[GRASS-SVN] r69457 - in sandbox/alexandris: . i.his.rgb i.rgb.his
Mon Sep 12 06:19:02 PDT 2016
Author: nikosa
Date: 2016-09-12 06:19:02 -0700 (Mon, 12 Sep 2016)
New Revision: 69457
Added:
   sandbox/alexandris/i.his.rgb/
   sandbox/alexandris/i.his.rgb/Makefile
   sandbox/alexandris/i.his.rgb/closefiles.c
   sandbox/alexandris/i.his.rgb/globals.h
   sandbox/alexandris/i.his.rgb/his2rgb.c
   sandbox/alexandris/i.his.rgb/i.his.rgb.html
   sandbox/alexandris/i.his.rgb/main.c
   sandbox/alexandris/i.his.rgb/openfiles.c
   sandbox/alexandris/i.rgb.his/closefiles.c
   sandbox/alexandris/i.rgb.his/globals.h
   sandbox/alexandris/i.rgb.his/i.rgb.his.html
   sandbox/alexandris/i.rgb.his/rgb2his.c
i.his.rgb (sandbox): added support for user defined bits per image, plus clean, comment, format for i.rgb.his
Added: sandbox/alexandris/i.his.rgb/Makefile
--- sandbox/alexandris/i.his.rgb/Makefile	                        (rev 0)
+++ sandbox/alexandris/i.his.rgb/Makefile	2016-09-12 13:19:02 UTC (rev 69457)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = i.his.rgb
+LIBES = $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: sandbox/alexandris/i.his.rgb/closefiles.c
--- sandbox/alexandris/i.his.rgb/closefiles.c	                        (rev 0)
+++ sandbox/alexandris/i.his.rgb/closefiles.c	2016-09-12 13:19:02 UTC (rev 69457)
@@ -0,0 +1,63 @@
+#include <stdlib.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include "globals.h"
+/* This routine closes up the cell maps, frees up the row buffers and
+   use a less than perfect way of setting the color maps for the output
+   to grey scale.  */
+int closefiles(char *red, char *green, char *blue,
+               int fd_output[3],
+               DCELL * rowbuf[3])
+    unsigned int color;
+    struct Colors colors;
+    struct FPRange range;
+    struct History history;
+    DCELL min, max;     // set to [0, max_colors] instead of [min, max] ?
+    const char *mapset;
+    for (color = 0; color < 3; color++)
+        Rast_close(fd_output[color]);
+        G_free(rowbuf[color]);
+    mapset = G_mapset();
+    /* write colors */
+    Rast_read_fp_range(red, mapset, &range);
+    Rast_get_fp_range_min_max(&range, &min, &max);
+    Rast_make_grey_scale_colors(&colors, min, max);
+    Rast_write_colors(red, mapset, &colors);
+    Rast_read_fp_range(green, mapset, &range);
+    Rast_write_colors(green, mapset, &colors);
+    Rast_read_fp_range(blue, mapset, &range);
+    Rast_write_colors(blue, mapset, &colors);
+    /* write metadata */
+    Rast_short_history(red, "raster", &history);
+    Rast_command_history(&history);
+    Rast_write_history(red, &history);
+    Rast_put_cell_title(red, "Image red");
+    Rast_short_history(green, "raster", &history);
+    Rast_write_history(green, &history);
+    Rast_put_cell_title(green, "Image green");
+    Rast_short_history(blue, "raster", &history);
+    Rast_write_history(blue, &history);
+    Rast_put_cell_title(blue, "Image blue");
+    return 0;
Added: sandbox/alexandris/i.his.rgb/globals.h
--- sandbox/alexandris/i.his.rgb/globals.h	                        (rev 0)
+++ sandbox/alexandris/i.his.rgb/globals.h	2016-09-12 13:19:02 UTC (rev 69457)
@@ -0,0 +1,32 @@
+#ifndef __GLOBALS_H__
+#define __GLOBALS_H__
+ * openfiles.c
+ * hue, saturation, intensity,
+ * red, green, blue,
+ * int fd_input[3], int fd_output[3],
+ * DCELL * rowbuf[3]
+void openfiles(char *, char *, char *, char *, char *, char *, int[3], int[3],
+        DCELL *[3]);
+ * his2rgb.c
+ * rowbuffer
+ * columns
+ * maximum number of colors
+void his2rgb(DCELL *[3], unsigned int, unsigned int);
+ * closefiles.c
+ * output file descriptors
+ * output rowbuffers
+int closefiles(char *, char *, char *, int[3], DCELL *[3]);
+#endif /* __GLOBALS_H__ */
Added: sandbox/alexandris/i.his.rgb/his2rgb.c
--- sandbox/alexandris/i.his.rgb/his2rgb.c	                        (rev 0)
+++ sandbox/alexandris/i.his.rgb/his2rgb.c	2016-09-12 13:19:02 UTC (rev 69457)
@@ -0,0 +1,165 @@
+NAME:       HIS to RGB
+PURPOSE:    To proces hue, intensity, saturation bands to red, green, blue.
