[GRASS-SVN] r70911 - grass-addons/grass7/raster/r.learn.ml
Fri Apr 21 20:32:03 PDT 2017
Author: spawley
Date: 2017-04-21 20:32:03 -0700 (Fri, 21 Apr 2017)
New Revision: 70911
Removed:
   grass-addons/grass7/raster/r.learn.ml/raster_learning.py
   grass-addons/grass7/raster/r.learn.ml/Makefile
   grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py
r.learn.ml reorganized module structure
Modified: grass-addons/grass7/raster/r.learn.ml/Makefile
--- grass-addons/grass7/raster/r.learn.ml/Makefile	2017-04-22 03:25:48 UTC (rev 70910)
+++ grass-addons/grass7/raster/r.learn.ml/Makefile	2017-04-22 03:32:03 UTC (rev 70911)
@@ -1,8 +1,6 @@
 MODULE_TOPDIR = ../..
 PGM = r.learn.ml
-ETCFILES = raster_learning
 include $(MODULE_TOPDIR)/include/Make/Script.make
 include $(MODULE_TOPDIR)/include/Make/Python.make
Modified: grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py
--- grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py	2017-04-22 03:25:48 UTC (rev 70910)
+++ grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py	2017-04-22 03:32:03 UTC (rev 70911)
@@ -356,23 +356,830 @@
 import atexit
 import os
+import tempfile
+import itertools
+from copy import deepcopy
 import numpy as np
+from numpy.random import RandomState
 import grass.script as grass
-from copy import deepcopy
 from grass.pygrass.modules.shortcuts import raster as r
-from grass.pygrass.utils import set_path
+from grass.pygrass.raster import RasterRow
+from grass.pygrass.gis.region import Region
+from grass.pygrass.raster.buffer import Buffer
+from grass.pygrass.modules.shortcuts import imagery as im
+from grass.pygrass.vector import VectorTopo
+from grass.pygrass.vector.table import Link
+from grass.pygrass.utils import get_raster_for_points
+from subprocess import PIPE
-set_path('r.learn.ml')
-from raster_learning import model_classifiers
-from raster_learning import save_training_data, load_training_data
-from raster_learning import maps_from_group, predict, cross_val_scores, extract_points
 tmp_rast = []
 def cleanup():
     for rast in tmp_rast:
         grass.run_command("g.remove", name=rast, type='raster', flags='f', quiet=True)
+def specificity_score(y_true, y_pred):
+    Function to calculate specificity score
+    Args
+    y_true: 1D numpy array of truth values
+    y_pred: 1D numpy array of predicted classes
+    Returns
+    specificity: specificity score
+    from sklearn.metrics import confusion_matrix
+    cm = confusion_matrix(y_true, y_pred)
+    tn = float(cm[0][0])
+    fp = float(cm[0][1])
+    return (tn/(tn+fp))
+def varimp_permutation(estimator, X_test, y_true,
+                       n_permutations, scorer,
+                       random_state):
+    Method to perform permutation-based feature importance during
+    cross-validation (cross-validation is applied externally to this
+    method)
+    Procedure is:
+    1. Pass fitted estimator and test partition X y
+    2. Assess AUC on the test partition (bestauc)
+    3. Permute each variable and assess the difference between bestauc and
+       the messed-up variable
+    4. Repeat (3) for many random permutations
+    5. Average the repeats
+    Args
+    estimator: estimator that has been fitted to a training partition
+    X_test, y_true: data and labels from a test partition
+    n_permutations: number of random permutations to apply
+    scorer: scikit-learn metric function to use
+    random_state: seed to pass to the numpy random.seed
+    Returns
+    scores: scores for each predictor following permutation
+    # calculate score on original variables without permutation
+    # determine best metric type for binary/multiclass/regression scenarios
+    y_pred = estimator.predict(X_test)
+    best_score = scorer(y_true, y_pred)
+    np.random.seed(seed=random_state)
+    rstate = RandomState(random_state)
+    scores = np.zeros((n_permutations, X_test.shape[1]))
+    # outer loop to repeat the pemutation rep times
+    for rep in range(n_permutations):
+        # inner loop to permute each predictor variable and assess
+        # difference in auc
+        for i in range(X_test.shape[1]):
+            Xscram = np.copy(X_test)
+            Xscram[:, i] = rstate.choice(X_test[:, i], X_test.shape[0])
+            # fit the model on the training data and predict the test data
+            y_pred = estimator.predict(Xscram)
+            scores[rep, i] = best_score-scorer(y_true, y_pred)
+            if scores[rep, i] < 0:
+                scores[rep, i] = 0
+    # average the repetitions
+    scores = scores.mean(axis=0)
+    return(scores)
+def cross_val_scores(estimator, X, y, groups=None, sample_weight=None, cv=3,
+                     scoring=['accuracy'], feature_importances=False,
+                     n_permutations=25, random_state=None):
+    Stratified Kfold and GroupFold cross-validation using multiple
+    scoring metrics and permutation feature importances
+    Args
+    estimator: Scikit learn estimator
+    X: 2D numpy array of training data
+    y: 1D numpy array representing response variable
+    groups: 1D numpy array containing group labels
+    sample_weight: 1D numpy array[n_samples,] of sample weights
+    cv: Integer of cross-validation folds or sklearn.model_selection object
+    sampling: Over- or under-sampling object with fit_sample method
+    scoring: List of performance metrics to use
+    feature_importances: Boolean to perform permutation-based importances
+    n_permutations: Number of permutations during feature importance
+    random_state: Seed to pass to the random number generator
+    from sklearn import metrics
+    from sklearn.model_selection import (
+        RandomizedSearchCV, GridSearchCV, StratifiedKFold)
+    estimator = deepcopy(estimator)
+    # create model_selection method
+    if isinstance(cv, int):
+        cv = StratifiedKFold(n_splits=cv)
+    # need the groups parameter because the estimator can be a
+    # RandomizedSearchCV or GridSearchCV estimator where cv=GroupKFold
+    if isinstance(estimator, RandomizedSearchCV) is True \
+            or isinstance(estimator, GridSearchCV):
+        param_search = True
+    else:
+        param_search = False
+    # create dictionary of lists to store metrics
+    scores = dict.fromkeys(scoring)
+    scores = { key: [] for key, value in scores.iteritems()}
+    scoring_methods = {'accuracy': metrics.accuracy_score,
+                       'balanced_accuracy': metrics.recall_score,
+                       'average_precision': metrics.average_precision_score,
+                       'brier_loss': metrics.brier_score_loss,
+                       'kappa': metrics.cohen_kappa_score,
+                       'f1': metrics.f1_score,
+                       'fbeta': metrics.fbeta_score,
+                       'hamming_loss': metrics.hamming_loss,
+                       'jaccard_similarity': metrics.jaccard_similarity_score,
