[GRASS-SVN] r70818 - in grass/trunk/scripts: d.correlate d.frame d.out.file d.polar d.rast.edit d.rast.leg d.redraw d.shade d.to.rast d.what.rast d.what.vect db.dropcolumn db.droptable db.in.ogr db.out.ogr db.test db.univar g.extension g.extension.all g.manual g.search.modules i.colors.enhance i.image.mosaic i.in.spotvgt i.oif i.pansharpen i.spectral i.tasscap m.proj r.blend r.buffer.lowmem r.fillnulls r.grow r.import r.in.aster r.in.srtm r.in.wms r.mask r.pack r.plane r.reclass.area r.rgb r.shade r.tileset r.unpack r3.in.xyz v.build.all v.centroids v.db.addcolumn v.db.addtable v.db.dropcolumn v.db.droprow v.db.droptable v.db.join v.db.reconnect.all v.db.renamecolumn v.db.univar v.db.update v.dissolve v.import v.in.e00 v.in.geonames v.in.lines v.in.mapgen v.in.wfs v.pack v.rast.stats v.report v.to.lines v.unpack v.what.strds
svn_grass at osgeo.org
Sat Apr 1 03:28:45 PDT 2017
Author: marisn
Date: 2017-04-01 03:28:45 -0700 (Sat, 01 Apr 2017)
New Revision: 70818
grass/trunk/scripts/d.correlate/d.correlate.py
grass/trunk/scripts/d.frame/d.frame.py
grass/trunk/scripts/d.out.file/d.out.file.py
grass/trunk/scripts/d.polar/d.polar.py
grass/trunk/scripts/d.rast.edit/d.rast.edit.py
grass/trunk/scripts/d.rast.leg/d.rast.leg.py
grass/trunk/scripts/d.redraw/d.redraw.py
grass/trunk/scripts/d.shade/d.shade.py
grass/trunk/scripts/d.to.rast/d.to.rast.py
grass/trunk/scripts/d.what.rast/d.what.rast.py
grass/trunk/scripts/d.what.vect/d.what.vect.py
grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py
grass/trunk/scripts/db.droptable/db.droptable.py
grass/trunk/scripts/db.in.ogr/db.in.ogr.py
grass/trunk/scripts/db.out.ogr/db.out.ogr.py
grass/trunk/scripts/db.test/db.test.py
grass/trunk/scripts/db.univar/db.univar.py
grass/trunk/scripts/g.extension.all/g.extension.all.py
grass/trunk/scripts/g.extension/g.extension.py
grass/trunk/scripts/g.manual/g.manual.py
grass/trunk/scripts/g.search.modules/g.search.modules.py
grass/trunk/scripts/i.colors.enhance/i.colors.enhance.py
grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
grass/trunk/scripts/i.oif/i.oif.py
grass/trunk/scripts/i.pansharpen/i.pansharpen.py
grass/trunk/scripts/i.spectral/i.spectral.py
grass/trunk/scripts/i.tasscap/i.tasscap.py
grass/trunk/scripts/m.proj/m.proj.py
grass/trunk/scripts/r.blend/r.blend.py
grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py
grass/trunk/scripts/r.fillnulls/r.fillnulls.py
grass/trunk/scripts/r.grow/r.grow.py
grass/trunk/scripts/r.import/r.import.py
grass/trunk/scripts/r.in.aster/r.in.aster.py
grass/trunk/scripts/r.in.srtm/r.in.srtm.py
grass/trunk/scripts/r.in.wms/r.in.wms.py
grass/trunk/scripts/r.in.wms/wms_base.py
grass/trunk/scripts/r.in.wms/wms_cap_parsers.py
grass/trunk/scripts/r.in.wms/wms_drv.py
grass/trunk/scripts/r.in.wms/wms_gdal_drv.py
grass/trunk/scripts/r.mask/r.mask.py
grass/trunk/scripts/r.pack/r.pack.py
grass/trunk/scripts/r.plane/r.plane.py
grass/trunk/scripts/r.reclass.area/r.reclass.area.py
grass/trunk/scripts/r.rgb/r.rgb.py
grass/trunk/scripts/r.shade/r.shade.py
grass/trunk/scripts/r.tileset/r.tileset.py
grass/trunk/scripts/r.unpack/r.unpack.py
grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
grass/trunk/scripts/v.build.all/v.build.all.py
grass/trunk/scripts/v.centroids/v.centroids.py
grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py
grass/trunk/scripts/v.db.addtable/v.db.addtable.py
grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py
grass/trunk/scripts/v.db.droprow/v.db.droprow.py
grass/trunk/scripts/v.db.droptable/v.db.droptable.py
grass/trunk/scripts/v.db.join/v.db.join.py
grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py
grass/trunk/scripts/v.db.univar/v.db.univar.py
grass/trunk/scripts/v.db.update/v.db.update.py
grass/trunk/scripts/v.dissolve/v.dissolve.py
grass/trunk/scripts/v.import/v.import.py
grass/trunk/scripts/v.in.e00/v.in.e00.py
grass/trunk/scripts/v.in.geonames/v.in.geonames.py
grass/trunk/scripts/v.in.lines/v.in.lines.py
grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
grass/trunk/scripts/v.in.wfs/v.in.wfs.py
grass/trunk/scripts/v.pack/v.pack.py
grass/trunk/scripts/v.rast.stats/v.rast.stats.py
grass/trunk/scripts/v.report/v.report.py
grass/trunk/scripts/v.to.lines/v.to.lines.py
grass/trunk/scripts/v.unpack/v.unpack.py
grass/trunk/scripts/v.what.strds/v.what.strds.py
Install gettext to Python script modules to use translated strings extracted by r70817
Modified: grass/trunk/scripts/d.correlate/d.correlate.py
--- grass/trunk/scripts/d.correlate/d.correlate.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/d.correlate/d.correlate.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -32,6 +32,11 @@
from grass.script import core as gcore
from grass.exceptions import CalledModuleError
+# i18N
+import gettext
+gettext.install('grassmods', os.path.join(os.getenv("GISBASE"), 'locale'))
def main():
layers = options['map'].split(',')
Modified: grass/trunk/scripts/d.frame/d.frame.py
--- grass/trunk/scripts/d.frame/d.frame.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/d.frame/d.frame.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -70,6 +70,10 @@
from grass.script.core import parser, read_command, fatal, debug, run_command, gisenv, warning, parse_command
+# i18N
+import gettext
# check if monitor is running
Modified: grass/trunk/scripts/d.out.file/d.out.file.py
--- grass/trunk/scripts/d.out.file/d.out.file.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/d.out.file/d.out.file.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -40,7 +40,12 @@
+# i18N
+import os
+import gettext
def main():
options, flags = gcore.parser()
gisenv = gcore.gisenv()
Modified: grass/trunk/scripts/d.polar/d.polar.py
--- grass/trunk/scripts/d.polar/d.polar.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/d.polar/d.polar.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -52,7 +52,11 @@
from grass.script.utils import try_remove, basename
+# i18N
+import gettext
def raster_map_required(name):
if not gcore.find_file(name, 'cell')['file']:
gcore.fatal(_("Raster map <%s> not found") % name)
Modified: grass/trunk/scripts/d.rast.edit/d.rast.edit.py
--- grass/trunk/scripts/d.rast.edit/d.rast.edit.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/d.rast.edit/d.rast.edit.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -79,6 +79,11 @@
import atexit
import grass.script as grass
+# i18N
+import os
+import gettext
try:
import wxversion
wxversion.select(['3.0', '2.8', '2.6'])
Modified: grass/trunk/scripts/d.rast.leg/d.rast.leg.py
--- grass/trunk/scripts/d.rast.leg/d.rast.leg.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/d.rast.leg/d.rast.leg.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -65,7 +65,11 @@
import os
+# i18N
+import gettext
def make_frame(f, b, t, l, r):
(fl, fr, ft, fb) = f
Modified: grass/trunk/scripts/d.redraw/d.redraw.py
--- grass/trunk/scripts/d.redraw/d.redraw.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/d.redraw/d.redraw.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -26,7 +26,11 @@
from grass.script import core as grass
from grass.script.utils import split
+# i18N
+import gettext
def main():
mon = grass.gisenv().get('MONITOR', None)
if not mon:
Modified: grass/trunk/scripts/d.shade/d.shade.py
--- grass/trunk/scripts/d.shade/d.shade.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/d.shade/d.shade.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -43,7 +43,12 @@
+# i18N
+import os
+import gettext
def main():
options, unused = gcore.parser()
Modified: grass/trunk/scripts/d.to.rast/d.to.rast.py
--- grass/trunk/scripts/d.to.rast/d.to.rast.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/d.to.rast/d.to.rast.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -25,7 +25,12 @@
+# i18N
+import os
+import gettext
def main():
Modified: grass/trunk/scripts/d.what.rast/d.what.rast.py
--- grass/trunk/scripts/d.what.rast/d.what.rast.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/d.what.rast/d.what.rast.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -25,7 +25,12 @@
