[GRASS-SVN] r69501 - grass/trunk/raster/r.in.gdal
svn_grass at osgeo.org
Thu Sep 15 06:31:36 PDT 2016
Author: neteler
Date: 2016-09-15 06:31:36 -0700 (Thu, 15 Sep 2016)
New Revision: 69501
grass/trunk/raster/r.in.gdal/r.in.gdal.html
r.in.gdal manual: (reduced) format table simplified
Modified: grass/trunk/raster/r.in.gdal/r.in.gdal.html
--- grass/trunk/raster/r.in.gdal/r.in.gdal.html 2016-09-15 13:18:39 UTC (rev 69500)
+++ grass/trunk/raster/r.in.gdal/r.in.gdal.html 2016-09-15 13:31:36 UTC (rev 69501)
@@ -17,112 +17,112 @@
<h3>GDAL supported raster formats</h3>
-Full details on GDAL supported formats are available at:
+Full details on all GDAL supported formats are available at:
<p>
<a href="http://www.gdal.org/formats_list.html">http://www.gdal.org/formats_list.html</a>
<p>
Selected formats out of the more than 140 supported formats:
<div class="code"><pre>
-Long Format Name Code Creation Georeferencing Maximum file size Compiled by default
-Arc/Info ASCII Grid AAIGrid Yes Yes 2GB Yes
-ADRG/ARC Digitilized Raster Graphics ADRG Yes Yes -- Yes
-Arc/Info Binary Grid (.adf) AIG No Yes -- Yes
-Microsoft Windows Device Independent Bitmap BMP Yes Yes 4GiB Yes
-BPG (Better Portable Graphics) BPG No No --- No, needs libbpg (manual build required for now)
-BSB Nautical Chart Format (.kap) BSB No Yes -- Yes, can be disabled
-VTP Binary Terrain Format (.bt) BT Yes Yes -- Yes
-CEOS (Spot for instance) CEOS No No -- Yes
-TerraSAR-X Complex SAR Data Product COSAR No No -- Yes
-DB2 DB2 Yes Yes No limits No, needs ODBC
-DODS / OPeNDAP DODS No Yes -- No, needs libdap
-Military Elevation Data (.dt0, .dt1, .dt2) DTED Yes Yes -- Yes
-Arc/Info Export E00 GRID E00GRID No Yes -- Yes
-ERDAS Compressed Wavelets (.ecw) ECW Yes Yes No, needs ECW SDK
-ESRI .hdr Labelled EHdr Yes Yes No limits Yes
-Erdas Imagine Raw EIR No Yes -- Yes
-ENVI .hdr Labelled Raster ENVI Yes Yes No limits Yes
-Epsilon - Wavelet compressed images EPSILON Yes No -- No, needs EPSILON library
-ERMapper (.ers) ERS Yes Yes Yes
-Envisat Image Product (.n1) ESAT No No -- Yes
-EOSAT FAST Format FAST No Yes -- Yes
-FIT FIT Yes No -- Yes
-FITS (.fits) FITS Yes No -- No, needs libcfitsio
-Fuji BAS Scanner Image FujiBAS No No -- Yes
-Generic Binary (.hdr Labelled) GENBIN No No -- Yes
-GeoPackage GPKG Yes Yes No limits No, needs libsqlite3
-Oracle Spatial GeoRaster GEORASTER Yes Yes No limits No, needs Oracle client libraries
-GSat File Format GFF No No -- Yes
-Graphics Interchange Format (.gif) GIF Yes No 2GB Yes (internal GIF library provided)
-WMO GRIB1/GRIB2 (.grb) GRIB No Yes 2GB Yes, can be disabled
