[GRASS-SVN] r69535 - in grass/trunk/vector/v.info: . testsuite
Mon Sep 19 09:42:28 PDT 2016
Author: huhabla
Date: 2016-09-19 09:42:28 -0700 (Mon, 19 Sep 2016)
New Revision: 69535
Added:
   grass/trunk/vector/v.info/testsuite/
   grass/trunk/vector/v.info/testsuite/test_vinfo.py
   grass/trunk/vector/v.info/local_proto.h
   grass/trunk/vector/v.info/main.c
   grass/trunk/vector/v.info/print.c
vector modules: Added layer specific database information to v.info extended metadata flag
Modified: grass/trunk/vector/v.info/local_proto.h
--- grass/trunk/vector/v.info/local_proto.h	2016-09-19 14:22:39 UTC (rev 69534)
+++ grass/trunk/vector/v.info/local_proto.h	2016-09-19 16:42:28 UTC (rev 69535)
@@ -10,8 +10,8 @@
 /* parse.c */
 void parse_args(int, char**,
-		char **, char**,
-		int *, int *, int *);
+                char **, char**,
+                int *, int *, int *);
 /* print.c */
 void format_double(double, char *);
@@ -19,4 +19,4 @@
 void print_topo(const struct Map_info *);
 void print_columns(const struct Map_info *, const char *, const char *);
 void print_info(const struct Map_info *);
-void print_shell(const struct Map_info *);
+void print_shell(const struct Map_info *, const char *);
Modified: grass/trunk/vector/v.info/main.c
--- grass/trunk/vector/v.info/main.c	2016-09-19 14:22:39 UTC (rev 69534)
+++ grass/trunk/vector/v.info/main.c	2016-09-19 16:42:28 UTC (rev 69535)
@@ -82,7 +82,7 @@
     if (shell_flag & SHELL_BASIC) {
-	print_shell(&Map);
+	print_shell(&Map, field_opt);
     if (shell_flag & SHELL_REGION) {
 	print_region(&Map);
Modified: grass/trunk/vector/v.info/print.c
--- grass/trunk/vector/v.info/print.c	2016-09-19 14:22:39 UTC (rev 69534)
+++ grass/trunk/vector/v.info/print.c	2016-09-19 16:42:28 UTC (rev 69535)
@@ -165,12 +165,12 @@
     db_shutdown_driver(driver);
-void print_shell(const struct Map_info *Map)
+void print_shell(const struct Map_info *Map, const char *field_opt)
     int map_type;
     int time_ok, first_time_ok, second_time_ok;
     char timebuff[256];
+    struct field_info *fi;
     struct TimeStamp ts;
     time_ok = first_time_ok = second_time_ok = FALSE;
@@ -263,6 +263,18 @@
     if (Vect_level(Map) > 0) {
         fprintf(stdout, "num_dblinks=%d\n",
                 Vect_get_num_dblinks(Map));
+        if (Vect_get_num_dblinks(Map) > 0) {
+            fi = Vect_get_field2(Map, field_opt);
+            if(fi != NULL) {
+                fprintf(stdout, "attribute_layer_number=%i\n",fi->number);
+                fprintf(stdout, "attribute_layer_name=%s\n",fi->name);
+                fprintf(stdout, "attribute_database=%s\n",fi->database);
+                fprintf(stdout, "attribute_database_driver=%s\n",fi->driver);
+                fprintf(stdout, "attribute_table=%s\n",fi->table);
+                fprintf(stdout, "attribute_primary_key=%s\n",fi->key);
     fprintf(stdout, "projection=%s\n",
Added: grass/trunk/vector/v.info/testsuite/test_vinfo.py
--- grass/trunk/vector/v.info/testsuite/test_vinfo.py	                        (rev 0)
+++ grass/trunk/vector/v.info/testsuite/test_vinfo.py	2016-09-19 16:42:28 UTC (rev 69535)
@@ -0,0 +1,137 @@
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+class TestVInfo(TestCase):
+    """Test the shell output of v.info that is not location/mapset or user dependent
+    test_vinfo_no_db = 'test_vinfo_no_db'
+    test_vinfo_with_db = 'test_vinfo_with_db'
+    test_vinfo_with_db_3d = 'test_vinfo_with_db_3d'
+    # All maps should be tested against these references
+    reference = dict(format="native", level=2,
+                     nodes=0, points=5, lines=0, boundaries=0,
+                     centroids=0, areas=0, islands=0, primitives=5,
+                     scale="1:1")
+    @classmethod
+    def setUpClass(cls):
+        """Generate some vector layer with attribute table, z coordinates
+        and timestamp
+        cls.runModule('v.random', output=cls.test_vinfo_no_db, npoints=5,
+                      zmin=0, zmax=100)
+        cls.runModule('v.random', output=cls.test_vinfo_with_db, npoints=5,
+                      zmin=0, zmax=100,
+                      column="elevation")
+        cls.runModule('v.random', output=cls.test_vinfo_with_db_3d, npoints=5,
+                      zmin=0, zmax=100,
+                      column="elevation",
+                      flags="z")
