[GRASS-SVN] r69614 - grass/trunk/display/d.linegraph
svn_grass at osgeo.org
Fri Sep 30 14:31:41 PDT 2016
Author: wenzeslaus
Date: 2016-09-30 14:31:41 -0700 (Fri, 30 Sep 2016)
New Revision: 69614
grass/trunk/display/d.linegraph/main.c
d.linegraph: add min and max for y
Modified: grass/trunk/display/d.linegraph/main.c
--- grass/trunk/display/d.linegraph/main.c 2016-09-30 19:25:55 UTC (rev 69613)
+++ grass/trunk/display/d.linegraph/main.c 2016-09-30 21:31:41 UTC (rev 69614)
@@ -8,7 +8,7 @@
* Huidae Cho <grass4u gmail.com>, Glynn Clements <glynn gclements.plus.com>,
* Hamish Bowman <hamish_b yahoo.com>
* PURPOSE:
- * COPYRIGHT: (C) 1999-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2016 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -110,6 +110,7 @@
struct Option *y_color_opt;
struct Option *title[3];
struct Option *t_color_opt;
+ struct Option *y_min, *y_max;
/* Initialize the GIS calls */
G_gisinit(argv[0]);
@@ -180,7 +181,18 @@
title[2]->required = NO;
title[2]->answer = "";
+ y_min = G_define_option();
+ y_min->key = "y_min";
+ y_min->description = _("Minimum value for Y axis");
+ y_min->type = TYPE_DOUBLE;
+ y_min->required = NO;
+ y_max = G_define_option();
+ y_max->key = "y_max";
+ y_max->description = _("Maximum value for Y axis");
+ y_max->type = TYPE_DOUBLE;
+ y_max->required = NO;
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -321,6 +333,11 @@
+ if (y_min->answer)
+ min_y = atof(y_min->answer);
+ if (y_max->answer)
+ max_y = atof(y_max->answer);
/* close all files */
for (i = 0; i <= num_y_files; i++)
