[GRASS-SVN] r70842 - grass/branches/releasebranch_7_2/display/d.text
svn_grass at osgeo.org
Wed Apr 5 21:06:41 PDT 2017
Author: hcho
Date: 2017-04-05 21:06:41 -0700 (Wed, 05 Apr 2017)
New Revision: 70842
grass/branches/releasebranch_7_2/display/d.text/main.c
d.text: Backport r70839, r70840, r70841
Modified: grass/branches/releasebranch_7_2/display/d.text/main.c
--- grass/branches/releasebranch_7_2/display/d.text/main.c 2017-04-06 02:19:45 UTC (rev 70841)
+++ grass/branches/releasebranch_7_2/display/d.text/main.c 2017-04-06 04:06:41 UTC (rev 70842)
@@ -71,9 +71,10 @@
static void set_color(char *);
-static int get_coordinates(double *, double *, double *, double *,
- struct rectinfo, char **, char, char);
-static void draw_text(char *, double *, double *, double, char *, double, char, int, int, int);
+static void get_coordinates(double *, double *, double *, double *,
+ struct rectinfo, char **, char, char);
+static void draw_text(char *, double *, double *, double, char *, double, char,
+ int, int, int);
int main(int argc, char **argv)
@@ -272,19 +273,15 @@
flag.s->description = _("Font size is height in pixels");
flag.s->guisection = _("Font settings");
+ G_option_exclusive(opt.line, opt.at, NULL);
+ G_option_exclusive(flag.p, flag.g, NULL);
/* check command line */
if (G_parser(argc, argv))
exit(1);
- /* parse and check options and flags */
- if ((opt.line->answer && opt.at->answer) ||
- (flag.p->answer && flag.g->answer))
- G_fatal_error(_("Please choose only one placement method"));
+ /* parse options */
text = opt.text->answer;
line = (opt.line->answer ? atoi(opt.line->answer) : 1);
/* calculate rotation angle in radian */
@@ -310,10 +307,10 @@
if (opt.charset->answer)
D_encoding(opt.charset->answer);
- D_setup_unity(0);
+ D_setup(0);
/* figure out where to put text */
- D_get_src(&win.t, &win.b, &win.l, &win.r);
+ D_get_dst(&win.t, &win.b, &win.l, &win.r);
if (flag.s->answer)
size = atof(opt.size->answer);
@@ -330,17 +327,18 @@
bg_color = D_parse_color(opt.bgcolor->answer, TRUE);
if (bg_color == 0) /* ie color="none" */
do_background = 0;
- } else
+ else {
do_background = 0;
+ bg_color = 0;
set_color(opt.fgcolor->answer);
orig_x = orig_y = 0;
- if (opt.at->answer) {
- if (get_coordinates(&x, &y, &east, &north,
- win, opt.at->answers,
- flag.p->answer, flag.g->answer))
- G_fatal_error(_("Invalid coordinates"));
+ if (opt.at->answers) {
+ get_coordinates(&x, &y, &east, &north, win, opt.at->answers,
+ flag.p->answer, flag.g->answer);
orig_x = x;
orig_y = y;
@@ -581,51 +579,45 @@
D_use_color(color);
- return;
-static int
-get_coordinates(double *x, double *y, double *east, double *north,
- struct rectinfo win, char **at, char pixel,
- char geocoor)
+static void get_coordinates(double *x, double *y, double *east, double *north,
+ struct rectinfo win, char **at, char pixel,
+ char geocoor)
double e, n;
- if (at) {
- e = atof(at[0]);
- n = atof(at[1]);
- if (pixel) {
- *x = e + win.l;
- *y = n + win.t;
- e = D_d_to_u_col(*x);
- n = D_d_to_u_row(*y);
- else if (geocoor) {
- *x = D_u_to_d_col(e);
- *y = D_u_to_d_row(n);
- else {
- *x = win.l + (win.r - win.l) * e / 100.0;
- *y = win.t + (win.b - win.t) * (100.0 - n) / 100.0;
+ if (!at)
+ G_fatal_error(_("Invalid coordinates"));
+ e = atof(at[0]);
+ n = atof(at[1]);
+ if (pixel) {
+ *x = e + win.l;
+ *y = n + win.t;
+ e = D_d_to_u_col(*x);
+ n = D_d_to_u_row(*y);
- else
- return 1;
+ else if (geocoor) {
+ *x = D_u_to_d_col(e);
+ *y = D_u_to_d_row(n);
+ else {
+ *x = win.l + (win.r - win.l) * e / 100.0;
+ *y = win.t + (win.b - win.t) * (100.0 - n) / 100.0;
if (east)
*east = e;
if (north)
*north = n;
- return 0;
-static void draw_text(char *text, double *x, double *y, double size, char *align,
- double rotation, char bold, int do_background, int fg_color, int bg_color)
+static void draw_text(char *text, double *x, double *y, double size,
+ char *align, double rotation, char bold,
+ int do_background, int fg_color, int bg_color)
double w, h;
double t, b, l, r;
@@ -639,6 +631,10 @@
D_text_rotation(0.0);
D_get_text_box(text, &t, &b, &l, &r);
+ t = D_u_to_d_row(t);
+ b = D_u_to_d_row(b);
+ l = D_u_to_d_col(l);
+ r = D_u_to_d_col(r);
if (rotation != 0.0)
D_text_rotation(rotation * 180.0 / M_PI);
@@ -687,27 +683,25 @@
if (do_background) {
- pl = *x - size/2; /* some pixels margin for both sides */
- pt = *y + size/2;
- pr = *x + w + size/2;
- pb = *y - h - size/2;
+ pl = D_d_to_u_col(*x - size/2); /* some pixels margin for both sides */
+ pt = D_d_to_u_row(*y + size/2);
+ pr = D_d_to_u_col(*x + w + size/2);
+ pb = D_d_to_u_row(*y - h - size/2);
D_use_color(bg_color);
D_box_abs(pl, pt, pr, pb); /* draw the box */
D_use_color(fg_color); /* restore */
- D_pos_abs(*x, *y);
+ D_pos_abs(D_d_to_u_col(*x), D_d_to_u_row(*y));
D_text(text);
if (bold) {
- D_pos_abs(*x, *y + 1);
+ D_pos_abs(D_d_to_u_col(*x), D_d_to_u_row(*y + 1));
D_text(text);
- D_pos_abs(*x + 1, *y);
+ D_pos_abs(D_d_to_u_col(*x + 1), D_d_to_u_row(*y));
D_text(text);
*x += w * c;
*y -= w * s;
- return;
