[GRASS-SVN] r70880 - grass-addons/grass7/raster/r.fill.gaps
Fri Apr 14 15:37:30 PDT 2017
Author: wenzeslaus
Date: 2017-04-14 15:37:29 -0700 (Fri, 14 Apr 2017)
New Revision: 70880
Added:
   grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.html
   grass-addons/grass7/raster/r.fill.gaps/r_fill_gaps_01.png
   grass-addons/grass7/raster/r.fill.gaps/r_fill_gaps_02.png
Removed:
   grass-addons/grass7/raster/r.fill.gaps/description.html
   grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.01.png
   grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.02.png
   grass-addons/grass7/raster/r.fill.gaps/Makefile
   grass-addons/grass7/raster/r.fill.gaps/cell_funcs.c
   grass-addons/grass7/raster/r.fill.gaps/cell_funcs.h
   grass-addons/grass7/raster/r.fill.gaps/main.c
r.fill.gaps: port code from G6 to G7
Modified: grass-addons/grass7/raster/r.fill.gaps/Makefile
--- grass-addons/grass7/raster/r.fill.gaps/Makefile	2017-04-14 22:31:39 UTC (rev 70879)
+++ grass-addons/grass7/raster/r.fill.gaps/Makefile	2017-04-14 22:37:29 UTC (rev 70880)
@@ -2,10 +2,9 @@
 PGM = r.fill.gaps
-LIBES = $(GISLIB)
-DEPENDENCIES = $(GISDEP)
+LIBES = $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
 default: cmd
Modified: grass-addons/grass7/raster/r.fill.gaps/cell_funcs.c
--- grass-addons/grass7/raster/r.fill.gaps/cell_funcs.c	2017-04-14 22:31:39 UTC (rev 70879)
+++ grass-addons/grass7/raster/r.fill.gaps/cell_funcs.c	2017-04-14 22:37:29 UTC (rev 70880)
@@ -21,31 +21,46 @@
 #include <math.h>
 #include <string.h>
 #include <stdlib.h>
 #include <grass/gis.h>
 #include <grass/glocale.h>
 #include "cell_funcs.h"
+RASTER_MAP_TYPE IN_TYPE;
+RASTER_MAP_TYPE OUT_TYPE;
+unsigned char CELL_IN_SIZE;
+unsigned char CELL_IN_PTR_SIZE;
+unsigned char CELL_OUT_SIZE;
+unsigned char CELL_OUT_PTR_SIZE;
+unsigned char CELL_ERR_SIZE;
+void (*WRITE_CELL_VAL) (void *, void *);
+void (*WRITE_DOUBLE_VAL) (void *, double);
+int (*IS_NULL) (void *);
+void (*SET_NULL) (void *, unsigned long);
  * Write cell values.
 void write_cell_value_c(void *cell_output, void *cell_input)
-    G_set_raster_value_c(cell_output,
-                         G_get_raster_value_c(cell_input, IN_TYPE), OUT_TYPE);
+    Rast_set_c_value(cell_output, Rast_get_c_value(cell_input, IN_TYPE),
+                     OUT_TYPE);
 void write_cell_value_f(void *cell_output, void *cell_input)
-    G_set_raster_value_f(cell_output,
-                         G_get_raster_value_f(cell_input, IN_TYPE), OUT_TYPE);
+    Rast_set_f_value(cell_output, Rast_get_f_value(cell_input, IN_TYPE),
+                     OUT_TYPE);
 void write_cell_value_d(void *cell_output, void *cell_input)
-    G_set_raster_value_d(cell_output,
-                         G_get_raster_value_d(cell_input, IN_TYPE), OUT_TYPE);
+    Rast_set_d_value(cell_output, Rast_get_d_value(cell_input, IN_TYPE),
+                     OUT_TYPE);
@@ -55,17 +70,17 @@
 void write_double_value_c(void *cell, double val)
-    G_set_raster_value_c(cell, (CELL) val, OUT_TYPE);
+    Rast_set_c_value(cell, (CELL) val, OUT_TYPE);
 void write_double_value_f(void *cell, double val)
-    G_set_raster_value_f(cell, (FCELL) val, OUT_TYPE);
+    Rast_set_f_value(cell, (FCELL) val, OUT_TYPE);
 void write_double_value_d(void *cell, double val)
-    G_set_raster_value_d(cell, (DCELL) val, OUT_TYPE);
+    Rast_set_d_value(cell, (DCELL) val, OUT_TYPE);
@@ -75,17 +90,17 @@
 int is_null_value_c(void *cell)
-    return (G_is_c_null_value((CELL *) cell));
+    return (Rast_is_c_null_value((CELL *) cell));
 int is_null_value_f(void *cell)
-    return (G_is_f_null_value((FCELL *) cell));
+    return (Rast_is_f_null_value((FCELL *) cell));
 int is_null_value_d(void *cell)
-    return (G_is_d_null_value((DCELL *) cell));
+    return (Rast_is_d_null_value((DCELL *) cell));
@@ -94,17 +109,17 @@
 void set_null_c(void *cells, unsigned long count)
-    G_set_c_null_value((CELL *) cells, count);
+    Rast_set_c_null_value((CELL *) cells, count);
 void set_null_f(void *cells, unsigned long count)
-    G_set_f_null_value((FCELL *) cells, count);
+    Rast_set_f_null_value((FCELL *) cells, count);
 void set_null_d(void *cells, unsigned long count)
-    G_set_d_null_value((DCELL *) cells, count);
+    Rast_set_d_null_value((DCELL *) cells, count);
Modified: grass-addons/grass7/raster/r.fill.gaps/cell_funcs.h
--- grass-addons/grass7/raster/r.fill.gaps/cell_funcs.h	2017-04-14 22:31:39 UTC (rev 70879)
