[GRASS-SVN] r70884 - grass-addons/grass7/raster/r.fill.gaps
svn_grass at osgeo.org
Sat Apr 15 18:26:20 PDT 2017
Author: wenzeslaus
Date: 2017-04-15 18:26:20 -0700 (Sat, 15 Apr 2017)
New Revision: 70884
Added:
grass-addons/grass7/raster/r.fill.gaps/r_fill_gaps_smoothing.png
grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.html
r.fill.gaps: figure showing influence of smoothing
Modified: grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.html
--- grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.html 2017-04-15 22:02:34 UTC (rev 70883)
+++ grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.html 2017-04-16 01:26:20 UTC (rev 70884)
@@ -173,6 +173,60 @@
are constant "1" and the uncertainty measure is a simple measure of how
many input data cells were present in the search window.
+<h3>Smoothing</h3>
+<center>
+<img src="r_fill_gaps_smoothing.png" alt="Smooth versus preserve">
+<p><em>
+The top row shows resulting surface (ground surface from lidar point
+cloud), its slope, aspect, and profile curvature
+using <tt>mode=wmean</tt> and <tt>power=2</tt>.
+The bottom row shows the same but using the <b>-p</b> flag,
+i.e. the original cell values were used, not the interpolated (and thus
+smoothed) ones.
+</em></p>
+</center>
+<!-- TODO: discuss r.slope.aspect versus r.param.scale -->
+r.fill.gaps input=ground output=ground_filled mode=wmean power=2.0 cells=8
+r.fill.gaps -p input=ground output=ground_filled2 mode=wmean power=2.0 cells=8
+r.slope.aspect elevation=ground_filled slope=slope aspect=aspect pcurvature=pcur tcurvature=tcur
+r.slope.aspect elevation=ground_filled2 slope=slope2 aspect=aspect2 pcurvature=pcur2 tcurvature=tcur2
+g.region n=219537 s=219172 w=636852 e=637218 -p
+d.mon cairo output=r_fill_gaps_smoothing.png width=600 height=300
+export GRASS_FONT=LiberationSans-Regular
+d.frame frame=u1 at=50,100,0,25 -c
+d.rast ground_filled
+d.text text="surf. (smoothed)" at=5,5 size=10 bgcolor=white color=black
+d.frame frame=u2 at=50,100,25,50 -c
+d.rast slope
+d.text text="slope" at=5,5 size=10 bgcolor=white color=black
+d.frame frame=u3 at=50,100,50,75 -c
+d.rast aspect
+d.text text="aspect" at=5,5 size=10 bgcolor=white color=black
+d.frame frame=u4 at=50,100,75,100 -c
+d.rast pcur
+d.text text="prof. curvature" at=5,5 size=10 bgcolor=white color=black
+d.frame frame=l1 at=0,50,0,25 -c
+d.rast ground_filled2
+d.text text="surf. (preserved)" at=5,5 size=10 bgcolor=white color=black
+d.frame frame=l2 at=0,50,25,50 -c
+d.rast slope2
+d.frame frame=l3 at=0,50,50,75 -c
+d.rast aspect2
+d.frame frame=l4 at=0,50,75,100 -c
+d.rast pcur2
+d.mon stop=cairo
<h3>Spatial weighting scheme</h3>
The key to getting good gap filling results is to understand the
@@ -296,6 +350,11 @@
<h3>Lidar point cloud example</h3>
+Using:
+http://fatra.cnr.ncsu.edu/uav-lidar-analytics-course/midpines_2015_spm.las
Inspect the point density and determine the extent of the point cloud
using the <em><a href="r.in.lidar.html">r.in.lidar</a></em> module:
Added: grass-addons/grass7/raster/r.fill.gaps/r_fill_gaps_smoothing.png
(Binary files differ)
Property changes on: grass-addons/grass7/raster/r.fill.gaps/r_fill_gaps_smoothing.png
___________________________________________________________________
Added: svn:mime-type
+ image/png
