[GRASS-SVN] r69510 - in grass/trunk/temporal: t.connect t.info t.info/testsuite t.rast.algebra t.rast.list t.rast.mapcalc t.rast.neighbors t.rast.univar t.rast.univar/testsuite t.rast3d.algebra t.rast3d.mapcalc t.sample t.select t.topology t.vect.algebra t.vect.list t.vect.univar
svn_grass at osgeo.org
Fri Sep 16 16:03:06 PDT 2016
Author: huhabla
Date: 2016-09-16 16:03:06 -0700 (Fri, 16 Sep 2016)
New Revision: 69510
grass/trunk/temporal/t.connect/main.c
grass/trunk/temporal/t.info/t.info.html
grass/trunk/temporal/t.info/t.info.py
grass/trunk/temporal/t.info/testsuite/test.t.info.sh
grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py
grass/trunk/temporal/t.rast.list/t.rast.list.py
grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
grass/trunk/temporal/t.rast.univar/t.rast.univar.html
grass/trunk/temporal/t.rast.univar/t.rast.univar.py
grass/trunk/temporal/t.rast.univar/testsuite/test_univar.py
grass/trunk/temporal/t.rast3d.algebra/t.rast3d.algebra.py
grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
grass/trunk/temporal/t.sample/t.sample.py
grass/trunk/temporal/t.select/t.select.py
grass/trunk/temporal/t.topology/t.topology.py
grass/trunk/temporal/t.vect.algebra/t.vect.algebra.py
grass/trunk/temporal/t.vect.list/t.vect.list.py
grass/trunk/temporal/t.vect.univar/t.vect.univar.py
temporal modules: Attempt to harmonize the flags of temporal modules
Modified: grass/trunk/temporal/t.connect/main.c
--- grass/trunk/temporal/t.connect/main.c 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.connect/main.c 2016-09-16 23:03:06 UTC (rev 69510)
@@ -31,9 +31,9 @@
/* Set description */
module = G_define_module();
- G_add_keyword(_("database"));
- G_add_keyword(_("attribute table"));
- G_add_keyword(_("connection settings"));
+ G_add_keyword(_("temporal"));
+ G_add_keyword(_("settings"));
+ G_add_keyword(_("metadata"));
module->description =
_("Prints/sets general temporal GIS database connection for current mapset.");
Modified: grass/trunk/temporal/t.info/t.info.html
--- grass/trunk/temporal/t.info/t.info.html 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.info/t.info.html 2016-09-16 23:03:06 UTC (rev 69510)
@@ -28,7 +28,7 @@
In order to obtain information about temporal DBMI backend, run:
<div class="code"><pre>
-t.info -s
+t.info -d
+------------------- Temporal DBMI backend information ----------------------+
| DBMI Python interface:...... sqlite3
| Temporal database string:... /grassdata/nc_spm_temporal_workshop/climate_2000_2012/tgis/sqlite.db
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.info/t.info.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -43,7 +43,7 @@
#%end
#%flag
-#% key: s
+#% key: d
#% description: Print information about the temporal DBMI interface and exit
#% suppress_required: yes
#%end
@@ -60,7 +60,7 @@
name = options["input"]
type_ = options["type"]
shellstyle = flags['g']
- system = flags['s']
+ system = flags['d']
history = flags['h']
# Make sure the temporal database exists
@@ -68,7 +68,6 @@
dbif, connected = tgis.init_dbif(None)
rows = tgis.get_tgis_metadata(dbif)
if system and not shellstyle:
Modified: grass/trunk/temporal/t.info/testsuite/test.t.info.sh
--- grass/trunk/temporal/t.info/testsuite/test.t.info.sh 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.info/testsuite/test.t.info.sh 2016-09-16 23:03:06 UTC (rev 69510)
@@ -2,7 +2,7 @@
# Test the info output
# We need to set a specific region in the
-# @preprocess step of this test.