+                       'log_loss': metrics.log_loss,
+                       'matthews_corrcoef': metrics.matthews_corrcoef,
+                       'precision': metrics.precision_score,
+                       'recall': metrics.recall_score,
+                       'specificity': specificity_score,
+                       'roc_auc': metrics.roc_auc_score,
+                       'zero_one_loss': metrics.zero_one_loss,
+                       'r2': metrics.r2_score,
+                       'neg_mean_squared_error': metrics.mean_squared_error}
+    byclass_methods = {'f1': metrics.f1_score,
+                       'recall': metrics.recall_score}
+    # create diction to store byclass metrics results
+    n_classes = len(np.unique(y))
+    labels = np.unique(y)
+    byclass_scores = dict.fromkeys(byclass_methods)
+    byclass_scores = { key: np.zeros((0, n_classes)) for key, value in byclass_scores.iteritems()}
+    # remove any byclass_scorers that are not in the scoring list
+    byclass_scores = {key: value for key, value in byclass_scores.iteritems() if key in scores}
+    # set averaging type for global binary or multiclass scores
+    if len(np.unique(y)) == 2 and all([0, 1] == np.unique(y)):
+        average='binary'
+    else:
+        average='macro'
+    # check to see if scoring is a valid sklearn metric
+    for i in scores.keys():
+        try:
+            list(scoring_methods.keys()).index(i)
+        except:
+            print('Scoring ' + i + ' is not a valid scoring method')
+            print('Valid methods are:')
+            print(scoring_methods.keys())
+    # create np array to store feature importance scores
+    if feature_importances is True:
+        fimp = np.zeros((cv.get_n_splits(), X.shape[1]))
+        fimp[:] = np.nan
+    else:
+        fimp = None
+    # generate Kfold indices
+    if groups is None:
+        k_fold = cv.split(X, y)
+    else:
+        k_fold = cv.split(X, y, groups=groups)
+    # train on k-1 folds and test of k folds
+    for train_indices, test_indices in k_fold:
+        # subset training and test fold data
+        X_train, X_test = X[train_indices], X[test_indices]
+        y_train, y_test = y[train_indices], y[test_indices]
+        # subset training and test fold group ids
+        if groups is not None: groups_train = groups[train_indices]
+        else: groups_train = None
+        # subset training and test fold sample_weight
+        if sample_weight is not None: weights = sample_weight[train_indices]
+        # train estimator on training fold
+        if groups is not None and param_search is True:
+            if sample_weight is None: estimator.fit(X_train, y_train, groups=groups_train)
+            else: estimator.fit(X_train, y_train, groups=groups_train, sample_weight=weights)
+        else:
+            if sample_weight is None: estimator.fit(X_train, y_train)
+            else: estimator.fit(X_train, y_train, sample_weight=weights)
+        # prediction of test fold
+        # calculate global performance metrics
+        for m in scores.keys():
+            # metrics that require probabilties
+            if m == 'brier_loss' or m == 'roc_auc':
+                y_prob = estimator.predict_proba(X_test)[:, 1]
+                scores[m] = np.append(
+                    scores[m], scoring_methods[m](y_test, y_prob))
+            # metrics that have no averaging for multiclass
+            elif m == 'kappa' or m == 'specificity' or m == 'accuracy' \
+            or m == 'hamming_loss' or m == 'jaccard_similarity' \
+            or m == 'log_loss' or m == 'zero_one_loss' or m == 'matthews_corrcoef':
+                    scores[m], scoring_methods[m](y_test, y_pred))
+            # balanced accuracy
+            elif m == 'balanced_accuracy':
+                        y_test, y_pred, average='macro'))
+            # metrics that have averaging for multiclass
+            else:
+                        y_test, y_pred, average=average))
+        # calculate per-class performance metrics
+        for key in byclass_scores.keys():
+            byclass_scores[key] = np.vstack((
+                byclass_scores[key], byclass_methods[key](
+                    y_test, y_pred, labels=labels, average=None)))
+        # feature importances using permutation
+            if bool((np.isnan(fimp)).all()) is True:
+                fimp = varimp_permutation(
+                    estimator, X_test, y_test, n_permutations,
+                    scoring_methods[scoring[0]],
+                    random_state)
+            else:
+                fimp = np.row_stack(
+                    (fimp, varimp_permutation(
+                        n_permutations, scoring_methods[scoring[0]],
+                        random_state)))
+    return(scores, byclass_scores, fimp)
+def predict(estimator, predictors, output, predict_type='raw', labels=None,
+            index=None, rowincr=25):
+    Prediction on list of GRASS rasters using a fitted scikit learn model
+    Args
+    estimator: scikit-learn estimator object
+    predictors: list of GRASS rasters
+    output: Name of GRASS raster to output classification results
+    predict_type: character, 'raw' for classification/regression;
+                  'prob' for class probabilities
+    index: Optional, list of class indices to export
+    rowincr: Integer of raster rows to process at one time
+    # current region
+    current = Region()
+    # determine output data type and nodata
+    if labels is not None:
+        ftype = 'CELL'
+        nodata = -2147483648
+    else:
+        ftype = 'FCELL'
+        nodata = np.nan
+    # open predictors as list of rasterrow objects
+    n_features = len(predictors)
+    rasstack = [0] * n_features
+    for i in range(n_features):
+        rasstack[i] = RasterRow(predictors[i])
+        if rasstack[i].exist() is True:
+            rasstack[i].open('r')
+        else:
+            grass.fatal("GRASS raster " + predictors[i] +
+                        " does not exist.... exiting")
+    # create and open RasterRow object for writing of classification result
+    if predict_type == 'raw':
+        classification = RasterRow(output)
+        classification.open('w', ftype, overwrite=True)
+    # Prediction using row blocks
+    for rowblock in range(0, current.rows, rowincr):
+        grass.percent(rowblock, current.rows, rowincr)
+        # check that the row increment does not exceed the number of rows
+        if rowblock+rowincr > current.rows:
+            rowincr = current.rows - rowblock
+        img_np_row = np.zeros((rowincr, current.cols, n_features))
+        # loop through each row, and each band
+        # and add these values to the 2D array img_np_row
+        for row in range(rowblock, rowblock+rowincr, 1):
+            for band in range(n_features):