+# i18N
+import os
+import gettext
def main():
Modified: grass/trunk/scripts/d.what.vect/d.what.vect.py
--- grass/trunk/scripts/d.what.vect/d.what.vect.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/d.what.vect/d.what.vect.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -25,7 +25,12 @@
+# i18N
+import os
+import gettext
def main():
Modified: grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py
--- grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -41,7 +41,12 @@
import grass.script as gscript
+# i18N
+import os
+import gettext
def main():
table = options['table']
column = options['column']
Modified: grass/trunk/scripts/db.droptable/db.droptable.py
--- grass/trunk/scripts/db.droptable/db.droptable.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/db.droptable/db.droptable.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -45,7 +45,12 @@
import sys
+# i18N
+import os
+import gettext
def main():
force = flags['f']
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -62,7 +62,12 @@
+# i18N
+import os
+import gettext
def main():
input = options['input']
db_table = options['db_table']
Modified: grass/trunk/scripts/db.out.ogr/db.out.ogr.py
--- grass/trunk/scripts/db.out.ogr/db.out.ogr.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/db.out.ogr/db.out.ogr.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -60,7 +60,11 @@
+# i18N
+import gettext
def main():
layer = options['layer']
Modified: grass/trunk/scripts/db.test/db.test.py
--- grass/trunk/scripts/db.test/db.test.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/db.test/db.test.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -33,7 +33,11 @@
from grass.script import db as grassdb
+# i18N
+import gettext
def main():
test_file = options['test']
Modified: grass/trunk/scripts/db.univar/db.univar.py
--- grass/trunk/scripts/db.univar/db.univar.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/db.univar/db.univar.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -61,7 +61,12 @@
+# i18N
+import os
+import gettext
def cleanup():
for ext in ['', '.sort']:
gscript.try_remove(tmp + ext)
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/g.extension/g.extension.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -161,6 +161,10 @@
from grass.script.utils import try_rmdir
+# i18N
+import gettext
# temp dir
REMOVE_TMPDIR = True
PROXIES = {}
Modified: grass/trunk/scripts/g.extension.all/g.extension.all.py
--- grass/trunk/scripts/g.extension.all/g.extension.all.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/g.extension.all/g.extension.all.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -47,7 +47,11 @@
+# i18N
+import gettext
def get_extensions():
addon_base = os.getenv('GRASS_ADDON_BASE')
if not addon_base:
Modified: grass/trunk/scripts/g.manual/g.manual.py
--- grass/trunk/scripts/g.manual/g.manual.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/g.manual/g.manual.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -60,7 +60,11 @@
from grass.script.utils import basename
+# i18N
+import gettext
def start_browser(entry):
if browser and \
browser not in ('xdg-open', 'start') and \
Modified: grass/trunk/scripts/g.search.modules/g.search.modules.py
--- grass/trunk/scripts/g.search.modules/g.search.modules.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/g.search.modules/g.search.modules.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -68,6 +68,10 @@
from grass.script.utils import diff_files, try_rmdir
+# i18N
+import gettext
try:
import xml.etree.ElementTree as etree
except ImportError:
Modified: grass/trunk/scripts/i.colors.enhance/i.colors.enhance.py
--- grass/trunk/scripts/i.colors.enhance/i.colors.enhance.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/i.colors.enhance/i.colors.enhance.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -71,6 +71,11 @@
+# i18N
+import os
+import gettext
try:
