[GRASS-SVN] r69498 - grass/trunk/raster/r.in.gdal
svn_grass at osgeo.org
Thu Sep 15 06:17:49 PDT 2016
Author: neteler
Date: 2016-09-15 06:17:48 -0700 (Thu, 15 Sep 2016)
New Revision: 69498
grass/trunk/raster/r.in.gdal/r.in.gdal.html
r.in.gdal manual: (reduced) format table updated; typo fixed
Modified: grass/trunk/raster/r.in.gdal/r.in.gdal.html
--- grass/trunk/raster/r.in.gdal/r.in.gdal.html 2016-09-15 12:20:00 UTC (rev 69497)
+++ grass/trunk/raster/r.in.gdal/r.in.gdal.html 2016-09-15 13:17:48 UTC (rev 69498)
@@ -1,6 +1,6 @@
<h2>DESCRIPTION</h2>
-<em>r.in.gdal</em> allows a user to create a (binary) GRASS raster map layer,
+<em>r.in.gdal</em> allows a user to create a GRASS GIS raster map layer,
or imagery group, from any GDAL supported raster map format, with an optional
title. The imported file may also be optionally used to create a new location.
@@ -21,60 +21,108 @@
<p>
<a href="http://www.gdal.org/formats_list.html">http://www.gdal.org/formats_list.html</a>
<p>
-Selected formats of the more than 80 supported formats:
+Selected formats out of the more than 140 supported formats:
<div class="code"><pre>
-Long Format Name Code Creation Georeferencing Maximum File Size
-Arc/Info ASCII Grid AAIGrid Yes Yes No limits
-Arc/Info Binary Grid AIG No Yes --
-AIRSAR Polarimetric AIRSAR No No --
-Microsoft Windows Device Independent Bitmap (.bmp) BMP Yes Yes 4GiB
-BSB Nautical Chart Format (.kap) BSB No Yes --
-VTP Binary Terrain Format (.bt) BT Yes Yes --
-CEOS (Spot for instance) CEOS No No --
-First Generation USGS DOQ (.doq) DOQ1 No Yes --
-New Labelled USGS DOQ (.doq) DOQ2 No Yes --
-Data (.dt0, .dt1) DTED No Yes --
-ERMapper Compressed Wavelets (.ecw) ECW Yes Yes
-ESRI .hdr Labelled EHdr No Yes --
-ENVI .hdr Labelled Raster ENVI Yes Yes No limits
-Envisat Image Product (.n1) Envisat No No --
-EOSAT FAST Format FAST No Yes --
-FITS (.fits) FITS Yes No
-Graphics Interchange Format (.gif) GIF Yes No 2GB
-Arc/Info Binary Grid (.adf) GIO Yes Yes
-GRASS Rasters GRASS No Yes --
-TIFF / GeoTIFF (.tif) GTiff Yes Yes 4GiB
-Hierarchical Data Format Release 4 (HDF4) HDF4 Yes Yes 2GiB
-Erdas Imagine (.img) HFA Yes Yes No limits
-Atlantis MFF2e HKV Yes Yes No limits
-Image Display and Analysis (WinDisp) IDA Yes Yes 2GB
-ILWIS Raster Map (.mpr,.mpl) ILWIS Yes Yes --
-Japanese DEM (.mem) JDEM No Yes --
-JPEG JFIF (.jpg) JPEG Yes Yes 4GiB (max dimentions 65500x65500)
-JPEG2000 (.jp2, .j2k) JPEG2000 Yes Yes 2GiB
-JPEG2000 (.jp2, .j2k) JP2KAK Yes Yes No limits
-NOAA Polar Orbiter Level 1b Data Set (AVHRR) L1B No Yes --
-Erdas 7.x .LAN and .GIS LAN No Yes 2GB
-In Memory Raster MEM Yes Yes 2GiB
-Atlantis MFF MFF Yes Yes No limits
-Multi-resolution Seamless Image Database MrSID No Yes --
-NDF NLAPS Data Format No Yes No limits
-NITF NITF Yes Yes
-NetCDF netCDF Yes Yes 2GB
-OGDI Bridge OGDI No Yes --
-PCI .aux Labelled PAux Yes No No limits
-PCI Geomatics Database File PCIDSK Yes Yes No limits
-Portable Network Graphics (.png) PNG Yes No
-PCRaster (.map) PCRaster Yes No
-Netpbm (.ppm,.pgm) PNM Yes No No limits
