[GRASS-SVN] r69527 - grass-addons/grass7/vector/v.in.pygbif
Mon Sep 19 00:45:27 PDT 2016
Author: sbl
Date: 2016-09-19 00:45:27 -0700 (Mon, 19 Sep 2016)
New Revision: 69527
   grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html
using html validator helps
Modified: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html
--- grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html	2016-09-19 07:35:01 UTC (rev 69526)
+++ grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html	2016-09-19 07:45:27 UTC (rev 69527)
@@ -1,11 +1,10 @@
 <h2>DESCRIPTION:</h2>
 <p>The module <em>v.in.pygbif</em> is a wrapper around the
-<a href=http://pygbif.readthedocs.io/en/latest/index.html>pygbif</a> package.<br>
-Thus, <em>pygbif</em> is a dependency of v.in.pygbif. pygbif can be installed like this:<br>
+<a href="http://pygbif.readthedocs.io/en/latest/index.html">pygbif</a> package.<br>
+Thus, <em>pygbif</em> is a dependency of v.in.pygbif. pygbif can be installed like this:</p>
 <div class="code"><pre>pip install pygbif</pre></div>
-Through <em>pygbif</em>, the module allows to download data from the Global Biodiversity
-Information Facility (<a href=www.gbif.org>GBIF</a>) using different search ⁄ filter
+<p>Through <em>pygbif</em>, the module allows to download data from the Global Biodiversity
+Information Facility (<a href="www.gbif.org">GBIF</a>) using different search ⁄ filter
 criteria.</p>
 <p>Since some of the Darwin Core attribute columns represent SQL key-words, the prefix "g_"
 was added to all attribute columns. The names of taxa provided at input to the search are
@@ -19,7 +18,7 @@
 computational region.</p>
 <p>Terminology in v.in.pygbif is oriented on the <em>Darwin Core</em> standard:
-<a href=http://rs.tdwg.org/dwc/> http://rs.tdwg.org/dwc/</a>.</p>
+<a href="http://rs.tdwg.org/dwc/"> http://rs.tdwg.org/dwc/</a>.</p>
 <p>Please note that the GBIF Search API has a hard limit of 200,000 occurrences
 per request. If you want to fetch more records, either subivide your area of
@@ -57,11 +56,11 @@
 <div id="references">
 <h2>REFERENCES:</h2>
 http://pygbif.readthedocs.io/en/latest/index.html</a><br>
-<a href=http://www.gbif.org>
+<a href="http://www.gbif.org">
 http://www.gbif.org</a><br>
-<a href=http://www.gbif.org/developer/summary>
+<a href="http://www.gbif.org/developer/summary">
 http://www.gbif.org/developer/summary</a>
 </div>
