[GRASS-SVN] r69560 - grass/branches/releasebranch_7_0/vector/v.out.ogr
svn_grass at osgeo.org
Fri Sep 23 06:03:12 PDT 2016
Author: mmetz
Date: 2016-09-23 06:03:12 -0700 (Fri, 23 Sep 2016)
New Revision: 69560
grass/branches/releasebranch_7_0/vector/v.out.ogr/export_areas.c
v.out.ogr: fix export areas without category as one multi-feature (backport trunk r69551)
Modified: grass/branches/releasebranch_7_0/vector/v.out.ogr/export_areas.c
--- grass/branches/releasebranch_7_0/vector/v.out.ogr/export_areas.c 2016-09-23 13:02:50 UTC (rev 69559)
+++ grass/branches/releasebranch_7_0/vector/v.out.ogr/export_areas.c 2016-09-23 13:03:12 UTC (rev 69560)
@@ -216,18 +216,10 @@
/* check lines without category, if -c flag is given write them as
* one multi-feature */
Ogr_geometry = OGR_G_CreateGeometry(wkbtype);
- /* TODO: if donocat, also export areas without centroid
- * -> loop over areas, not centroids */
- Vect_rewind(In);
- Vect_set_constraint_type(In, GV_CENTROID);
- while(TRUE) {
- type = Vect_read_next_line(In, NULL, Cats);
- if (type < 0)
- break;
- /* get centroid's category */
+ for (area = 1; area <= Vect_get_num_areas(In); area++) {
+ /* get areas's category */
+ Vect_get_area_cats(In, area, Cats);
Vect_cat_get(Cats, field, &cat);
if (cat > 0)
continue; /* skip features with category */
@@ -237,12 +229,6 @@
* not labeled */
- /* find corresponding area */
- line = Vect_get_next_line_id(In);
- area = Vect_get_centroid_area(In, line);
- if (area <= 0)
- continue;
/* create polygon from area */
Ogr_geometry_part = create_polygon(In, area, Points);
