[GRASS-SVN] r70940 - grass/trunk/vector/v.kernel
svn_grass at osgeo.org
Sun Apr 23 19:41:12 PDT 2017
Author: annakrat
Date: 2017-04-23 19:41:12 -0700 (Sun, 23 Apr 2017)
New Revision: 70940
grass/trunk/vector/v.kernel/main.c
v.kernel: add separate option for network density map, see #635
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c 2017-04-23 21:23:09 UTC (rev 70939)
+++ grass/trunk/vector/v.kernel/main.c 2017-04-24 02:41:12 UTC (rev 70940)
@@ -74,14 +74,13 @@
int main(int argc, char **argv)
- struct Option *in_opt, *net_opt, *out_opt;
+ struct Option *in_opt, *net_opt, *out_opt, *net_out_opt;
struct Option *radius_opt, *dsize_opt, *segmax_opt, *netmax_opt,
*multip_opt, *node_opt, *kernel_opt;
struct Flag *flag_o, *flag_q, *flag_normalize, *flag_multiply;
char *desc;
struct Map_info In, Net, Out;
- int overwrite;
int fdout = -1, maskfd = -1;
int node_method, kernel_function;
int row, col;
@@ -119,6 +118,7 @@
in_opt = G_define_standard_option(G_OPT_V_INPUT);
in_opt->label = _("Name of input vector map with training points");
in_opt->description = NULL;
+ in_opt->guisection = _("Basic");
net_opt = G_define_standard_option(G_OPT_V_INPUT);
net_opt->key = "net";
@@ -127,19 +127,25 @@
net_opt->required = NO;
net_opt->guisection = _("Network");
- out_opt = G_define_option();
+ out_opt = G_define_standard_option(G_OPT_R_OUTPUT);
out_opt->key = "output";
- out_opt->type = TYPE_STRING;
- out_opt->key_desc = "name";
- out_opt->required = YES;
- out_opt->label = _("Name for output raster/vector map");
- out_opt->description = _("Outputs vector map if network map is given, otherwise raster map");
+ out_opt->required = NO;
+ out_opt->label = _("Name for output raster map");
+ out_opt->guisection = _("Basic");
+ net_out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
+ net_out_opt->key = "net_output";
+ net_out_opt->required = NO;
+ net_out_opt->label = _("Name for output vector density map");
+ net_out_opt->description = _("Outputs vector map if network map is given");
+ net_out_opt->guisection = _("Network");
radius_opt = G_define_option();
radius_opt->key = "radius";
radius_opt->type = TYPE_DOUBLE;
radius_opt->required = YES;
radius_opt->description = _("Kernel radius in map units");
+ radius_opt->guisection = _("Basic");
dsize_opt = G_define_option();
dsize_opt->key = "dsize";
@@ -216,29 +222,21 @@
flag_multiply->description =
_("In network mode, multiply the result by number of input points");
flag_multiply->guisection = _("Network");
- overwrite = G_check_overwrite(argc, argv);
+ G_option_required(out_opt, net_out_opt, NULL);
+ G_option_exclusive(out_opt, net_out_opt, NULL);
+ /* this should be activated for GRASS 8
+ G_option_requires(net_opt, net_out_opt, NULL);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- if (net_opt->answer) {
- if (G_find_vector2(out_opt->answer, G_mapset())) {
- if (overwrite)
- G_warning(_("Vector map <%s> already exists and will be overwritten"),
- out_opt->answer);
- else
- G_fatal_error(_("Vector map <%s> already exists"),
- out_opt->answer);
- } else {
- if (G_find_raster(out_opt->answer, G_mapset())) {
- if (overwrite)
- G_warning(_("Raster map <%s> already exists and will be overwritten"),
- out_opt->answer);
- else
- G_fatal_error(_("Raster map <%s> already exists"),
- out_opt->answer);
+ if (net_opt->answer && out_opt->answer) {
+ G_warning(_("Use option net_output if you compute network density. "
+ "Name provided in option output will be used for net_output."));
+ net_out_opt->answer = out_opt->answer;
+ out_opt->answer = NULL;
/*read options */
@@ -291,9 +289,9 @@
- Vect_check_input_output_name(in_opt->answer, out_opt->answer,
+ Vect_check_input_output_name(in_opt->answer, net_out_opt->answer,
G_FATAL_EXIT);
- Vect_check_input_output_name(net_opt->answer, out_opt->answer,
+ Vect_check_input_output_name(net_opt->answer, net_out_opt->answer,
G_FATAL_EXIT);
@@ -334,9 +332,9 @@
Vect_net_build_graph(&Net, GV_LINES, 0, 0, NULL, NULL, NULL, 0, 0);
if (!flag_q->answer) {
- if (Vect_open_new(&Out, out_opt->answer, 0) < 0)
+ if (Vect_open_new(&Out, net_out_opt->answer, 0) < 0)
G_fatal_error(_("Unable to create vector map <%s>"),
- out_opt->answer);
+ net_out_opt->answer);
Vect_hist_command(&Out);
