[GRASS-SVN] r69521 - grass-addons/grass7/raster3d/r3.profile
Sun Sep 18 18:32:09 PDT 2016
Author: wenzeslaus
Date: 2016-09-18 18:32:08 -0700 (Sun, 18 Sep 2016)
New Revision: 69521
Removed:
   grass-addons/grass7/raster3d/r3.profile/testsuite/
   grass-addons/grass7/raster3d/r3.profile/input.c
   grass-addons/grass7/raster3d/r3.profile/local_proto.h
   grass-addons/grass7/raster3d/r3.profile/main.c
   grass-addons/grass7/raster3d/r3.profile/read_rast.c
r3.profile: whitespace and testsuite clean up
Modified: grass-addons/grass7/raster3d/r3.profile/input.c
--- grass-addons/grass7/raster3d/r3.profile/input.c	2016-09-19 01:27:53 UTC (rev 69520)
+++ grass-addons/grass7/raster3d/r3.profile/input.c	2016-09-19 01:32:08 UTC (rev 69521)
@@ -7,57 +7,57 @@
 #include "local_proto.h"
 int input(char *blank1, char *word1, char *blank2, char *word2, char *rest,
-	  FILE *infile)
+          FILE * infile)
     char buf[1024];
     char *b, *w1, *w2;
     int string_size;
     if (isatty(0))
-	fprintf(stderr, "> ");
+        fprintf(stderr, "> ");
     *blank1 = *blank2 = 0;
     *word1 = *word2 = *rest = 0;
     if (!fgets(buf, 1024, infile)) {
-	*buf = 0;
-	return 0;
+        *buf = 0;
+        return 0;
     /* note ebuf and nbuf in main.c (w1 and w2 here) are only 256 chars, we
        check here to make sure we don't move the pointer past sizeof(buf) */
     if (strlen(buf) >= 1023)
-	G_fatal_error(_("One coordinate pair per line, please"));
+        G_fatal_error(_("One coordinate pair per line, please"));
     b = buf;
     w1 = word1;
     w2 = word2;
     while (*b == ' ' || *b == '\t' || *b == ',')
-	*blank1++ = *b++;
+        *blank1++ = *b++;
     *blank1 = 0;
     while (*b != '\n' && *b != ' ' && *b != '\t' && *b != ',')
-	*word1++ = *b++;
+        *word1++ = *b++;
     *word1 = 0;
     string_size = strlen(w1);
     G_debug(5, "strlen w1=%d  [%s]", string_size, w1);
     if (string_size > 255)
-	*blank2++ = *b++;
+        *blank2++ = *b++;
     *blank2 = 0;
-	*word2++ = *b++;
+        *word2++ = *b++;
     *word2 = 0;
     string_size = strlen(w2);
     G_debug(5, "strlen w2=%d  [%s]", string_size, w2);
     /* bug? really = and not ==? */
     /* not a bug: we are filling "rest" with the remaining fgets buffer.
@@ -65,7 +65,7 @@
     while ((*rest++ = *b++)) ;
     if (isatty(0) && strcmp("end", w1) == 0 && *w2 == 0)
-	return 0;
+        return 0;
     return 1;
Modified: grass-addons/grass7/raster3d/r3.profile/local_proto.h
--- grass-addons/grass7/raster3d/r3.profile/local_proto.h	2016-09-19 01:27:53 UTC (rev 69520)
+++ grass-addons/grass7/raster3d/r3.profile/local_proto.h	2016-09-19 01:32:08 UTC (rev 69521)
@@ -7,11 +7,11 @@
 /* main.c */
 int do_profile(double, double, double, double, int, double, int, int,
-	       FILE *, char *, const char *, double);
+               FILE *, char *, const char *, double);
 /* read_rast.c */
 int read_rast(double, double, double, int, int, RASTER_MAP_TYPE, FILE *,
-	      char *);
+              char *);
 /* input.c */
 int input(char *, char *, char *, char *, char *, FILE *);
Modified: grass-addons/grass7/raster3d/r3.profile/main.c
--- grass-addons/grass7/raster3d/r3.profile/main.c	2016-09-19 01:27:53 UTC (rev 69520)
+++ grass-addons/grass7/raster3d/r3.profile/main.c	2016-09-19 01:32:08 UTC (rev 69521)
@@ -40,8 +40,9 @@
     struct Cell_head window;
     struct
-	struct Option *opt1, *profile, *res, *output, *null_str, *coord_file, *units;
-	struct Flag *g, *c, *m;
+        struct Option *opt1, *profile, *res, *output, *null_str, *coord_file,
+            *units;
+        struct Flag *g, *c, *m;
     parm;
     struct GModule *module;
@@ -53,7 +54,7 @@
     G_add_keyword(_("raster"));
     G_add_keyword(_("profile"));