-GMT Compatible netCDF GMT Yes Yes 2GB No, needs libnetcdf
-GRASS Raster Format GRASS No Yes -- No, needs libgrass
-Golden Software Surfer 7 Binary Grid GS7BG Yes Yes 4GiB Yes
-TIFF / BigTIFF / GeoTIFF (.tif) GTiff Yes Yes 4GiB / No limits for BigTIFF Yes (internal libtiff and libgeotiff provided)
-Hierarchical Data Format Release 4 (HDF4) HDF4 Yes Yes 2GiB No, needs libdf
-Hierarchical Data Format Release 5 (HDF5) HDF5 No Yes 2GiB No, needs libhdf5
-Erdas Imagine (.img) HFA Yes Yes No limits2 Yes
-Image Display and Analysis (WinDisp) IDA Yes Yes 2GB Yes
-ILWIS Raster Map (.mpr,.mpl) ILWIS Yes Yes -- Yes
-Intergraph Raster INGR Yes Yes 2GiB Yes
-IRIS IRIS No Yes -- Yes
-USGS Astrogeology ISIS cube (Version 3) ISIS3 No Yes -- Yes
-JAXA PALSAR Product Reader (Level 1.1/1.5) JAXAPALSAR No No -- Yes
-Japanese DEM (.mem) JDEM No Yes -- Yes
-JPEG JFIF (.jpg) JPEG Yes Yes 4GiB (max dimensions 65500x65500) Yes (internal libjpeg provided)
-JPEG2000 (.jp2, .j2k) JP2OpenJPEG Yes Yes No, needs OpenJPEG library (v2)
-KMLSUPEROVERLAY KMLSUPEROVERLAY Yes Yes Yes
-NOAA Polar Orbiter Level 1b Data Set (AVHRR) L1B No Yes -- Yes
-Erdas 7.x .LAN and .GIS LAN No Yes 2GB Yes
-MBTiles MBTiles Yes Yes -- No (needs OGR SQLite driver)
-OziExplorer .MAP MAP No Yes -- Yes
-In Memory Raster MEM Yes Yes Yes
-Vexcel MFF MFF Yes Yes No limits Yes
-MG4 Encoded Lidar MG4Lidar No Yes -- No, needs LIDAR SDK
-Meta Raster Format MRF Yes Yes -- Yes
-Multi-resolution Seamless Image Database MrSID No Yes -- No, needs MrSID SDK
-Meteosat Second Generation MSG No Yes No, needs msg library
-EUMETSAT Archive native (.nat) MSGN No Yes Yes
-NLAPS Data Format NDF No Yes No limits Yes
-NOAA NGS Geoid Height Grids NGSGEOID No Yes Yes
-NITF NITF Yes Yes 10GB Yes
-NetCDF netCDF Yes Yes 2GB No, needs libnetcdf
-OGDI Bridge OGDI No Yes -- No, needs OGDI library
-OZI OZF2/OZFX3 OZI No Yes -- No
-PCI Geomatics Database File PCIDSK Yes Yes No limits Yes
-PCRaster PCRaster Yes Yes Yes (internal libcsf provided)
-Geospatial PDF PDF Yes Yes -- Yes (but needs libpoppler, libpodofo or PDFium)
-NASA Planetary Data System PDS No Yes -- Yes
-Planet Labs Mosaics API PLMosaic No Yes -- No, needs libcurl
-Portable Network Graphics (.png) PNG Yes No Yes (internal libpng provided)
-PostGIS Raster (previously WKTRaster) PostGISRaster No Yes -- No, needs PostgreSQL library
-Netpbm (.ppm,.pgm) PNM Yes No No limits Yes
-R Object Data Store R Yes No -- Yes
-Rasdaman RASDAMAN No No No limits No (needs raslib)
-Rasterlite - Rasters in SQLite DB Rasterlite Yes Yes -- No (needs OGR SQLite driver)
-ROI_PAC Raster ROI_PAC Yes Yes -- Yes
