[GRASS-SVN] r69599 - grass/branches/releasebranch_7_0/lib/db/dbmi_base
Wed Sep 28 06:48:13 PDT 2016
Author: martinl
Date: 2016-09-28 06:48:13 -0700 (Wed, 28 Sep 2016)
New Revision: 69599
   grass/branches/releasebranch_7_0/lib/db/dbmi_base/login.c
db.connect: connection to remote database does not work (see #3167)
            (relbr72: merge r69597 from trunk)
Modified: grass/branches/releasebranch_7_0/lib/db/dbmi_base/login.c
--- grass/branches/releasebranch_7_0/lib/db/dbmi_base/login.c	2016-09-28 13:45:49 UTC (rev 69598)
+++ grass/branches/releasebranch_7_0/lib/db/dbmi_base/login.c	2016-09-28 13:48:13 UTC (rev 69599)
@@ -63,6 +63,10 @@
     int login_idx;
+    G_debug(3, "add_login(): drv='%s' db='%s' usr='%s' pwd='%s' host='%s', port='%s'",
+            dr, db, usr ? usr : "null", pwd ? pwd : "null", host ? host : "null",
+            port ? port : "null");
     if (login->n == login->a) {
 	login->a += 10;
 	login->data =
@@ -93,7 +97,8 @@
     int ret;
     const char *file;
     FILE *fd;
-    char buf[2001], dr[500], db[500], usr[500], pwd[500], host[500], port[500];
+    char buf[DB_SQL_MAX];
+    char **tokens;
     login->n = 0;
     file = login_filename();
@@ -114,19 +119,24 @@
     while (G_getl2(buf, 2000, fd)) {
 	G_chop(buf);
-	usr[0] = pwd[0] = host[0] = port[0] = '\0';
-	ret = sscanf(buf, "%[^|]|%[^|]|%[^|]|%[^|]|%[^|]|%[^\n]",
-                     dr, db, usr, pwd, host, port);
+        tokens = G_tokenize(buf, "|");
+        ret = G_number_of_tokens(tokens);
-	G_debug(3, "ret = %d : drv=[%s] db=[%s] usr=[%s] pwd=[%s] host=[%s], port=[%s]",
-		ret, dr, db, usr, pwd, host, port);
 	if (ret < 2) {
 	    G_warning(_("Login file (%s) corrupted (line: %s)"), file, buf);
+            G_free_tokens(tokens);
 	    continue;
-	add_login(login, dr, db, usr, pwd, host, port, -1);
+	add_login(login,
+                  tokens[0],                  /* driver */
+                  tokens[1],                  /* database */
+                  ret > 2 ? tokens[2] : NULL, /* user*/
+                  ret > 3 ? tokens[3] : NULL, /* password */
+                  ret > 4 ? tokens[4] : NULL, /* host */
+                  ret > 5 ? tokens[5] : NULL, /* port */
+                  -1);
     fclose(fd);