+ALGORITHM:  Get hue, intensity, saturation from input buffer
+            Create the RGB bands
+            Write to output buffer
+ASSUMPTION: The input images are read to the input buffer.
+NOTE:       For GRASS one row from each cell map is passed in and each cell in
+            each band is processed and written out.   CWU GIS Lab: DBS 8/90
+void his2rgb(DCELL *rowbuffer[3], unsigned int columns, unsigned int max_colors)
+    long column;        // column indicator
+    double red;         // red output image
+    double green;       // green output image
+    double blue;        // blue output image
+    double scaled_red;  // ranging in [0,1], used to compute hue
+    double scaled_green;// likewise
+    double scaled_blue; // likewise
+    double m1;          // value used to determine RGB
+    double m2;          // value used to determine RGB
+    double scaled_intensity;    // input image ranging in [0,1]
+    double scaled_saturation;   // input image ranging in [0,1]
+    double hue;         // input image ranging in [0, 360]
+    double savehue;     // save the hue for future processing
+    /* loop over columns and appropriately set NULLs */
+    for (column = 0; column < columns; column++)
+        if (Rast_is_d_null_value(&rowbuffer[0][column]) ||
+                Rast_is_d_null_value(&rowbuffer[1][column]) ||
+                Rast_is_d_null_value(&rowbuffer[2][column]))
+            Rast_set_d_null_value(&rowbuffer[0][column], 1);
+            Rast_set_d_null_value(&rowbuffer[1][column], 1);
+            Rast_set_d_null_value(&rowbuffer[2][column], 1);
+            continue;
+        /* initialize zero red, green, blue */
+        red = green = blue = 0.0;
+        /* input intensity (from i.rgb.his) ranges in [0,1] */
+        scaled_intensity = rowbuffer[1][column];
+        /* input saturation (from i.rgb.his) ranges in [0,1] */
+        scaled_saturation = rowbuffer[2][column];
+        m2 = 0.0;
+        if (scaled_intensity <= 0.50)
+            m2 = scaled_intensity * (1.0 + scaled_saturation);
+        else if (scaled_intensity > 0.50)
+            m2 = scaled_intensity + scaled_saturation - (scaled_intensity * scaled_saturation);
+        m1 = 2.0 * scaled_intensity - m2;
+        /* input hue (from i.rgb.his) ranges in [0, 360] */
+        hue = rowbuffer[0][column];
+        if (scaled_saturation == 0.0) {
+            if (hue == -1.0) {
+                red = scaled_intensity;
+                green = scaled_intensity;
+                blue = scaled_intensity;
+        else {
+            /* calculate the red band */
+            savehue = hue + 120.0;
+            if (savehue > 360.0)
+                savehue -= 360.0;
+            if (savehue < 0.0)
+                savehue += 360.0;
+            if (savehue < 60.0)
+                red = m1 + (m2 - m1) * savehue / 60.0;
+            else if (savehue < 180.0)
+                red = m2;
+            else if (savehue < 240.0)
+                red = m1 + (m2 - m1) * (240.0 - savehue) / 60.0;
+            else
+                red = m1;
+            /* calculate the green band */
+            savehue = hue;
+                savehue -= 360.0;
+                savehue += 360.0;
+                green = m1 + (m2 - m1) * savehue / 60.0;
+                green = m2;
+                green = m1 + (m2 - m1) * (240.0 - savehue) / 60.0;
+            else
+                green = m1;
+            /* calculate the blue band */
+            savehue = hue - 120.0;
+                savehue -= 360.0;
+                savehue += 360.0;
+                blue = m1 + (m2 - m1) * savehue / 60.0;
+                blue = m2;
+                blue = m1 + (m2 - m1) * (240.0 - savehue) / 60.0;
+            else
+                blue = m1;
+        scaled_red = red * max_colors;
