[GRASS-SVN] r69577 - in grass/trunk/lib/python/pygrass: . modules/interface
svn_grass at osgeo.org
Mon Sep 26 05:14:47 PDT 2016
Author: huhabla
Date: 2016-09-26 05:14:47 -0700 (Mon, 26 Sep 2016)
New Revision: 69577
grass/trunk/lib/python/pygrass/modules/interface/module.py
grass/trunk/lib/python/pygrass/utils.py
pygrass module: Documentation update
Modified: grass/trunk/lib/python/pygrass/modules/interface/module.py
--- grass/trunk/lib/python/pygrass/modules/interface/module.py 2016-09-26 11:59:33 UTC (rev 69576)
+++ grass/trunk/lib/python/pygrass/modules/interface/module.py 2016-09-26 12:14:47 UTC (rev 69577)
@@ -789,25 +789,30 @@
class MultiModule(object):
- """This class is designed to run a list of modules in serial in the provided order.
+ """This class is designed to run a list of modules in serial in the provided order
+ within a temporary region environment.
Module can be run in serial synchronously or asynchronously.
- Synchronously: When calling run() all modules will run in serial order
- until they are finished and then return. The modules can be accessed by
- calling get_modules().
- - Asynchronously: When calling run() all modules will run in serial order in a background process,
- run() will return after starting the modules without waiting for them to finish.
+ until they are finished, The run() method will return until all modules finished.
+ The modules objects can be accessed by calling get_modules() to check their return
+ values.
+ - Asynchronously: When calling run() all modules will run in serial order in a background process.
+ Method run() will return after starting the modules without waiting for them to finish.
The user must call the wait() method to wait for the modules to finish.
- Asynchonously called module can be optionally run in a temporary region.
+ Asynchronously called module can be optionally run in a temporary region
+ environment, hence invokeing g.region will not alter the current
+ region or the region of other MultiModule runs.
Note:
Modules run in asynchronous mode can only be accessed via the wait() method.
- The wait/( method will return all finished modules as list.
+ The wait() method will return all finished module objects as list.
- This class can be passed to the ParallelModuleQueue to run lists of modules in parallel. This
- is meaningful if region settings must be applied to each parallel module run.
+ Objects of this class can be passed to the ParallelModuleQueue to run serial stacks
+ of modules in parallel. This is meaningful if region settings must be applied
+ to each parallel module run.
>>> from grass.pygrass.modules import Module
>>> from grass.pygrass.modules import MultiModule
@@ -880,13 +885,17 @@
def __init__(self, module_list, sync=True, set_temp_region=False):
"""Constructor of the multi module class
- :param module_list: A list of pre-configured modules that should be run by this module
+ :param module_list: A list of pre-configured Module objects that should be run
:param sync: If set True the run() method will wait for all processes to finish -> synchronously run.
If set False, the run() method will return after starting the processes -> asynchronously run.
The wait() method must be called to finish the modules.
:param set_temp_region: Set a temporary region in which the modules should be run, hence
region settings in the process list will not affect the current
computation region.
+ Note:
+ This flag is only available in asynchronous mode!
:return:
self.module_list = module_list
@@ -909,7 +918,7 @@
return self.module_list
def run(self):
- """Start the modules in the list. if self.finished_ is set True
+ """Start the modules in the list. If self.finished_ is set True
this method will return after all processes finished.
If self.finish_ is set False, this method will return
@@ -917,7 +926,8 @@
In a background process, the processes in the list will
be run one after the another.
- :return: None in case of self.finish_ is True, Process object that runs the module otherwise
+ :return: None in case of self.finish_ is True,
+ otherwise a multiprocessing.Process object that invokes the modules
if self.finish_ is True:
@@ -937,7 +947,8 @@
return self.p
def wait(self):
- """Wait for all processes to finish. Call this method if finished was set False.
+ """Wait for all processes to finish. Call this method
+ in asynchronous mode, hence if finished was set False.
:return: The process list with finished processes to check their return states
@@ -949,8 +960,11 @@
def run_modules_in_temp_region(module_list, q):
- """Run the modules in a temporary region
+ """Run the modules in a temporary region environment
+ This function is the argument for multiprocessing.Process class
+ in the MultiModule asynchronous execution.
:param module_list: The list of modules to run in serial
:param q: The process queue to put the finished process list
@@ -969,6 +983,9 @@
def run_modules(module_list, q):
"""Run the modules
Modified: grass/trunk/lib/python/pygrass/utils.py
--- grass/trunk/lib/python/pygrass/utils.py 2016-09-26 11:59:33 UTC (rev 69576)
+++ grass/trunk/lib/python/pygrass/utils.py 2016-09-26 12:14:47 UTC (rev 69577)
@@ -254,7 +254,7 @@
(12.0, 1.0)
>>> remove('test_vect_2','vect')
- :param point: A VectorTopo object that contains points
+ :param poi_vector: A VectorTopo object that contains points
:param raster: raster object
:param str column: column name to update in the attrinute table,
if set to None a list of sampled values will be returned
