[GRASS-SVN] r69512 - grass-addons/grass7/vector/v.in.pygbif
Sat Sep 17 15:06:59 PDT 2016
Author: sbl
Date: 2016-09-17 15:06:58 -0700 (Sat, 17 Sep 2016)
New Revision: 69512
   grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html
fixed examples + dependencies named
Modified: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html
--- grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html	2016-09-17 22:05:19 UTC (rev 69511)
+++ grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html	2016-09-17 22:06:58 UTC (rev 69512)
@@ -1,7 +1,10 @@
 <h2>DESCRIPTION:</h2>
 <p>The module <em>v.in.pygbif</em> is a wrapper around the
-<a href=http://pygbif.readthedocs.io/en/latest/index.html>pygbif</a> package.
-Through pygbif, it allows to download data from the Global Biodiversity
+<a href=http://pygbif.readthedocs.io/en/latest/index.html>pygbif</a> package.<br>
+Thus, <em>pygbif</em> is a dependency of v.in.pygbif. pygbif can be installed like this:<br>
+<div class="code"><pre>pip install pygbif</pre></div>
+Through <em>pygbif</em>, the module allows to download data from the Global Biodiversity
 Information Facility (<a href=www.gbif.org>GBIF</a>) using different search /
 filter criteria.</p>
 <p>The point data is downloaded and projected into the current location. By default
@@ -9,7 +12,8 @@
 possible projection errors, e.g. when projecting global data into UTM locations.
 However, in lat/lon location this limitation can be skiped using the <b><em>-r</em></b>
 flag.<br>
-Providing a mask overrides the limitation of the search to the current computational region.</p>
+Providing a mask automatically overrides the limitation of the search to the current
+computational region.</p>
 <p>Terminology in v.in.pygbif is oriented on the <em>Darwin Core</em> standard:
 <a href=http://rs.tdwg.org/dwc/> http://rs.tdwg.org/dwc/</a>.</p>
@@ -24,16 +28,19 @@
 <h2>EXAMPLES:</h2>
 # Check matching taxon names and alternatives in GBIF:
-v.in.pygbif species="Poa,Plantago" rank=genus  -p
+v.in.pygbif taxa="Poa,Plantago" rank=genus  -p
+# Check matching taxon names and alternatives in GBIF and print output in table:
+v.in.pygbif taxa="Poa pratensis,Plantago media,Acer negundo" rank=species -t
 # Get number of occurrences for two geni:
-v.in.pygbif species="Poa,Plantago" rank=genus  -o
+v.in.pygbif taxa="Poa,Plantago" rank=genus  -o
 # Get number of occurrences for two species:
-v.in.pygbif species="Poa pratensis,Plantago media" rank=species  -o
+v.in.pygbif taxa="Poa pratensis,Plantago media" rank=species  -o
 # Fetch occurrences for two species into a map for each species:
-v.in.pygbif species="Poa pratensis,Plantago media" rank=species output=gbif -i
+v.in.pygbif taxa="Poa pratensis,Plantago media" rank=species output=gbif -i
 </pre></div>
 </div>
