[GRASS-SVN] r69571 - grass/branches/releasebranch_7_0/lib/vector/vedit
svn_grass at osgeo.org
Sat Sep 24 13:23:27 PDT 2016
Author: mmetz
Date: 2016-09-24 13:23:27 -0700 (Sat, 24 Sep 2016)
New Revision: 69571
grass/branches/releasebranch_7_0/lib/vector/vedit/merge.c
v.edit tool=merge: improve iteration over list of lines, handle zero-length lines (backport trunk r69569)
Modified: grass/branches/releasebranch_7_0/lib/vector/vedit/merge.c
--- grass/branches/releasebranch_7_0/lib/vector/vedit/merge.c 2016-09-24 20:23:08 UTC (rev 69570)
+++ grass/branches/releasebranch_7_0/lib/vector/vedit/merge.c 2016-09-24 20:23:27 UTC (rev 69571)
@@ -120,17 +120,33 @@
* merge lines only if two lines found in the region
* i.e. the current line and an adjacent line
+ /* NOTE
+ * - this merges two lines also if more than two lines are
+ * found in the region, but only two of these lines are
+ * in the List
+ * - this not only merges lines connected by end points
+ * but also any adjacent line with a mid point identical
+ * to one of the end points of the current line
if (0 < Vect_find_line_list(Map, Points1->x[i], Points1->y[i],
Points1->z[i], GV_LINES, 0, 0,
NULL, List_in_box)) {
do_merge = 1;
line2 = -1;
- for (j = 0; do_merge && j < List->n_values; j++) {
- if (List->value[j] == line1 ||
- !Vect_line_alive(Map, List->value[j]))
+ for (j = 0; do_merge && j < List_in_box->n_values; j++) {
+ if (List_in_box->value[j] == line1 ||
+ !Vect_line_alive(Map, List_in_box->value[j]))
continue;
- if (Vect_val_in_list(List_in_box, List->value[j])) {
+ if (Vect_val_in_list(List, List_in_box->value[j])) {
+ Vect_read_line(Map, Points2, Cats2, List_in_box->value[j]);
+ Vect_line_prune(Points2);
+ if (Points2->n_points == 1) {
+ line2 = List_in_box->value[j];
+ do_merge = 1;
+ break;
if (line2 > 0) {
/* three lines found
* selected lines will be not merged
@@ -138,7 +154,7 @@
do_merge = 0;
else {
- line2 = List->value[j];
@@ -173,7 +189,7 @@
nlines_merged++;
/* update number of lines */
- Vect_list_append(List, line);
+ G_ilist_add(List, line);
} /* for each line */
