[GRASS-SVN] r69504 - grass-addons/grass7/misc/m.printws
svn_grass at osgeo.org
Fri Sep 16 04:19:23 PDT 2016
Author: kuszinger
Date: 2016-09-16 04:19:23 -0700 (Fri, 16 Sep 2016)
New Revision: 69504
grass-addons/grass7/misc/m.printws/m.printws.py
Adding support for latlong coordinate systems
Modified: grass-addons/grass7/misc/m.printws/m.printws.py
--- grass-addons/grass7/misc/m.printws/m.printws.py 2016-09-15 13:32:42 UTC (rev 69503)
+++ grass-addons/grass7/misc/m.printws/m.printws.py 2016-09-16 11:19:23 UTC (rev 69504)
@@ -220,7 +220,7 @@
DVECTDIC = {}
DVECTDIC['size'] = 1.0 # symbol size
-DVECTDIC['label_size'] = 1.5 # label size
+DVECTDIC['label_size'] = 1.0 # label size
UPSD['d.vect'] = DVECTDIC
DGRIDDIC = {}
@@ -585,6 +585,12 @@
result = re.sub(key, dic[key], result)
return result
+def decdeg2dms(dd):
+ mnt,sec = divmod(dd*3600,60)
+ deg,mnt = divmod(mnt,60)
+ return str(int(deg)) + ':' + str(int(mnt)) + ':' + str(sec)
@@ -794,24 +800,38 @@
# Correcting map area ratio to ratio of region edges
# OR screen window edges depeding on "regionmode"
# for later: grass.use_temp_region()
+ ISLATLONG=False
s = grass.read_command("g.region", flags='p')
kv = grass.parse_key_val(s, sep=':')
regioncols = float(kv['cols'].strip())
regionrows = float(kv['rows'].strip())
- ewres = float(kv['ewres'].strip())
- nsres = float(kv['nsres'].strip())
+ ewrestemp = kv['ewres'].strip()
+ nsrestemp = kv['nsres'].strip()
+ if ewrestemp.find(':') > 0:
+ ISLATLONG=True
+ ewrestemp = ewrestemp.split(':')
+ ewres = float(ewrestemp[0]) + float(ewrestemp[1]) / 60.0 + float(ewrestemp[2]) / 3600.0
+ nsrestemp = nsrestemp.split(':')
+ nsres = float(nsrestemp[0]) + float(nsrestemp[1]) / 60.0 + float(nsrestemp[2]) / 3600.0
+ else:
+ ewres = float(ewrestemp)
+ nsres = float(nsrestemp)
sizex = regioncols * ewres
sizey = regionrows * nsres
+ grass.verbose(_("printws: sizex " + str(sizex)))
+ grass.verbose(_("printws: sizey " + str(sizey)))
if regionmode == 'region':
- hregionratio = sizex / sizey
- grass.verbose(_("printws: REGION MODE - region "))
+ hregionratio = float(sizex) / float(sizey)
+ grass.verbose(_("printws: REGION MODE -> region "))
else: # surprisingly doing the SAME
# using screen window ratio for map area
# next line was a test for this but didn't help on gadgets positioning
#hregionratio = float(extents[8]) / float(extents[9])
- grass.verbose(_("printws: REGION MODE - window"))
+ grass.verbose(_("printws: REGION MODE -> window"))
hmapratio = mapsizes['w'] / mapsizes['h']
grass.verbose(_("printws: raw mapsizes: " + str(mapsizesindots)))
@@ -831,8 +851,8 @@
# to eliminate unnecessary CPU heating/data transfer
# so as to make it faster
# with only invisible detail loss.
- colsregiontomap = mapsizesindots['w'] / regioncols
- rowsregiontomap = mapsizesindots['h'] / regionrows
+ colsregiontomap = float(mapsizesindots['w']) / regioncols
+ rowsregiontomap = float(mapsizesindots['h']) / regionrows
newewres = ewres
newnsres = nsres
@@ -843,9 +863,17 @@
newewres = ewres / colsregiontomap
# if rowsregiontomap < 1:
newnsres = nsres / rowsregiontomap
+ # WOW - no necessary to convert back to DMS for nsres / ewres
+ #if ISLATLONG:
+ # newewresstr=decdeg2dms(newewres)
+ # newnsresstr=decdeg2dms(newnsres)
+ #else:
+ newewresstr=str(newewres)
+ newnsresstr=str(newnsres)
+ grass.run_command("g.region", ewres=newewresstr, nsres=newnsresstr)
- grass.run_command("g.region", ewres=str(newewres), nsres=str(newnsres))
# it seems that d.wms uses the GRASS_REGION from region info
# others may also do so we set it
@@ -855,8 +883,8 @@
kv2['n'] = kv['north']
kv2['s'] = kv['south']
kv2['w'] = kv['west']
- kv2['ewres'] = str(newewres)
- kv2['nsres'] = str(newnsres)
+ kv2['ewres'] = newewresstr
+ kv2['nsres'] = newnsresstr
#kv2['rows'] #- autocalculated to resolution - no need to set explicitly
#kv2['cols'] #- autocalculated to resolution - no need to set explicitly
#grass.message(str(kv2))
