[GRASS-SVN] r70895 - grass-addons/grass7/raster/r.fill.gaps
svn_grass at osgeo.org
Mon Apr 17 12:18:12 PDT 2017
Author: wenzeslaus
Date: 2017-04-17 12:18:12 -0700 (Mon, 17 Apr 2017)
New Revision: 70895
grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.html
grass-addons/grass7/raster/r.fill.gaps/r_fill_gaps_smoothing.png
r.fill.gaps: use high-res image, add description
Modified: grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.html
--- grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.html 2017-04-17 18:26:58 UTC (rev 70894)
+++ grass-addons/grass7/raster/r.fill.gaps/r.fill.gaps.html 2017-04-17 19:18:12 UTC (rev 70895)
@@ -175,8 +175,15 @@
<h3>Smoothing</h3>
+The <em>r.fill.gaps</em> uses the interpolated values to create
+a smooth surface. It can also preserve the original raster values
+and combine them with the interpolated ones when the <b>-p</b> flag
+is specified.
<center>
-<img src="r_fill_gaps_smoothing.png" alt="Smooth versus preserve">
+<a href="r_fill_gaps_smoothing.png">
+ <img src="r_fill_gaps_smoothing.png" alt="Smooth versus preserve" width="600" height="300">
+</a>
<p><em>
The top row shows resulting surface (ground surface from lidar point
cloud), its slope, aspect, and profile curvature
@@ -187,9 +194,23 @@
</em></p>
</center>
-<!-- TODO: discuss r.slope.aspect versus r.param.scale -->
+When the slope, aspect, and profile curvature are computed using the
+<em><a href="r.slope.aspect.html">r.slope.aspect</a></em> module
+as in the figure above, only the immediate cell neighborhood is
+considered the result with may contain artifacts caused by combining
+the interpolated and original values in the surface (using the
+<b>-p</b> flag). The effect of this can be avoided with certain modules,
+for example the aspect and other morphometric parameters can computed
+using the <em><a href="r.param.scale.html">r.param.scale</a></em> module
+which considers larger cell neighborhood.
+wget http://fatra.cnr.ncsu.edu/uav-lidar-analytics-course/midpines_2015_spm.las -O points.las
+g.region n=220220 s=218690 e=637800 w=636270 res=1
+r.in.lidar input=points.las output=ground method=mean class_filter=2
r.fill.gaps input=ground output=ground_filled mode=wmean power=2.0 cells=8
r.fill.gaps -p input=ground output=ground_filled2 mode=wmean power=2.0 cells=8
@@ -198,7 +219,7 @@
g.region n=219537 s=219172 w=636852 e=637218 -p
-d.mon cairo output=r_fill_gaps_smoothing.png width=600 height=300
+d.mon cairo output=r_fill_gaps_smoothing.png width=1464 height=730
export GRASS_FONT=LiberationSans-Regular
d.frame frame=u1 at=50,100,0,25 -c
d.rast ground_filled
Modified: grass-addons/grass7/raster/r.fill.gaps/r_fill_gaps_smoothing.png
(Binary files differ)
