colors, min, max);
Rast_write_colors(hue, mapset, &colors);
- G_debug(1, "Wrote color table for %s", hue);
Rast_read_fp_range(lightness, mapset, &range);
Modified: sandbox/alexandris/i.rgb.hsl/globals.h
--- sandbox/alexandris/i.rgb.hsl/globals.h 2016-09-10 16:31:19 UTC (rev 69427)
+++ sandbox/alexandris/i.rgb.hsl/globals.h 2016-09-10 18:50:46 UTC (rev 69428)
@@ -3,23 +3,23 @@
#include <grass/raster.h>
- * open_files.c
+ * open_files.c
* red, green, blue
* hue, saturation, lightness,
* input file descriptors, output file descriptors
* input rowbuffer
void open_files(char *, char *, char *,
- char *, char *, char *,
- int[3], int[3],
- DCELL *[3]);
+ char *, char *, char *,
+ int[3], int[3],
+ DCELL *[3]);
* rgb_to_hsl.c
* input rowbuffer, columns, maximum range value
-void rgb_to_hsl(DCELL *[3], int, double);
+void rgb_to_hsl(DCELL *[3], unsigned int, double);
* close_files.c
@@ -28,7 +28,7 @@
* output rowbuffers
int close_files(char *, char *, char *,
- int[3],
- DCELL *[3]);
+ int[3],
+ DCELL *[3]);
#endif /* __GLOBALS_H__ */
Modified: sandbox/alexandris/i.rgb.hsl/main.c
--- sandbox/alexandris/i.rgb.hsl/main.c 2016-09-10 16:31:19 UTC (rev 69427)
+++ sandbox/alexandris/i.rgb.hsl/main.c 2016-09-10 18:50:46 UTC (rev 69428)
@@ -4,7 +4,6 @@
* MODULE: i.rgb.hsl
* AUTHOR(S): Nikos Alexandris
- * submitted in GRASS-GIS' trac ticket #774
* PURPOSE: Color space conversion, RGB to HSL
@@ -32,8 +31,8 @@
int main(int argc, char **argv)
- long row; /* long is 32-/64-bit, ~4 billion/~18 qunitillion */
- int band, rows, cols; /* input band counter, number of rows, columns */
+ long row; // long is 32-/64-bit, ~4 billion/~18 qunitillion
+ int band, rows, cols; // input band counter, number of rows, columns
DCELL *rowbuffer[3];
struct Option *opt_red;
struct Option *opt_green;
@@ -42,14 +41,13 @@
struct Option *opt_saturation;
struct Option *opt_lightness;
struct Option *opt_bits;
- struct GModule *module;
- int fd_input[3]; /* input file descriptors */
- int fd_output[3]; /* output file descriptors */
- int bits; /* bitness of input raster maps */
- double max_colors; /* maximum level based on input bitness */
+ struct GModule *module; // GRASS module for parsing arguments
+ int fd_input[3]; // input file descriptors
+ int fd_output[3]; // output file descriptors
+ int bits; // bitness of input raster maps
+ double max_colors; // maximum level based on input bitness
- /* Initialize GIS engine */
- G_gisinit(argv[0]);
+ G_gisinit(argv[0]); // initialize GIS engine
/* Set description */
module = G_define_module();
@@ -59,7 +57,7 @@
G_add_keyword("red");
G_add_keyword("green");
G_add_keyword("blue");
- G_add_keyword("HSL"); /* Lightness, Luminosity or Luminance */
+ G_add_keyword("HSL"); // Lightness, Luminosity or Luminance
G_add_keyword("hue");
G_add_keyword("saturation");
G_add_keyword("lightness");
@@ -103,7 +101,6 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
/* bit depth, should be > 0 */
bits = atoi(opt_bits->answer);
if (bits <= 0)
@@ -113,15 +110,14 @@
max_colors = pow(2, bits) - 1.0;
G_debug(1, "%d-bit data ranging in [0,%.0f)", bits, max_colors);
/* get image dimensions */
rows = Rast_window_rows();
cols = Rast_window_cols();
/* open files */
open_files(opt_red->answer, opt_green->answer, opt_blue->answer,
- opt_hue->answer, opt_saturation->answer, opt_lightness->answer,
- fd_input, fd_output, rowbuffer);
+ opt_hue->answer, opt_saturation->answer, opt_lightness->answer,
+ fd_input, fd_output, rowbuffer);
/* read in maps per row*/
for (row = 0; row < rows; row++) {
@@ -144,7 +140,7 @@
/* close files */
close_files(opt_hue->answer, opt_saturation->answer, opt_lightness->answer,
- fd_output, rowbuffer);