-RadarSat2 XML (product.xml) RS2 No Yes 4GB
-USGS SDTS DEM (*CATD.DDF) SDTS No Yes --
-SAR CEOS SAR_CEOS No Yes --
-USGS ASCII DEM (.dem) USGSDEM No Yes --
-X11 Pixmap (.xpm) XPM Yes No
+Long Format Name Code Creation Georeferencing Maximum file size Compiled by default
+Arc/Info ASCII Grid AAIGrid Yes Yes 2GB Yes
+ADRG/ARC Digitilized Raster Graphics ADRG Yes Yes -- Yes
+Arc/Info Binary Grid (.adf) AIG No Yes -- Yes
+Microsoft Windows Device Independent Bitmap BMP Yes Yes 4GiB Yes
+BPG (Better Portable Graphics) BPG No No --- No, needs libbpg (manual build required for now)
+BSB Nautical Chart Format (.kap) BSB No Yes -- Yes, can be disabled
+VTP Binary Terrain Format (.bt) BT Yes Yes -- Yes
+CEOS (Spot for instance) CEOS No No -- Yes
+TerraSAR-X Complex SAR Data Product COSAR No No -- Yes
+DB2 DB2 Yes Yes No limits No, needs ODBC
+DODS / OPeNDAP DODS No Yes -- No, needs libdap
+Military Elevation Data (.dt0, .dt1, .dt2) DTED Yes Yes -- Yes
+Arc/Info Export E00 GRID E00GRID No Yes -- Yes
+ERDAS Compressed Wavelets (.ecw) ECW Yes Yes No, needs ECW SDK
+ESRI .hdr Labelled EHdr Yes Yes No limits Yes
+Erdas Imagine Raw EIR No Yes -- Yes
+ENVI .hdr Labelled Raster ENVI Yes Yes No limits Yes
+Epsilon - Wavelet compressed images EPSILON Yes No -- No, needs EPSILON library
+ERMapper (.ers) ERS Yes Yes Yes
+Envisat Image Product (.n1) ESAT No No -- Yes
+EOSAT FAST Format FAST No Yes -- Yes
+FIT FIT Yes No -- Yes
+FITS (.fits) FITS Yes No -- No, needs libcfitsio
+Fuji BAS Scanner Image FujiBAS No No -- Yes
+Generic Binary (.hdr Labelled) GENBIN No No -- Yes
+GeoPackage GPKG Yes Yes No limits No, needs libsqlite3
+Oracle Spatial GeoRaster GEORASTER Yes Yes No limits No, needs Oracle client libraries
+GSat File Format GFF No No -- Yes
+Graphics Interchange Format (.gif) GIF Yes No 2GB Yes (internal GIF library provided)
+WMO GRIB1/GRIB2 (.grb) GRIB No Yes 2GB Yes, can be disabled
+GMT Compatible netCDF GMT Yes Yes 2GB No, needs libnetcdf
+GRASS Raster Format GRASS No Yes -- No, needs libgrass
+Golden Software Surfer 7 Binary Grid GS7BG Yes Yes 4GiB Yes
+TIFF / BigTIFF / GeoTIFF (.tif) GTiff Yes Yes 4GiB / No limits for BigTIFF Yes (internal libtiff and libgeotiff provided)
+Hierarchical Data Format Release 4 (HDF4) HDF4 Yes Yes 2GiB No, needs libdf
+Hierarchical Data Format Release 5 (HDF5) HDF5 No Yes 2GiB No, needs libhdf5
+Erdas Imagine (.img) HFA Yes Yes No limits2 Yes
+Image Display and Analysis (WinDisp) IDA Yes Yes 2GB Yes
+ILWIS Raster Map (.mpr,.mpl) ILWIS Yes Yes -- Yes
+Intergraph Raster INGR Yes Yes 2GiB Yes
+IRIS IRIS No Yes -- Yes
+USGS Astrogeology ISIS cube (Version 3) ISIS3 No Yes -- Yes
+JAXA PALSAR Product Reader (Level 1.1/1.5) JAXAPALSAR No No -- Yes
+Japanese DEM (.mem) JDEM No Yes -- Yes
+JPEG JFIF (.jpg) JPEG Yes Yes 4GiB (max dimensions 65500x65500) Yes (internal libjpeg provided)
+JPEG2000 (.jp2, .j2k) JP2OpenJPEG Yes Yes No, needs OpenJPEG library (v2)
+KMLSUPEROVERLAY KMLSUPEROVERLAY Yes Yes Yes
+NOAA Polar Orbiter Level 1b Data Set (AVHRR) L1B No Yes -- Yes