# new for python 2.6, in 2.5 it may be easy_install'd.
import multiprocessing as mp
Modified: grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
--- grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -36,7 +36,12 @@
+# i18N
+import os
+import gettext
def copy_colors(fh, map, offset):
p = gscript.pipe_command('r.colors.out', map=map)
for line in p.stdout:
Modified: grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
--- grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -53,7 +53,11 @@
+# i18N
+import gettext
vrt = """<VRTDataset rasterXSize="$XSIZE" rasterYSize="$YSIZE">
<SRS>GEOGCS["wgs84",DATUM["WGS_1984",SPHEROID["wgs84",6378137,298.257223563],TOWGS84[0.000,0.000,0.000]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]]</SRS>
<GeoTransform>$WESTCORNER, $RESOLUTION, 0.0000000000000000e+00, $NORTHCORNER, 0.0000000000000e+00, -$RESOLUTION</GeoTransform>
Modified: grass/trunk/scripts/i.oif/i.oif.py
--- grass/trunk/scripts/i.oif/i.oif.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/i.oif/i.oif.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -45,7 +45,11 @@
from grass.script.utils import parse_key_val
+# i18N
+import gettext
def oifcalc(sdev, corr, k1, k2, k3):
grass.debug(_("Calculating OIF for combination: %s, %s, %s" % (k1, k2,
k3)), 1)
Modified: grass/trunk/scripts/i.pansharpen/i.pansharpen.py
--- grass/trunk/scripts/i.pansharpen/i.pansharpen.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/i.pansharpen/i.pansharpen.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -90,7 +90,11 @@
+# i18N
+import gettext
def main():
if not hasNumPy:
grass.fatal(_("Required dependency NumPy not found. Exiting."))
Modified: grass/trunk/scripts/i.spectral/i.spectral.py
--- grass/trunk/scripts/i.spectral/i.spectral.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/i.spectral/i.spectral.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -79,7 +79,11 @@
+# i18N
+import gettext
def cleanup():
try_rmdir(tmp_dir)
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.py
--- grass/trunk/scripts/i.tasscap/i.tasscap.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -73,6 +73,11 @@
+# i18N
+import os
+import gettext
# weights for 6 Landsat bands: TM4, TM5, TM7, OLI
# MODIS: Red, NIR1, Blue, Green, NIR2, SWIR1, SWIR2
parms = [[(0.3037, 0.2793, 0.4743, 0.5585, 0.5082, 0.1863), # Landsat TM4
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/m.proj/m.proj.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -98,7 +98,11 @@
from grass.script.utils import separator, parse_key_val
+# i18N
+import gettext
class TrThread(threading.Thread):
def __init__(self, ifs, inf, outf):
Modified: grass/trunk/scripts/r.blend/r.blend.py
--- grass/trunk/scripts/r.blend/r.blend.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.blend/r.blend.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -47,7 +47,11 @@
import string
+# i18N
+import gettext
def main():
first = options['first']
second = options['second']
Modified: grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py
--- grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -47,6 +47,10 @@
import math
+# i18N
+import gettext
scales = {
'meters': 1.0,
'kilometers': 1000.0,
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -103,6 +103,10 @@
+# i18N
+import gettext
tmp_rmaps = list()
tmp_vmaps = list()
usermask = None
Modified: grass/trunk/scripts/r.grow/r.grow.py
--- grass/trunk/scripts/r.grow/r.grow.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.grow/r.grow.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -67,7 +67,11 @@
+# i18N
+import gettext
# what to do in case of user break:
def cleanup():
for map in [temp_dist, temp_val]:
Modified: grass/trunk/scripts/r.import/r.import.py
--- grass/trunk/scripts/r.import/r.import.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.import/r.import.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -129,7 +129,11 @@
+# i18N
+import gettext
# initialize global vars
TMPLOC = None
SRCGISRC = None
Modified: grass/trunk/scripts/r.in.aster/r.in.aster.py
--- grass/trunk/scripts/r.in.aster/r.in.aster.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.in.aster/r.in.aster.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -56,6 +56,10 @@
import platform
+# i18N
+import gettext
bands = {
'L1A': {
'1': "VNIR_Band1:ImageData",
