[GRASS-SVN] r70861 - in grass-addons/grass7/raster/r.pi: r.pi.nlm r.pi.nlm.stats
svn_grass at osgeo.org
Tue Apr 11 06:05:55 PDT 2017
Author: mmetz
Date: 2017-04-11 06:05:55 -0700 (Tue, 11 Apr 2017)
New Revision: 70861
grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/fractal.c
grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/func.c
grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/local_proto.h
grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/main.c
grass-addons/grass7/raster/r.pi/r.pi.nlm/func.c
grass-addons/grass7/raster/r.pi/r.pi.nlm/local_proto.h
grass-addons/grass7/raster/r.pi/r.pi.nlm/main.c
r.pi.nlm: fix bugs
Modified: grass-addons/grass7/raster/r.pi/r.pi.nlm/func.c
--- grass-addons/grass7/raster/r.pi/r.pi.nlm/func.c 2017-04-11 12:32:44 UTC (rev 70860)
+++ grass-addons/grass7/raster/r.pi/r.pi.nlm/func.c 2017-04-11 13:05:55 UTC (rev 70861)
@@ -1,14 +1,11 @@
#include "local_proto.h"
-int GetCell(double *map, int x, int y, int size, double *res)
+int GetCell(double *map, int x, int y, int size, double val, double *res)
if ((x >= 0) && (x < size) && (y >= 0) && (y < size)) {
*res = map[x + y * size];
if (Rast_is_d_null_value(res)) {
- double min, max;
- MinMax(map, &min, &max, size * size);
- *res = min;
+ *res = val;
return 1;
@@ -26,7 +23,7 @@
/* fprintf(stderr, "map[%d,%d] = %f\n", x, y, map[x + y * size]); */
-double DownSample(double *map, int x, int y, int newcols, int newrows,
+double DownSample(double *map, double min, int x, int y, int newcols, int newrows,
int oldsize)
int topleftX = oldsize * x / newcols;
@@ -41,7 +38,7 @@
for (i = topleftX; i < bottomrightX; i++) {
for (j = topleftY; j < bottomrightY; j++) {
- if (GetCell(map, i, j, oldsize, &cell)) {
+ if (GetCell(map, i, j, oldsize, min, &cell)) {
cnt++;
sum += cell;
@@ -115,6 +112,8 @@
/* get parameters */
MinMax(map, &min, &max, size);
+ if (min == max)
+ G_fatal_error("CutValues(): min %g == max %g", min, max);
span = max - min;
pixels = Round(size * mapcover);
@@ -159,7 +158,7 @@
-void FractalStep(double *map, Point v1, Point v2, Point v3, Point v4,
+void FractalStep(double *map, double min, Point v1, Point v2, Point v3, Point v4,
double d, int size)
Point mid;
@@ -170,13 +169,13 @@
/* get values */
int cnt = 0;
- if (GetCell(map, v1.x, v1.y, size, &val1))
+ if (GetCell(map, v1.x, v1.y, size, min, &val1))
cnt++;
- if (GetCell(map, v2.x, v2.y, size, &val2))
+ if (GetCell(map, v2.x, v2.y, size, min, &val2))
cnt++;
- if (GetCell(map, v3.x, v3.y, size, &val3))
+ if (GetCell(map, v3.x, v3.y, size, min, &val3))
cnt++;
- if (GetCell(map, v4.x, v4.y, size, &val4))
+ if (GetCell(map, v4.x, v4.y, size, min, &val4))
cnt++;
/* calculate midpoints */
@@ -198,7 +197,10 @@
int i, x, y, dx;
double actd = d;
int xdisp;
+ double min, max;
+ MinMax(map, &min, &max, size * size);
/* initialize corners */
SetCell(map, 0, 0, size, 2 * (Randomf() - 0.5));
SetCell(map, size - 1, 0, size, 2 * (Randomf() - 0.5));
@@ -206,7 +208,7 @@
SetCell(map, size - 1, size - 1, size, 2 * (Randomf() - 0.5));
/* calculate starting step width */
- step = size;
+ step = size - 1;
for (i = 0; i < n; i++) {
/* do diamond step */
@@ -220,7 +222,8 @@
v3.y = (y + 1) * step;
v4.x = (x + 1) * step;
v4.y = (y + 1) * step;
- FractalStep(map, v1, v2, v3, v4, actd, size);
+ FractalStep(map, min, v1, v2, v3, v4, actd, size);
@@ -229,8 +232,8 @@
/* do square step */
xdisp = 1;
- for (y = 0; y <= (1 << (i + 1)); y++) {
- for (x = 0; x <= (1 << i) - xdisp; x++) {
+ for (y = 1; y <= (1 << (i + 0)); y++) {
+ for (x = 1; x <= (1 << i) - xdisp - 1; x++) {
dx = 2 * x + xdisp;
v1.x = dx * step;
v1.y = (y - 1) * step;
@@ -240,7 +243,8 @@
v4.x = (dx - 1) * step;
v4.y = y * step;
/* switch row offset */
Modified: grass-addons/grass7/raster/r.pi/r.pi.nlm/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.nlm/local_proto.h 2017-04-11 12:32:44 UTC (rev 70860)