-Raster Product Format/RPF (CADRG, CIB) RPFTOC No Yes -- Yes
-RadarSat2 XML (product.xml) RS2 No Yes 4GB Yes
-R Raster (.grd) RRASTER No Yes - Yes
-Idrisi Raster RST Yes Yes No limits Yes
-Sentinel 1 SAR SAFE (manifest.safe) SAFE No Yes No limits Yes
-Sentinel 2 SENTINEL2 No Yes No limits Yes
-SAGA GIS Binary format SAGA Yes Yes -- Yes
-SAR CEOS SAR_CEOS No Yes -- Yes
-ArcSDE Raster SDE No Yes -- No, needs ESRI SDE
-USGS SDTS DEM (*CATD.DDF) SDTS No Yes -- Yes
-SGI Image Format SGI Yes Yes -- Yes
-SRTM HGT Format SRTMHGT Yes Yes -- Yes
-EarthWatch/DigitalGlobe .TIL TIL No No -- Yes
-TerraSAR-X Product TSX Yes No -- Yes
-USGS ASCII DEM / CDED (.dem) USGSDEM Yes Yes -- Yes
-VICAR VICAR No Yes -- Yes
-GDAL Virtual (.vrt) VRT Yes Yes -- Yes
-OGC Web Coverage Service WCS No Yes -- No, needs libcurl
-WEBP WEBP Yes No -- No, needs libwebp
-OGC Web Map Service, and TMS, WorldWind, On EaWMS No Yes -- No, needs libcurl
-OGC Web Map Tile Service WMTS No Yes -- No, needs libcurl
-ASCII Gridded XYZ XYZ Yes Yes -- Yes
+Long Format Name Code Creation Georeferencing Maximum file size
+ADRG/ARC Digitilized Raster Graphics ADRG Yes Yes --
+Arc/Info ASCII Grid AAIGrid Yes Yes 2GB
+Arc/Info Binary Grid (.adf) AIG No Yes --
+Arc/Info Export E00 GRID E00GRID No Yes --
+ArcSDE Raster SDE No Yes --
+ASCII Gridded XYZ XYZ Yes Yes --
+BSB Nautical Chart Format (.kap) BSB No Yes --
+CEOS (Spot for instance) CEOS No No --
+DB2 DB2 Yes Yes No limits
+DODS / OPeNDAP DODS No Yes --
+EarthWatch/DigitalGlobe .TIL TIL No No --
+ENVI .hdr Labelled Raster ENVI Yes Yes No limits
+Envisat Image Product (.n1) ESAT No No --
+EOSAT FAST Format FAST No Yes --
+Epsilon - Wavelet compressed images EPSILON Yes No --
+Erdas 7.x .LAN and .GIS LAN No Yes 2GB
+ERDAS Compressed Wavelets (.ecw) ECW Yes Yes
+Erdas Imagine (.img) HFA Yes Yes No limits
+Erdas Imagine Raw EIR No Yes --
+ERMapper (.ers) ERS Yes Yes
+ESRI .hdr Labelled EHdr Yes Yes No limits
+EUMETSAT Archive native (.nat) MSGN No Yes
+FIT FIT Yes No --
+FITS (.fits) FITS Yes No --
+Fuji BAS Scanner Image FujiBAS No No --
+GDAL Virtual (.vrt) VRT Yes Yes --
+Generic Binary (.hdr Labelled) GENBIN No No --
+GeoPackage GPKG Yes Yes No limits
+Geospatial PDF PDF Yes Yes --
+GMT Compatible netCDF GMT Yes Yes 2GB
+Golden Software Surfer 7 Binary Grid GS7BG Yes Yes 4GiB
+Graphics Interchange Format (.gif) GIF Yes No 2GB
+GRASS Raster Format GRASS No Yes --
+GSat File Format GFF No No --
+Hierarchical Data Format Release 4 (HDF4) HDF4 Yes Yes 2GiB
+Hierarchical Data Format Release 5 (HDF5) HDF5 No Yes 2GiB