+++ grass-addons/grass7/raster/r.fill.gaps/cell_funcs.h	2017-04-14 22:37:29 UTC (rev 70880)
@@ -17,19 +17,23 @@
 #ifndef CELL_FUNCS_H
 #define CELL_FUNCS_H
-RASTER_MAP_TYPE IN_TYPE;        /* stuff for cell input and output data */
-RASTER_MAP_TYPE OUT_TYPE;
+#include <grass/raster.h>
+void init_cell_funcs();
+extern RASTER_MAP_TYPE IN_TYPE; /* stuff for cell input and output data */
+extern RASTER_MAP_TYPE OUT_TYPE;
 /* below are the sizes (in bytes) for the different GRASS cell types */
-unsigned char CELL_IN_SIZE;
-unsigned char CELL_IN_PTR_SIZE;
-unsigned char CELL_OUT_SIZE;
-unsigned char CELL_OUT_PTR_SIZE;
-unsigned char CELL_ERR_SIZE;
+extern unsigned char CELL_IN_SIZE;
+extern unsigned char CELL_IN_PTR_SIZE;
+extern unsigned char CELL_OUT_SIZE;
+extern unsigned char CELL_OUT_PTR_SIZE;
+extern unsigned char CELL_ERR_SIZE;
-void (*WRITE_CELL_VAL) (void *, void *);        /* write a cell value of any type into an output cell */
-void (*WRITE_DOUBLE_VAL) (void *, double);      /* write a double value into an output cell */
-int (*IS_NULL) (void *);        /* check if a cell is "no data" */
-void (*SET_NULL) (void *, unsigned long);       /* write null value(s) */
+extern void (*WRITE_CELL_VAL) (void *, void *); /* write a cell value of any type into an output cell */
+extern void (*WRITE_DOUBLE_VAL) (void *, double);       /* write a double value into an output cell */
+extern int (*IS_NULL) (void *); /* check if a cell is "no data" */
+extern void (*SET_NULL) (void *, unsigned long);        /* write null value(s) */
 #endif /* CELL_FUNCS_H */
Deleted: grass-addons/grass7/raster/r.fill.gaps/description.html
--- grass-addons/grass7/raster/r.fill.gaps/description.html	2017-04-14 22:31:39 UTC (rev 70879)
+++ grass-addons/grass7/raster/r.fill.gaps/description.html	2017-04-14 22:37:29 UTC (rev 70880)
@@ -1,255 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em><b>r.fill.gaps</b></em> - Fast gap filling and interpolation of dense raster data.
-<p>
-The <em>r.fill.gaps</em> module is capable of quickly filling small "no data" areas (gaps) in large raster maps.
-As a rule of thumb, there should be at least as many data cells as there are "no data" cells in
-the input raster map. Several interpolation modes are available.
-By default, all values of the input raster map will be replaced with locally interpolated values in the output raster map.
-With dense data and small gaps, this should result in only slight deviations from the original data
-and produce smooth output. Alternatively, setting the <em>-p</em> flag will preserve the original cell values.
-<p>
-Available gap filling modes:
-<ul>
-<li>spatially weighted mean (default)</li>
-<li>simple mean</li>
-<li>simple median</li>
-<li>simple mode</li>
-</ul>
-<p>
-The spatially weighted mean is equivalent to an Inverse Distance Weighting (IDW; see
-also <em><a href="r.surf.idw.html">r.surf.idw</a></em>) interpolation. The simple
-mean is equivalent to a low-pass filter. Median and mode replacements can also be
-achieved using <em><a href="r.neighbors.html">r.neighbors</a></em>.
-<p>
-Note that <em>r.fill.gaps</em> is highly optimized for fast processing of large raster datasets
-with a small interpolation distance threshold (i.e. closing small gaps). As a trade-off
-for speed and a small memory foot print, some spatial accuracy is lost due to the rounding
-of the distance threshold to the closest approximation in input raster cells and the use of a matrix of precomputed weights at cell resolution (see further
-down for details). Note also that processing time will increase exponentially with higher distance settings.
-Cells outside the distance threshold will not be interpolated, preserving the edges of the data zones in the input data.
-<p>
-This module is not well suited for interpolating sparse input data and closing large gaps.
-For such purposes solutions more appropriate methods are available, such as <em><a href="v.surf.idw.html">v.surf.idw</a></em>
-or <em><a href="v.surf.rst.html">v.surf.rst</a></em>.
-<p>
-Applications where the properties of <em>r.fill.gaps</em> are advantageous include the processing of
-high resolution, close range scanning and remote sensing datasets. Such datasets commonly feature densely spaced
-measurements that have some gaps after rasterization, due to blind spots, instrument failures,
-and misalignments between the GIS' raster cell grids and the original measurement locations.