+                img_np_row[row-rowblock, :, band] = \
+                    np.array(rasstack[band][row])
+        # create mask
+        img_np_row[img_np_row == -2147483648] = np.nan
+        mask = np.zeros((img_np_row.shape[0], img_np_row.shape[1]))
+        for feature in range(n_features):
+            invalid_indexes = np.nonzero(np.isnan(img_np_row[:, :, feature]))
+            mask[invalid_indexes] = np.nan
+        # reshape each row-band matrix into a n*m array
+        nsamples = rowincr * current.cols
+        flat_pixels = img_np_row.reshape((nsamples, n_features))
+        # remove NaNs prior to passing to scikit-learn predict
+        flat_pixels = np.nan_to_num(flat_pixels)
+        # perform prediction for classification/regression
+            result = estimator.predict(flat_pixels)
+            result = result.reshape((rowincr, current.cols))
+            # replace NaN values so that the prediction does not have a border
+            result[np.nonzero(np.isnan(mask))] = nodata
+            # for each row we can perform computation, and write the result
+            for row in range(rowincr):
+                newrow = Buffer((result.shape[1],), mtype=ftype)
+                newrow[:] = result[row, :]
+                classification.put_row(newrow)
+        # perform prediction for class probabilities
+        if predict_type == 'prob':
+            result_proba = estimator.predict_proba(flat_pixels)
+            # on first loop determine number of probability classes
+            # and open rasterrow objects for writing
+            if rowblock == 0:
+                if index is None:
+                    index = range(result_proba.shape[1])
+                    n_classes = len(index)
+                else:
+                    n_classes = len(np.unique(index))
+                # create and open RasterRow objects for probabilities
+                prob_out_raster = [0] * n_classes
+                prob = [0] * n_classes
+                for iclass, label in enumerate(index):
+                    prob_out_raster[iclass] = output + '_classPr' + str(label)
+                    prob[iclass] = RasterRow(prob_out_raster[iclass])
+                    prob[iclass].open('w', 'FCELL', overwrite=True)
+                result_proba_class = result_proba[:, label]
+                result_proba_class = result_proba_class.reshape((rowincr, current.cols))
+                result_proba_class[np.nonzero(np.isnan(mask))] = np.nan
+                    newrow = Buffer((result_proba_class.shape[1],), mtype='FCELL')
+                    newrow[:] = result_proba_class[row, :]
+                    prob[iclass].put_row(newrow)
+    # close all maps
+    for i in range(n_features): rasstack[i].close()
+    # close all class probability maps
+        classification.close()
+        try:
+            for iclass in range(n_classes):
+                prob[iclass].close()
+        except:
+            pass
+def model_classifiers(estimator, random_state, n_jobs, p, weights=None):
+    Provides the classifiers and parameters using by the module
+    Args
+    estimator: Name of estimator
+    random_state: Seed to use in randomized components
+    n_jobs: Integer, number of processing cores to use
+    p: Dict, containing classifier setttings
+    weights: None, or 'balanced' to add class_weights
+    Returns
+    clf: Scikit-learn classifier object
+    mode: Flag to indicate whether classifier performs classification or
+          regression
+    from sklearn.linear_model import LogisticRegression
+    from sklearn.discriminant_analysis import LinearDiscriminantAnalysis
+    from sklearn.discriminant_analysis import QuadraticDiscriminantAnalysis
+    from sklearn.naive_bayes import GaussianNB
+    from sklearn.tree import DecisionTreeClassifier, DecisionTreeRegressor
+    from sklearn.ensemble import (
+        RandomForestClassifier, RandomForestRegressor, ExtraTreesClassifier,
+        ExtraTreesRegressor)
+    from sklearn.ensemble import GradientBoostingClassifier
+    from sklearn.ensemble import GradientBoostingRegressor
+    from sklearn.svm import SVC
+    # optional packages that add additional classifiers here
+    if estimator == 'EarthClassifier' or estimator == 'EarthRegressor':
+        try:
+            from sklearn.pipeline import Pipeline
+            from pyearth import Earth
+            earth_classifier = Pipeline([('Earth',
+                                          Earth(max_degree=p['max_degree'])),
+                                         ('Logistic', LogisticRegression(n_jobs=n_jobs))])
+            classifiers = {'EarthClassifier': earth_classifier,
+                           'EarthRegressor': Earth(max_degree=p['max_degree'])}
+        except:
+            grass.fatal('Py-earth package not installed')
+    elif estimator == 'XGBClassifier' or estimator == 'XGBRegressor':
+        try:
+            from xgboost import XGBClassifier, XGBRegressor
+            if p['max_depth'] is None:
+                p['max_depth'] = int(3)
+            classifiers = {
+                'XGBClassifier':
+                    XGBClassifier(learning_rate=p['learning_rate'],
+                                  n_estimators=p['n_estimators'],
+                                  max_depth=p['max_depth'],
+                                  subsample=p['subsample'],
+                                  nthread=n_jobs),
+                'XGBRegressor':
+                    XGBRegressor(learning_rate=p['learning_rate'],
+                                 nthread=n_jobs)}
+        except:
+            grass.fatal('XGBoost package not installed')
+    else:
+        # core sklearn classifiers go here
+        classifiers = {
+            'SVC': SVC(C=p['C'],
+                       class_weight=weights,
+                       probability=True,
+                       random_state=random_state),
+            'LogisticRegression':
+                LogisticRegression(C=p['C'],
+                                   random_state=random_state,
+                                   n_jobs=n_jobs,
+                                   fit_intercept=True),
+            'DecisionTreeClassifier':
+                DecisionTreeClassifier(max_depth=p['max_depth'],
+                                       max_features=p['max_features'],
+                                       min_samples_split=p['min_samples_split'],
+                                       min_samples_leaf=p['min_samples_leaf'],
+            'DecisionTreeRegressor':
+                DecisionTreeRegressor(max_features=p['max_features'],
+            'RandomForestClassifier':
+                RandomForestClassifier(n_estimators=p['n_estimators'],
+                                       n_jobs=n_jobs,
+                                       oob_score=False),
+            'RandomForestRegressor':
+                RandomForestRegressor(n_estimators=p['n_estimators'],