+        cls.runModule("v.timestamp", map=cls.test_vinfo_with_db_3d, date='15 jan 1994')
+    @classmethod
+    def tearDownClass(cls):
+        """Remove created maps
+        cls.runModule('g.remove', flags='f', type='vector',
+                      name=[cls.test_vinfo_no_db,
+                            cls.test_vinfo_with_db,
+                            cls.test_vinfo_with_db_3d])
+    def test_smoke(self):
+        """Simply test running the module with different parameters
+        self.assertModule('v.info', map=self.test_vinfo_with_db_3d)
+        self.assertModule('v.info', map=self.test_vinfo_with_db_3d, flags='e')
+        self.assertModule('v.info', map=self.test_vinfo_with_db_3d, flags='et')
+        self.assertModule('v.info', map=self.test_vinfo_with_db_3d, flags='tg')
+        self.assertModule('v.info', map=self.test_vinfo_with_db_3d, flags='t')
+        self.assertModule('v.info', map=self.test_vinfo_with_db_3d, flags='c')
+        self.assertModule('v.info', map=self.test_vinfo_with_db_3d, flags='h')
+    def test_common_references(self):
+        """Test all maps against the common references
+        self.assertModuleKeyValue('v.info', map=self.test_vinfo_no_db, flags='etg',
+                                  sep="=", precision=0.1,
+                                  reference=self.reference)
+        self.assertModuleKeyValue('v.info', map=self.test_vinfo_with_db, flags='etg',
+        self.assertModuleKeyValue('v.info', map=self.test_vinfo_with_db_3d, flags='etg',
+    def test_info_no_db(self):
+        """Test the simple vector map
+                                  reference=dict(name=self.test_vinfo_no_db,
+                                                 map3d=0,
+                                                 num_dblinks=0,
+                                                 bottom=0.0,
+                                                 top=0.0))
+    def test_info_with_db(self):
+        """Test the vector map with database
+                                  sep="=", precision=0.1, layer="1",
+                                  reference=dict(name=self.test_vinfo_with_db,
+                                                 num_dblinks=1,
+                                                 attribute_layer_name=self.test_vinfo_with_db,
+                                                 attribute_layer_number=1,
+                                                 attribute_database_driver="sqlite",
+                                                 attribute_table=self.test_vinfo_with_db,
+                                                 attribute_primary_key="cat",
+                                                 timestamp="none",
+                                                 map3d=0,
+                                                 bottom=0.0,
+                                                 top=0.0))
+    def test_info_with_db_wrong_layer(self):
+        """Test the vector map with database and set the wrong layer, the output should not contain attribute data
+                                  sep="=", precision=0.1, layer="2",
+                                                 num_dblinks=1,
+                                                 timestamp="none",
+                                                 map3d=0,
+                                                 bottom=0.0,
+                                                 top=0.0))
+    def test_info_with_db_3d(self):
+        """Test the vector map with database, z coordinates and timestamp
+                                  reference=dict(name=self.test_vinfo_with_db_3d,
+                                                 num_dblinks=1,
+                                                 attribute_layer_name=self.test_vinfo_with_db_3d,
+                                                 attribute_table=self.test_vinfo_with_db_3d,
+                                                 map3d=1, timestamp='15 Jan 1994'))
+    def test_database_table(self):
+        """Test the database table column and type of the two vector maps with attribute data
+        self.assertModuleKeyValue('v.info', map=self.test_vinfo_with_db, flags='c',
+                                  sep="|", precision=0.1,
+                                  reference={"INTEGER":"cat", "DOUBLE PRECISION":"elevation"})
+if __name__ == '__main__':
+    test()