-In these cases, <em>r.fill.gaps</em> should typically be run using the "weighted mean" (default) method
-and with a small distance setting (the default is to use a search radius of just three cells).
-<p>
-The images below show a gradiometer dataset with gaps and its interpolated equivalent, produced using
-the spatially weighted mean operator (<em>mode="wmean"</em>).
-<p>
-<img src="r.fill.gaps.01.png" alt="">  <img src="r.fill.gaps.02.png" alt="">
-<p>
-In addition, <em>r.fill.gaps</em> can be useful for raster map generalization. Often, this involves removing small
-clumps of categorized cells and then filling the resulting data gaps without "inventing" any new values.
-In such cases, the "mode" or "median" interpolators should be used.
-<h2>USAGE</h2>
-The most critical user-provided settings are the interpolation/gap filling method (<em>mode=</em>)
-and the maximum distance, up to which <em>r.fill.gaps</em> will scan for given data points
-when attempting to fill/interpolate a value at any given location (<em>distance=</em>).
-The distance can be expressed as a number of cells (default) or in the current location's units (if the <em>-m</em> flag is given).
-The latter are typically meters, but can be any other units of a <em>planar</em> coordinate system.
-<p>
-Note that proper handling of geodetic coordinates (lat/lon) and distances is currently not implemented.
-For lat/lon data, the distance should therefore be specified in cells and usage of <em>r.fill.gaps</em> should
-be restricted to small areas to avoid large inaccuracies that may arise from the different extents of cells
-along the latitudinal and longitudinal axes.
-<p>
-Distances specfied in map units will be approximated as accurately as the current region's cell resolution
-settings allow. The program will warn if the distance cannot be expressed as whole
-cells at the current region's resolution. In such case, the number of cells in the search window
-will be rounded up. Due to the rounding effect introduced by using cells as spatial units,
-the actual maximum distance considered by the interpolation may be up to half a cell diagonal
-larger than the one specified by the user.
-<p>
-The interpolator type "wmean" uses a pre-computed matrix of spatial weights To speed up computation. This matrix can
-be examined (printed to the screen) before running the interpolation, by setting the <em>-w</em> flag.
-In mode "wmean", the <em>power=</em> option has the usual meaning: higher values mean
-that cell values in the neighborhood lose their influence on the cell to be interpolated more rapidly with increasing distance from the latter.
-Another way of explaining this effect is to state that larger "power" settings result in more
-localized interpolation, smaller ones in more globalized interpolation. The default setting is <em>power=2.0</em>.
-<p>
-The interpolators "mean", "median" and "mode" are calculated from all cell values
-within the search radius. No spatial weighting is applied for these methods.
-The "mode" of the input data may not always be unique. In such case, the mode will be the smallest
-value with the highest frequency.
-<p>
-Often, input data will contain spurious extreme measurements (spikes, outliers, noise) caused by the limits
-of device sensitivity, hardware defects, environmental influences, etc. If the normal, valid
-range of input data is known beforehand, then the <em>minimum=</em> and <em>maximum=</em> options can be used
-to exclude those input cells that have values below or above that range, respectively.
-This will prevent the influence of spikes and outliers from spreading through the interpolation.
-<p>
-Unless the <em>-p</em> (replace) flag is given, data cells of the input map will be replaced
-with interpolated values instead of preserving them in the output.
-Besides the result of the interpolation/gap filling, a second output map can be specified via the
-<em>uncertainty=</em> option. The cell values in this map represent a simple measure of how
-much uncertainty was involved in interpolating each cell value of the primary output map, with
-"0" being the lowest and "1" being the theoretic highest uncertainty. Uncertainty is measured
-by summing up all cells in the neighborhood (defined by the search radius <em>distance=</em>) that contain a value in the <em>input</em> map,
-multiplied by their weights, and dividing the result by the sum of all weights in the neighborhood.
-For <em>mode=wmean</em>, this means that interpolated output cells that
-were computed from many nearby input cells have very low uncertainty and vice versa.
-For all other modes, all weights in the neighborhood are constant "1" and the uncertainty measure
-is a simple measure of how many input data cells were present in the search window.
-<h2>NOTES</h2>
-The key to getting good gap filling results is to understand the spatial weighting scheme
-used in mode "wmean". The weights are precomputed and assigned per cell within the search
-window centered on the location at which to interpolate/gap fill all cells within
-the user-specified distance.
-<p>
-The illustration below shows the precomputed weights matrix for a search distance of four cells from the center cell:
-<pre>
-000.00 000.01 000.04 000.07 000.09 000.07 000.04 000.01 000.00
-000.01 000.06 000.13 000.19 000.22 000.19 000.13 000.06 000.01
-000.04 000.13 000.25 000.37 000.42 000.37 000.25 000.13 000.04
-000.07 000.19 000.37 000.56 000.68 000.56 000.37 000.19 000.07
-000.09 000.22 000.42 000.68 001.00 000.68 000.42 000.22 000.09
-</pre>
-Note that the weights in such a small window drop rapidly for the default setting of <em>power=2</em>.
-<p>
-If the distance is given in map units (flag <em>-m</em>), then the search window can be modeled more accurately as a circle.
-The illustration below shows the precomputed weights for a distance in map units that is approximately equivalent to four cells from the center cell:
-<pre>
-...... ...... ...... 000.00 000.00 000.00 ...... ...... ......