+                                      n_jobs=n_jobs,
+                                      oob_score=False),
+            'ExtraTreesClassifier':
+                ExtraTreesClassifier(n_estimators=p['n_estimators'],
+                                     n_jobs=n_jobs,
+                                     oob_score=False),
+            'ExtraTreesRegressor':
+                ExtraTreesRegressor(n_estimators=p['n_estimators'],
+                                    n_jobs=n_jobs,
+                                    oob_score=False),
+            'GradientBoostingClassifier':
+                GradientBoostingClassifier(learning_rate=p['learning_rate'],
+            'GradientBoostingRegressor':
+                GradientBoostingRegressor(learning_rate=p['learning_rate'],
+            'GaussianNB': GaussianNB(),
+            'LinearDiscriminantAnalysis': LinearDiscriminantAnalysis(),
+            'QuadraticDiscriminantAnalysis': QuadraticDiscriminantAnalysis(),
+    # define classifier
+    clf = classifiers[estimator]
+    # classification or regression
+    if estimator == 'LogisticRegression' \
+        or estimator == 'DecisionTreeClassifier' \
+        or estimator == 'RandomForestClassifier' \
+        or estimator == 'ExtraTreesClassifier' \
+        or estimator == 'GradientBoostingClassifier' \
+        or estimator == 'GaussianNB' \
+        or estimator == 'LinearDiscriminantAnalysis' \
+        or estimator == 'QuadraticDiscriminantAnalysis' \
+        or estimator == 'EarthClassifier' \
+        or estimator == 'XGBClassifier' \
+        or estimator == 'SVC':
+        mode = 'classification'
+    else:
+        mode = 'regression'
+    return (clf, mode)
+def save_training_data(X, y, groups, file):
+    Saves any extracted training data to a csv file
+    Args
+    X: Numpy array containing predictor values
+    y: Numpy array containing labels
+    groups: Numpy array of group labels
+    file: Path to a csv file to save data to
+    # if there are no group labels, create a nan filled array
+        groups = np.empty((y.shape[0]))
+        groups[:] = np.nan
+    training_data = np.column_stack([X, y, groups])
+    np.savetxt(file, training_data, delimiter=',')
+def load_training_data(file):
+    Loads training data and labels from a csv file
+    Args
+    Returns
+    groups: Numpy array of group labels, or None
+    training_data = np.loadtxt(file, delimiter=',')
+    n_cols = training_data.shape[1]
+    last_Xcol = n_cols-2
+    # check to see if last column contains group labels or nans
+    groups = training_data[:, -1]
+    # if all nans then set groups to None
+    if bool(np.isnan(groups).all()) is True:
+        groups = None
+    # fetch X and y
+    X = training_data[:, 0:last_Xcol]
+    y = training_data[:, -2]
+    return(X, y, groups)
+def extract(response, predictors, lowmem=False):
+    Samples a list of GRASS rasters using a labelled raster
+    Per raster sampling
+    Args
+    response: String; GRASS raster with labelled pixels
+    predictors: List of GRASS rasters containing explanatory variables
+    lowmem: Boolean, use numpy memmap to query predictors
+    Returns
+    training_data: Numpy array of extracted raster values
+    training_labels: Numpy array of labels
+    is_train: Row and Columns of label positions
+    # open response raster as rasterrow and read as np array
+    if RasterRow(response).exist() is True:
+        roi_gr = RasterRow(response)
+        roi_gr.open('r')
+        if lowmem is False:
+            response_np = np.array(roi_gr)
+        else:
+            response_np = np.memmap(tempfile.NamedTemporaryFile(),
+                                    dtype='float32', mode='w+',
+                                    shape=(current.rows, current.cols))
+            response_np[:] = np.array(roi_gr)[:]
+    else:
+        grass.fatal("GRASS response raster does not exist.... exiting")
+    # determine number of predictor rasters
+    # check to see if all predictors exist
+        if RasterRow(predictors[i]).exist() is not True:
+    # check if any of those pixels are labelled (not equal to nodata)
+    # can use even if roi is FCELL because nodata will be nan
+    is_train = np.nonzero(response_np > -2147483648)
+    training_labels = response_np[is_train]
+    n_labels = np.array(is_train).shape[1]
+    # Create a zero numpy array of len training labels
+        training_data = np.zeros((n_labels, n_features))
+    else:
+        training_data = np.memmap(tempfile.NamedTemporaryFile(),
+                                  shape=(n_labels, n_features))
+    # Loop through each raster and sample pixel values at training indexes
+    if lowmem is True:
+        feature_np = np.memmap(tempfile.NamedTemporaryFile(),
+    for f in range(n_features):
+        predictor_gr = RasterRow(predictors[f])
+        predictor_gr.open('r')
+            feature_np = np.array(predictor_gr)
+        else:
+            feature_np[:] = np.array(predictor_gr)[:]
+        training_data[0:n_labels, f] = feature_np[is_train]
+        # close each predictor map
+        predictor_gr.close()
+    # convert any CELL maps no datavals to NaN in the training data
+        training_data[training_data[:, i] == -2147483648] = np.nan
+    # convert indexes of training pixels from tuple to n*2 np array
+    is_train = np.array(is_train).T
+    # close the response map
+    roi_gr.close()
+    return(training_data, training_labels, is_train)
+def maps_from_group(group):
+    Parse individual rasters into a list from an imagery group
+    Args
+    group: String; GRASS imagery group
+    Returns
+    maplist: Python list containing individual GRASS raster maps
+    groupmaps = im.group(group=group, flags="g",
+                         quiet=True, stdout_=PIPE).outputs.stdout
+    maplist = groupmaps.split(os.linesep)
+    maplist = maplist[0:len(maplist)-1]
+    map_names = []
+    for rastername in maplist:
+        map_names.append(rastername.split('@')[0])
+    return(maplist, map_names)
+def extract_points(gvector, grasters, field):
+    Extract values from grass rasters using vector points input
+    Args
+    gvector: character, name of grass points vector
+    grasters: list of names of grass raster to query
+    field: character, name of field in table to use as response variable
+    Returns
+    y: 1D numpy array with the response variable
+    coordinates: 2D numpy array of sample coordinates
+    import pandas as pd
+    # open grass vector
+    points = VectorTopo(gvector.split('@')[0])
+    points.open('r')
+    # create link to attribute table
+    points.dblinks.by_name(name=gvector)
+    link = points.dblinks[0]
+    # convert to pandas array
+    gvector_df = pd.DataFrame(points.table_to_dict()).T
+    gvector_df.columns = points.table.columns
+    y = gvector_df.loc[:, field].as_matrix()
