[GRASS-SVN] r69452 - in sandbox/alexandris: . i.hsl.rgb i.rgb.his i.rgb.hsl
svn_grass at osgeo.org
Mon Sep 12 02:30:44 PDT 2016
Author: nikosa
Date: 2016-09-12 02:30:44 -0700 (Mon, 12 Sep 2016)
New Revision: 69452
Added:
sandbox/alexandris/i.rgb.his/
sandbox/alexandris/i.rgb.his/Makefile
sandbox/alexandris/i.rgb.his/closefiles.c
sandbox/alexandris/i.rgb.his/globals.h
sandbox/alexandris/i.rgb.his/i.rgb.his.html
sandbox/alexandris/i.rgb.his/main.c
sandbox/alexandris/i.rgb.his/openfiles.c
sandbox/alexandris/i.rgb.his/rgb2his.c
sandbox/alexandris/i.hsl.rgb/close_files.c
sandbox/alexandris/i.hsl.rgb/globals.h
sandbox/alexandris/i.hsl.rgb/hsl_to_rgb.c
sandbox/alexandris/i.hsl.rgb/i.hsl.rgb.html
sandbox/alexandris/i.hsl.rgb/i.hsl.rgb.md
sandbox/alexandris/i.hsl.rgb/main.c
sandbox/alexandris/i.hsl.rgb/open_files.c
sandbox/alexandris/i.rgb.hsl/rgb_to_hsl.c
i.rgb.his (sandbox): support for user defined bits per image
Modified: sandbox/alexandris/i.hsl.rgb/close_files.c
--- sandbox/alexandris/i.hsl.rgb/close_files.c 2016-09-12 03:06:33 UTC (rev 69451)
+++ sandbox/alexandris/i.hsl.rgb/close_files.c 2016-09-12 09:30:44 UTC (rev 69452)
@@ -7,14 +7,14 @@
use a less than perfect way of setting the color maps for the output
to grey scale. */
* free allocated memory (row buffers),
* close raster maps
* set color table for output maps to grey scale.
int close_files(char *red, char *green, char *blue,
- int fd_output[3], DCELL * rowbuffer[3])
+ int fd_output[3], DCELL * rowbuffer[3])
int row;
struct Colors colors;
@@ -25,8 +25,8 @@
/* free allocated memory, close raster maps */
for (row = 0; row < 3; row++) {
- G_free(rowbuffer[row]);
- Rast_close(fd_output[row]);
+ G_free(rowbuffer[row]);
+ Rast_close(fd_output[row]);
mapset = G_mapset();
Modified: sandbox/alexandris/i.hsl.rgb/globals.h
--- sandbox/alexandris/i.hsl.rgb/globals.h 2016-09-12 03:06:33 UTC (rev 69451)
+++ sandbox/alexandris/i.hsl.rgb/globals.h 2016-09-12 09:30:44 UTC (rev 69452)
@@ -11,21 +11,26 @@
* DCELL * rowbuf[3]
void open_files(char *, char *, char *,
- char *, char *, char *,
- int[3], int[3],
- DCELL *[3]);
+ char *, char *, char *,
+ int[3], int[3],
+ DCELL *[3]);
-/* hsl_to_rgb.c */
-void hsl_to_rgb(DCELL *[3], int, double);
+ * hsl_to_rgb.c
+ * rowbuffer
+ * columns
+ * maximum number of colors
+void hsl_to_rgb(DCELL *[3], unsigned int, unsigned int);
* close_files.c
* close raster maps
int close_files(char *, char *, char *,
- int[3],
- DCELL *[3]);
+ int[3],
+ DCELL *[3]);
#endif /* __GLOBALS_H__ */
Modified: sandbox/alexandris/i.hsl.rgb/hsl_to_rgb.c
--- sandbox/alexandris/i.hsl.rgb/hsl_to_rgb.c 2016-09-12 03:06:33 UTC (rev 69451)
+++ sandbox/alexandris/i.hsl.rgb/hsl_to_rgb.c 2016-09-12 09:30:44 UTC (rev 69452)
@@ -1,26 +1,26 @@
* PURPOSE Convert hue, saturation and lightness properties of the HSL
- * color space model to red, green and blue of the RGB color space
- * model
+ * color space model to red, green and blue of the RGB color space
+ * model
#include <grass/gis.h>
#include "globals.h"
#include <math.h>
-void hsl_to_rgb(DCELL *rowbuffer[3], int columns, double max_colors)
+void hsl_to_rgb(DCELL *rowbuffer[3], unsigned int columns, unsigned int max_colors)
- long column; /* column indicator */
- double red; /* the red band output */
- double green; /* the green band output */
- double blue; /* the blue band output */
- double chroma; /* value used for determining RGB */
- double intermediate;/* value used for determining RGB */
- double baseline_rgb;/* value used for determining RGB */
- double lightness; /* lightness value */
- double saturation; /* saturation value */
- double hue; /* hue */
- double hue60; /* hue */
+ unsigned long column; // column indicator
+ double red; // the red band output
+ double green; // the green band output