+Erdas 7.x .LAN and .GIS LAN No Yes 2GB Yes
+MBTiles MBTiles Yes Yes -- No (needs OGR SQLite driver)
+OziExplorer .MAP MAP No Yes -- Yes
+In Memory Raster MEM Yes Yes Yes
+Vexcel MFF MFF Yes Yes No limits Yes
+MG4 Encoded Lidar MG4Lidar No Yes -- No, needs LIDAR SDK
+Meta Raster Format MRF Yes Yes -- Yes
+Multi-resolution Seamless Image Database MrSID No Yes -- No, needs MrSID SDK
+Meteosat Second Generation MSG No Yes No, needs msg library
+EUMETSAT Archive native (.nat) MSGN No Yes Yes
+NLAPS Data Format NDF No Yes No limits Yes
+NOAA NGS Geoid Height Grids NGSGEOID No Yes Yes
+NITF NITF Yes Yes 10GB Yes
+NetCDF netCDF Yes Yes 2GB No, needs libnetcdf
+OGDI Bridge OGDI No Yes -- No, needs OGDI library
+OZI OZF2/OZFX3 OZI No Yes -- No
+PCI Geomatics Database File PCIDSK Yes Yes No limits Yes
+PCRaster PCRaster Yes Yes Yes (internal libcsf provided)
+Geospatial PDF PDF Yes Yes -- Yes (but needs libpoppler, libpodofo or PDFium)
+NASA Planetary Data System PDS No Yes -- Yes
+Planet Labs Mosaics API PLMosaic No Yes -- No, needs libcurl
+Portable Network Graphics (.png) PNG Yes No Yes (internal libpng provided)
+PostGIS Raster (previously WKTRaster) PostGISRaster No Yes -- No, needs PostgreSQL library
+Netpbm (.ppm,.pgm) PNM Yes No No limits Yes
+R Object Data Store R Yes No -- Yes
+Rasdaman RASDAMAN No No No limits No (needs raslib)
+Rasterlite - Rasters in SQLite DB Rasterlite Yes Yes -- No (needs OGR SQLite driver)
+ROI_PAC Raster ROI_PAC Yes Yes -- Yes
+Raster Product Format/RPF (CADRG, CIB) RPFTOC No Yes -- Yes
+RadarSat2 XML (product.xml) RS2 No Yes 4GB Yes
+R Raster (.grd) RRASTER No Yes - Yes
+Idrisi Raster RST Yes Yes No limits Yes
+Sentinel 1 SAR SAFE (manifest.safe) SAFE No Yes No limits Yes
+Sentinel 2 SENTINEL2 No Yes No limits Yes
+SAGA GIS Binary format SAGA Yes Yes -- Yes
+SAR CEOS SAR_CEOS No Yes -- Yes
+ArcSDE Raster SDE No Yes -- No, needs ESRI SDE
+USGS SDTS DEM (*CATD.DDF) SDTS No Yes -- Yes
+SGI Image Format SGI Yes Yes -- Yes
+SRTM HGT Format SRTMHGT Yes Yes -- Yes
+EarthWatch/DigitalGlobe .TIL TIL No No -- Yes
+TerraSAR-X Product TSX Yes No -- Yes
+USGS ASCII DEM / CDED (.dem) USGSDEM Yes Yes -- Yes
+VICAR VICAR No Yes -- Yes
+GDAL Virtual (.vrt) VRT Yes Yes -- Yes
+OGC Web Coverage Service WCS No Yes -- No, needs libcurl
+WEBP WEBP Yes No -- No, needs libwebp
+OGC Web Map Service, and TMS, WorldWind, On EaWMS No Yes -- No, needs libcurl
+OGC Web Map Tile Service WMTS No Yes -- No, needs libcurl
+ASCII Gridded XYZ XYZ Yes Yes -- Yes
</pre></div>
<h3>Location Creation</h3>
@@ -249,7 +297,7 @@
(<a href="http://eca.knmi.nl/download/ensembles/ensembles.php">Terms of use</a>).
To import the different chunks of data provided by the project as netCDF files,
the offset parameter can be used to properly assign numbers to the series
-of daily raster maps from 1st Jan 1950 (in case if importing the ECAD data
+of daily raster maps from 1st Jan 1950 (in case of importing the ECAD data
split into multi-annual chunks). The ECAD data must be imported into a
LatLong location.
<p>