     module->description =
-	_("Outputs the raster map layer values lying on user-defined line(s).");
+        _("Outputs the raster map layer values lying on user-defined line(s).");
     parm.opt1 = G_define_standard_option(G_OPT_R_INPUT);
@@ -61,7 +62,7 @@
     parm.output->required = NO;
     parm.output->answer = "-";
     parm.output->description =
-	_("Name of file for output (use output=- for stdout)");
+        _("Name of file for output (use output=- for stdout)");
     parm.profile = G_define_standard_option(G_OPT_M_COORDS);
     parm.profile->required = NO;
@@ -72,17 +73,17 @@
     parm.coord_file->key = "file";
     parm.coord_file->required = NO;
     parm.coord_file->label =
-	_("Name of input file containing coordinate pairs");
+        _("Name of input file containing coordinate pairs");
     parm.coord_file->description =
-	_("Use instead of the 'coordinates' option. "
-	  "\"-\" reads from stdin.");
+        _("Use instead of the 'coordinates' option. "
+          "\"-\" reads from stdin.");
     parm.res = G_define_option();
     parm.res->key = "resolution";
     parm.res->type = TYPE_DOUBLE;
     parm.res->required = NO;
     parm.res->description =
-	_("Resolution along profile (default = current region resolution)");
+        _("Resolution along profile (default = current region resolution)");
     parm.null_str = G_define_standard_option(G_OPT_M_NULL_VALUE);
     parm.null_str->answer = "*";
@@ -90,32 +91,33 @@
     parm.g = G_define_flag();
     parm.g->key = 'g';
     parm.g->description =
-	_("Output easting and northing in first two columns of four column output");
+        _("Output easting and northing in first two columns of four column output");
     parm.c = G_define_flag();
     parm.c->key = 'c';
     parm.c->description =
-	_("Output RRR:GGG:BBB color values for each profile point");
+        _("Output RRR:GGG:BBB color values for each profile point");
     parm.units = G_define_standard_option(G_OPT_M_UNITS);
     parm.units->options = "meters,kilometers,feet,miles";
     parm.units->label = parm.units->description;
-    parm.units->description = _("If units are not specified, current location units are used. "
-                                "Meters are used by default in geographic (latlon) locations.");
+    parm.units->description =
+        _("If units are not specified, current location units are used. "
+          "Meters are used by default in geographic (latlon) locations.");
     if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
+        exit(EXIT_FAILURE);
     clr = 0;
     if (parm.c->answer)
-	clr = 1;		/* color output */
+        clr = 1;                /* color output */
     null_string = parm.null_str->answer;
     if ((parm.profile->answer && parm.coord_file->answer) ||
-	(!parm.profile->answer && !parm.coord_file->answer))
-	G_fatal_error(_("Either use profile option or coordinate_file "
-			" option, but not both"));
+        (!parm.profile->answer && !parm.coord_file->answer))
+        G_fatal_error(_("Either use profile option or coordinate_file "
+                        " option, but not both"));
     G_get_window(&window);
     projection = G_projection();
@@ -130,7 +132,7 @@
     else if (projection == PROJECTION_LL) {
         factor = 1;
         unit = "meters";
     else {
         /* get conversion factor to current units */
         unit = G_database_unit_name(1);
@@ -138,14 +140,15 @@
     if (parm.res->answer) {
-	res = atof(parm.res->answer);
-	/* Catch bad resolution ? */
-	if (res <= 0)
-	    G_fatal_error(_("Illegal resolution %g [%s]"), res / factor, unit);
+        res = atof(parm.res->answer);
+        /* Catch bad resolution ? */
+        if (res <= 0)