+        scaled_green = green * max_colors;
+        scaled_blue = blue * max_colors;
+        if (scaled_red > max_colors)
+            red = max_colors;
+        else
+            red = scaled_red;
+        if (scaled_green > max_colors)
+            green = max_colors;
+        else
+            green = scaled_green;
+        if (scaled_blue > max_colors)
+            blue = max_colors;
+        else
+            blue = scaled_blue;
+        if (red < 0.0)
+            red = 0.0;
+        if (green < 0.0)
+            green = 0.0;
+        if (blue < 0.0)
+            blue = 0.0;
+        G_debug(2, "Red, Green, Blue [scaled up to]: %f, %f, %f, [%.d]",
+                red, green, blue, max_colors);
+        /* write value into corresponding row, col */
+        rowbuffer[0][column] = red;
+        rowbuffer[1][column] = green;
+        rowbuffer[2][column] = blue;
Added: sandbox/alexandris/i.his.rgb/i.his.rgb.html
--- sandbox/alexandris/i.his.rgb/i.his.rgb.html	                        (rev 0)
+++ sandbox/alexandris/i.his.rgb/i.his.rgb.html	2016-09-12 13:19:02 UTC (rev 69457)
@@ -0,0 +1,28 @@
+<h2>DESCRIPTION</h2>
+<p><em>i.his.rgb</em> is an image processing program that processes three input
+images as hue, intensity and saturation components and produces three output
+images representing the red, green and blue colors.</p>
+<p>Hue values are expected to be degrees, ranging in [0, 360] while intensity and
+saturation should range within [0,1].
+The output images base upon a standard hue-intensity-saturation (his) to red-green-blue
+(rgb) color space transformation.</p>
+<p>Each output raster map layer is given a linear gray scale color table.  The
+current geographic region definition and mask settings are respected.</p>
+<h2>SEE ALSO</h2>
+<em>
+<a href="i.rgb.his.html">i.rgb.his</a>,
+<a href="r.colors.html">r.colors</a>
+</em>
+<h2>AUTHOR</h2>
+David Satnik, GIS Laboratory, Central Washington University
+<br>
+with acknowledgements to Ali Vali, Univ. of Texas, Space Research Center, for the core routine.
+Nikos Alexandris
Added: sandbox/alexandris/i.his.rgb/main.c
--- sandbox/alexandris/i.his.rgb/main.c	                        (rev 0)
+++ sandbox/alexandris/i.his.rgb/main.c	2016-09-12 13:19:02 UTC (rev 69457)
@@ -0,0 +1,137 @@
+ * MODULE:       i.his.rgb
+ * AUTHOR(S):    David Satnik, GIS Laboratory, Central Washington University
+ *               with acknowledgements to Ali Vali,
+ *               Univ. of Texas Space Research Center, for the core routine.
+ * PURPOSE:      Hue-intensity-saturation (his) to red-green-blue (rgb)
+ *               raster map color transformation function.
+ * COPYRIGHT:    (C) 2007-2008 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdio.h>
+#include <string.h>
+#include <math.h>
+#include <grass/glocale.h>
+int main(int argc, char **argv)
+    long i;
+    int rows, cols;
+    DCELL *rowbuffer[3];
+    struct Option *opt_hue;
+    struct Option *opt_int;
+    struct Option *opt_sat;
+    struct Option *opt_red;
+    struct Option *opt_green;
+    struct Option *opt_blue;
+    struct Option *opt_bits;    // bits per input image, as in bits per channel
+    struct GModule *module;
+    unsigned int bits;
+    unsigned int max_colors;          // maximum number of colors
+    int fd_output[3];
+    int fd_input[3];
+    G_gisinit(argv[0]);
+    /* Set description */
+    module = G_define_module();
+    G_add_keyword(_("imagery"));
+    G_add_keyword(_("color transformation"));
+    G_add_keyword("RGB");
+    G_add_keyword("HIS");
+    G_add_keyword("IHS");
+    module->description =
+        _("Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
+                "RGB (Red-Green-Blue) color space.");
+    /* Define the different options */
+    opt_hue = G_define_standard_option(G_OPT_R_INPUT);