-...... 000.00 000.02 000.06 000.09 000.06 000.02 000.00 ......
-...... 000.02 000.11 000.22 000.28 000.22 000.11 000.02 ......
-000.00 000.07 000.22 000.44 000.58 000.44 000.22 000.07 000.00
-000.00 000.09 000.28 000.58 001.00 000.58 000.28 000.09 000.00
-</pre>
-<p>
-When using a small search radius, <em>cells=</em> must also be set to a small value. Otherwise, there may not be enough cells with data within
-the search radius to support interpolation.
-<p>
-This module can handle cells with different X and Y resolutions. However, note that the weight matrix
-will be skewed in such cases, with higher weights occurring close to the center and along the axis with the higher resolution.
-This is because weights on the lower resolution axis are less accurately calculated.
-The skewing effect will be stronger if the difference between the X and Y axis resolution  is greater and a larger "power" setting is chosen.
-This property of the weights matrix directly reflects the higher information density along the higher resolution axis.
-<p>
-Note on printing the weights matrix (using the <em>-w</em> flag): the matrix cannot be printed if it is too large.
-<p>
-The memory estimate provided by the <em>-m</em> flag is a lower limit on the amount of RAM that will be needed.
-<p>
-If the <em>-s</em> flag is set, floating point type output will be saved as a "single precision" raster map, saving ~50% disk space compared to the default "double precision" output.
-<h2>EXAMPLES</h2>
-Gap-fill a dataset using spatially weighted mean (IDW) and a maximum search radius of 3.0 map units;
-also produce uncertainty estimation map:
-<pre>
-r.fill.gaps input=measurements output=result dist=3.0 -m mode=wmean uncertainty=uncert_map
-</pre>
-Run a fast low-pass filter (replacement all cells with mean value of neighboring cells) on the input map:
-<pre>
-r.fill.gaps input=measurements output=result dist=10 mode=mean
-</pre>
-Fill data gaps in a categorized raster map; preserve existing data:
-<pre>
-r.fill.gaps input=categories output=result dist=100 -m mode=mode -p
-</pre>
-<h2>SEE ALSO</h2>
-<em><a href="http://en.wikipedia.org/wiki/Inverse_distance_weighting">Wikipedia on Inverse Distance Weighting</a></em>,<br>
-<em><a href="r.neighbors.html">r.neighbors</a></em>,<br>
-<em><a href="r.surf.idw2.html">r.surf.idw</a></em>,<br>
-<em><a href="v.surf.idw.html">v.surf.idw</a></em>,<br>
-<em><a href="v.surf.rst.html">v.surf.rst</a></em>
-<h2>CAVEATS</h2>
-The straight-line metric used for converting distances in map units to cell numbers is only adequate for planar coordinate systems.
-Using this module with lat/lon input data will likely give inaccurate results, especially when interpolating over large geographical areas.
-<p>
-If the distance is set to a relatively large value, processing time
-will quickly approach and eventually exceed that of point-based interpolation modules such
-as <em><a href="v.surf.rst.html">v.surf.rst</a></em>.
-<h2>AUTHOR</h2>
-Benjamin Ducke <br>
-<p>
-Latest revision: <i>Mar 20 2015</i>.
Modified: grass-addons/grass7/raster/r.fill.gaps/main.c
--- grass-addons/grass7/raster/r.fill.gaps/main.c	2017-04-14 22:31:39 UTC (rev 70879)
+++ grass-addons/grass7/raster/r.fill.gaps/main.c	2017-04-14 22:37:29 UTC (rev 70880)
@@ -152,7 +152,7 @@
     G_message(_("Spatial weights neighborhood (cells):"));
     for (i = 0; i < rows; i++) {
-        G_strncpy(weight_matrix_line_buf, "", 1);
+        weight_matrix_line_buf[0] = '\0';
         for (j = 0; j < cols; j++) {
             if (WEIGHTS[i][j] != -1.0) {
                 snprintf(weight_matrix_weight_buf, weight_matrix_line_length,
@@ -170,12 +170,12 @@
             if (strlen(weight_matrix_weight_buf) +
                 strlen(weight_matrix_line_buf) > weight_matrix_line_length) {
-                G_strncpy(weight_matrix_line_buf, "[line too long to print]",
-                          weight_matrix_line_length);
+                strncpy(weight_matrix_line_buf, "[line too long to print]",
+                        weight_matrix_line_length);
                 break;
             else {
-                G_strcat(weight_matrix_line_buf, weight_matrix_weight_buf);
+                strcat(weight_matrix_line_buf, weight_matrix_weight_buf);
         fprintf(stdout, "%s\n", weight_matrix_line_buf);
@@ -356,11 +356,11 @@
                     /* center cell: copy through if needed */
                     stats->overwrite = G_malloc(sizeof(double));
                     *stats->overwrite =
-                        (double)G_get_raster_value_d(cell, IN_TYPE);
+                        (double)Rast_get_d_value(cell, IN_TYPE);
                 else {
                     /* only add non-null cells to stats */
-                    cell_value = (double)G_get_raster_value_d(cell, IN_TYPE);
+                    cell_value = (double)Rast_get_d_value(cell, IN_TYPE);
                     /* only add if within neighborhood */
