[GRASS-SVN] r69579 - in grass/trunk/gui/wxpython: core vdigit
svn_grass at osgeo.org
Mon Sep 26 08:02:43 PDT 2016
Author: annakrat
Date: 2016-09-26 08:02:42 -0700 (Mon, 26 Sep 2016)
New Revision: 69579
grass/trunk/gui/wxpython/core/settings.py
grass/trunk/gui/wxpython/vdigit/preferences.py
grass/trunk/gui/wxpython/vdigit/wxdisplay.py
wxGUI/vdigit: better fix for #2848
Modified: grass/trunk/gui/wxpython/core/settings.py
--- grass/trunk/gui/wxpython/core/settings.py 2016-09-26 14:05:26 UTC (rev 69578)
+++ grass/trunk/gui/wxpython/core/settings.py 2016-09-26 15:02:42 UTC (rev 69579)
@@ -394,7 +394,7 @@
# snapping
'snapping': {
'value': 10,
- 'units': 'screen pixels'
+ 'units': 0
'snapToVertex': {
'enabled': True
Modified: grass/trunk/gui/wxpython/vdigit/preferences.py
--- grass/trunk/gui/wxpython/vdigit/preferences.py 2016-09-26 14:05:26 UTC (rev 69578)
+++ grass/trunk/gui/wxpython/vdigit/preferences.py 2016-09-26 15:02:42 UTC (rev 69579)
@@ -217,11 +217,12 @@
self.snappingValue.Bind(wx.EVT_TEXT, self.OnChangeSnappingValue)
self.snappingUnit = wx.Choice(parent=panel, id=wx.ID_ANY, size=(
125, -1), choices=[_("screen pixels"), _("map units")])
- self.snappingUnit.SetStringSelection(
- UserSettings.Get(
- group='vdigit',
- key="snapping",
- subkey='units'))
+ try:
+ self.snappingUnit.SetSelection(UserSettings.Get(group='vdigit',
+ key="snapping",
+ subkey='units'))
+ except:
+ self.snappingUnit.SetSelection(0)
self.snappingUnit.Bind(wx.EVT_CHOICE, self.OnChangeSnappingUnits)
flexSizer.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
flexSizer.Add(
@@ -885,7 +886,7 @@
res = (region['nsres'] + region['ewres']) / 2.
threshold = self.digit.GetDisplay().GetThreshold(value=res)
else:
- if self.snappingUnit.GetStringSelection() == "map units":
+ if self.snappingUnit.GetSelection() == 1: # map units
threshold = value
else:
threshold = self.digit.GetDisplay().GetThreshold(value=value)
@@ -909,10 +910,10 @@
"""Snapping units change -> update static text
value = self.snappingValue.GetValue()
- units = self.snappingUnit.GetStringSelection()
+ units = self.snappingUnit.GetSelection()
threshold = self.digit.GetDisplay().GetThreshold(value=value, units=units)
- if units == "map units":
+ if units == 1: # map units
self.snappingInfo.SetLabel(
_("Snapping threshold is %(value).1f %(units)s") %
{'value': value, 'units': self.mapUnits})
@@ -1003,7 +1004,7 @@
UserSettings.Set(group='vdigit', key="snapping", subkey='value',
value=int(self.snappingValue.GetValue()))
UserSettings.Set(group='vdigit', key="snapping", subkey='units',
- value=self.snappingUnit.GetStringSelection())
+ value=self.snappingUnit.GetSelection())
UserSettings.Set(group='vdigit', key="snapToVertex", subkey='enabled',
value=self.snapVertex.IsChecked())
Modified: grass/trunk/gui/wxpython/vdigit/wxdisplay.py
--- grass/trunk/gui/wxpython/vdigit/wxdisplay.py 2016-09-26 14:05:26 UTC (rev 69578)
+++ grass/trunk/gui/wxpython/vdigit/wxdisplay.py 2016-09-26 15:02:42 UTC (rev 69579)
@@ -1099,7 +1099,7 @@
:param type: snapping mode (node, vertex)
:param value: threshold to be set up
- :param units: units (map, screen)
+ :param units: units (0 for screen pixels, 1 for map units)
:return: threshold value
@@ -1112,7 +1112,7 @@
if value < 0:
value = (self.region['nsres'] + self.region['ewres']) / 2.0
- if units == _("screen pixels"):
+ if units == 0:
# pixel -> cell
res = max(self.region['nsres'], self.region['ewres'])
return value * res