+    opt_hue->key = "hue";
+    opt_hue->description = _("Name of input raster map (hue)");
+    opt_int = G_define_standard_option(G_OPT_R_INPUT);
+    opt_int->key = "intensity";
+    opt_int->description = _("Name of input raster map (intensity)");
+    opt_sat = G_define_standard_option(G_OPT_R_INPUT);
+    opt_sat->key = "saturation";
+    opt_sat->description = _("Name of input raster map (saturation)");
+    opt_red = G_define_standard_option(G_OPT_R_OUTPUT);
+    opt_red->key = "red";
+    opt_red->description = _("Name for output raster map (red)");
+    opt_green = G_define_standard_option(G_OPT_R_OUTPUT);
+    opt_green->key = "green";
+    opt_green->description = _("Name for output raster map (green)");
+    opt_blue = G_define_standard_option(G_OPT_R_OUTPUT);
+    opt_blue->key = "blue";
+    opt_blue->description = _("Name for output raster map (blue)");
+    opt_bits = G_define_option();
+    opt_bits->key = "bits";
+    opt_bits->type = TYPE_INTEGER;
+    opt_bits->required = NO;
+    opt_bits->answer = "8";
+    opt_bits->options = "2-16";
+    opt_bits->description = _("Bits per output image");
+    if (G_parser(argc, argv))
+        exit(EXIT_FAILURE);
+    /* bits per image, should be > 0 */
+    bits = atoi(opt_bits->answer);
+    if (bits <= 0)
+        G_fatal_error(_("Invalid bit depth definition!"));
+    /* open half ended range for maximum number of colors */
+    max_colors = pow(2, bits) - 1;
+    G_debug(1, "%d-bit data ranging in [0,%.0d)", bits, max_colors);
+    /* get dimension of the image */
+    rows = Rast_window_rows();
+    cols = Rast_window_cols();
+    openfiles(opt_hue->answer, opt_int->answer, opt_sat->answer,
+            opt_red->answer, opt_green->answer, opt_blue->answer,
+            fd_input, fd_output, rowbuffer);
+    for (i = 0; i < rows; i++) {
+        int band;
+        G_percent(i, rows, 2);
+        /* read in a row from each cell map */
+        for (band = 0; band < 3; band++)
+            Rast_get_d_row(fd_input[band], rowbuffer[band], i);
+        /* process this row of the map */
+        his2rgb(rowbuffer, cols, max_colors);
+        /* write out the new row for each cell map */
+            Rast_put_row(fd_output[band], rowbuffer[band], DCELL_TYPE);
+    G_percent(1, 1, 1);
+    closefiles(opt_red->answer, opt_green->answer, opt_blue->answer,
+            fd_output, rowbuffer);
+    exit(EXIT_SUCCESS);
Added: sandbox/alexandris/i.his.rgb/openfiles.c
--- sandbox/alexandris/i.his.rgb/openfiles.c	                        (rev 0)
+++ sandbox/alexandris/i.his.rgb/openfiles.c	2016-09-12 13:19:02 UTC (rev 69457)
@@ -0,0 +1,32 @@
+#include <stdio.h>
+void openfiles(char *hue, char *intensity, char *saturation,
+               char *red, char *green, char *blue,
+               int fd_input[3], int fd_output[3],
+    /* open output files */
+    fd_output[0] = Rast_open_fp_new(red);
+    fd_output[1] = Rast_open_fp_new(green);
+    fd_output[2] = Rast_open_fp_new(blue);
+    /* allocate the cell row buffer */
+    rowbuf[0] = Rast_allocate_d_buf();
+    rowbuf[1] = Rast_allocate_d_buf();
+    rowbuf[2] = Rast_allocate_d_buf();
+    /* open input files (maps can be in different mapsets) */
+    fd_input[0] = Rast_open_old(hue, "");
+    fd_input[1] = Rast_open_old(intensity, "");
+    fd_input[2] = Rast_open_old(saturation, "");
Modified: sandbox/alexandris/i.rgb.his/closefiles.c
--- sandbox/alexandris/i.rgb.his/closefiles.c	2016-09-12 13:15:45 UTC (rev 69456)
+++ sandbox/alexandris/i.rgb.his/closefiles.c	2016-09-12 13:19:02 UTC (rev 69457)
@@ -8,7 +8,9 @@
    to grey scale.  */
 int closefiles(char *hue, char *intensity, char *saturation,
-	       int fd_output[3], DCELL * rowbuffer[3])
+               int fd_output[3],
+               DCELL * rowbuffer[3])
