[GRASS-SVN] r71329 - grass-addons/grass7/raster/r.hypso
Sat Aug 5 01:49:54 PDT 2017
Author: madi
Date: 2017-08-05 01:49:54 -0700 (Sat, 05 Aug 2017)
New Revision: 71329
   grass-addons/grass7/raster/r.hypso/r.hypso.py
fixed warning: VisibleDeprecationWarning: using a non-integer number instead of an integer will result in an error in the future
Modified: grass-addons/grass7/raster/r.hypso/r.hypso.py
--- grass-addons/grass7/raster/r.hypso/r.hypso.py	2017-08-04 18:38:24 UTC (rev 71328)
+++ grass-addons/grass7/raster/r.hypso/r.hypso.py	2017-08-05 08:49:54 UTC (rev 71329)
@@ -4,10 +4,10 @@
 # MODULE:       r.hypso.py
 # AUTHOR(S):    Margherita Di Leo, Massimo Di Stefano, Francesco Di Stefano
-# PURPOSE:      Output a hypsometric and hypsographic graph
+# PURPOSE:      Output a hypsometric and hypsographic graph
 # COPYRIGHT:    (c) 2010 Margherita Di Leo, Massimo Di Stefano, Francesco Di Stefano
 #               This program is free software under the GNU General Public
@@ -16,8 +16,8 @@
 # REQUIRES:     Matplotlib
 #               http://matplotlib.sourceforge.net/
 #%module
 #% description: Outputs a hypsometric and hypsographic graph.
@@ -120,10 +120,10 @@
     Xf = np.where(Xf==Xf.min())
     item = itemgetter(0)(Xf)
     Xf = item[0]  # added this further step to handle the case the function has 2 min
-    z1 = kl[float(Xf)][0]
-    z2 = kl[float(Xf-1)][0]
-    f1 = kl[float(Xf)][1]
-    f2 = kl[float(Xf-1)][1]
+    z1 = kl[Xf][0]
+    z2 = kl[Xf-1][0]
+    f1 = kl[Xf][1]
+    f2 = kl[Xf-1][1]
     z = z1 + ((z2 - z1) / (f2 - f1)) * (f - f1)
     return z
@@ -136,11 +136,8 @@
     plt.title(title)
     plt.grid(True)
     plt.savefig(image)
-    plt.close('all')
+    plt.close('all')
 if __name__ == "__main__":
 	options, flags = grass.parser()
 	sys.exit(main())