+            G_fatal_error(_("Illegal resolution %g [%s]"), res / factor,
+                          unit);
     else {
-	/* Do average of EW and NS res */
-	res = (window.ew_res + window.ns_res) / 2;
+        /* Do average of EW and NS res */
+        res = (window.ew_res + window.ns_res) / 2;
     G_message(_("Using resolution: %g [%s]"), res / factor, unit);
@@ -156,23 +159,23 @@
     /* Get Input Name */
     name = parm.opt1->answer;
     if (parm.g->answer)
-	coords = 1;
+        coords = 1;
     /* Open Raster File */
     fd = Rast_open_old(name, "");
     /* initialize color structure */
     if (clr)
-	Rast_read_colors(name, "", &colors);
+        Rast_read_colors(name, "", &colors);
     /* Open ASCII file for output or stdout */
     outfile = parm.output->answer;
     if ((strcmp("-", outfile)) == 0) {
-	fp = stdout;
+        fp = stdout;
     else if (NULL == (fp = fopen(outfile, "w")))
-	G_fatal_error(_("Unable to open file <%s>"), outfile);
+        G_fatal_error(_("Unable to open file <%s>"), outfile);
     /* Get Raster Type */
     data_type = Rast_get_map_type(fd);
@@ -181,92 +184,93 @@
     /* Show message giving output format */
     G_message(_("Output columns:"));
     if (coords == 1)
-	sprintf(formatbuff,
-		_("Easting, Northing, Along track dist. [%s], Elevation"), unit);
+        sprintf(formatbuff,
+                _("Easting, Northing, Along track dist. [%s], Elevation"),
+                unit);
     else
-	sprintf(formatbuff, _("Along track dist. [%s], Elevation"), unit);
+        sprintf(formatbuff, _("Along track dist. [%s], Elevation"), unit);
     if (clr)
-	strcat(formatbuff, _(" RGB color"));
+        strcat(formatbuff, _(" RGB color"));
     G_message("%s", formatbuff);
     /* Get Profile Start Coords */
     if (parm.coord_file->answer) {
-	if (strcmp("-", parm.coord_file->answer) == 0)
-	    coor_fp = stdin;
-	else
-	    coor_fp = fopen(parm.coord_file->answer, "r");
+        if (strcmp("-", parm.coord_file->answer) == 0)
+            coor_fp = stdin;
+        else
+            coor_fp = fopen(parm.coord_file->answer, "r");
-	if (coor_fp == NULL)
-	    G_fatal_error(_("Could not open <%s>"), parm.coord_file->answer);
+        if (coor_fp == NULL)
+            G_fatal_error(_("Could not open <%s>"), parm.coord_file->answer);
-	for (n = 1; input(b1, ebuf, b2, nbuf, label, coor_fp); n++) {
-	    G_debug(4, "stdin line %d: ebuf=[%s]  nbuf=[%s]", n, ebuf, nbuf);
-	    if (!G_scan_easting(ebuf, &e2, G_projection()) ||
-		!G_scan_northing(nbuf, &n2, G_projection()))
-		G_fatal_error(_("Invalid coordinates %s %s"), ebuf, nbuf);
+        for (n = 1; input(b1, ebuf, b2, nbuf, label, coor_fp); n++) {
+            G_debug(4, "stdin line %d: ebuf=[%s]  nbuf=[%s]", n, ebuf, nbuf);
+            if (!G_scan_easting(ebuf, &e2, G_projection()) ||
+                !G_scan_northing(nbuf, &n2, G_projection()))
+                G_fatal_error(_("Invalid coordinates %s %s"), ebuf, nbuf);
-	    if (havefirst)
-		do_profile(e1, e2, n1, n2, coords, res, fd, data_type,
-			   fp, null_string, unit, factor);
-	    e1 = e2;
-	    n1 = n2;
-	    havefirst = TRUE;
+            if (havefirst)
+                do_profile(e1, e2, n1, n2, coords, res, fd, data_type,
+                           fp, null_string, unit, factor);
+            e1 = e2;
+            n1 = n2;
+            havefirst = TRUE;
-	if (coor_fp != stdin)
-	    fclose(coor_fp);
+        if (coor_fp != stdin)
+            fclose(coor_fp);
     else {
-	/* Coords given on the Command Line using the profile= option */
-	for (i = 0; parm.profile->answers[i]; i += 2) {
-	    /* Test for number coordinate pairs */
-	    k = i;
+        /* Coords given on the Command Line using the profile= option */