                         /* get data needed for chosen statistic */
@@ -522,8 +522,7 @@
         cell_input += CELL_IN_SIZE;
     /* get next row from disk */
-    G_get_raster_row(file_desc, cell_input, current_row + DATA_HEIGHT,
-                     IN_TYPE);
+    Rast_get_row(file_desc, cell_input, current_row + DATA_HEIGHT, IN_TYPE);
     /* re-assign all row handlers below current replacement position */
     j = PADDING_HEIGHT;
@@ -568,7 +567,7 @@
         if (stats->num_values < min_cells) {
             SET_NULL(cell_output, 1);
             if (write_err)
-                G_set_f_null_value(err_output, 1);
+                Rast_set_f_null_value(err_output, 1);
         else {
             if (stats->overwrite != NULL) {
@@ -583,10 +582,10 @@
             /* write error/uncertainty output map? */
             if (write_err) {
-                G_set_raster_value_f(err_output,
-                                     (FCELL) 1.0 -
-                                     (stats->certainty / SUM_WEIGHTS),
-                                     FCELL_TYPE);
+                Rast_set_f_value(err_output,
+                                 (FCELL) 1.0 -
+                                 (stats->certainty / SUM_WEIGHTS),
+                                 FCELL_TYPE);
         /* advance cell pointers by one cell size */
@@ -1010,25 +1009,21 @@
     /* open raster input map and get its storage type */
-    mapset = G_find_cell2(input, "");
+    mapset = G_find_raster(input, "");
     if (!mapset)
         G_fatal_error(_("Raster map <%s> not found"), input);
-    if (G_get_cellhd(input, mapset, &cellhd) < 0)
-        G_fatal_error(_("Unable to read header of raster map <%s@%s>"), input,
-                      mapset);
-    if ((in_fd = G_open_cell_old(input, mapset)) < 0)
-        G_fatal_error(_("Unable to open raster map <%s> in mapset <%s>"),
-                      input, mapset);
-    IN_TYPE = G_get_raster_map_type(in_fd);
+    Rast_get_cellhd(input, mapset, &cellhd);
+    in_fd = Rast_open_old(input, mapset);
+    IN_TYPE = Rast_get_map_type(in_fd);
     /* minimum and maximum values for interpolating range */
     if (IN_TYPE == CELL_TYPE) {
-        G_read_range(input, mapset, &int_range);
+        Rast_read_range(input, mapset, &int_range);
         min = (double)int_range.min;
         max = (double)int_range.max;
     else {
-        G_read_fp_range(input, mapset, &fp_range);
+        Rast_read_fp_range(input, mapset, &fp_range);
         min = (double)fp_range.min;
         max = (double)fp_range.max;
@@ -1074,26 +1069,26 @@
-    char data_type_string_in[21];
-    char data_type_string_out[21];
+    char *data_type_string_in;
+    char *data_type_string_out;
-        G_strncpy(data_type_string_in, "integer", 20);
+        data_type_string_in = "integer";
     else if (IN_TYPE == FCELL_TYPE) {
-        G_strncpy(data_type_string_in, "single", 20);
+        data_type_string_in = "single";
     else if (IN_TYPE == DCELL_TYPE) {
-        G_strncpy(data_type_string_in, "double", 20);
+        data_type_string_in = "double";
     if (OUT_TYPE == CELL_TYPE) {
-        G_strncpy(data_type_string_out, "integer", 20);
+        data_type_string_out = "integer";
     else if (OUT_TYPE == FCELL_TYPE) {
-        G_strncpy(data_type_string_out, "single", 20);
+        data_type_string_out = "single";
     else if (OUT_TYPE == DCELL_TYPE) {
-        G_strncpy(data_type_string_out, "double", 20);
+        data_type_string_out = "double";
     /* initialize data type dependent cell handling functions */
@@ -1123,7 +1118,8 @@
         CELL_INPUT[i] = G_malloc(CELL_IN_SIZE * (cols + (PADDING_WIDTH * 2)));
     for (i = 0; i < WINDOW_HEIGHT; i++) {
-        G_set_null_value(CELL_INPUT[i], cols + (PADDING_WIDTH * 2), IN_TYPE);
+        Rast_set_null_value(CELL_INPUT[i], cols + (PADDING_WIDTH * 2),
+                            IN_TYPE);
@@ -1201,14 +1197,14 @@
     /* Open output map with right data type */
-    out_fd = G_open_raster_new(output, OUT_TYPE);
+    out_fd = Rast_open_new(output, OUT_TYPE);
     if (out_fd < 0) {
         G_fatal_error("Cannot open output map.");
         exit(EXIT_FAILURE);
     /* Reserve memory for one output row buffer */
-    CELL_OUTPUT = G_allocate_raster_buf(OUT_TYPE);
+    CELL_OUTPUT = Rast_allocate_buf(OUT_TYPE);
     /* initialize output row */
     SET_NULL(CELL_OUTPUT, cols);
@@ -1216,14 +1212,14 @@
     /* produce uncertainty output map? */
     if (parm.error->answer) {
-        err_fd = G_open_raster_new(parm.error->answer, FCELL_TYPE);
+        err_fd = Rast_open_new(parm.error->answer, FCELL_TYPE);
         if (err_fd < 0) {
             G_fatal_error("Cannot open uncertainty output map.");
             exit(EXIT_FAILURE);
-        ERR_OUTPUT = G_allocate_raster_buf(FCELL_TYPE);
+        ERR_OUTPUT = Rast_allocate_buf(FCELL_TYPE);
-        G_set_f_null_value(ERR_OUTPUT, cols);
+        Rast_set_f_null_value(ERR_OUTPUT, cols);