+    y = y.astype(float)
+    # extract training data
+    X = np.zeros((points.num_primitives()['point'], len(grasters)), dtype=float)
+    for i, raster in enumerate(grasters):
+        rio = RasterRow(raster)
+        values = np.asarray(get_raster_for_points(points, rio))
+        coordinates = values[:, 1:3]
+        X[:, i] = values[:, 3]
+    # set any grass integer nodata values to NaN
+    X[X == -2147483648] = np.nan
+    # remove missing response data
+    X = X[~np.isnan(y)]
+    coordinates = coordinates[~np.isnan(y)]
+    y = y[~np.isnan(y)]
+    # close
+    points.close()
+    return(X, y, coordinates)
 def main():
     try:
         from sklearn.externals import joblib
Deleted: grass-addons/grass7/raster/r.learn.ml/raster_learning.py
--- grass-addons/grass7/raster/r.learn.ml/raster_learning.py	2017-04-22 03:25:48 UTC (rev 70910)
+++ grass-addons/grass7/raster/r.learn.ml/raster_learning.py	2017-04-22 03:32:03 UTC (rev 70911)
@@ -1,818 +0,0 @@
-# -*- coding: utf-8 -*-
-import os
-import numpy as np
-from numpy.random import RandomState
-import tempfile
-import itertools
-import grass.script as grass
-from grass.pygrass.raster import RasterRow
-from grass.pygrass.gis.region import Region
-from grass.pygrass.raster.buffer import Buffer
-from grass.pygrass.modules.shortcuts import imagery as im
-from grass.pygrass.vector import VectorTopo
-from grass.pygrass.vector.table import Link
-from grass.pygrass.utils import get_raster_for_points
-from subprocess import PIPE
-def specificity_score(y_true, y_pred):
-    Function to calculate specificity score
-    Args
-    y_true: 1D numpy array of truth values
-    y_pred: 1D numpy array of predicted classes
-    Returns
-    specificity: specificity score
-    from sklearn.metrics import confusion_matrix
-    cm = confusion_matrix(y_true, y_pred)
-    tn = float(cm[0][0])
-    fp = float(cm[0][1])
-    return (tn/(tn+fp))
-def varimp_permutation(estimator, X_test, y_true,
-                       n_permutations, scorer,
-                       random_state):
-    Method to perform permutation-based feature importance during
-    cross-validation (cross-validation is applied externally to this
-    method)
-    Procedure is:
-    1. Pass fitted estimator and test partition X y
-    2. Assess AUC on the test partition (bestauc)
-    3. Permute each variable and assess the difference between bestauc and
-       the messed-up variable
-    4. Repeat (3) for many random permutations
-    5. Average the repeats
-    Args
-    estimator: estimator that has been fitted to a training partition
-    X_test, y_true: data and labels from a test partition
-    n_permutations: number of random permutations to apply
-    scorer: scikit-learn metric function to use
-    random_state: seed to pass to the numpy random.seed
-    Returns
-    scores: scores for each predictor following permutation
-    # calculate score on original variables without permutation
-    # determine best metric type for binary/multiclass/regression scenarios
-    y_pred = estimator.predict(X_test)
-    best_score = scorer(y_true, y_pred)
-    np.random.seed(seed=random_state)
-    rstate = RandomState(random_state)
-    scores = np.zeros((n_permutations, X_test.shape[1]))
-    # outer loop to repeat the pemutation rep times
-    for rep in range(n_permutations):
-        # inner loop to permute each predictor variable and assess
-        # difference in auc
-        for i in range(X_test.shape[1]):
-            Xscram = np.copy(X_test)
-            Xscram[:, i] = rstate.choice(X_test[:, i], X_test.shape[0])
-            # fit the model on the training data and predict the test data
-            y_pred = estimator.predict(Xscram)
-            scores[rep, i] = best_score-scorer(y_true, y_pred)
-            if scores[rep, i] < 0:
-                scores[rep, i] = 0
-    # average the repetitions
-    scores = scores.mean(axis=0)
-    return(scores)
-def cross_val_scores(estimator, X, y, groups=None, sample_weight=None, cv=3,
-                     scoring=['accuracy'], feature_importances=False,
-                     n_permutations=25, random_state=None):
-    Stratified Kfold and GroupFold cross-validation using multiple
-    scoring metrics and permutation feature importances
-    Args
-    estimator: Scikit learn estimator
-    X: 2D numpy array of training data
-    y: 1D numpy array representing response variable
-    groups: 1D numpy array containing group labels
-    sample_weight: 1D numpy array[n_samples,] of sample weights
-    cv: Integer of cross-validation folds or sklearn.model_selection object
-    sampling: Over- or under-sampling object with fit_sample method
-    scoring: List of performance metrics to use
-    feature_importances: Boolean to perform permutation-based importances
-    n_permutations: Number of permutations during feature importance
-    random_state: Seed to pass to the random number generator
-    from sklearn import metrics
-    from sklearn.model_selection import (
-        RandomizedSearchCV, GridSearchCV, StratifiedKFold)
-    estimator = deepcopy(estimator)
-    # create model_selection method
-    if isinstance(cv, int):
-        cv = StratifiedKFold(n_splits=cv)
-    # need the groups parameter because the estimator can be a
-    # RandomizedSearchCV or GridSearchCV estimator where cv=GroupKFold
-    if isinstance(estimator, RandomizedSearchCV) is True \
-            or isinstance(estimator, GridSearchCV):
-        param_search = True
-    else:
-        param_search = False
-    # create dictionary of lists to store metrics
-    scores = dict.fromkeys(scoring)
-    scores = { key: [] for key, value in scores.iteritems()}
-    scoring_methods = {'accuracy': metrics.accuracy_score,
-                       'balanced_accuracy': metrics.recall_score,
-                       'average_precision': metrics.average_precision_score,
-                       'brier_loss': metrics.brier_score_loss,
-                       'kappa': metrics.cohen_kappa_score,
-                       'f1': metrics.f1_score,
-                       'fbeta': metrics.fbeta_score,
-                       'hamming_loss': metrics.hamming_loss,
-                       'jaccard_similarity': metrics.jaccard_similarity_score,
-                       'log_loss': metrics.log_loss,
-                       'matthews_corrcoef': metrics.matthews_corrcoef,
-                       'precision': metrics.precision_score,
-                       'recall': metrics.recall_score,
-                       'specificity': specificity_score,
-                       'roc_auc': metrics.roc_auc_score,
-                       'zero_one_loss': metrics.zero_one_loss,
-                       'r2': metrics.r2_score,
-                       'neg_mean_squared_error': metrics.mean_squared_error}
-    byclass_methods = {'f1': metrics.f1_score,
