[GRASS-SVN] r69518 - grass-addons/grass7/vector/v.in.pygbif
Sun Sep 18 14:15:32 PDT 2016
Author: sbl
Date: 2016-09-18 14:15:32 -0700 (Sun, 18 Sep 2016)
New Revision: 69518
   grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html
add column information
Modified: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html
--- grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html	2016-09-18 20:34:21 UTC (rev 69517)
+++ grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html	2016-09-18 21:15:32 UTC (rev 69518)
@@ -7,6 +7,9 @@
 Through <em>pygbif</em>, the module allows to download data from the Global Biodiversity
 Information Facility (<a href=www.gbif.org>GBIF</a>) using different search /
 filter criteria.</p>
+<p>Since some of the Darwin Core attribute columns represent SQL key-words, the prefix "g_"
+was added to all attribute columns. The names of taxa provided at input to the search are
+written to the column "g_search".</p>
 <p>The point data is downloaded and projected into the current location. By default
 import is limited to the current computational region in order to avoid
 possible projection errors, e.g. when projecting global data into UTM locations.
@@ -66,4 +69,5 @@
 <h2>AUTHOR:</h2>
 Stefan Blumentrath, Norwegian Institute for Nature Research, Oslo, Norway
+Helmut Kudrnovsky
 </div>