+ double blue; // the blue band output
+ double chroma; // value used for determining RGB
+ double intermediate; // value used for determining RGB
+ double baseline_rgb; // value used for determining RGB
+ double lightness; // lightness value
+ double saturation; // saturation value
+ double hue; // hue
+ double hue60; // hue
/* loop over columns and appropriately set NULLs */
for (column = 0; column < columns; column++) {
@@ -38,7 +38,8 @@
hue = rowbuffer[0][column];
saturation = rowbuffer[1][column];
lightness = rowbuffer[2][column];
- G_debug(2, "Input Hue, Saturation, Lightness: %f, %f, %f", hue, saturation, lightness);
+ G_debug(2, "Input Hue, Saturation, Lightness: %f, %f, %f",
+ hue, saturation, lightness);
/* chroma, hue/60, intermediate `x`, baseline RGB */
chroma = (1.0 - fabs(2.0*lightness - 1.0)) * saturation;
@@ -95,7 +96,7 @@
red = green = blue = 0.0;
- /* add baseline RGB value*/
+ /* add baseline RGB value */
red += baseline_rgb;
green += baseline_rgb;
blue += baseline_rgb;
@@ -105,7 +106,8 @@
red *= max_colors;
green *= max_colors;
blue *= max_colors;
- G_debug(2, "Red, Green, Blue [scaled up to]: %f, %f, %f, [%.0f]", red, green, blue, max_colors);
+ G_debug(2, "Red, Green, Blue [scaled up to]: %f, %f, %f, [%.d]",
+ red, green, blue, max_colors);
/* place output row into corresponding buffer */
rowbuffer[0][column] = (DCELL) red;
Modified: sandbox/alexandris/i.hsl.rgb/i.hsl.rgb.html
--- sandbox/alexandris/i.hsl.rgb/i.hsl.rgb.html 2016-09-12 03:06:33 UTC (rev 69451)
+++ sandbox/alexandris/i.hsl.rgb/i.hsl.rgb.html 2016-09-12 09:30:44 UTC (rev 69452)
@@ -1,12 +1,13 @@
<h2 id="description">DESCRIPTION</h2>
<p><em>i.hsl.rgb</em> converts hue, saturation and lightness input images, being dimensions of the HSL color space, into red, green and blue values in the RGB color space. Each output image is given a linear gray scale color table. The current geographic region and mask settings are respected.</p>
+<h2 id="examples">EXAMPLES</h2>
+<p>Read examples in the manual of <a href="i.rgb.hsl.html">i.rgb.hsl</a></p>
<h2 id="notes">NOTES</h2>
<ul>
-<li><p>The <em>bits</em> option refers to the bit (or color) depth of the input images, as in bits per color channel. Not to be confused with bits-per-pixel, which refers to the sum of all three color channels. For example, an 8-bit image feaures 256 number of colors. Expecting all input images to be of the same color depth, in example 8 bits, then, an RGB composite would feature 24 bits per pixel.</p></li>
+<li><p>The <em>bits</em> option refers to the bit (or color) depth of the input images, as in <em>bits per color channel</em>. Not to confuse with <em>bits-per-pixel</em>, which refers to the sum of all three color channels. For example, an 8-bit image feaures 256 number of colors. Expecting all input images to be of the same color depth, in this case 8 bits, then, an RGB composite would feature 24 bits per pixel.</p></li>
<li><p>It is possible to process three images with <em>i.hsl.rgb</em> and then recover the original images with <em>i.rgb.hsl</em>.</p></li>
</ul>
<h2 id="see-also">SEE ALSO</h2>
-<p><em><a href="i.rgb.his.html">i.rgb.his</a>, <a href="i.his.rgb.html">i.rgb.his</a>, <a href="r.colors.html">r.colors</a></em></p>
+<p><em><a href="i.rgb.hsl.html">i.rgb.hsl</a>, <a href="i.rgb.his.html">i.rgb.his</a>, <a href="i.his.rgb.html">i.rgb.his</a>, <a href="r.colors.html">r.colors</a></em></p>
<h2 id="author">AUTHOR</h2>
<p>Nikos Alexandris</p>
-<p><em>Last changed: $Date: 2016-09-09 13:10:00 +0100 (Fri, 9 Sep 2016) $</em></p>
Modified: sandbox/alexandris/i.hsl.rgb/i.hsl.rgb.md
--- sandbox/alexandris/i.hsl.rgb/i.hsl.rgb.md 2016-09-12 03:06:33 UTC (rev 69451)
+++ sandbox/alexandris/i.hsl.rgb/i.hsl.rgb.md 2016-09-12 09:30:44 UTC (rev 69452)
@@ -7,14 +7,19 @@
respected.
