[GRASS-SVN] r70980 - grass/trunk/lib/init
svn_grass at osgeo.org
Fri Apr 28 06:29:50 PDT 2017
Author: martinl
Date: 2017-04-28 06:29:50 -0700 (Fri, 28 Apr 2017)
New Revision: 70980
grass/trunk/lib/init/grass.py
grass startup: do not fail on gui mode when GUI is not available
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2017-04-28 13:21:09 UTC (rev 70979)
+++ grass/trunk/lib/init/grass.py 2017-04-28 13:29:50 UTC (rev 70980)
@@ -737,13 +737,17 @@
p.stdin.write("variable=True".encode(ENCODING))
p.stdin.close()
p.wait()
+ msg = None
if p.returncode != 0:
# Python was not found - switch to text interface mode
- warning(_("The python command does not work as expected!\n"
- "Please check your GRASS_PYTHON environment variable.\n"
- "Use the -help option for details.\n"
- "Switching to text based interface mode.\n\n"
- "Hit RETURN to continue.\n"))
+ msg = _("The python command does not work as expected!\n"
+ "Please check your GRASS_PYTHON environment variable.\n"
+ "Use the -help option for details.\n")
+ if not os.path.exists(wxpath("wxgui.py")):
+ msg = _("GRASS GUI not found. Please check your installation.")
+ if msg:
+ warning(_("{}\nSwitching to text based interface mode.\n\n"
+ "Hit RETURN to continue.\n").format(msg))
sys.stdin.readline()
grass_gui = 'text'
