[GRASS-SVN] r70947 - grass-addons/grass7/vector/v.lfp
Tue Apr 25 01:40:47 PDT 2017
Author: hcho
Date: 2017-04-25 01:40:47 -0700 (Tue, 25 Apr 2017)
New Revision: 70947
   grass-addons/grass7/vector/v.lfp/v.lfp.py
v.lfp: Use libgis_revision when revision is not available
Modified: grass-addons/grass7/vector/v.lfp/v.lfp.py
--- grass-addons/grass7/vector/v.lfp/v.lfp.py	2017-04-25 04:55:40 UTC (rev 70946)
+++ grass-addons/grass7/vector/v.lfp/v.lfp.py	2017-04-25 08:40:47 UTC (rev 70947)
@@ -171,7 +171,17 @@
                 grass.fatal(_("Cannot flip the longest flow path"))
     # write history if supported
-    if int(grass.version()["revision"][1:]) >= 70740:
+    version = grass.version()
+    if version["revision"] != "exported":
+        # the revision number is available
+        version = int(version["revision"][1:])
+    else:
+        # some binary distributions don't build from the SVN repository and
+        # revision is not available; use the libgis revision as a fallback in
+        # this case
+        version = int(version["libgis_revision"])
+    if version >= 70740:
         # v.support -h added in r70740
         grass.run_command("v.support", flags="h", map=output,
                           cmdhist=os.environ["CMDLINE"])