+EXAMPLES
+Read examples in the manual of [i.rgb.hsl](i.rgb.hsl.html)
NOTES
-- The *bits* option refers to the bit (or color) depth of the input
-images, as in bits per color channel. Not to be confused with bits-per-pixel,
+- The <em>bits</em> option refers to the bit (or color) depth of the input
+images, as in *bits per color channel*. Not to confuse with *bits-per-pixel*,
-same color depth, in example 8 bits, then, an RGB composite would feature 24
+same color depth, in this case 8 bits, then, an RGB composite would feature 24
bits per pixel.
- It is possible to process three images with *i.hsl.rgb* and then recover
@@ -30,5 +35,3 @@
Nikos Alexandris
-*Last changed: \$Date: 2016-09-09 13:10:00 +0100 (Fri, 9 Sep 2016) \$*
Modified: sandbox/alexandris/i.hsl.rgb/main.c
--- sandbox/alexandris/i.hsl.rgb/main.c 2016-09-12 03:06:33 UTC (rev 69451)
+++ sandbox/alexandris/i.hsl.rgb/main.c 2016-09-12 09:30:44 UTC (rev 69452)
@@ -33,8 +33,8 @@
int main(int argc, char **argv)
- long row;
- int rows, cols;
+ unsigned long row;
+ unsigned int rows, cols;
DCELL *rowbuffer[3];
struct Option *opt_hue;
struct Option *opt_saturation;
@@ -42,12 +42,12 @@
struct Option *opt_red;
struct Option *opt_green;
struct Option *opt_blue;
- struct Option *opt_bits; /* bits per input image, as in bits per channel */
+ struct Option *opt_bits; // bits per input image, as in bits per channel
struct GModule *module;
int fd_input[3];
int fd_output[3];
- int bits;
- double max_colors; /* maximum number of colors */
+ unsigned int bits;
+ unsigned int max_colors; // maximum number of colors
G_gisinit(argv[0]);
@@ -106,8 +106,8 @@
G_fatal_error(_("Invalid bit depth definition!"));
/* open half ended range for maximum number of colors */
- max_colors = pow(2, bits) - 1.0;
- G_debug(1, "%d-bit data ranging in [0,%.0f)", bits, max_colors);
+ max_colors = pow(2, bits) - 1;
+ G_debug(1, "%d-bit data ranging in [0,%.0d)", bits, max_colors);
/* get image dimensions */
rows = Rast_window_rows();
@@ -115,24 +115,23 @@
/* open input and output files */
open_files(opt_hue->answer, opt_saturation->answer, opt_lightness->answer,
- opt_red->answer, opt_green->answer, opt_blue->answer,
- fd_input, fd_output, rowbuffer);
+ opt_red->answer, opt_green->answer, opt_blue->answer,
+ fd_input, fd_output, rowbuffer);
/* loop over hue, saturation and lightness color space properties */
for (row = 0; row < rows; row++) {
- int property;
+ int property;
/* read in row from each cell map */
for (property = 0; property < 3; property++)
- Rast_get_d_row(fd_input[property], rowbuffer[property], row);
+ Rast_get_d_row(fd_input[property], rowbuffer[property], row);
/* process row of image */
hsl_to_rgb(rowbuffer, cols, max_colors);
/* write out the new row for each cell map */
- Rast_put_row(fd_output[property], rowbuffer[property], DCELL_TYPE);
+ Rast_put_row(fd_output[property], rowbuffer[property], DCELL_TYPE);
/* progress */
@@ -140,7 +139,7 @@
/* close output files */
close_files(opt_red->answer, opt_green->answer, opt_blue->answer,
- fd_output, rowbuffer);
+ fd_output, rowbuffer);
exit(EXIT_SUCCESS);
Modified: sandbox/alexandris/i.hsl.rgb/open_files.c
--- sandbox/alexandris/i.hsl.rgb/open_files.c 2016-09-12 03:06:33 UTC (rev 69451)
+++ sandbox/alexandris/i.hsl.rgb/open_files.c 2016-09-12 09:30:44 UTC (rev 69452)
@@ -11,10 +11,10 @@
* (input/output?) rowbuffers
-void open_files(char *hue, char *saturation, char *lightness,