-                       'recall': metrics.recall_score}
-    # create diction to store byclass metrics results
-    n_classes = len(np.unique(y))
-    labels = np.unique(y)
-    byclass_scores = dict.fromkeys(byclass_methods)
-    byclass_scores = { key: np.zeros((0, n_classes)) for key, value in byclass_scores.iteritems()}
-    # remove any byclass_scorers that are not in the scoring list
-    byclass_scores = {key: value for key, value in byclass_scores.iteritems() if key in scores}
-    # set averaging type for global binary or multiclass scores
-    if len(np.unique(y)) == 2 and all([0, 1] == np.unique(y)):
-        average='binary'
-    else:
-        average='macro'
-    # check to see if scoring is a valid sklearn metric
-    for i in scores.keys():
-        try:
-            list(scoring_methods.keys()).index(i)
-        except:
-            print('Scoring ' + i + ' is not a valid scoring method')
-            print('Valid methods are:')
-            print(scoring_methods.keys())
-    # create np array to store feature importance scores
-    if feature_importances is True:
-        fimp = np.zeros((cv.get_n_splits(), X.shape[1]))
-        fimp[:] = np.nan
-    else:
-        fimp = None
-    # generate Kfold indices
-    if groups is None:
-        k_fold = cv.split(X, y)
-    else:
-        k_fold = cv.split(X, y, groups=groups)
-    # train on k-1 folds and test of k folds
-    for train_indices, test_indices in k_fold:
-        # subset training and test fold data
-        X_train, X_test = X[train_indices], X[test_indices]
-        y_train, y_test = y[train_indices], y[test_indices]
-        # subset training and test fold group ids
-        if groups is not None: groups_train = groups[train_indices]
-        else: groups_train = None
-        # subset training and test fold sample_weight
-        if sample_weight is not None: weights = sample_weight[train_indices]
-        # train estimator on training fold
-        if groups is not None and param_search is True:
-            if sample_weight is None: estimator.fit(X_train, y_train, groups=groups_train)
-            else: estimator.fit(X_train, y_train, groups=groups_train, sample_weight=weights)
-        else:
-            if sample_weight is None: estimator.fit(X_train, y_train)
-            else: estimator.fit(X_train, y_train, sample_weight=weights)
-        # prediction of test fold
-        # calculate global performance metrics
-        for m in scores.keys():
-            # metrics that require probabilties
-            if m == 'brier_loss' or m == 'roc_auc':
-                y_prob = estimator.predict_proba(X_test)[:, 1]
-                scores[m] = np.append(
-                    scores[m], scoring_methods[m](y_test, y_prob))
-            # metrics that have no averaging for multiclass
-            elif m == 'kappa' or m == 'specificity' or m == 'accuracy' \
-            or m == 'hamming_loss' or m == 'jaccard_similarity' \
-            or m == 'log_loss' or m == 'zero_one_loss' or m == 'matthews_corrcoef':
-                    scores[m], scoring_methods[m](y_test, y_pred))
-            # balanced accuracy
-            elif m == 'balanced_accuracy':
-                        y_test, y_pred, average='macro'))
-            # metrics that have averaging for multiclass
-            else:
-                        y_test, y_pred, average=average))
-        # calculate per-class performance metrics
-        for key in byclass_scores.keys():
-            byclass_scores[key] = np.vstack((
-                byclass_scores[key], byclass_methods[key](
-                    y_test, y_pred, labels=labels, average=None)))
-        # feature importances using permutation
-            if bool((np.isnan(fimp)).all()) is True:
-                fimp = varimp_permutation(
-                    estimator, X_test, y_test, n_permutations,
-                    scoring_methods[scoring[0]],
-                    random_state)
-            else:
-                fimp = np.row_stack(
-                    (fimp, varimp_permutation(
-                        n_permutations, scoring_methods[scoring[0]],
-                        random_state)))
-    return(scores, byclass_scores, fimp)
-def predict(estimator, predictors, output, predict_type='raw', labels=None,
-            index=None, rowincr=25):
-    Prediction on list of GRASS rasters using a fitted scikit learn model
-    Args
-    estimator: scikit-learn estimator object
-    predictors: list of GRASS rasters
-    output: Name of GRASS raster to output classification results
-    predict_type: character, 'raw' for classification/regression;
-                  'prob' for class probabilities
-    index: Optional, list of class indices to export
-    rowincr: Integer of raster rows to process at one time
-    # current region
-    current = Region()
-    # determine output data type and nodata
-    if labels is not None:
-        ftype = 'CELL'
-        nodata = -2147483648
-    else:
-        ftype = 'FCELL'
-        nodata = np.nan
-    # open predictors as list of rasterrow objects
-    n_features = len(predictors)
-    rasstack = [0] * n_features
-    for i in range(n_features):
-        rasstack[i] = RasterRow(predictors[i])
-        if rasstack[i].exist() is True:
-            rasstack[i].open('r')
-        else:
-            grass.fatal("GRASS raster " + predictors[i] +
-                        " does not exist.... exiting")
-    # create and open RasterRow object for writing of classification result
-    if predict_type == 'raw':
-        classification = RasterRow(output)
-        classification.open('w', ftype, overwrite=True)
-    # Prediction using row blocks
-    for rowblock in range(0, current.rows, rowincr):
-        grass.percent(rowblock, current.rows, rowincr)
-        # check that the row increment does not exceed the number of rows
-        if rowblock+rowincr > current.rows:
-            rowincr = current.rows - rowblock
-        img_np_row = np.zeros((rowincr, current.cols, n_features))
-        # loop through each row, and each band
-        # and add these values to the 2D array img_np_row
-        for row in range(rowblock, rowblock+rowincr, 1):
-            for band in range(n_features):
-                img_np_row[row-rowblock, :, band] = \
-                    np.array(rasstack[band][row])
-        # create mask
-        img_np_row[img_np_row == -2147483648] = np.nan
-        mask = np.zeros((img_np_row.shape[0], img_np_row.shape[1]))
-        for feature in range(n_features):
-            invalid_indexes = np.nonzero(np.isnan(img_np_row[:, :, feature]))
-            mask[invalid_indexes] = np.nan
-        # reshape each row-band matrix into a n*m array
-        nsamples = rowincr * current.cols
-        flat_pixels = img_np_row.reshape((nsamples, n_features))
-        # remove NaNs prior to passing to scikit-learn predict