+        for (i = 0; parm.profile->answers[i]; i += 2) {
+            /* Test for number coordinate pairs */
+            k = i;
-	if (k == 0) {
-	    /* Only one coordinate pair supplied */
-	    G_scan_easting(parm.profile->answers[0], &e1, G_projection());
-	    G_scan_northing(parm.profile->answers[1], &n1, G_projection());
-	    e2 = e1;
-	    n2 = n1;
+        if (k == 0) {
+            /* Only one coordinate pair supplied */
+            G_scan_easting(parm.profile->answers[0], &e1, G_projection());
+            G_scan_northing(parm.profile->answers[1], &n1, G_projection());
+            e2 = e1;
+            n2 = n1;
-	    /* Get profile info */
-	    do_profile(e1, e2, n1, n2, coords, res, fd, data_type, fp,
-		       null_string, unit, factor);
-	else {
-	    for (i = 0; i <= k - 2; i += 2) {
-		G_scan_easting(parm.profile->answers[i], &e1, G_projection());
-		G_scan_northing(parm.profile->answers[i + 1], &n1,
-				G_projection());
-		G_scan_easting(parm.profile->answers[i + 2], &e2,
-			       G_projection());
-		G_scan_northing(parm.profile->answers[i + 3], &n2,
-				G_projection());
+            /* Get profile info */
+            do_profile(e1, e2, n1, n2, coords, res, fd, data_type, fp,
+                       null_string, unit, factor);
+        else {
+            for (i = 0; i <= k - 2; i += 2) {
+                G_scan_easting(parm.profile->answers[i], &e1, G_projection());
+                G_scan_northing(parm.profile->answers[i + 1], &n1,
+                                G_projection());
+                G_scan_easting(parm.profile->answers[i + 2], &e2,
+                               G_projection());
+                G_scan_northing(parm.profile->answers[i + 3], &n2,
+                                G_projection());
     Rast_close(fd);
     fclose(fp);
     if (clr)
-	Rast_free_colors(&colors);
+        Rast_free_colors(&colors);
     exit(EXIT_SUCCESS);
-}				/* Done with main */
+}                               /* Done with main */
 /* Calculate the Profile Now */
 /* Establish parameters */
 int do_profile(double e1, double e2, double n1, double n2,
-	       int coords, double res, int fd, int data_type, FILE * fp,
-	       char *null_string, const char *unit, double factor)
+               int coords, double res, int fd, int data_type, FILE * fp,
+               char *null_string, const char *unit, double factor)
     double rows, cols, LEN;
     double Y, X, k;
@@ -278,14 +282,15 @@
     G_message(_("Approx. transect length: %f [%s]"), LEN / factor, unit);
     if (!G_point_in_region(e2, n2))
-	G_warning(_("Endpoint coordinates are outside of current region settings"));
+        G_warning(_("Endpoint coordinates are outside of current region settings"));
     /* Calculate Azimuth of Line */
     if (rows == 0 && cols == 0) {
-	/* Special case for no movement */
-	e = e1;
-	n = n1;
-	read_rast(e, n, dist / factor, fd, coords, data_type, fp, null_string);
+        /* Special case for no movement */
+        e = e1;
+        n = n1;
+        read_rast(e, n, dist / factor, fd, coords, data_type, fp,
+                  null_string);
     k = res / hypot(rows, cols);
@@ -301,43 +306,46 @@
     if (rows >= 0 && cols < 0) {
-	/* SE Quad or due east */
-	for (e = e1, n = n1; e < e2 || n > n2; e += X, n -= Y) {
-	    /* d+=res; */
-	    dist += G_distance(e - X, n + Y, e, n);
+        /* SE Quad or due east */
+        for (e = e1, n = n1; e < e2 || n > n2; e += X, n -= Y) {
+                      null_string);
+            /* d+=res; */
+            dist += G_distance(e - X, n + Y, e, n);
     if (rows < 0 && cols <= 0) {
-	/* NE Quad  or due north */
-	for (e = e1, n = n1; e < e2 || n < n2; e += X, n += Y) {