     /* row indices to handle input data buffer */
@@ -1250,16 +1246,16 @@
         for (j = 0; j < PADDING_WIDTH; j++) {
-        G_get_raster_row(in_fd, cell_input, i, IN_TYPE);
+        Rast_get_row(in_fd, cell_input, i, IN_TYPE);
     for (i = 0; i <= PADDING_HEIGHT; i++) {
         row_idx = PADDING_HEIGHT + i;
         interpolate_row(row_idx, cols, min, max, parm.preserve->answer,
                         min_cells, &cell_stats, write_error);
         /* write output row buffer to disk */
-        G_put_raster_row(out_fd, CELL_OUTPUT, OUT_TYPE);
+        Rast_put_row(out_fd, CELL_OUTPUT, OUT_TYPE);
-            G_put_raster_row(err_fd, ERR_OUTPUT, FCELL_TYPE);
+            Rast_put_row(err_fd, ERR_OUTPUT, FCELL_TYPE);
         G_percent(current_row + 1, rows, 2);
         current_row++;
@@ -1273,9 +1269,9 @@
         current_row++;
@@ -1285,25 +1281,25 @@
     for (i = rows - DATA_HEIGHT; i < rows; i++) {
         row_idx = (DATA_HEIGHT + PADDING_HEIGHT) - (rows - i);
         cell_input = get_input_row(row_idx);
     for (i = rows - PADDING_HEIGHT - 1; i < rows; i++) {
         row_idx = PADDING_HEIGHT + (DATA_HEIGHT) - (rows - i);
         current_row++;
     /* close all maps */
-    G_close_cell(out_fd);
-    G_close_cell(in_fd);
+    Rast_close(out_fd);
+    Rast_close(in_fd);
-        G_close_cell(err_fd);
+        Rast_close(err_fd);
     /* Free memory */
@@ -1330,31 +1326,34 @@
     G_free(cell_stats.frequencies);
     /* write metadata into result and error maps */
-    G_short_history(parm.output->answer, "raster", &hist);
-    sprintf(hist.title, "Result of interpolation/gap filling");
-    hist.edlinecnt = 2;
+    Rast_short_history(parm.output->answer, "raster", &hist);
+    Rast_put_cell_title(parm.output->answer,
+                        "Result of interpolation/gap filling");
     if (parm.dist_m->answer) {
-        sprintf(hist.edhist[0],
-                "Settings: mode=%s, distance (map units)=%.6f, power=%.3f",
-                parm.mode->answer, radius, power);
+        Rast_append_format_history(&hist,
+                                   "Settings: mode=%s, distance (map units)=%.6f, power=%.3f",
+                                   parm.mode->answer, radius, power);
     else {
-                "Settings: mode=%s, distance (cells)=%lu, power=%.3f",
-                parm.mode->answer, (unsigned long)radius, power);
+                                   "Settings: mode=%s, distance (cells)=%lu, power=%.3f",
+                                   parm.mode->answer, (unsigned long)radius,
+                                   power);
-    sprintf(hist.edhist[1], "          min=%.3f, max=%.3f, min. points=%lu",
-            min, max, min_cells);
-    G_write_history(parm.output->answer, &hist);
+                               "          min=%.3f, max=%.3f, min. points=%lu",
+                               min, max, min_cells);
+    Rast_write_history(parm.output->answer, &hist);
-        G_short_history(parm.error->answer, "raster", &hist);
-        sprintf(hist.title, "Uncertainty of interpolation/gap filling");
-        sprintf(hist.edhist[0], "Result map: %s", parm.output->answer);
-                "Theoretic range is '0' (lowest) to '1' (highest).");
-        G_write_history(parm.error->answer, &hist);
+        Rast_short_history(parm.error->answer, "raster", &hist);
+        Rast_put_cell_title(parm.error->answer,
+                            "Uncertainty of interpolation/gap filling");
+        Rast_append_format_history(&hist, "Result map: %s",
+                                   parm.output->answer);
+                                   "Theoretic range is '0' (lowest) to '1' (highest).");
+        Rast_write_history(parm.error->answer, &hist);
     finish = time(NULL);
Deleted: grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.01.png
(Binary files differ)
Deleted: grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.02.png
Copied: grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.html (from rev 70879, grass-addons/grass7/raster/r.fill.gaps/description.html)
--- grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.html	2017-04-14 22:37:29 UTC (rev 70880)
@@ -0,0 +1,255 @@
+<h2>DESCRIPTION</h2>
+<em><b>r.fill.gaps</b></em> - Fast gap filling and interpolation of dense raster data.
+<p>
+The <em>r.fill.gaps</em> module is capable of quickly filling small "no data" areas (gaps) in large raster maps.
+As a rule of thumb, there should be at least as many data cells as there are "no data" cells in
+the input raster map. Several interpolation modes are available.
+By default, all values of the input raster map will be replaced with locally interpolated values in the output raster map.
+With dense data and small gaps, this should result in only slight deviations from the original data
+and produce smooth output. Alternatively, setting the <em>-p</em> flag will preserve the original cell values.
