[GRASS-SVN] r69573 - in grass-addons/grass7/raster3d: . r3.count.cats
svn_grass at osgeo.org
Sun Sep 25 19:53:55 PDT 2016
Author: wenzeslaus
Date: 2016-09-25 19:53:54 -0700 (Sun, 25 Sep 2016)
New Revision: 69573
Added:
grass-addons/grass7/raster3d/r3.count.cats/
grass-addons/grass7/raster3d/r3.count.cats/Makefile
grass-addons/grass7/raster3d/r3.count.cats/r3.count.cats.html
grass-addons/grass7/raster3d/r3.count.cats/r3.count.cats.py
grass-addons/grass7/raster3d/Makefile
r3.count.cats: count categories in a vertical column
Modified: grass-addons/grass7/raster3d/Makefile
--- grass-addons/grass7/raster3d/Makefile 2016-09-24 22:57:14 UTC (rev 69572)
+++ grass-addons/grass7/raster3d/Makefile 2016-09-26 02:53:54 UTC (rev 69573)
@@ -1,6 +1,7 @@
MODULE_TOPDIR = ..
SUBDIRS = \
+ r3.count.cats \
r3.profile \
r3.scatterplot \
r3.what
Added: grass-addons/grass7/raster3d/r3.count.cats/Makefile
--- grass-addons/grass7/raster3d/r3.count.cats/Makefile (rev 0)
+++ grass-addons/grass7/raster3d/r3.count.cats/Makefile 2016-09-26 02:53:54 UTC (rev 69573)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r3.count.cats
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster3d/r3.count.cats/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/raster3d/r3.count.cats/r3.count.cats.html
--- grass-addons/grass7/raster3d/r3.count.cats/r3.count.cats.html (rev 0)
+++ grass-addons/grass7/raster3d/r3.count.cats/r3.count.cats.html 2016-09-26 02:53:54 UTC (rev 69573)
@@ -0,0 +1,30 @@
+<h2>DESCRIPTION</h2>
+<em>r3.count.cats</em> iterates over whole numbers (categories, classes)
+in the 3D raster (considers values to be integers) and for each vertical
+column counts them in the given column.
+<p>
+The 3D raster map is considered to be integer, i.e. all values are
+converted to integer values with truncation. When some conversion
+is appropriate the <b>multiply</b> option can be used to scale
+the value before conversion. For example, if the values are percentages
+with values between 0 and 1, value 100 can be used to obtain percentages
+between 0 and 100. The values will be then preserved with precision 1
+(decimal part is truncated).
+<h2>SEE ALSO</h2>
+<em>
+<a href="r3.to.rast.html">r3.to.rast</a>,
+<a href="r3.to.group.html">r3.to.group</a>,
+<a href="r3.what.html">r3.what</a>
+</em>
+<h2>AUTHORS</h2>
+Vaclav Petras, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a>
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/raster3d/r3.count.cats/r3.count.cats.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/raster3d/r3.count.cats/r3.count.cats.py
--- grass-addons/grass7/raster3d/r3.count.cats/r3.count.cats.py (rev 0)
+++ grass-addons/grass7/raster3d/r3.count.cats/r3.count.cats.py 2016-09-26 02:53:54 UTC (rev 69573)
@@ -0,0 +1,188 @@
+#!/usr/bin/env python
+# MODULE: r3.count.cats
+# AUTHOR(S): Vaclav Petras <wenzeslaus gmail com>
+# PURPOSE: Count categories in vertical direction
+# COPYRIGHT: (C) 2016 by Vaclav Petras, and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Count categories in vertical direction
+#% keyword: raster3d
+#% keyword: conversion
+#% keyword: raster
+#% keyword: categories
+#% keyword: voxel
+#%end
+#%option G_OPT_R3_INPUT
+#%end
+#%option G_OPT_R_BASENAME_OUTPUT
+#% required: yes
+#%end
+#% key: slices
+# TODO: required: no
+#% required: yes
+#% label: Basename for horizontal slices of the 3D raster
+#%end
+#%option
+#% key: multiply
+#% type: double
+#% required: no
+#% label: Value to multiply the raster values with
+#% description: Coefficient a in the equation y = ax + b
+#%end
+#%option
+#% key: add
+#% type: double
+#% required: no
+#% label: Value to add to the raster values
+#% description: Coefficient b in the equation y = ax + b
+#%end
+#%option
+#% key: size
+#% type: integer
+#% required: no
+#% label: Moving window size
+#% description: By default, only the given cell is considered
+#%end
+import grass.script as gs