- char *red, char *green, char *blue,
- int fd_input[3], int fd_output[3],
- DCELL * rowbuffer[3])
+void open_files(char *hue, char *saturation, char *lightness,
+ char *red, char *green, char *blue,
+ int fd_input[3], int fd_output[3],
+ DCELL * rowbuffer[3])
/* open output files */
fd_output[0] = Rast_open_fp_new(red);
Added: sandbox/alexandris/i.rgb.his/Makefile
--- sandbox/alexandris/i.rgb.his/Makefile (rev 0)
+++ sandbox/alexandris/i.rgb.his/Makefile 2016-09-12 09:30:44 UTC (rev 69452)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = i.rgb.his
+LIBES = $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: sandbox/alexandris/i.rgb.his/closefiles.c
--- sandbox/alexandris/i.rgb.his/closefiles.c (rev 0)
+++ sandbox/alexandris/i.rgb.his/closefiles.c 2016-09-12 09:30:44 UTC (rev 69452)
@@ -0,0 +1,60 @@
+#include <stdlib.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include "globals.h"
+/* This routine closes up the cell maps, frees up the row buffers and
+ uses a less than perfect way of setting the color maps for the output
+ to grey scale. */
+int closefiles(char *hue, char *intensity, char *saturation,
+ unsigned int property; // color properties: hue, intensity, saturation
+ struct Colors colors;
+ struct FPRange range;
+ struct History history;
+ DCELL min, max;
+ const char *mapset;
+ for (property = 0; property < 3; property++) {
+ Rast_close(fd_output[property]);
+ G_free(rowbuffer[property]);
+ mapset = G_mapset();
+ /* write colors */
+ Rast_read_fp_range(hue, mapset, &range);
+ Rast_get_fp_range_min_max(&range, &min, &max);
+ Rast_make_grey_scale_colors(&colors, min, max); // set to [0,max] instead ?
+ Rast_write_colors(hue, mapset, &colors);
+ Rast_read_fp_range(intensity, mapset, &range);
+ Rast_write_colors(intensity, mapset, &colors);
+ Rast_read_fp_range(saturation, mapset, &range);
+ Rast_write_colors(saturation, mapset, &colors);
+ /* write metadata */
+ Rast_short_history(hue, "raster", &history);
+ Rast_command_history(&history);
+ Rast_write_history(hue, &history);
+ Rast_put_cell_title(hue, "Image hue");
+ Rast_short_history(intensity, "raster", &history);
+ Rast_write_history(intensity, &history);
+ Rast_put_cell_title(intensity, "Image intensity");
+ Rast_short_history(saturation, "raster", &history);
+ Rast_write_history(saturation, &history);
+ Rast_put_cell_title(saturation, "Image saturation");
+ return 0;
Added: sandbox/alexandris/i.rgb.his/globals.h
--- sandbox/alexandris/i.rgb.his/globals.h (rev 0)
+++ sandbox/alexandris/i.rgb.his/globals.h 2016-09-12 09:30:44 UTC (rev 69452)
@@ -0,0 +1,16 @@
+#ifndef __GLOBALS_H__
+#define __GLOBALS_H__
+/* closefiles.c */
+int closefiles(char *, char *, char *, int[3], DCELL *[3]);
+/* openfiles.c */
+void openfiles(char *, char *, char *, char *, char *, char *, int[3], int[3],
+ DCELL *[3]);
+/* rgb2his.c */
+void rgb2his(DCELL *[3], unsigned int, double);
+#endif /* __GLOBALS_H__ */
Added: sandbox/alexandris/i.rgb.his/i.rgb.his.html
--- sandbox/alexandris/i.rgb.his/i.rgb.his.html (rev 0)
+++ sandbox/alexandris/i.rgb.his/i.rgb.his.html 2016-09-12 09:30:44 UTC (rev 69452)
@@ -0,0 +1,31 @@
+<h2>DESCRIPTION</h2>
+<em>i.rgb.his</em> is an image processing program that
+processes three input images as red, green, and
+blue components and produces three output images
+representing the hue, intensity, and saturation color properties.