+<p>
+Available gap filling modes:
+<ul>
+<li>spatially weighted mean (default)</li>
+<li>simple mean</li>
+<li>simple median</li>
+<li>simple mode</li>
+</ul>
+<p>
+The spatially weighted mean is equivalent to an Inverse Distance Weighting (IDW; see
+also <em><a href="r.surf.idw.html">r.surf.idw</a></em>) interpolation. The simple
+mean is equivalent to a low-pass filter. Median and mode replacements can also be
+achieved using <em><a href="r.neighbors.html">r.neighbors</a></em>.
+<p>
+Note that <em>r.fill.gaps</em> is highly optimized for fast processing of large raster datasets
+with a small interpolation distance threshold (i.e. closing small gaps). As a trade-off
+for speed and a small memory foot print, some spatial accuracy is lost due to the rounding
+of the distance threshold to the closest approximation in input raster cells and the use of a matrix of precomputed weights at cell resolution (see further
+down for details). Note also that processing time will increase exponentially with higher distance settings.
+Cells outside the distance threshold will not be interpolated, preserving the edges of the data zones in the input data.
+<p>
+This module is not well suited for interpolating sparse input data and closing large gaps.
+For such purposes solutions more appropriate methods are available, such as <em><a href="v.surf.idw.html">v.surf.idw</a></em>
+or <em><a href="v.surf.rst.html">v.surf.rst</a></em>.
+<p>
+Applications where the properties of <em>r.fill.gaps</em> are advantageous include the processing of
+high resolution, close range scanning and remote sensing datasets. Such datasets commonly feature densely spaced
+measurements that have some gaps after rasterization, due to blind spots, instrument failures,
+and misalignments between the GIS' raster cell grids and the original measurement locations.
+In these cases, <em>r.fill.gaps</em> should typically be run using the "weighted mean" (default) method
+and with a small distance setting (the default is to use a search radius of just three cells).
+<p>
+The images below show a gradiometer dataset with gaps and its interpolated equivalent, produced using
+the spatially weighted mean operator (<em>mode="wmean"</em>).
+<p>
+<img src="r_fill_gaps_01.png" alt="">  <img src="r_fill_gaps_02.png" alt="">
+<p>
+In addition, <em>r.fill.gaps</em> can be useful for raster map generalization. Often, this involves removing small
+clumps of categorized cells and then filling the resulting data gaps without "inventing" any new values.
+In such cases, the "mode" or "median" interpolators should be used.
+<h2>USAGE</h2>
+The most critical user-provided settings are the interpolation/gap filling method (<em>mode=</em>)
+and the maximum distance, up to which <em>r.fill.gaps</em> will scan for given data points
+when attempting to fill/interpolate a value at any given location (<em>distance=</em>).
+The distance can be expressed as a number of cells (default) or in the current location's units (if the <em>-m</em> flag is given).
+The latter are typically meters, but can be any other units of a <em>planar</em> coordinate system.
+<p>
+Note that proper handling of geodetic coordinates (lat/lon) and distances is currently not implemented.
+For lat/lon data, the distance should therefore be specified in cells and usage of <em>r.fill.gaps</em> should
+be restricted to small areas to avoid large inaccuracies that may arise from the different extents of cells
+along the latitudinal and longitudinal axes.
+<p>
+Distances specfied in map units will be approximated as accurately as the current region's cell resolution
+settings allow. The program will warn if the distance cannot be expressed as whole
+cells at the current region's resolution. In such case, the number of cells in the search window
+will be rounded up. Due to the rounding effect introduced by using cells as spatial units,
+the actual maximum distance considered by the interpolation may be up to half a cell diagonal
+larger than the one specified by the user.
+<p>
+The interpolator type "wmean" uses a pre-computed matrix of spatial weights To speed up computation. This matrix can
+be examined (printed to the screen) before running the interpolation, by setting the <em>-w</em> flag.
+In mode "wmean", the <em>power=</em> option has the usual meaning: higher values mean
+that cell values in the neighborhood lose their influence on the cell to be interpolated more rapidly with increasing distance from the latter.
+Another way of explaining this effect is to state that larger "power" settings result in more
+localized interpolation, smaller ones in more globalized interpolation. The default setting is <em>power=2.0</em>.
+<p>
+The interpolators "mean", "median" and "mode" are calculated from all cell values
+within the search radius. No spatial weighting is applied for these methods.
+The "mode" of the input data may not always be unique. In such case, the mode will be the smallest
+value with the highest frequency.
+<p>
+Often, input data will contain spurious extreme measurements (spikes, outliers, noise) caused by the limits
+of device sensitivity, hardware defects, environmental influences, etc. If the normal, valid
+range of input data is known beforehand, then the <em>minimum=</em> and <em>maximum=</em> options can be used
+to exclude those input cells that have values below or above that range, respectively.
+This will prevent the influence of spikes and outliers from spreading through the interpolation.
+<p>
+Unless the <em>-p</em> (replace) flag is given, data cells of the input map will be replaced
+with interpolated values instead of preserving them in the output.
