[GRASS-SVN] r71334 - grass/trunk/lib/python/pygrass/gis
svn_grass at osgeo.org
Mon Aug 7 05:40:38 PDT 2017
Author: zarch
Date: 2017-08-07 05:40:37 -0700 (Mon, 07 Aug 2017)
New Revision: 71334
grass/trunk/lib/python/pygrass/gis/__init__.py
pygrass: fix _check funtion to not raise an Error when iterating over available mapset in a location if exist a not valid mapset inside
Modified: grass/trunk/lib/python/pygrass/gis/__init__.py
--- grass/trunk/lib/python/pygrass/gis/__init__.py 2017-08-07 12:12:20 UTC (rev 71333)
+++ grass/trunk/lib/python/pygrass/gis/__init__.py 2017-08-07 12:40:37 UTC (rev 71334)
@@ -1,5 +1,5 @@
+#!/usr/bin/env python
# -*- coding: utf-8 -*-
-#!/usr/bin/env python2.7
from __future__ import (nested_scopes, generators, division, absolute_import,
with_statement, print_function, unicode_literals)
@@ -11,12 +11,10 @@
import grass.lib.gis as libgis
-libgis.G_gisinit('')
from grass.pygrass.errors import GrassError
+libgis.G_gisinit('')
-test_vector_name="Gis_test_vector"
-test_raster_name="Gis_test_raster"
ETYPE = {'raster': libgis.G_ELEMENT_RASTER,
'raster_3d': libgis.G_ELEMENT_RASTER3D,
@@ -32,7 +30,7 @@
"MAPSET": libgis.G_is_mapset}
-def _check(value, path, type):
+def is_valid(value, path, type):
"""Private function to check the correctness of a value.
:param value: Name of the directory
@@ -45,11 +43,30 @@
valid types are: GISBASE, GISDBASE, LOCATION_NAME, MAPSET
:type type: str
+ :return: True if valid else False
+ :rtype: str
+ return bool(CHECK_IS[type](join(path, value)))
+def _check_raise(value, path, type):
+ """Private function to check the correctness of a value.
+ :param value: Name of the directory
+ :type value: str
+ :param path: Path where the directory is located
+ :type path: path
+ :param type: it is a string defining the type that will e checked,
+ valid types are: GISBASE, GISDBASE, LOCATION_NAME, MAPSET
+ :type type: str
:return: the value if verify else None and
if value is empty return environmental variable
:rtype: str
- if value and CHECK_IS[type](join(path, value)):
+ if value and is_valid(value, path, type):
return value
elif value is '':
from grass.pygrass.utils import getenv
@@ -113,7 +130,7 @@
return self._name
def _set_name(self, name):
- self._name = _check(name, '', "GISDBASE")
+ self._name = _check_raise(name, '', "GISDBASE")
name = property(fget=_get_name, fset=_set_name,
doc="Set or obtain the name of GISDBASE")
@@ -185,7 +202,7 @@
return self._gisdb
def _set_gisdb(self, gisdb):
- self._gisdb = _check(gisdb, '', "GISDBASE")
+ self._gisdb = _check_raise(gisdb, '', "GISDBASE")
gisdbase = property(fget=_get_gisdb, fset=_set_gisdb,
@@ -194,7 +211,7 @@
return self._name
- self._name = _check(name, self._gisdb, "LOCATION_NAME")
+ self._name = _check_raise(name, self._gisdb, "LOCATION_NAME")
doc="Set or obtain the name of LOCATION")
@@ -208,7 +225,7 @@
def __iter__(self):
lpath = self.path()
return (m for m in listdir(lpath)
- if (isdir(join(lpath, m)) and _check(m, lpath, "MAPSET")))
+ if (isdir(join(lpath, m)) and is_valid(m, lpath, "MAPSET")))
def __len__(self):
return len(self.mapsets())
@@ -276,7 +293,7 @@
return self._gisdb
@@ -285,7 +302,7 @@
return self._loc
def _set_loc(self, loc):
- self._loc = _check(loc, self._gisdb, "LOCATION_NAME")
+ self._loc = _check_raise(loc, self._gisdb, "LOCATION_NAME")
location = property(fget=_get_loc, fset=_set_loc,
@@ -294,7 +311,7 @@
return self._name
- self._name = _check(name, join(self._gisdb, self._loc), "MAPSET")
+ self._name = _check_raise(name, join(self._gisdb, self._loc), "MAPSET")
doc="Set or obtain the name of MAPSET")
@@ -443,23 +460,29 @@
final = [self.mapset, 'PERMANENT']
self._write(final)
if __name__ == "__main__":
import doctest
from grass.pygrass import utils
from grass.script.core import run_command
+ test_vector_name = "Gis_test_vector"
+ test_raster_name = "Gis_test_raster"
utils.create_test_vector_map(test_vector_name)
run_command("g.region", n=50, s=0, e=60, w=0, res=1)
- run_command("r.mapcalc", expression="%s = 1"%(test_raster_name),
- overwrite=True)
+ run_command("r.mapcalc", expression="%s = 1" % (test_raster_name),
+ overwrite=True)
run_command("g.region", n=40, s=0, e=40, w=0, res=2)
doctest.testmod()
- """Remove the generated vector map, if exist"""
+ # Remove the generated vector map, if exist
mset = utils.get_mapset_vector(test_vector_name, mapset='')
if mset:
- run_command("g.remove", flags='f', type='vector', name=test_vector_name)
+ run_command("g.remove", flags='f', type='vector',
+ name=test_vector_name)
mset = utils.get_mapset_raster(test_raster_name, mapset='')
if mset:
- run_command("g.remove", flags='f', type='raster', name=test_raster_name)
+ run_command("g.remove", flags='f', type='raster',
+ name=test_raster_name)