+The output images base upon a standard red-green-blue (rgb) to
+hue-intensity-saturation (his) color space transformation. Hue ranges in degrees [0,
+360] while intensity and saturation range in [0, 1].
+<h2>NOTES</h2>
+The module supports various bits per image (as in bits per color channel, bitness ranging in [2,16]).
+Each output raster map layer is given a linear gray scale color table. The current geographic region definition and mask settings are
+respected.
+<h2>SEE ALSO</h2>
+<em><a href="i.his.rgb.html">i.his.rgb</a></em>
+<h2>AUTHOR</h2>
+David Satnik, GIS Laboratory,
+Central Washington University,
+<br>
+with acknowledgements to Ali Vali, Space Research
+Center, for the core routine.
+<p><i>Last changed: $Date: 2011-11-08 23:24:20 +0200 (Tue, 08 Nov 2011) $</i>
Added: sandbox/alexandris/i.rgb.his/main.c
--- sandbox/alexandris/i.rgb.his/main.c (rev 0)
+++ sandbox/alexandris/i.rgb.his/main.c 2016-09-12 09:30:44 UTC (rev 69452)
@@ -0,0 +1,142 @@
+ * MODULE: i.rgb.his
+ * AUTHOR(S): David Satnik, GIS Laboratory, Central Washington University
+ * Nikos Alexandris, support various bit depths
+ * with acknowledgements to Ali Vali,
+ * Univ. of Texas Space Research Center, for the core routine.
+ * PURPOSE: Red-green-blue (rgb) to hue-intensity-saturation (his)
+ * raster map color transformation function
+ * COPYRIGHT: (C) 2007-2016 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+#include <stdio.h>
+#include <string.h>
+#include <math.h>
+#include <grass/glocale.h>
+int main(int argc, char **argv)
+ unsigned int band;
+ unsigned int rows;
+ unsigned int cols;
+ DCELL *rowbuffer[3];
+ struct Option *opt_red;
+ struct Option *opt_green;
+ struct Option *opt_blue;
+ struct Option *opt_hue;
+ struct Option *opt_intensity;
+ struct Option *opt_saturation;
+ struct GModule *module;
+ int fd_input[3];
+ int fd_output[3];
+ int bits; // bitness of input raster maps
+ double max_colors; // maximum level based on input bitness
+ G_gisinit(argv[0]); // initialize GIS engine
+ /* Set description */
+ module = G_define_module();
+ G_add_keyword(_("imagery"));
+ G_add_keyword(_("color transformation"));
+ G_add_keyword("RGB");
+ G_add_keyword("HIS");
+ G_add_keyword("IHS");
+ module->description =
+ _("Transforms raster maps from RGB (Red-Green-Blue) color space to "
+ "HIS (Hue-Intensity-Saturation) color space.");
+ /* Define the different options */
+ opt_red = G_define_standard_option(G_OPT_R_INPUT);
+ opt_red->key = "red";
+ opt_red->description = _("Name of input raster map (red)");
+ opt_green = G_define_standard_option(G_OPT_R_INPUT);
+ opt_green->key = "green";
+ opt_green->description = _("Name of input raster map (green)");
+ opt_blue = G_define_standard_option(G_OPT_R_INPUT);
+ opt_blue->key = "blue";
+ opt_blue->description = _("Name of input raster map (blue)");
+ opt_hue = G_define_standard_option(G_OPT_R_OUTPUT);
+ opt_hue->key = "hue";
+ opt_hue->description = _("Name for output raster map (hue)");