+++ grass-addons/grass7/raster/r.pi/r.pi.nlm/local_proto.h 2017-04-11 13:05:55 UTC (rev 70861)
@@ -4,12 +4,12 @@
#include <string.h>
#include <stdlib.h>
#include <unistd.h>
+#include <math.h>
+#include <time.h>
#include <grass/gis.h>
#include <grass/glocale.h>
#include <grass/stats.h>
#include "../r.pi.library/r_pi.h"
-#include <math.h>
-#include <time.h>
typedef struct
@@ -42,7 +42,7 @@
/* func.c */
void FractalIter(double *map, double d, double dmod, int n, int size);
int oldsize);
double CutValues(double *map, double mapcover, int size);
double UpSample(int *map, int x, int y, int oldcols, int oldrows,
Modified: grass-addons/grass7/raster/r.pi/r.pi.nlm/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.nlm/main.c 2017-04-11 12:32:44 UTC (rev 70860)
+++ grass-addons/grass7/raster/r.pi/r.pi.nlm/main.c 2017-04-11 13:05:55 UTC (rev 70861)
@@ -6,7 +6,7 @@
* Markus Metz (update to GRASS 7)
* PURPOSE: Generation of Neutral Landscapes (fractal landscapes), similar to r.pi.nlm, but fractal landscapes instead of circular growth
- * COPYRIGHT: (C) 2009-2011 by the GRASS Development Team
+ * COPYRIGHT: (C) 2009-2011,2017 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -196,7 +196,7 @@
/* init buffers */
memset(bigbuf, 0, size * size * sizeof(double));
- memset(buffer, TYPE_NOTHING, sx * sy * sizeof(int));
+ memset(buffer, 0, sx * sy * sizeof(int));
/* load values from input file */
if (oldname) {
@@ -255,7 +255,7 @@
/* resample map to desired size */
for (i = 0; i < sx; i++) {
for (j = 0; j < sy; j++) {
- double val = DownSample(bigbuf, i, j, sx, sy, size);
+ double val = DownSample(bigbuf, min, i, j, sx, sy, size);
double old = buffer[i + j * sx];
if (val >= edge && old == 0) {
Modified: grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/fractal.c
--- grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/fractal.c 2017-04-11 12:32:44 UTC (rev 70860)
+++ grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/fractal.c 2017-04-11 13:05:55 UTC (rev 70861)
@@ -22,10 +22,12 @@
/* find edge */
edge = CutValues(fractbuf, landcover, size * size);
+ MinMax(fractbuf, &min, &max, size * size);
- double val = DownSample(fractbuf, i, j, sx, sy, size);
+ double val = DownSample(fractbuf, min, i, j, sx, sy, size);
Modified: grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/func.c
--- grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/func.c 2017-04-11 12:32:44 UTC (rev 70860)
+++ grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/func.c 2017-04-11 13:05:55 UTC (rev 70861)
@@ -1,14 +1,11 @@
- double min, max;
- *res = min;
+ *res = val;
return 1;
@@ -26,7 +23,7 @@
int oldsize)
@@ -41,7 +38,7 @@
cnt++;
sum += cell;
@@ -115,6 +112,8 @@
+ if (min == max)
span = max - min;
@@ -159,7 +158,7 @@
double d, int size)
Point mid;
/* get values */
int cnt = 0;
cnt++;
cnt++;
cnt++;
cnt++;
int i, x, y, dx;
double actd = d;
int xdisp;
+ double min, max;
@@ -206,7 +208,7 @@
- step = size;
+ step = size - 1;
@@ -220,7 +222,8 @@
@@ -229,8 +232,8 @@
xdisp = 1;
dx = 2 * x + xdisp;
v1.x = dx * step;
@@ -240,7 +243,8 @@
v4.y = y * step;
Modified: grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/local_proto.h
--- grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/local_proto.h 2017-04-11 12:32:44 UTC (rev 70860)
+++ grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/local_proto.h 2017-04-11 13:05:55 UTC (rev 70861)
@@ -30,7 +30,7 @@
/* func.c */
int oldsize);
Modified: grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/main.c
--- grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/main.c 2017-04-11 12:32:44 UTC (rev 70860)
+++ grass-addons/grass7/raster/r.pi/r.pi.nlm.stats/main.c 2017-04-11 13:05:55 UTC (rev 70861)
@@ -7,7 +7,7 @@
* PURPOSE: Generation of Neutral Landscapes and statistical analysis
* of fragmentation indices
@@ -327,7 +327,6 @@
/* init fragments structure */
fragments[0] = cells;
/* init buffers */