+# @preprocess step of this test.
g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
export GRASS_OVERWRITE=1
@@ -17,8 +17,8 @@
v.random -z output=lidar_abs_2 n=20 zmin=0 zmax=100 column=height
# The first @test
-t.info -s
-t.info -sg
+t.info -d
+t.info -dg
t.create type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
t.create type=strds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
Modified: grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py
--- grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -50,7 +50,7 @@
#%flag
#% key: s
-#% description: Activate spatial topology
+#% description: Check the spatial topology of temporally related maps and process only spatially related maps
#%end
#%flag
@@ -97,11 +97,11 @@
nprocs=nprocs,
register_null=register_null,
dry_run=dry_run)
if granularity:
if not p.setup_common_granularity(expression=expression, lexer = tgis.TemporalRasterAlgebraLexer()):
grass.script.fatal(_("Unable to process the expression in granularity algebra mode"))
pc = p.parse(expression, basename, grass.script.overwrite())
if dry_run is True:
Modified: grass/trunk/temporal/t.rast.list/t.rast.list.py
--- grass/trunk/temporal/t.rast.list/t.rast.list.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.rast.list/t.rast.list.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -80,7 +80,7 @@
#%end
#%flag
-#% key: s
+#% key: u
#% description: Suppress printing of column names
#% guisection: Formatting
#%end
@@ -101,7 +101,7 @@
separator = grass.separator(options["separator"])
method = options["method"]
granule = options["granule"]
- header = flags["s"]
+ header = flags["u"]
output = options["output"]
Modified: grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
--- grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -64,11 +64,9 @@
#%flag
#% key: s
-#% description: Check spatial overlap
#%end
-from multiprocessing import Process
-import copy
import grass.script as grass
import grass.temporal as tgis
Modified: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -84,7 +84,6 @@
#% description: Register Null maps
#%end
#%flag
#% key: r
#% description: Ignore the current region settings and use the raster map regions
Modified: grass/trunk/temporal/t.rast.univar/t.rast.univar.html
--- grass/trunk/temporal/t.rast.univar/t.rast.univar.html 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.rast.univar/t.rast.univar.html 2016-09-16 23:03:06 UTC (rev 69510)
@@ -6,7 +6,7 @@
<p>
By default it returns the name of the map, the start and end date of
dataset and the following values: mean, minimum and maximum vale,
-mean_of_abs, standard deviation, variance,coeff_var, number of null
+mean_of_abs, standard deviation, variance, coeff_var, number of null
cells, total number of cell.
<p>
Using the <em>e</em> flag it can calculate also extended statistics:
Modified: grass/trunk/temporal/t.rast.univar/t.rast.univar.py
--- grass/trunk/temporal/t.rast.univar/t.rast.univar.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.rast.univar/t.rast.univar.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -49,7 +49,7 @@
#%end
#%flag
-#% key: s
+#% key: u
#%end
@@ -67,7 +67,7 @@
where = options["where"]
extended = flags["e"]
- no_header = flags["s"]
+ no_header = flags["u"]
rast_region = bool(flags["r"])
Modified: grass/trunk/temporal/t.rast.univar/testsuite/test_univar.py
--- grass/trunk/temporal/t.rast.univar/testsuite/test_univar.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.rast.univar/testsuite/test_univar.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -25,23 +25,23 @@
cls.runModule("r.mapcalc", expression="a_3 = 300", overwrite=True)
cls.runModule("r.mapcalc", expression="a_4 = 400", overwrite=True)
- cls.runModule("t.create", type="strds", temporaltype="absolute",
- output="A", title="A test", description="A test",
+ cls.runModule("t.create", type="strds", temporaltype="absolute",
+ output="A", title="A test", description="A test",