-        flat_pixels = np.nan_to_num(flat_pixels)
-        # perform prediction for classification/regression
-            result = estimator.predict(flat_pixels)
-            result = result.reshape((rowincr, current.cols))
-            # replace NaN values so that the prediction does not have a border
-            result[np.nonzero(np.isnan(mask))] = nodata
-            # for each row we can perform computation, and write the result
-            for row in range(rowincr):
-                newrow = Buffer((result.shape[1],), mtype=ftype)
-                newrow[:] = result[row, :]
-                classification.put_row(newrow)
-        # perform prediction for class probabilities
-        if predict_type == 'prob':
-            result_proba = estimator.predict_proba(flat_pixels)
-            # on first loop determine number of probability classes
-            # and open rasterrow objects for writing
-            if rowblock == 0:
-                if index is None:
-                    index = range(result_proba.shape[1])
-                    n_classes = len(index)
-                else:
-                    n_classes = len(np.unique(index))
-                # create and open RasterRow objects for probabilities
-                prob_out_raster = [0] * n_classes
-                prob = [0] * n_classes
-                for iclass, label in enumerate(index):
-                    prob_out_raster[iclass] = output + '_classPr' + str(label)
-                    prob[iclass] = RasterRow(prob_out_raster[iclass])
-                    prob[iclass].open('w', 'FCELL', overwrite=True)
-                result_proba_class = result_proba[:, label]
-                result_proba_class = result_proba_class.reshape((rowincr, current.cols))
-                result_proba_class[np.nonzero(np.isnan(mask))] = np.nan
-                    newrow = Buffer((result_proba_class.shape[1],), mtype='FCELL')
-                    newrow[:] = result_proba_class[row, :]
-                    prob[iclass].put_row(newrow)
-    # close all maps
-    for i in range(n_features): rasstack[i].close()
-    # close all class probability maps
-        classification.close()
-        try:
-            for iclass in range(n_classes):
-                prob[iclass].close()
-        except:
-            pass
-def model_classifiers(estimator, random_state, n_jobs, p, weights=None):
-    Provides the classifiers and parameters using by the module
-    Args
-    estimator: Name of estimator
-    random_state: Seed to use in randomized components
-    n_jobs: Integer, number of processing cores to use
-    p: Dict, containing classifier setttings
-    weights: None, or 'balanced' to add class_weights
-    Returns
-    clf: Scikit-learn classifier object
-    mode: Flag to indicate whether classifier performs classification or
-          regression
-    from sklearn.linear_model import LogisticRegression
-    from sklearn.discriminant_analysis import LinearDiscriminantAnalysis
-    from sklearn.discriminant_analysis import QuadraticDiscriminantAnalysis
-    from sklearn.naive_bayes import GaussianNB
-    from sklearn.tree import DecisionTreeClassifier, DecisionTreeRegressor
-    from sklearn.ensemble import (
-        RandomForestClassifier, RandomForestRegressor, ExtraTreesClassifier,
-        ExtraTreesRegressor)
-    from sklearn.ensemble import GradientBoostingClassifier
-    from sklearn.ensemble import GradientBoostingRegressor
-    from sklearn.svm import SVC
-    # optional packages that add additional classifiers here
-    if estimator == 'EarthClassifier' or estimator == 'EarthRegressor':
-        try:
-            from sklearn.pipeline import Pipeline
-            from pyearth import Earth
-            earth_classifier = Pipeline([('Earth',
-                                          Earth(max_degree=p['max_degree'])),
-                                         ('Logistic', LogisticRegression(n_jobs=n_jobs))])
-            classifiers = {'EarthClassifier': earth_classifier,
-                           'EarthRegressor': Earth(max_degree=p['max_degree'])}
-        except:
-            grass.fatal('Py-earth package not installed')
-    elif estimator == 'XGBClassifier' or estimator == 'XGBRegressor':
-        try:
-            from xgboost import XGBClassifier, XGBRegressor
-            if p['max_depth'] is None:
-                p['max_depth'] = int(3)
-            classifiers = {
-                'XGBClassifier':
-                    XGBClassifier(learning_rate=p['learning_rate'],
-                                  n_estimators=p['n_estimators'],
-                                  max_depth=p['max_depth'],
-                                  subsample=p['subsample'],
-                                  nthread=n_jobs),
-                'XGBRegressor':
-                    XGBRegressor(learning_rate=p['learning_rate'],
-                                 nthread=n_jobs)}
-        except:
-            grass.fatal('XGBoost package not installed')
-    else:
-        # core sklearn classifiers go here
-        classifiers = {
-            'SVC': SVC(C=p['C'],
-                       class_weight=weights,
-                       probability=True,
-                       random_state=random_state),
-            'LogisticRegression':
-                LogisticRegression(C=p['C'],
-                                   random_state=random_state,
-                                   n_jobs=n_jobs,
-                                   fit_intercept=True),
-            'DecisionTreeClassifier':
-                DecisionTreeClassifier(max_depth=p['max_depth'],
-                                       max_features=p['max_features'],
-                                       min_samples_split=p['min_samples_split'],
-                                       min_samples_leaf=p['min_samples_leaf'],
-            'DecisionTreeRegressor':
-                DecisionTreeRegressor(max_features=p['max_features'],
-            'RandomForestClassifier':
-                RandomForestClassifier(n_estimators=p['n_estimators'],
-                                       n_jobs=n_jobs,
-                                       oob_score=False),
-            'RandomForestRegressor':
-                RandomForestRegressor(n_estimators=p['n_estimators'],
-                                      n_jobs=n_jobs,
-                                      oob_score=False),
-            'ExtraTreesClassifier':
-                ExtraTreesClassifier(n_estimators=p['n_estimators'],
-                                     n_jobs=n_jobs,
-                                     oob_score=False),
-            'ExtraTreesRegressor':
-                ExtraTreesRegressor(n_estimators=p['n_estimators'],
-                                    n_jobs=n_jobs,
-                                    oob_score=False),
-            'GradientBoostingClassifier':
