[GRASS-SVN] r70966 - in grass/trunk/temporal/t.rast.accdetect: . testsuite
svn_grass at osgeo.org
Thu Apr 27 12:27:38 PDT 2017
Author: huhabla
Date: 2017-04-27 12:27:38 -0700 (Thu, 27 Apr 2017)
New Revision: 70966
grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py
grass/trunk/temporal/t.rast.accdetect/testsuite/test_simple.py
temporal modules: Fixed naming bug of indicator maps in t.rast.accdetect
Modified: grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py
--- grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py 2017-04-27 16:19:37 UTC (rev 70965)
+++ grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py 2017-04-27 19:27:38 UTC (rev 70966)
@@ -330,12 +330,13 @@
if input_strds.get_temporal_type() == 'absolute' and time_suffix == 'gran':
suffix = tgis.create_suffix_from_datetime(map.temporal_extent.get_start_time(),
input_strds.get_granularity())
- indicator_map_name = "{ba}_{su}".format(ba=base, su=suffix)
+ indicator_map_name = "{ba}_indicator_{su}".format(ba=base, su=suffix)
elif input_strds.get_temporal_type() == 'absolute' and time_suffix == 'time':
suffix = tgis.create_time_suffix(map)
else:
- indicator_map_name = tgis.create_numeric_suffic(base, indi_count, time_suffix)
+ indicator_map_name = tgis.create_numeric_suffic(base + "_indicator",
+ indi_count, time_suffix)
indicator_map_id = dummy.build_id(indicator_map_name, mapset)
indicator_map = input_strds.get_new_map_instance(indicator_map_id)
Modified: grass/trunk/temporal/t.rast.accdetect/testsuite/test_simple.py
--- grass/trunk/temporal/t.rast.accdetect/testsuite/test_simple.py 2017-04-27 16:19:37 UTC (rev 70965)
+++ grass/trunk/temporal/t.rast.accdetect/testsuite/test_simple.py 2017-04-27 19:27:38 UTC (rev 70966)
@@ -47,11 +47,12 @@
def tearDown(self):
"""Remove generated data"""
self.runModule("t.remove", flags="rf", type="strds", inputs="B")
+ self.runModule("t.remove", flags="rf", type="strds", inputs="C")
def test_simple(self):
self.assertModule('t.rast.accdetect', input='A', occurrence='B',
- start="2001-01-01", cycle="12 months",
- basename='b_occu', range=(1,8))
+ indicator="C", start="2001-01-01", cycle="12 months",
+ basename='result', range=(1,8))
tinfo_string="""semantic_type=mean
start_time=2001-01-01 00:00:00
end_time=2009-05-01 00:00:00
@@ -62,10 +63,20 @@
self.assertModuleKeyValue(module=info, reference=tinfo_string,
precision=2, sep="=")
+ tinfo_string="""semantic_type=mean
+ start_time=2001-01-01 00:00:00
+ end_time=2009-05-01 00:00:00
+ granularity=1 month
+ map_time=interval
+ number_of_maps=100"""
+ info = SimpleModule("t.info", flags="g", type="strds", input="C")
+ self.assertModuleKeyValue(module=info, reference=tinfo_string,
+ precision=2, sep="=")
def test_stop(self):
- start="2001-01-01", stop='2008-12-31',
- cycle="12 months", basename='b_occu', range=(1,8))
+ indicator="C", start="2001-01-01", stop='2008-12-31',
+ cycle="12 months", basename='result', range=(1,8))
end_time=2009-01-01 00:00:00
@@ -75,22 +86,38 @@
info = SimpleModule("t.info", flags="g", type="strds", input="B")
+ end_time=2009-01-01 00:00:00
+ map_time=interval
+ number_of_maps=96"""
def test_time_suffix(self):
- start="2001-01-01", cycle="12 months", suffix='time',
- self.assertRasterDoesNotExist('b_occu_2001_01')
- self.assertRasterExists('b_occu_2001_01_01T00_00_00')
+ indicator="C", start="2001-01-01", cycle="12 months", suffix='time',
+ self.assertRasterDoesNotExist('result_2001_01')
+ self.assertRasterExists('result_2001_01_01T00_00_00')
+ self.assertRasterDoesNotExist('result_indicator_2001_01')
+ self.assertRasterExists('result_indicator_2001_01_01T00_00_00')
def test_num_suffix(self):
- suffix='count%03', basename='b_occu', range=(1,8))
- self.assertRasterExists('b_occu_001')
- self.assertRasterDoesNotExist('b_occu_00001')
+ suffix='count%03', basename='result', range=(1,8))
+ self.assertRasterExists('result_001')
+ self.assertRasterDoesNotExist('result_00001')
+ self.assertRasterExists('result_indicator_001')
+ self.assertRasterDoesNotExist('result_indicator_00001')
if __name__ == '__main__':
from grass.gunittest.main import test
test()