+Idrisi Raster RST Yes Yes No limits
+ILWIS Raster Map (.mpr,.mpl) ILWIS Yes Yes --
+Image Display and Analysis (WinDisp) IDA Yes Yes 2GB
+In Memory Raster MEM Yes Yes
+Intergraph Raster INGR Yes Yes 2GiB
+IRIS IRIS No Yes --
+Japanese DEM (.mem) JDEM No Yes --
+JAXA PALSAR Product Reader (Level 1.1/1.5) JAXAPALSAR No No --
+JPEG2000 (.jp2, .j2k) JP2OpenJPEG Yes Yes
+JPEG JFIF (.jpg) JPEG Yes Yes 4GiB
+KMLSUPEROVERLAY KMLSUPEROVERLAY Yes Yes
+MBTiles MBTiles Yes Yes --
+Meta Raster Format MRF Yes Yes --
+Meteosat Second Generation MSG No Yes
+MG4 Encoded Lidar MG4Lidar No Yes --
+Microsoft Windows Device Independent Bitmap BMP Yes Yes 4GiB
+Military Elevation Data (.dt0, .dt1, .dt2) DTED Yes Yes --
+Multi-resolution Seamless Image Database MrSID No Yes --
+NASA Planetary Data System PDS No Yes --
+NetCDF netCDF Yes Yes 2GB
+Netpbm (.ppm,.pgm) PNM Yes No No limits
+NITF NITF Yes Yes 10GB
+NLAPS Data Format NDF No Yes No limits
+NOAA NGS Geoid Height Grids NGSGEOID No Yes
+NOAA Polar Orbiter Level 1b Data Set (AVHRR) L1B No Yes --
+OGC Web Coverage Service WCS No Yes --
+OGC Web Map Service, and TMS, WorldWind, On EaWMS No Yes --
+OGC Web Map Tile Service WMTS No Yes --
+OGDI Bridge OGDI No Yes --
+Oracle Spatial GeoRaster GEORASTER Yes Yes No limits
+OziExplorer .MAP MAP No Yes --
+OZI OZF2/OZFX3 OZI No Yes --
+PCI Geomatics Database File PCIDSK Yes Yes No limits
+PCRaster PCRaster Yes Yes
+Planet Labs Mosaics API PLMosaic No Yes --
+Portable Network Graphics (.png) PNG Yes No
+PostGIS Raster (previously WKTRaster) PostGISRaster No Yes --
+RadarSat2 XML (product.xml) RS2 No Yes 4GB
+Rasdaman RASDAMAN No No No limits
+Rasterlite - Rasters in SQLite DB Rasterlite Yes Yes --
+Raster Product Format/RPF (CADRG, CIB) RPFTOC No Yes --
+R Object Data Store R Yes No --
+ROI_PAC Raster ROI_PAC Yes Yes --
+R Raster (.grd) RRASTER No Yes --
+SAGA GIS Binary format SAGA Yes Yes --
+SAR CEOS SAR_CEOS No Yes --
+Sentinel 1 SAR SAFE (manifest.safe) SAFE No Yes No limits
+Sentinel 2 SENTINEL2 No Yes No limits
+SGI Image Format SGI Yes Yes --
+SRTM HGT Format SRTMHGT Yes Yes --
+TerraSAR-X Complex SAR Data Product COSAR No No --
+TerraSAR-X Product TSX Yes No --
+TIFF / BigTIFF / GeoTIFF (.tif) GTiff Yes Yes 4GiB/None for BigTIFF
+USGS ASCII DEM / CDED (.dem) USGSDEM Yes Yes --
+USGS Astrogeology ISIS cube (Version 3) ISIS3 No Yes --
+USGS SDTS DEM (*CATD.DDF) SDTS No Yes --
+Vexcel MFF MFF Yes Yes No limits
+VICAR VICAR No Yes --
+VTP Binary Terrain Format (.bt) BT Yes Yes --
+WEBP WEBP Yes No --
+WMO GRIB1/GRIB2 (.grb) GRIB No Yes 2GB
</pre></div>
<h3>Location Creation</h3>
