[GRASS-SVN] r69557 - grass/branches/releasebranch_7_2/lib/vector/vedit
svn_grass at osgeo.org
Fri Sep 23 05:57:42 PDT 2016
Author: mmetz
Date: 2016-09-23 05:57:41 -0700 (Fri, 23 Sep 2016)
New Revision: 69557
grass/branches/releasebranch_7_2/lib/vector/vedit/merge.c
v.edit tool=merge: skip zero length lines; a single point is not a polygon (backport trunk r69556)
Modified: grass/branches/releasebranch_7_2/lib/vector/vedit/merge.c
--- grass/branches/releasebranch_7_2/lib/vector/vedit/merge.c 2016-09-23 12:57:02 UTC (rev 69556)
+++ grass/branches/releasebranch_7_2/lib/vector/vedit/merge.c 2016-09-23 12:57:41 UTC (rev 69557)
@@ -64,6 +64,8 @@
return 0;
+ G_debug(1, "Vedit_merge_lines(): merging %d lines", List->n_values);
Points1 = Vect_new_line_struct();
Cats1 = Vect_new_cats_struct();
Points2 = Vect_new_line_struct();
@@ -86,6 +88,14 @@
if (!(type1 & GV_LINES))
continue;
+ /* remove duplicate points */
+ Vect_line_prune(Points1);
+ if (Points1->n_points == 1) {
+ G_debug(3, "Vedit_merge_lines(): skipping zero length line");
+ continue;
Vect_reset_line(Points);
for (i = 0; i < Points1->n_points; i += Points1->n_points - 1) {
@@ -110,8 +120,9 @@
* merge lines only if two lines found in the region
* i.e. the current line and an adjacent line
- if (1 < Vect_select_lines_by_polygon(Map, Points2, 0, NULL,
- GV_LINES, List_in_box)) {
+ if (0 < Vect_find_line_list(Map, Points1->x[i], Points1->y[i],
+ Points1->z[i], GV_LINES, 0, 0,
+ NULL, List_in_box)) {
do_merge = 1;
line2 = -1;
for (j = 0; do_merge && j < List->n_values; j++) {