+ opt_intensity = G_define_standard_option(G_OPT_R_OUTPUT);
+ opt_intensity->key = "intensity";
+ opt_intensity->description = _("Name for output raster map (intensity)");
+ opt_saturation = G_define_standard_option(G_OPT_R_OUTPUT);
+ opt_saturation->key = "saturation";
+ opt_saturation->description = _("Name for output raster map (saturation)");
+ opt_bits = G_define_option();
+ opt_bits->key = "bits";
+ opt_bits->type = TYPE_INTEGER;
+ opt_bits->required = NO;
+ opt_bits->answer = "8";
+ opt_bits->options = "2-16";
+ opt_bits->description = _("Bits per input image");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ /* bit depth, should be > 0 */
+ bits = atoi(opt_bits->answer);
+ if (bits <= 0)
+ G_fatal_error(_("Invalid bit depth definition!"));
+ /* open half ended range for maximum level */
+ max_colors = pow(2, bits) - 1.0;
+ G_debug(1, "%d-bit data ranging in [0,%.0f)", bits, max_colors);
+ /* get dimension of the image */
+ rows = Rast_window_rows();
+ cols = Rast_window_cols();
+ openfiles(opt_red->answer, opt_green->answer, opt_blue->answer,
+ opt_hue->answer, opt_intensity->answer, opt_saturation->answer,
+ for (row = 0; row < rows; row++) {
+ /* read in a row from each cell map */
+ G_percent(row, rows, 2);
+ for (band = 0; band < 3; band++)
+ Rast_get_d_row(fd_input[band], rowbuffer[band], row);
+ /* process this row of the map */
+ rgb2his(rowbuffer, cols, max_colors);
+ /* write out the new row for each cell map */
+ Rast_put_row(fd_output[band], rowbuffer[band], DCELL_TYPE);
+ /* progress */
+ /* close output files */
+ closefiles(opt_hue->answer, opt_intensity->answer, opt_saturation->answer,
+ exit(EXIT_SUCCESS);
Added: sandbox/alexandris/i.rgb.his/openfiles.c
--- sandbox/alexandris/i.rgb.his/openfiles.c (rev 0)
+++ sandbox/alexandris/i.rgb.his/openfiles.c 2016-09-12 09:30:44 UTC (rev 69452)
@@ -0,0 +1,26 @@
+#include <stdio.h>
+void openfiles(char *red, char *green, char *blue,
+ char *hue, char *intensity, char *saturation,
+ DCELL *rowbuffer[3])
+ /* input file descriptors */
+ fd_input[0] = Rast_open_old(red, "");
+ fd_input[1] = Rast_open_old(green, "");
+ fd_input[2] = Rast_open_old(blue, "");
+ /* open output files */
+ fd_output[0] = Rast_open_fp_new(hue);
+ fd_output[1] = Rast_open_fp_new(intensity);
+ fd_output[2] = Rast_open_fp_new(saturation);
+ /* allocate the cell row buffer */
+ rowbuffer[0] = Rast_allocate_d_buf();
+ rowbuffer[1] = Rast_allocate_d_buf();
+ rowbuffer[2] = Rast_allocate_d_buf();
Added: sandbox/alexandris/i.rgb.his/rgb2his.c
--- sandbox/alexandris/i.rgb.his/rgb2his.c (rev 0)
+++ sandbox/alexandris/i.rgb.his/rgb2his.c 2016-09-12 09:30:44 UTC (rev 69452)
@@ -0,0 +1,170 @@
+NAME: RGB2HIS
+PURPOSE To process red,green,blue bands to hue,intensity,saturation.
+ALGORITHM:
+ Get red, green, blue from input buffer
+ Create the HIS bands
+ Write to output buffer
+ASSUMPTION:
+ The input images are read to the input buffer.
