[GRASS-SVN] r70858 - grass/trunk/imagery/i.ortho.photo/i.ortho.elev
svn_grass at osgeo.org
Sun Apr 9 23:58:55 PDT 2017
Author: ychemin
Date: 2017-04-09 23:58:54 -0700 (Sun, 09 Apr 2017)
New Revision: 70858
grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c
Some more comments
Modified: grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c
--- grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c 2017-04-09 22:00:21 UTC (rev 70857)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c 2017-04-10 06:58:54 UTC (rev 70858)
@@ -146,9 +146,12 @@
G_fatal_error(_("Target location [%s] not found\n"), location);
+ /*Report the contents of the ELEVATION file as in the GROUP */
if (print_flag->answer) {
+ /*If the content is empty report an error */
if(!I_get_group_elev(group, elev_layer, mapset_elev, location_elev, math_exp, units, nd)){
G_fatal_error(_("Cannot find default elevation map for target in group [%s]"),group);
+ /*If there is a content, report it as a message */
} else {
G_message("map:\t\t\t%s",elev_layer);
G_message("mapset:\t\t\t%s",mapset_elev);
@@ -176,7 +179,7 @@
G_switch_env();
/*Switch to alternate search path */
G_switch_search_path();
+ /*Source Env = 0 ; Target Env = 1 */
which_env = 0;
/*Select the target environment */
select_target_env();
@@ -193,7 +196,7 @@
select_current_env();
G_fatal_error(_("Raster map <%s> not found"), elev_opt->answer);
- /* load information from the ELEVATION file in the GROUP*/
+ /* load information from the ELEVATION file in the GROUP */
I_get_group_elev(group, elev_layer, mapset_elev, location_elev, math_exp, units, nd);
/*Modify ELEVATION file in source GROUP */
I_put_group_elev(group,elev_opt->answer,mapset_opt->answer,loc_opt->answer,