Modified: grass/trunk/scripts/r.in.srtm/r.in.srtm.py
--- grass/trunk/scripts/r.in.srtm/r.in.srtm.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.in.srtm/r.in.srtm.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -113,7 +113,11 @@
+# i18N
+import gettext
def cleanup():
if not in_temp:
return
Modified: grass/trunk/scripts/r.in.wms/r.in.wms.py
--- grass/trunk/scripts/r.in.wms/r.in.wms.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.in.wms/r.in.wms.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -178,7 +178,11 @@
+# i18N
+import gettext
def GetRegionParams(opt_region):
# set region
Modified: grass/trunk/scripts/r.in.wms/wms_base.py
--- grass/trunk/scripts/r.in.wms/wms_base.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.in.wms/wms_base.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -31,7 +31,11 @@
+# i18N
+import gettext
class WMSBase:
def __init__(self):
Modified: grass/trunk/scripts/r.in.wms/wms_cap_parsers.py
--- grass/trunk/scripts/r.in.wms/wms_cap_parsers.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.in.wms/wms_cap_parsers.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -24,7 +24,12 @@
+# i18N
+import os
+import gettext
class BaseCapabilitiesTree(etree.ElementTree):
def __init__(self, cap_file):
Modified: grass/trunk/scripts/r.in.wms/wms_drv.py
--- grass/trunk/scripts/r.in.wms/wms_drv.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.in.wms/wms_drv.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -19,6 +19,11 @@
import socket
+# i18N
+import os
+import gettext
from time import sleep
try:
Modified: grass/trunk/scripts/r.in.wms/wms_gdal_drv.py
--- grass/trunk/scripts/r.in.wms/wms_gdal_drv.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.in.wms/wms_gdal_drv.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -16,6 +16,10 @@
import os
+# i18N
+import gettext
try:
from osgeo import gdal
from osgeo import gdalconst
Modified: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.mask/r.mask.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -73,7 +73,11 @@
+# i18N
+import gettext
def cleanup():
if tmp:
grass.run_command('g.remove', flags='f', type='raster',
Modified: grass/trunk/scripts/r.pack/r.pack.py
--- grass/trunk/scripts/r.pack/r.pack.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.pack/r.pack.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -40,7 +40,11 @@
from grass.script.utils import try_rmdir, try_remove
+# i18N
+import gettext
def cleanup():
try_rmdir(tmp)
Modified: grass/trunk/scripts/r.plane/r.plane.py
--- grass/trunk/scripts/r.plane/r.plane.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.plane/r.plane.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -66,7 +66,12 @@
import string
+# i18N
+import os
+import gettext
def main():
name = options['output']
type = options['type']
Modified: grass/trunk/scripts/r.reclass.area/r.reclass.area.py
--- grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -77,6 +77,10 @@
import atexit
+# i18N
+import gettext
TMPRAST = []
Modified: grass/trunk/scripts/r.rgb/r.rgb.py
--- grass/trunk/scripts/r.rgb/r.rgb.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.rgb/r.rgb.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -43,7 +43,12 @@
+# i18N
+import os
+import gettext
def main():
options, unused = gscript.parser()
Modified: grass/trunk/scripts/r.shade/r.shade.py
--- grass/trunk/scripts/r.shade/r.shade.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.shade/r.shade.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -67,7 +67,11 @@
from grass.script import raster as grast
+# i18N
+import gettext
def remove(maps):
"""Remove raster maps"""
gcore.run_command('g.remove', flags='f', quiet=True,
Modified: grass/trunk/scripts/r.tileset/r.tileset.py
--- grass/trunk/scripts/r.tileset/r.tileset.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.tileset/r.tileset.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -116,7 +116,12 @@
+# i18N
+import os
+import gettext
def bboxToPoints(bbox):
"""Make points that are the corners of a bounding box"""
points = []
Modified: grass/trunk/scripts/r.unpack/r.unpack.py
--- grass/trunk/scripts/r.unpack/r.unpack.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r.unpack/r.unpack.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -44,7 +44,11 @@
+# i18N
+import gettext
def cleanup():