+NOTE: For GRASS one row from each cell map is passed in and each cell in
+ each band is processed and written out. CWU GIS Lab: DBS 8/90
+void rgb2his(DCELL * rowbuffer[3], unsigned int columns, double max_colors)
+ int column; // column counter
+ double scaled_red; // red input band, to be scaled to [0,1]
+ double scaled_green; // green input band, likewise
+ double scaled_blue; // blue input output, likewise
+ double red; // red value used for computing hue
+ double green; // green value, likewise
+ double blue; // blue value, likewise
+ double min; // minimum among red, green, blue
+ double max; // maximum among red, green, blue
+ double chroma; // maximum - minimum
+ double hue = 0.0L;
+ double intensity;
+ for (column = 0; column < columns; column++) {
+ if (Rast_is_d_null_value(&rowbuffer[0][column]) ||
+ Rast_is_d_null_value(&rowbuffer[1][column]) ||
+ Rast_is_d_null_value(&rowbuffer[2][column]))
+ Rast_set_d_null_value(&rowbuffer[0][column], 1);
+ Rast_set_d_null_value(&rowbuffer[1][column], 1);
+ Rast_set_d_null_value(&rowbuffer[2][column], 1);
+ continue;
+ /* scale red, green, blue to [0.0,1.0] */
+ scaled_red = rowbuffer[0][column];
+ scaled_red /= max_colors;
+ scaled_green = rowbuffer[1][column];
+ scaled_green /= max_colors;
+ scaled_blue = rowbuffer[2][column];
+ scaled_blue /= max_colors;
+ /* max of {r,g,b} */
+ max = scaled_red;
+ if (scaled_green > max)
+ max = scaled_green;
+ if (scaled_blue > max)
+ max = scaled_blue;
+ /* min of {r,g,b} */
+ min = scaled_red;
+ if (scaled_green < min)
+ min = scaled_green;
+ if (scaled_blue < min)
+ min = scaled_blue;
+ /* chroma and intensity */
+ chroma = max - min;
+ intensity = ((max + min) / 2.0);
+ /* if R == G == B, then min == max, which is achromatic */
+ if (chroma == 0.0)
+ saturation = 0.0;
+ hue = -1.0; // undefined hue, set to -1.0
+ /* else chromatic */
+ else if (chroma != 0.0) {
+ if (intensity <= 0.5)
+ saturation = chroma / (max + min);
+ G_debug(2, "Saturation (for I <= 0.5): %f", saturation);
+ else if (intensity > 0.5)
+ saturation = chroma / (2 - max - min);
+ G_debug(2, "Saturation (for I > 0.5): %f", saturation);
+ /* set red, green, blue for computing hue */
+ red = (max - scaled_red) / chroma;
+ green = (max - scaled_green) / chroma;
+ blue = (max - scaled_blue) / chroma;
+ /* resulting color between yelmin and magenta */
+ if (scaled_red == max)
+ hue = blue - green;
+ G_debug(2, "Hue (blue - green): %f", hue);
+ /* resulting color between cyan and yelmin */
+ else if (scaled_green == max)
+ hue = 2 + red - blue;
+ G_debug(2, "Hue (red - blue): %f", hue);
+ /* resulting color between magenta and cyan */
+ else if (scaled_blue == max)
+ hue = 4 + green - red;
+ G_debug(2, "Hue (green - red): %f", hue);
+ /* convert to degrees */
+ hue *= 60.0;
+ /* make nonnegative */
+ if (hue < 0.0)
+ hue += 360.0;
+ G_debug(2, "Minimum and Maximum levels among r, g, b: [%f, %f]", min, max);
+ G_debug(2, "HIS: %f, %f, %f", hue, intensity, saturation);
+ /* HIS output values */
+ /* set hue = -1.0 to NULL */
+ if (hue == -1.0)
+ else
+ rowbuffer[0][column] = (FCELL)hue;
+ rowbuffer[1][column] = (FCELL)intensity;
+ rowbuffer[2][column] = (FCELL)saturation;
+ /* for debugging purposes */
+ G_debug(3, "Output rowbuffers 0, 1, 2: %f, %f, %f\n",
+ rowbuffer[0][column], rowbuffer[1][column], rowbuffer[2][column]);
Modified: sandbox/alexandris/i.rgb.hsl/rgb_to_hsl.c
--- sandbox/alexandris/i.rgb.hsl/rgb_to_hsl.c 2016-09-12 03:06:33 UTC (rev 69451)
+++ sandbox/alexandris/i.rgb.hsl/rgb_to_hsl.c 2016-09-12 09:30:44 UTC (rev 69452)
@@ -26,6 +26,7 @@
float chroma; // chrome, intermediate value
float lightness; // lightness
float saturation; // saturation
+ int negative_value; // flag to warn if out of range value detected
float hue = 0.0L; // hue
@@ -130,10 +131,15 @@
/* set saturation, lightness */
+ if (saturation < 0)
+ negative_value = 1;
rowbuffer[1][column] = (FCELL)saturation;
rowbuffer[2][column] = (FCELL)lightness;
+// move this to main, emmit only once!
+if (negative_value == 1)
+ G_warning("Detected a negative Saturation value. Is the bits setting correct?");