overwrite=True)
- cls.runModule("t.register", flags="i", type="raster", input="A",
- maps="a_1,a_2,a_3,a_4", start="2001-01-01",
+ cls.runModule("t.register", flags="i", type="raster", input="A",
+ maps="a_1,a_2,a_3,a_4", start="2001-01-01",
increment="3 months", overwrite=True)
@classmethod
def tearDownClass(cls):
"""Remove the temporary region
- cls.runModule("t.remove", flags="rf", type="strds",
+ cls.runModule("t.remove", flags="rf", type="strds",
inputs="A")
cls.del_temp_region()
def test_1(self):
t_rast_univar = SimpleModule("t.rast.univar", input="A",
where="start_time >= '2001-01-01'",
overwrite=True, verbose=True)
@@ -122,7 +122,7 @@
def test_5(self):
self.runModule("g.region", res=10)
- self.assertModule("t.rast.univar", input="A", flags="rs",
+ self.assertModule("t.rast.univar", input="A", flags="ru",
output="univar_output.txt",
where="start_time >= '2001-03-01'",
Modified: grass/trunk/temporal/t.rast3d.algebra/t.rast3d.algebra.py
--- grass/trunk/temporal/t.rast3d.algebra/t.rast3d.algebra.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.rast3d.algebra/t.rast3d.algebra.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -51,7 +51,7 @@
#%flag
#% key: s
#%end
#%flag
@@ -88,11 +88,11 @@
tgis.init(True)
p = tgis.TemporalRaster3DAlgebraParser(run = True, debug=False, spatial = spatial, nprocs = nprocs, register_null = register_null)
if granularity:
if not p.setup_common_granularity(expression=expression, stdstype = 'str3ds', lexer = tgis.TemporalRasterAlgebraLexer()):
if __name__ == "__main__":
Modified: grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
--- grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -68,7 +68,7 @@
#%flag
#% key: s
#%end
Modified: grass/trunk/temporal/t.sample/t.sample.py
--- grass/trunk/temporal/t.sample/t.sample.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.sample/t.sample.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -57,7 +57,7 @@
#%flag
#% key: s
+#% description: Check for spatial topological overlap
#%end
Modified: grass/trunk/temporal/t.select/t.select.py
--- grass/trunk/temporal/t.select/t.select.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.select/t.select.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -37,7 +37,7 @@
#%flag
#% key: s
+#% description: Check the spatial topology of temporally related maps and select only spatially related maps
#%end
#%flag
Modified: grass/trunk/temporal/t.topology/t.topology.py
--- grass/trunk/temporal/t.topology/t.topology.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.topology/t.topology.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -34,12 +34,12 @@
#%flag
#% key: m
-#% description: Print temporal relationships and exit
+#% description: Print temporal topological relationships and exit
#%end
#%flag
#% key: s
-#% description: Print spatio-temporal relationships and exit
+#% description: Print spatio-temporal topological relationships and exit
#%end
from __future__ import print_function
Modified: grass/trunk/temporal/t.vect.algebra/t.vect.algebra.py
--- grass/trunk/temporal/t.vect.algebra/t.vect.algebra.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.vect.algebra/t.vect.algebra.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -43,7 +43,7 @@
#%flag
#% key: s
#%end
import grass.script
Modified: grass/trunk/temporal/t.vect.list/t.vect.list.py
--- grass/trunk/temporal/t.vect.list/t.vect.list.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.vect.list/t.vect.list.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -72,7 +72,7 @@
#%end
#%flag
-#% key: s
+#% key: u
#%end
@@ -92,7 +92,7 @@
Modified: grass/trunk/temporal/t.vect.univar/t.vect.univar.py
--- grass/trunk/temporal/t.vect.univar/t.vect.univar.py 2016-09-16 22:23:02 UTC (rev 69509)
+++ grass/trunk/temporal/t.vect.univar/t.vect.univar.py 2016-09-16 23:03:06 UTC (rev 69510)
@@ -62,7 +62,7 @@
#%end
#%flag
-#% key: s
+#% key: u
#%end
@@ -83,7 +83,7 @@
column = options["column"]