+Besides the result of the interpolation/gap filling, a second output map can be specified via the
+<em>uncertainty=</em> option. The cell values in this map represent a simple measure of how
+much uncertainty was involved in interpolating each cell value of the primary output map, with
+"0" being the lowest and "1" being the theoretic highest uncertainty. Uncertainty is measured
+by summing up all cells in the neighborhood (defined by the search radius <em>distance=</em>) that contain a value in the <em>input</em> map,
+multiplied by their weights, and dividing the result by the sum of all weights in the neighborhood.
+For <em>mode=wmean</em>, this means that interpolated output cells that
+were computed from many nearby input cells have very low uncertainty and vice versa.
+For all other modes, all weights in the neighborhood are constant "1" and the uncertainty measure
+is a simple measure of how many input data cells were present in the search window.
+<h2>NOTES</h2>
+The key to getting good gap filling results is to understand the spatial weighting scheme
+used in mode "wmean". The weights are precomputed and assigned per cell within the search
+window centered on the location at which to interpolate/gap fill all cells within
+the user-specified distance.
+<p>
+The illustration below shows the precomputed weights matrix for a search distance of four cells from the center cell:
+<pre>
+000.00 000.01 000.04 000.07 000.09 000.07 000.04 000.01 000.00
+000.01 000.06 000.13 000.19 000.22 000.19 000.13 000.06 000.01
+000.04 000.13 000.25 000.37 000.42 000.37 000.25 000.13 000.04
+000.07 000.19 000.37 000.56 000.68 000.56 000.37 000.19 000.07
+000.09 000.22 000.42 000.68 001.00 000.68 000.42 000.22 000.09
+</pre>
+Note that the weights in such a small window drop rapidly for the default setting of <em>power=2</em>.
+<p>
+If the distance is given in map units (flag <em>-m</em>), then the search window can be modeled more accurately as a circle.
+The illustration below shows the precomputed weights for a distance in map units that is approximately equivalent to four cells from the center cell:
+<pre>
+...... ...... ...... 000.00 000.00 000.00 ...... ...... ......
+...... 000.00 000.02 000.06 000.09 000.06 000.02 000.00 ......
+...... 000.02 000.11 000.22 000.28 000.22 000.11 000.02 ......
+000.00 000.07 000.22 000.44 000.58 000.44 000.22 000.07 000.00
+000.00 000.09 000.28 000.58 001.00 000.58 000.28 000.09 000.00
+</pre>
+<p>
+When using a small search radius, <em>cells=</em> must also be set to a small value. Otherwise, there may not be enough cells with data within
+the search radius to support interpolation.
+<p>
+This module can handle cells with different X and Y resolutions. However, note that the weight matrix
+will be skewed in such cases, with higher weights occurring close to the center and along the axis with the higher resolution.
+This is because weights on the lower resolution axis are less accurately calculated.
+The skewing effect will be stronger if the difference between the X and Y axis resolution  is greater and a larger "power" setting is chosen.
+This property of the weights matrix directly reflects the higher information density along the higher resolution axis.
+<p>
+Note on printing the weights matrix (using the <em>-w</em> flag): the matrix cannot be printed if it is too large.
+<p>
+The memory estimate provided by the <em>-m</em> flag is a lower limit on the amount of RAM that will be needed.
+<p>
+If the <em>-s</em> flag is set, floating point type output will be saved as a "single precision" raster map, saving ~50% disk space compared to the default "double precision" output.
+<h2>EXAMPLES</h2>
+Gap-fill a dataset using spatially weighted mean (IDW) and a maximum search radius of 3.0 map units;
+also produce uncertainty estimation map:
+<pre>
+r.fill.gaps input=measurements output=result dist=3.0 -m mode=wmean uncertainty=uncert_map
+</pre>
+Run a fast low-pass filter (replacement all cells with mean value of neighboring cells) on the input map:
+<pre>
+r.fill.gaps input=measurements output=result dist=10 mode=mean
+</pre>
+Fill data gaps in a categorized raster map; preserve existing data:
+<pre>
+r.fill.gaps input=categories output=result dist=100 -m mode=mode -p
+</pre>
+<h2>SEE ALSO</h2>
+<em><a href="http://en.wikipedia.org/wiki/Inverse_distance_weighting">Wikipedia on Inverse Distance Weighting</a></em>,<br>
+<em><a href="r.neighbors.html">r.neighbors</a></em>,<br>
+<em><a href="r.surf.idw2.html">r.surf.idw</a></em>,<br>
+<em><a href="v.surf.idw.html">v.surf.idw</a></em>,<br>
+<em><a href="v.surf.rst.html">v.surf.rst</a></em>
+<h2>CAVEATS</h2>
+The straight-line metric used for converting distances in map units to cell numbers is only adequate for planar coordinate systems.
+Using this module with lat/lon input data will likely give inaccurate results, especially when interpolating over large geographical areas.
+<p>
+If the distance is set to a relatively large value, processing time
+will quickly approach and eventually exceed that of point-based interpolation modules such
+as <em><a href="v.surf.rst.html">v.surf.rst</a></em>.
+<h2>AUTHOR</h2>
+Benjamin Ducke <br>
+<p>
+Latest revision: <i>Mar 20 2015</i>.
Copied: grass-addons/grass7/raster/r.fill.gaps/r_fill_gaps_01.png (from rev 70879, grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.01.png)
Copied: grass-addons/grass7/raster/r.fill.gaps/r_fill_gaps_02.png (from rev 70879, grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.02.png)