+from grass.exceptions import CalledModuleError
+def check_raster3d_exists(name):
+ """Check if the raster map exists, call GRASS fatal otherwise"""
+ file_info = gs.find_file(name, element='grid3')
+ if not file_info['fullname']:
+ gs.fatal(_("3D Raster map <%s> not found") % name)
+def remove(maps):
+ """Remove raster maps"""
+ if maps:
+ gs.run_command('g.remove', flags='f', quiet=True,
+ type='rast', name=maps)
+def list_in_current_mapset(pattern):
+ """List names of raster maps in the current mapset"""
+ maps = gs.list_pairs(type='rast', mapset=".", pattern=pattern, flag='e')
+ maps = [name for name, mapset in maps]
+ return maps
+def basename_in_use_message(basename, rasters):
+ if len(rasters) > 3:
+ formatted = "%s,..." % ", ".join(rasters[:3])
+ else:
+ formatted = ", ".join(rasters)
+ gs.fatal(_("There are rasters with basename <%s> (%s), use"
+ " different name or overwrite") % (basename, formatted))
+# TODO: create name for slices if not provided
+def create_tmp_map_name(name):
+ return '{mod}_{pid}_{map_}_tmp'.format(mod='r3_reduce',
+ pid=os.getpid(),
+ map_=name)
+def main():
+ options, flags = gs.parser()
+ input_ = options['input']
+ output_basename = options['output']
+ slices_basename = options['slices']
+ check_raster3d_exists(input_)
+ size = None
+ if options['size']:
+ size = int(options['size'])
+ if size % 2 == 0:
+ gs.fatal(_("Please provide an odd number for the moving"
+ " window size, not %d") % size)
+ # options to be passed to r3.to.rast
+ additional_options = {}
+ for option in ['multiply', 'add']:
+ if options[option]:
+ additional_options[option] = options[option]
+ additional_options['type'] = 'CELL'
+ basename_sep = "_"
+ output_pattern = "%s%s[0-9]+" % (output_basename, basename_sep)
+ slices_pattern = "%s%s[0-9]+" % (slices_basename, basename_sep)
+ overwrite = gs.overwrite()
+ rasters = list_in_current_mapset(output_pattern)
+ if not overwrite and rasters:
+ basename_in_use_message(output_basename, rasters)
+ rasters = list_in_current_mapset(slices_pattern)
+ basename_in_use_message(slices_basename, rasters)
+ # TODO: list of categories would be better
+ info = gs.parse_command('r3.info', map=input_, flags='r')
+ map_min = int(float(info['min']))
+ map_max = int(float(info['max']))
+ gs.verbose(_("Categories from %d to %d") % (map_min, map_max))
+ rasters = []
+ try:
+ # TODO: we should switch to 3D region for the following computations?
+ # or should we require resolutions to be the same?
+ gs.run_command('r3.to.rast', input=input_, output=slices_basename,
+ **additional_options)
+ # it's clear we created just the ones in the current mapset
+ # and we need to make the command line as short as possible
+ if size:
+ base_expr = "int({m}[{a},{b}] == $num)"
+ size = int((size - 1) / 2) # window size to max index
+ expr_list = []
+ for raster in rasters:
+ for j in range(-size, size + 1):
+ for i in range(-size, size + 1):
+ expr_list.append(base_expr.format(
+ m=raster, a=i, b=j))
+ expr = " + ".join(expr_list)
+ expr = "{out}{sep}$num = {inp}".format(
+ out=output_basename, sep=basename_sep,
+ inp=expr)
+ else:
+ expr = "{out}{sep}$num = int({inp} == $num)".format(
+ inp=" == $num) + int(".join(rasters))
+ # TODO: define behavior when the map is empty or has just one class
+ try:
+ # TODO: this uses uncommitted experimental code for trunk
+ from grass.script.parallel import ModuleCallList, execute_by_module
+ call = ModuleCallList()
+ parallel = True
+ except ImportError:
+ call = gs # fall back to grass.script
+ parallel = False
+ for i in range(map_min, map_max + 1):
+ # TODO: parallelize here
+ call.mapcalc(expr, num=i)
+ if parallel:
+ execute_by_module(call, nprocs=4)
+ except CalledModuleError as error:
+ remove(rasters)
+ gs.fatal(_("Module %s failed. Check the above error messages.") %
+ error.cmd)
+if __name__ == "__main__":
+ main()
Property changes on: grass-addons/grass7/raster3d/r3.count.cats/r3.count.cats.py
+ text/x-python
+ native