try_rmdir(tmp_dir)
Modified: grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
--- grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -174,7 +174,11 @@
+# i18N
+import gettext
def cleanup():
type="rast", pattern='tmp.r3xyz.%d.*' % os.getpid(),
Modified: grass/trunk/scripts/v.build.all/v.build.all.py
--- grass/trunk/scripts/v.build.all/v.build.all.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.build.all/v.build.all.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -22,7 +22,12 @@
+# i18N
+import os
+import gettext
def main():
env = grass.gisenv()
mapset = env['MAPSET']
Modified: grass/trunk/scripts/v.centroids/v.centroids.py
--- grass/trunk/scripts/v.centroids/v.centroids.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.centroids/v.centroids.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -52,7 +52,12 @@
import sys
+# i18N
+import os
+import gettext
def main():
if options['option'] == 'add':
num_bound = gscript.vector_info_topo(map=options['input'])['boundaries']
Modified: grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py
--- grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -44,7 +44,11 @@
import os
+# i18N
+import gettext
def main():
map = options['map']
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -57,7 +57,11 @@
+# i18N
+import gettext
def main():
vector = options['map']
Modified: grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py
--- grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -43,7 +43,11 @@
+# i18N
+import gettext
def main():
Modified: grass/trunk/scripts/v.db.droprow/v.db.droprow.py
--- grass/trunk/scripts/v.db.droprow/v.db.droprow.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.db.droprow/v.db.droprow.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -39,7 +39,12 @@
+# i18N
+import os
+import gettext
def main():
# delete vectors via reverse selection
try:
Modified: grass/trunk/scripts/v.db.droptable/v.db.droptable.py
--- grass/trunk/scripts/v.db.droptable/v.db.droptable.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.db.droptable/v.db.droptable.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -39,7 +39,11 @@
+# i18N
+import gettext
def main():
force = flags['f']
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.db.join/v.db.join.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -61,7 +61,12 @@
+# i18N
+import os
+import gettext
def main():
Modified: grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
--- grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -56,6 +56,10 @@
+# i18N
+import gettext
# substitute variables (gisdbase, location_name, mapset)
Modified: grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py
--- grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -43,7 +43,11 @@
import os
+# i18N
+import gettext
def main():
Modified: grass/trunk/scripts/v.db.univar/v.db.univar.py
--- grass/trunk/scripts/v.db.univar/v.db.univar.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.db.univar/v.db.univar.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -56,7 +56,11 @@
+# i18N
+import gettext
def main():
global tmp
tmp = gscript.tempfile()
Modified: grass/trunk/scripts/v.db.update/v.db.update.py
--- grass/trunk/scripts/v.db.update/v.db.update.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.db.update/v.db.update.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -54,7 +54,11 @@
import os
+# i18N
+import gettext
def main():
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -40,7 +40,11 @@
+# i18N
+import gettext
def cleanup():
nuldev = file(os.devnull, 'w')
grass.run_command(
Modified: grass/trunk/scripts/v.import/v.import.py
--- grass/trunk/scripts/v.import/v.import.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.import/v.import.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -104,6 +104,10 @@
+# i18N
+import gettext
TMPLOC = None
SRCGISRC = None
Modified: grass/trunk/scripts/v.in.e00/v.in.e00.py
--- grass/trunk/scripts/v.in.e00/v.in.e00.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.in.e00/v.in.e00.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -46,7 +46,11 @@
+# i18N
+import gettext
def main():
filename = options['input']
Modified: grass/trunk/scripts/v.in.geonames/v.in.geonames.py