-	    /* d+=res; */
-	    dist += G_distance(e - X, n - Y, e, n);
+        /* NE Quad  or due north */
+        for (e = e1, n = n1; e < e2 || n < n2; e += X, n += Y) {
+                      null_string);
+            /* d+=res; */
+            dist += G_distance(e - X, n - Y, e, n);
     if (rows > 0 && cols >= 0) {
-	/* SW Quad or due south */
-	for (e = e1, n = n1; e > e2 || n > n2; e -= X, n -= Y) {
-	    /* d+=res; */
-	    dist += G_distance(e + X, n + Y, e, n);
+        /* SW Quad or due south */
+        for (e = e1, n = n1; e > e2 || n > n2; e -= X, n -= Y) {
+                      null_string);
+            /* d+=res; */
+            dist += G_distance(e + X, n + Y, e, n);
     if (rows <= 0 && cols > 0) {
-	/* NW Quad  or due west */
-	for (e = e1, n = n1; e > e2 || n < n2; e -= X, n += Y) {
-	    /* d+=res; */
-	    dist += G_distance(e + X, n - Y, e, n);
+        /* NW Quad  or due west */
+        for (e = e1, n = n1; e > e2 || n < n2; e -= X, n += Y) {
+                      null_string);
+            /* d+=res; */
+            dist += G_distance(e + X, n - Y, e, n);
      * return dist;
     return 0;
-}				/* done with do_profile */
+}                               /* done with do_profile */
Modified: grass-addons/grass7/raster3d/r3.profile/read_rast.c
--- grass-addons/grass7/raster3d/r3.profile/read_rast.c	2016-09-19 01:27:53 UTC (rev 69520)
+++ grass-addons/grass7/raster3d/r3.profile/read_rast.c	2016-09-19 01:32:08 UTC (rev 69521)
@@ -13,7 +13,7 @@
 int read_rast(double east, double north, double dist, int fd, int coords,
-	      RASTER_MAP_TYPE data_type, FILE * fp, char *null_string)
+              RASTER_MAP_TYPE data_type, FILE * fp, char *null_string)
     static DCELL *dcell;
     static int cur_row = -1;
@@ -24,11 +24,11 @@
     int outofbounds = FALSE;
     if (!dcell) {
-	Rast_set_c_null_value(&nullcell, 1);
-	dcell = Rast_allocate_d_buf();
-	G_get_window(&window);
-	nrows = window.rows;
-	ncols = window.cols;
+        Rast_set_c_null_value(&nullcell, 1);
+        dcell = Rast_allocate_d_buf();
+        G_get_window(&window);
+        nrows = window.rows;
+        ncols = window.cols;
     row = (window.north - north) / window.ns_res;
@@ -36,38 +36,37 @@
     G_debug(4, "row=%d:%d  col=%d:%d", row, nrows, col, ncols);
     if ((row < 0) || (row >= nrows) || (col < 0) || (col >= ncols))
-	outofbounds = TRUE;
+        outofbounds = TRUE;
     if (!outofbounds) {
-	if (row != cur_row)
-	    Rast_get_d_row(fd, dcell, row);
-	cur_row = row;
+        if (row != cur_row)
+            Rast_get_d_row(fd, dcell, row);
+        cur_row = row;
     if (coords)
-	fprintf(fp, "%f %f", east, north);
+        fprintf(fp, "%f %f", east, north);
     fprintf(fp, " %f", dist);
     if (outofbounds || Rast_is_d_null_value(&dcell[col]))
-	fprintf(fp, " %s", null_string);
+        fprintf(fp, " %s", null_string);
     else {
-	if (data_type == CELL_TYPE)
-	    fprintf(fp, " %d", (int) dcell[col]);
-	else
-	    fprintf(fp, " %f", dcell[col]);
+        if (data_type == CELL_TYPE)
+            fprintf(fp, " %d", (int)dcell[col]);
+        else
+            fprintf(fp, " %f", dcell[col]);
     if (clr) {
-	int red, green, blue;
+        int red, green, blue;
-	if (outofbounds)
-	    Rast_get_c_color(&nullcell, &red, &green, &blue, &colors);
-	else
-	    Rast_get_d_color(&dcell[col], &red, &green, &blue,
-				 &colors);
+        if (outofbounds)
+            Rast_get_c_color(&nullcell, &red, &green, &blue, &colors);
+        else
+            Rast_get_d_color(&dcell[col], &red, &green, &blue, &colors);
-	fprintf(fp, " %03d:%03d:%03d", red, green, blue);
+        fprintf(fp, " %03d:%03d:%03d", red, green, blue);
     fprintf(fp, "\n");