+ fd_output, rowbuffer);
exit(EXIT_SUCCESS);
Modified: sandbox/alexandris/i.rgb.hsl/open_files.c
--- sandbox/alexandris/i.rgb.hsl/open_files.c 2016-09-10 16:31:19 UTC (rev 69427)
+++ sandbox/alexandris/i.rgb.hsl/open_files.c 2016-09-10 18:50:46 UTC (rev 69428)
@@ -12,17 +12,11 @@
void open_files(char *red, char *green, char *blue,
- char *hue, char *saturation, char *lightness,
- int fd_input[3], int fd_output[3],
- DCELL *rowbuffer[3])
+ char *hue, char *saturation, char *lightness,
+ int fd_input[3], int fd_output[3],
+ DCELL *rowbuffer[3])
- /* declarations */
- /* const char *mapset; /1* mapset name *1/ */
- /* RASTER_MAP_TYPE red_data_type; */
- /* RASTER_MAP_TYPE green_data_type; */
- /* RASTER_MAP_TYPE blue_data_type; */
/* open input files */
fd_input[0] = Rast_open_old(red, "");
fd_input[1] = Rast_open_old(green, "");
@@ -38,27 +32,4 @@
rowbuffer[1] = Rast_allocate_d_buf();
rowbuffer[2] = Rast_allocate_d_buf();
- /* how to dynamically set the map type? */
- * To Do: replicate an `any` function?
- /* get mapset (NULL if map not found in any mapset) */
- /* mapset = (char *) G_find_raster2(red, ""); */
- /* if (mapset == NULL) */
- /* G_fatal_error(_("Raster map <%s> not found"), red); */
- /* G_debug(1, "Working in current Mapset which is: %s", mapset); */
- /* determine input raster map type */
- /* red_data_type = Rast_map_type(red, mapset); */
- /* G_debug(1, "Red input raster map is of type: %RASTER_MAP_TYPE", red_data_type); */
- /* repeat for green and blue ------------------------------------------ */
- /* allocate the cell row buffer */
- /* rowbuffer[0] = Rast_allocate_buf(red_data_type); */
- /* rowbuffer[1] = Rast_allocate_buf(green_data_type); */
- /* rowbuffer[2] = Rast_allocate_buf(blue_data_type); */
Modified: sandbox/alexandris/i.rgb.hsl/rgb_to_hsl.c
--- sandbox/alexandris/i.rgb.hsl/rgb_to_hsl.c 2016-09-10 16:31:19 UTC (rev 69427)
+++ sandbox/alexandris/i.rgb.hsl/rgb_to_hsl.c 2016-09-10 18:50:46 UTC (rev 69428)
@@ -14,19 +14,19 @@
* maximum level of range 2^bit_depth
-void rgb_to_hsl(DCELL *rowbuffer[3], int columns, double max_level)
+void rgb_to_hsl(DCELL *rowbuffer[3], unsigned int columns, double max_level)
- int column; /* column indicator */
- double red; /* the red band output */
- double green; /* the green band output */
- double blue; /* the blue band output */
- double min; /* minimum among red, green, blue */
- double max; /* maximum among red, green, blue */
- float chroma; /* chrome, intermediate value */
- float lightness; /* lightness */
- float saturation; /* saturation */
- float hue = 0.0L; /* hue */
+ unsigned int column;// column indicator
+ double red; // red input image
+ double green; // green input image
+ double blue; // blue input image
+ double min; // minimum among red, green, blue
+ double max; // maximum among red, green, blue
+ float chroma; // chrome, intermediate value
+ float lightness; // lightness
+ float saturation; // saturation
+ float hue = 0.0L; // hue
for (column = 0; column < columns; column++) {
@@ -78,16 +78,18 @@
/* if R == G == B, then min == max, which is achromatic */
if (chroma == 0.0) {
saturation = 0.0;
- /* undefined hue, set to -1. */
+ /* undefined hue, set to -1.0 */
hue = -1.0;
/* else chromatic */
else if (chroma != 0.0) {
saturation = chroma / (1.0 - fabs(2.0 * lightness - 1.0));
@@ -102,9 +104,11 @@
hue = ((red - green) / chroma) + 4.0;
/* convert hue to degrees */
hue *= 60.0;
/* make nonnegative */
if (hue < 0.0)
hue += 360.0;
@@ -115,7 +119,7 @@
/* HSL output values */
- /* set hue = -1 to NULL */
+ /* set hue = -1.0 to NULL */
if (hue == -1.0)
Rast_set_d_null_value(&rowbuffer[0][column], 1);