--- grass/trunk/scripts/v.in.geonames/v.in.geonames.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.in.geonames/v.in.geonames.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -37,7 +37,11 @@
import os
+# i18N
+import gettext
def main():
infile = options['input']
outfile = options['output']
Modified: grass/trunk/scripts/v.in.lines/v.in.lines.py
--- grass/trunk/scripts/v.in.lines/v.in.lines.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.in.lines/v.in.lines.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -41,7 +41,11 @@
from grass.script.utils import separator, try_remove
+# i18N
+import gettext
def cleanup():
try_remove(tmp)
Modified: grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
--- grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -54,7 +54,11 @@
+# i18N
+import gettext
def cleanup():
try_remove(tmp)
try_remove(tmp + '.dig')
Modified: grass/trunk/scripts/v.in.wfs/v.in.wfs.py
--- grass/trunk/scripts/v.in.wfs/v.in.wfs.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.in.wfs/v.in.wfs.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -83,7 +83,11 @@
except ImportError:
from urllib.request import urlopen
+# i18N
+import gettext
def main():
out = options['output']
wfs_url = options['url']
@@ -100,12 +104,14 @@
if options['maximum_features']:
wfs_url += '&MAXFEATURES=' + options['maximum_features']
if int(options['maximum_features']) < 1:
- grass.fatal('Invalid maximum number of features')
+ # GTC Invalid WFS maximum features parameter
+ grass.fatal(_("Invalid maximum number of features"))
if options['start_index']:
wfs_url += '&STARTINDEX=' + options['start_index']
if int(options['start_index']) < 1:
- grass.fatal('Features begin with index "1"')
+ # GTC Invalid WFS start index parameter
+ grass.fatal(_('Features begin with index "1"'))
if flags['r']:
bbox = grass.read_command("g.region", flags='w').split('=')[1]
@@ -119,6 +125,7 @@
grass.debug(wfs_url)
+ # GTC Downloading WFS features
grass.message(_("Retrieving data..."))
inf = urlopen(wfs_url)
outf = file(tmpxml, 'wb')
@@ -133,7 +140,7 @@
if flags['l']:
import shutil
if os.path.exists('wms_capabilities.xml'):
- grass.fatal('A file called "wms_capabilities.xml" already exists here')
+ grass.fatal(_('A file called "wms_capabilities.xml" already exists here'))
# os.move() might fail if the temp file is on another volume, so we copy instead
shutil.copy(tmpxml, 'wms_capabilities.xml')
try_remove(tmpxml)
@@ -142,7 +149,7 @@
grass.message(_("Importing data..."))
try:
grass.run_command('v.in.ogr', flags='o', input=tmpxml, output=out)
- grass.message(_("Vector points map <%s> imported from WFS.") % out)
+ grass.message(_("Vector map <%s> imported from WFS.") % out)
except:
grass.message(_("WFS import failed"))
finally:
Modified: grass/trunk/scripts/v.pack/v.pack.py
--- grass/trunk/scripts/v.pack/v.pack.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.pack/v.pack.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -43,7 +43,11 @@
from grass.script import vector as vector
+# i18N
+import gettext
def cleanup():
try_rmdir(basedir)
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -69,7 +69,11 @@
+# i18N
+import gettext
def cleanup():
if rastertmp:
Modified: grass/trunk/scripts/v.report/v.report.py
--- grass/trunk/scripts/v.report/v.report.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.report/v.report.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -47,7 +47,11 @@
import os
+# i18N
+import gettext
def uniq(l):
result = []
last = None
Modified: grass/trunk/scripts/v.to.lines/v.to.lines.py
--- grass/trunk/scripts/v.to.lines/v.to.lines.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.to.lines/v.to.lines.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -44,7 +44,11 @@
import os
+# i18N
+import gettext
def main():
# Get the options
input = options["input"]
Modified: grass/trunk/scripts/v.unpack/v.unpack.py
--- grass/trunk/scripts/v.unpack/v.unpack.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.unpack/v.unpack.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -48,7 +48,11 @@
+# i18N
+import gettext
def cleanup():
try_rmdir(tmp_dir)
Modified: grass/trunk/scripts/v.what.strds/v.what.strds.py
--- grass/trunk/scripts/v.what.strds/v.what.strds.py 2017-04-01 09:34:12 UTC (rev 70817)
+++ grass/trunk/scripts/v.what.strds/v.what.strds.py 2017-04-01 10:28:45 UTC (rev 70818)
@@ -52,6 +52,11 @@
+# i18N
+import os
+import gettext