     unsigned int property;  // color properties: hue, intensity, saturation
@@ -17,7 +19,8 @@
     DCELL min, max;
     const char *mapset;
-    for (property = 0; property < 3; property++) {
+    for (property = 0; property < 3; property++)
         Rast_close(fd_output[property]);
         G_free(rowbuffer[property]);
Modified: sandbox/alexandris/i.rgb.his/globals.h
--- sandbox/alexandris/i.rgb.his/globals.h	2016-09-12 13:15:45 UTC (rev 69456)
+++ sandbox/alexandris/i.rgb.his/globals.h	2016-09-12 13:19:02 UTC (rev 69457)
@@ -3,14 +3,28 @@
-/* closefiles.c */
-int closefiles(char *, char *, char *, int[3], DCELL *[3]);
-/* openfiles.c */
+ * openfiles.c
+ * input file descriptors, output file descriptors
+ * input rowbuffer
         DCELL *[3]);
-/* rgb2his.c */
+ * rgb2hsl.c
+ * input rowbuffer, columns, maximum range value
 void rgb2his(DCELL *[3], unsigned int, double);
+ * closefiles.c
Modified: sandbox/alexandris/i.rgb.his/i.rgb.his.html
--- sandbox/alexandris/i.rgb.his/i.rgb.his.html	2016-09-12 13:15:45 UTC (rev 69456)
+++ sandbox/alexandris/i.rgb.his/i.rgb.his.html	2016-09-12 13:19:02 UTC (rev 69457)
@@ -1,31 +1,35 @@
-<em>i.rgb.his</em> is an image processing program that
-processes three input images as red, green, and
-blue components and produces three output images
-representing the hue, intensity, and saturation color properties.
+<p><em>i.rgb.his</em> is an image processing program that processes three input
+images as red, green, and blue components and produces three output images
+representing the hue, intensity, and saturation color properties.</p>
-The output images base upon a standard red-green-blue (rgb) to
-hue-intensity-saturation (his) color space transformation.  Hue ranges in degrees [0,
-360] while intensity and saturation range in [0, 1].
+<p>The output images base upon a standard red-green-blue (rgb) to
+hue-intensity-saturation (his) color space transformation.  Hue ranges in
+degrees [0, 360] while intensity and saturation range in [0, 1].</p>
 <h2>NOTES</h2>
-The module supports various bits per image (as in bits per color channel, bitness ranging in [2,16]).
+<p>The module supports various bits per image (as in bits per color channel,
+bitness ranging in [2,16]).</p>
-Each output raster map layer is given a linear gray scale color table.  The current geographic region definition and mask settings are
-respected.
+<p>It is possible to process three bands with <em>i.rgb.his</em> and recover the
+original bands, nearly identical, with <em>i.his.rgb</em>.
+Due to rounding, minor loss of precision is expected. Cell values will be
+reproduced exactly after transformation in both directions, within plus or
+minus 1.</p>
 <h2>SEE ALSO</h2>
 <em><a href="i.his.rgb.html">i.his.rgb</a></em>
 <h2>AUTHOR</h2>
-David Satnik, GIS Laboratory,
-Central Washington University,
+David Satnik, GIS Laboratory,  Central Washington University,
 <br>
-with acknowledgements to Ali Vali, Space Research
-Center, for the core routine.
-<p><i>Last changed: $Date: 2011-11-08 23:24:20 +0200 (Tue, 08 Nov 2011) $</i>
+Nikos Alexandris, support for user defined bits per image
Modified: sandbox/alexandris/i.rgb.his/rgb2his.c
--- sandbox/alexandris/i.rgb.his/rgb2his.c	2016-09-12 13:15:45 UTC (rev 69456)
+++ sandbox/alexandris/i.rgb.his/rgb2his.c	2016-09-12 13:19:02 UTC (rev 69457)
@@ -1,17 +1,15 @@
-NAME:       RGB2HIS
+NAME:       RGB to HIS
-PURPOSE     To process red,green,blue bands to hue,intensity,saturation.
+PURPOSE     To process red, green, blue bands to hue, intensity, saturation.
-ALGORITHM:
-            Get red, green, blue from input buffer
+ALGORITHM:  Get red, green, blue from input buffer
             Create the HIS bands
-ASSUMPTION:
-            The input images are read to the input buffer.