-                GradientBoostingClassifier(learning_rate=p['learning_rate'],
-            'GradientBoostingRegressor':
-                GradientBoostingRegressor(learning_rate=p['learning_rate'],
-            'GaussianNB': GaussianNB(),
-            'LinearDiscriminantAnalysis': LinearDiscriminantAnalysis(),
-            'QuadraticDiscriminantAnalysis': QuadraticDiscriminantAnalysis(),
-    # define classifier
-    clf = classifiers[estimator]
-    # classification or regression
-    if estimator == 'LogisticRegression' \
-        or estimator == 'DecisionTreeClassifier' \
-        or estimator == 'RandomForestClassifier' \
-        or estimator == 'ExtraTreesClassifier' \
-        or estimator == 'GradientBoostingClassifier' \
-        or estimator == 'GaussianNB' \
-        or estimator == 'LinearDiscriminantAnalysis' \
-        or estimator == 'QuadraticDiscriminantAnalysis' \
-        or estimator == 'EarthClassifier' \
-        or estimator == 'XGBClassifier' \
-        or estimator == 'SVC':
-        mode = 'classification'
-    else:
-        mode = 'regression'
-    return (clf, mode)
-def save_training_data(X, y, groups, file):
-    Saves any extracted training data to a csv file
-    Args
-    X: Numpy array containing predictor values
-    y: Numpy array containing labels
-    groups: Numpy array of group labels
-    file: Path to a csv file to save data to
-    # if there are no group labels, create a nan filled array
-        groups = np.empty((y.shape[0]))
-        groups[:] = np.nan
-    training_data = np.column_stack([X, y, groups])
-    np.savetxt(file, training_data, delimiter=',')
-def load_training_data(file):
-    Loads training data and labels from a csv file
-    Args
-    Returns
-    groups: Numpy array of group labels, or None
-    training_data = np.loadtxt(file, delimiter=',')
-    n_cols = training_data.shape[1]
-    last_Xcol = n_cols-2
-    # check to see if last column contains group labels or nans
-    groups = training_data[:, -1]
-    # if all nans then set groups to None
-    if bool(np.isnan(groups).all()) is True:
-        groups = None
-    # fetch X and y
-    X = training_data[:, 0:last_Xcol]
-    y = training_data[:, -2]
-    return(X, y, groups)
-def extract(response, predictors, lowmem=False):
-    Samples a list of GRASS rasters using a labelled raster
-    Per raster sampling
-    Args
-    response: String; GRASS raster with labelled pixels
-    predictors: List of GRASS rasters containing explanatory variables
-    lowmem: Boolean, use numpy memmap to query predictors
-    Returns
-    training_data: Numpy array of extracted raster values
-    training_labels: Numpy array of labels
-    is_train: Row and Columns of label positions
-    # open response raster as rasterrow and read as np array
-    if RasterRow(response).exist() is True:
-        roi_gr = RasterRow(response)
-        roi_gr.open('r')
-        if lowmem is False:
-            response_np = np.array(roi_gr)
-        else:
-            response_np = np.memmap(tempfile.NamedTemporaryFile(),
-                                    dtype='float32', mode='w+',
-                                    shape=(current.rows, current.cols))
-            response_np[:] = np.array(roi_gr)[:]
-    else:
-        grass.fatal("GRASS response raster does not exist.... exiting")
-    # determine number of predictor rasters
-    # check to see if all predictors exist
-        if RasterRow(predictors[i]).exist() is not True:
-    # check if any of those pixels are labelled (not equal to nodata)
-    # can use even if roi is FCELL because nodata will be nan
-    is_train = np.nonzero(response_np > -2147483648)
-    training_labels = response_np[is_train]
-    n_labels = np.array(is_train).shape[1]
-    # Create a zero numpy array of len training labels
-        training_data = np.zeros((n_labels, n_features))
-    else:
-        training_data = np.memmap(tempfile.NamedTemporaryFile(),
-                                  shape=(n_labels, n_features))
-    # Loop through each raster and sample pixel values at training indexes
-    if lowmem is True:
-        feature_np = np.memmap(tempfile.NamedTemporaryFile(),
-    for f in range(n_features):
-        predictor_gr = RasterRow(predictors[f])
-        predictor_gr.open('r')
-            feature_np = np.array(predictor_gr)
-        else:
-            feature_np[:] = np.array(predictor_gr)[:]
-        training_data[0:n_labels, f] = feature_np[is_train]
-        # close each predictor map
-        predictor_gr.close()
-    # convert any CELL maps no datavals to NaN in the training data
-        training_data[training_data[:, i] == -2147483648] = np.nan
-    # convert indexes of training pixels from tuple to n*2 np array
-    is_train = np.array(is_train).T
-    # close the response map
-    roi_gr.close()
-    return(training_data, training_labels, is_train)
-def maps_from_group(group):
-    Parse individual rasters into a list from an imagery group
-    Args
-    group: String; GRASS imagery group
-    Returns
-    maplist: Python list containing individual GRASS raster maps
-    groupmaps = im.group(group=group, flags="g",
-                         quiet=True, stdout_=PIPE).outputs.stdout
-    maplist = groupmaps.split(os.linesep)
-    maplist = maplist[0:len(maplist)-1]
-    map_names = []
-    for rastername in maplist:
-        map_names.append(rastername.split('@')[0])
-    return(maplist, map_names)
-def extract_points(gvector, grasters, field):
-    Extract values from grass rasters using vector points input
-    Args
-    gvector: character, name of grass points vector
-    grasters: list of names of grass raster to query
-    field: character, name of field in table to use as response variable
-    Returns
-    y: 1D numpy array with the response variable
-    coordinates: 2D numpy array of sample coordinates
-    import pandas as pd
-    # open grass vector
-    points = VectorTopo(gvector.split('@')[0])
-    points.open('r')
-    # create link to attribute table
-    points.dblinks.by_name(name=gvector)
-    link = points.dblinks[0]
-    # convert to pandas array
-    gvector_df = pd.DataFrame(points.table_to_dict()).T
-    gvector_df.columns = points.table.columns
-    y = gvector_df.loc[:, field].as_matrix()
-    y = y.astype(float)
-    # extract training data
-    X = np.zeros((points.num_primitives()['point'], len(grasters)), dtype=float)
-    for i, raster in enumerate(grasters):
-        rio = RasterRow(raster)
-        values = np.asarray(get_raster_for_points(points, rio))
-        coordinates = values[:, 1:3]
-        X[:, i] = values[:, 3]
-    # set any grass integer nodata values to NaN
-    X[X == -2147483648] = np.nan
-    # remove missing response data
-    X = X[~np.isnan(y)]
-    coordinates = coordinates[~np.isnan(y)]
-    y = y[~np.isnan(y)]
-    # close
-    points.close()
-    return(X, y, coordinates)
