[GRASS-SVN] r69589 - in grass/trunk: misc/m.cogo misc/m.measure misc/m.nviz.image scripts/m.proj
Tue Sep 27 13:08:58 PDT 2016
Author: wenzeslaus
Date: 2016-09-27 13:08:58 -0700 (Tue, 27 Sep 2016)
New Revision: 69589
   grass/trunk/misc/m.cogo/main.c
   grass/trunk/misc/m.measure/main.c
   grass/trunk/misc/m.nviz.image/main.c
   grass/trunk/scripts/m.proj/m.proj.py
doc: module class/family name as first keyword for m.nviz.image, at least 3 keywords per module for m.* modules
Modified: grass/trunk/misc/m.cogo/main.c
--- grass/trunk/misc/m.cogo/main.c	2016-09-27 19:59:11 UTC (rev 69588)
+++ grass/trunk/misc/m.cogo/main.c	2016-09-27 20:08:58 UTC (rev 69589)
@@ -224,6 +224,7 @@
     module = G_define_module();
     G_add_keyword(_("miscellaneous"));
     G_add_keyword(_("distance"));
+    G_add_keyword(_("polar"));
     module->label = _("A simple utility for converting bearing and "
 		      "distance measurements to coordinates and vice versa.");
     module->description = _("It assumes a cartesian coordinate system");
Modified: grass/trunk/misc/m.measure/main.c
--- grass/trunk/misc/m.measure/main.c	2016-09-27 19:59:11 UTC (rev 69588)
+++ grass/trunk/misc/m.measure/main.c	2016-09-27 20:08:58 UTC (rev 69589)
@@ -45,6 +45,8 @@
     module->description = _("Measures the lengths and areas of features.");
     G_add_keyword(_("measurement"));
+    G_add_keyword(_("distance"));
+    G_add_keyword(_("area"));
     coords = G_define_standard_option(G_OPT_M_COORDS);
     coords->required = YES;
Modified: grass/trunk/misc/m.nviz.image/main.c
--- grass/trunk/misc/m.nviz.image/main.c	2016-09-27 19:59:11 UTC (rev 69588)
+++ grass/trunk/misc/m.nviz.image/main.c	2016-09-27 20:08:58 UTC (rev 69589)
@@ -47,6 +47,7 @@
     G_gisinit(argv[0]);
+    G_add_keyword(_("miscellaneous"));
     G_add_keyword(_("visualization"));
     G_add_keyword(_("graphics"));
     G_add_keyword(_("raster"));
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py	2016-09-27 19:59:11 UTC (rev 69588)
+++ grass/trunk/scripts/m.proj/m.proj.py	2016-09-27 20:08:58 UTC (rev 69589)
@@ -29,6 +29,7 @@
 #% description: Converts coordinates from one projection to another (cs2cs frontend).
 #% keyword: miscellaneous
 #% keyword: projection
+#% keyword: transformation
 #%end
 #%option G_OPT_M_COORDS
 #% description: Input coordinates to reproject
